imageRUNNER ADVANCE C7570i III
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The imageRUNNER ADVANCE C7570i III is registered EPEAT Gold.
- 10.1" intuitive touchscreen with smartphone-like usability.
- A unique, customized experience tailored to individual preferences using My ADVANCE.
- Supports mobile solutions and integration with many popular cloud services like Google Drive15.
- Scan and convert documents to searchable digital files in a variety of file formats.
- Integration with Canon and various third-party software with embedded application platform.
- Advanced standard security feature set to help safeguard sensitive information and assist in regulatory compliance.
- Integrates with existing, third-party Security Information and Event Management (SIEM) systems to help provide real-time comprehensive insights into potential threats to the network and printers.
- Technology to verify that the device boot process, firmware, and applications initialize at startup, without any alterations or tampering by malicious third parties. During operation, McAfee Embedded Control utilizes a whitelist to protect against malware and tampering of firmware and applications.*
- Security policy settings can be controlled with a dedicated password, configured from a central location, and exported to other supported devices.
- Control access to the device and specific features, using a host of flexible authentication methods - PIN code, user name/password, or card access.
* These features are available on third generation imageRUNNER ADVANCE 3rd edition models only. McAfee Embedded Control requires Unified Firmware Platform v3.9.
- Canon's signature reliability and engine technologies help keep productivity high and minimize the impact on support resources.
- Outstanding imaging technologies and toner allow for consistently striking images, thanks to Canon's V2 color profile.
- Designed to achieve maximum uptime with status notifications that help keep supplies replenished and intuitive maintenance videos for consumables replacement.
- imageRUNNER ADVANCE models have received many awards and recognition from leading industry analysts, often referencing strong reliability.
- Designed for quick, easy deployment.
- Remote diagnostics and parts life management for proactive maintenance and rapid fixes.
- Easy and intuitive to monitor device status and consumable levels, turn off devices remotely, observe meter readings, manage settings, and implement security policies.
- Common firmware and regular updates with Unified Firmware Platform (UFP) for continuous improvements and consistency across a fleet.
- Track and assess print, copy, scan, and fax usage and allocate costs to departments or projects.
- Apply print policies and restrict usage by user to help reduce unnecessary printing and contribute to cost efficiency.
- Standard cloud-based solution provides a centralized dashboard with up-to-the-minute insights into printer activity.
- Upgrade to uniFLOW server or cloud-based solutions for full accounting and reporting for compatible Canon and third-party devices, pull printing, job routing, and powerful scan workflows.
- A combination of fusing technologies and low-melting-point toner minimizes power requirements and helps achieve low energy consumption.
- Encourage environmentally conscious work practices by enabling multiple settings that can help save paper and energy.
- ENERGY STAR® certified and rated EPEAT® Gold.14
- Some types of tracing paper cannot be used.
- Time from device power-on, until copy ready (not print reservation).
- Time from exiting Sleep mode to when printing is operational.
- Time from device power-on to when key operations can be performed on the touch panel display.
- Includes main unit, ADF, and consumables.
- PDF print from Web sites is supported.
- EPS can be printed directly only from the Remote User Interface.
- Requires the optional PCL International Font Set-A1.
- Requires the optional Barcode Printer Kit-D1.
- Other operating systems and environments including AS/400, UNIX, Linux and Citrix may be supported. Some of these solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative.
- No charge for this solution; however activation is required.
- Reference Value: measured one unit.
- 0.9 W Sleep mode is not available in all circumstances due to certain settings.
- For current EPEAT rating (Gold/Silver/Bronze), please visit www.cla.canon.com/cla/en/epeat.
- Subscription to a third-party cloud service required. Subject to third-party cloud service providers’ terms and conditions.
- Requires Unified Firmware Platform v3.9.
| Model Name | ImageRUNNER ADVANCE C7570i III |
| Type | Color Laser Multifunctional |
| Functions | Standard: Print, Copy, Scan, Send, Store Optional: Fax |
| Operation Panel | Standard: 10.1" TFT LCD WSVGA Color Touch-Panel Optional: 10.4" TFT LCD WSVGA Color Upright-Panel |
| Image Server Memory | 4.0 GB RAM |
| Hard Disk Drive | Standard: 250 GB Maximum: 1 TB |
| Mirroring Hard Disk Drive | Optional: 250 GB, 1 TB Method: Raid1 |
| Network Interface Connection | Standard: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 B/G/N) Optional: NFC, Bluetooth Low Energy |
| Other Interface | Standard: USB 2.0 X2 (Host), USB 3.0 X1 (Host), USB 2.0 X1 (Device)
Max Mailboxes Supported100 User In-Boxes, 1 Memory RX In-Box, 50 Confidential Fax In-Boxes
Max Pages Stored30,000 Maximum Pages Stored
Available Disk SpaceApprox. 16 GB (Standard HDD) Approx. 480 GB (With Optional 1 TB HDD) Common ProtocolSMB Or WebDAV Supported Supported Client PcWindows (Windows 7/8.1/10) Max Number Of Concurrent ConnectionsSMB: 64 WebDAV: 3 (Active Sessions) Advanced Box FeaturesAuthentication For Advanced Box Log-In, Sort Function, Printing A PDF File With A Password, ImageWARE Secure Audit Manager Support StandardStandard: USB Optional Network Twain Scan Network Scan Utility Max Copy Reservation Scanning Resolution600 X 600, 400 X 400, 300 X 300, 200 X 400, 200 X 200, 200 X 100, 150 X 150, 100 X 100 Printing Resolution2400 Dpi X 2400 Dpi Interpolated Resolution Halftone LetterUp To 70/65 Ppm Letter RUp To 52/48 Ppm LegalUp To 41/38 Ppm LedgerUp To 35/32 Ppm Statement First Copy TimeAs Fast As 4.8 Seconds (BW)/ 5.9 Seconds (Color) Multiple CopiesUp To 9,999 Copies Color Mode Copy ExposureAutomatic Or Manual (9 Levels) Magnification25%-400% (1% Increments) Preset Reductions25%, 50%, 64%, 73%, 78% Preset Enlargements121%, 129%, 200%, 400% Acceptable OriginalsSheet, Book, 3-Dimensional Objects [Height: Up To 2" (50mm), Weight: Up To 4.4 Lb. (2kg)] Maximum Original Size Standard Paper CapacityTwo 1,100-Sheet Paper Drawers, Two 550-Sheet Paper Cassettes, Optional3,500-Sheet Paper Deck (Paper Deck Unit-E1), 3,500-Sheet Paper Deck (Pod Deck Lite-C1), 6,000-Sheet Paper Deck (Multi-Drawer Paper Deck-C1) Manual Bypass250-Sheet Stack Bypass Maximum Paper Capacity9,300 Sheets (With Multi-Drawer Paper Deck-C1) Output Paper Capacity(LTR, 20 Lb. Bond): 250 Sheets (With Copy Tray-R2) 3,500 Sheets (With External Finisher-V2) 4,250 Sheets (With External Finisher-X1) CassettesPaper Drawers (1/2): Letter Paper Cassettes (3/4): 13" X 19", 12" X 18", 11" X 17", Legal, Letter, Letter-R, Executive, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom Size (5-1/2" X 7-1/8" To 13" X 19-1/4"), Envelope Custom Size (3-7/8" X 5-7/8" To 13" X 19-1/4") Bypass13" X 19", 12" X 18", 11" X 17", Legal, Letter, Letter-R, Executive, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom Size (4" X 5-7/8" To 13" X 19-1/4"), Envelope Custom Size (3-1/2" X 5-7/8" To 13" X 19-1/4"), Free Size (4" X 7-1/8" To 13" X 19-1/4") Other Option CassettePaper Drawers: 14 Lb. Bond To 80 Lb. Cover (52 To 220 G/M2) Paper Cassettes: 14 Lb. Bond To 140 Lb. Index (52 To 256 G/M2) Bypass14 Lb. Bond To 110 Lb. Cover (52 To 300 G/M2) Duplexing Paper Size Paper Weight14 Lb. Bond To 80 Lb. Cover (52 To 220 G/M2) Special Media Support Warm Up TimeFrom Power On: Approx. 30 Seconds2 From Sleep Mode: Approx. 30 Seconds3 Quick Startup Mode: Approx. 4 Seconds4 Exposure Control Power Requirements120-127V AC, 60 Hz,16 A 220-240V AC, 50/60Hz, 10 A Power ConsumptionMaximum: Approx. 2,000 W (120V/230V) Standby: Approx. 119.2 W (120V), 136.6 W (230V) Sleep Mode: Approx. 0.9 W Typical Electricity Consumption (TEC) Rating: 4.6 KWh (120V)/ 4.8kWh (230V) PlugNEMA 5-20P (120V) CEE 7/7 (230V) Dim27-1/8" X 37-1/8" X 48" (689 Mm X 941 Mm X 1,220 Mm) Installation SpaceBasic [With Front Door Open + Stack Bypass/Upper-Right Cover Open + Buffer Pass+ Booklet Finisher-V2 /Extension Tray And Rotary Tray Extended)]: 79-3/4" X 60" (2,026 Mm X 1,524 Mm) Fully Configured [With Front Cover Open + Multi-Drawer Paper Deck-C1 + Buffer Pass + Document Insertion Unit-N1 + Multi Function Professional Puncher-A1 + Paper Folding Unit-J1+ Booklet Finisher-X1)]: 150-3/8" X 60" (3,818 Mm X 1,524 Mm) WeightApprox. 593 Lb. (269 Kg)5 Scan Resolution Acceptable Originals Maximum Original Size Basic Copy FeaturesPreset Reduction/Enlargement Ratios By Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel Special Copy FeaturesBook To Two Pages, Two-Sided Original, Finishing, Booklet, Job Build, N On 1, Add Cover, Insert Sheets, Different-Size Originals, Density Adjustment, Original Type Selection, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Gutter, Print & Check, Negative/Positive, Repeat Images, Merge Job Blocks, Job Done Notice, Mirror Image, Print On Tab, Store In Mail Box, Superimpose Image, Copy ID Card, Detect Feeder Multi Sheet Feed, Free Size Original, Color Balance, Adjust One-Touch Color, Area Designation, Skip Blank Pages Standard SAuthentication: Universal Login Manager, UniFLOW Online Express,13 User Authentication, Department ID Authentication, Access Management System, Device And Function Level Log-In Data: Trusted Platform Module (TPM), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption (FIPS140-2 Validated), McAfee Embedded Control16 Network: Encrypted Secure Print, IP/Mac Address Filtering, IPsec, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication Before SMTP, S/MIME, SIEM Integration Document: Secure Watermark, Secure Print, Forced Hold Printing, Adobe LiveCycle Rights Management ES2.5 Integration, Encrypted PDF, Encrypted Secure Print, Device Signatures OptionalAuthentication: UniFLOW Data: Hard Disk Drive Mirroring, Hard Disk Drive Removal, IEEE 2600.2 Common Criteria Certification, Data Loss Prevention (Requires UniFLOW) Document: User Signatures, Document Scan Lock Environmental FeaturesOperating Environment Temperature: 50 To 86 ºF Humidity: 20 To 80 % RH (Relative Humidity) Standards ENERGY STAR® Certified Rated EPEAT® Gold14 TonerGPR-56 Toner Estimated Toner Yield(ESTIMATED @ 5% COVERAGE): Black: 82,000 Images Color (C,M,Y): 66,500 Images Drum Estimated Drum Yield Developer Estimated Developer Yield Description Acceptable Originals Bw Originals Color Originals Scan Method Scanning Speed Capacity Paper Weight Different Size Originals Power Source Power Consumption Dimensions Weight Description Number Of Cassettes Paper Capacity Paper Size Paper Weight Paper Type Folding Speed Power Source Power Consumption Plug Dimensions Weights Description Total Output Capacity Paper Size Paper Weight Paper Type Dimensions Weight Description Paper Size Paper Weight Paper Type Number Of Trays Total Output Capacity Top Tray Middle Tray Lower Tray Saddle Stitch Tray Paper Capacity Of Saddle Stitch Mode Staple Capacity Staple Positions Hole Punch Paper Sizes Stapling Capacity Booklet Stapling Capacity Fold Type Folding Capacity Trimming Type Of Staple Power Source Power Consumption Plug Dimensions Weight Description Paper Size Paper Weight Paper Type Number Of Bins Sort Mode Staple Sort Mode Group Mode Non Sort Mode Paper Fold Staple Capacity Staple Positions Power Source Power Consumption Plug Dimensions Weight Description Paper Size Paper Weight Paper Type Punch Type Productivity Tray Capacity Punch Patterns Distance Between Punch Holes Power Requirements Power Consumption Plug Dimensions Weight Description Margin Trimming Sheet Capacity Stack Capacity Dust Capacity Trimming Method Trim Amount Trim Thickness Waste Tray Capacity Paper Size Paper Weight Paper Type Output Tray Capacity Power Requirements Power Consumption Dimensions Weight Description Paper Size Paper Weight Paper Type Feeder Capacity Paper Capacity Post Process Insertion Number Of Trays Acceptable Media Tray Capacity Power Requirements Power Consumption Plug Dimensions Weight Description Paper Size Paper Weight Paper Type Fold Type Folding Method Power Requirements Power Consumption Dimensions Weight Description Offset Stack Capacity Top Tray Capacity Paper Size Paper Weight Paper Type Maximum Connectivity Power Requirements Power Consumption Dimensions Weight Description Cutting Method Finished Book Width Finished Book Length Cover Weight Book Thickness Glue Warm Up Time Trim Range Power Requirements Power Consumption Plug Dimensions Weight Description Applicable Line1 Compatibility Modem SpeedSuper G3: 33.6 Kbps G3: 14.4 Kbps Transmission Speed Data CompressionMH, MR, MMR, JBIG Resolution400 X 400 Dpi, 200 X 400 Dpi, 200 X 200 Dpi, 200 X 100 Dpi Scanning Recording SizeStatement-R To 11" X 17" MemoryUp To 30,000 Pages Maximum Memory Memory BackupYes One Touch Speed Dialing LocationsMax. 200 Dials Coded Speed Dialing LocationsMax. 199 Dials Sequential Broadcast: Max. 256 Addresses Fax FeaturesOriginal Type Selection, Two-Sided Original, Book To Two Pages, Different-Size Originals, Density For Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Specifying The Sender's Name (When Sending Fax), Sender's Name (TTI), Selecting The Telephone Line (When Sending Fax), Direct Send, Delayed Send, Preview, Finished Stamp, Job Done Notice, TX Report, Detect Feeder Multi Sheet Feed Download Specifications ↓ Description Processor Type System Standard Memory Maximum Memory Hard Disk Dvd Rom Drive Engine Resolution Print Resolution Continuous Print Speed Pdl Support Postscript Fonts Pcl Fonts Interface Connections Protocols Supported Print Controller Technology Utility Software Other Features Print Features Dimensions Weight Description Sending Method Color Mode Scan Resolution Address Book Capacity Communication Protocol File Format I Fax Data Format Sending Size Scan Density |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
