imageRUNNER ADVANCE C7570i
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Workflow Efficiency
The Canon imageRUNNER ADVANCE C7570i all-in-one printing solution starts with an intuitive user interface: a color touch-screen display equipped with smartphone-like usability, including flick and pinch functionality. Designed on the My ADVANCE platform, this device allows users to create a customized experience for their workflow needs. Preferences such as display language, initial log-in screen and accessibility options can be synchronized across multiple compatible devices for consistency. The imageRUNNER ADVANCE C7570i also offers users the ability to capture, print or access documents via certain cloud applications.*
The imageRUNNER ADVANCE C7570i model comes loaded with features, like a motion sensor and the ability to automatically remove blank pages from documents when scanning. The printer also offers convenient and advanced built-in finishing options and scanned documents can be fed through the 300-sheet-capacity document feeder and converted to Searchable PDF, Microsoft® Word, and/or Microsoft® PowerPoint® files.
* Subscription to a third-party cloud service required. Subject to third-party cloud service providers' terms and conditions.
Cost Management
For high-volume work environments, the imageRUNNER ADVANCE C7570i is designed to be an easy to use, consistent, and durable printing, copying and scanning solution. The ability to closely monitor output, apply print policies, and restrict usage helps reduce unnecessary printing, promote cost management, and limit unnecessary downtime. The imageRUNNER ADVANCE C7570i offers outstanding reliability and remote diagnostic tools to help reduce time for technical support. And when combined with output solutions, such as Canon's optional uniFLOW management system, the imageRUNNER ADVANCE C7570i can carry out detailed tracking, reporting and cost analysis.
Security
The multifunction printers in the Canon imageRUNNER ADVANCE C7500 Series come standard with Universal Login Manager (ULM), a built-in application allowing controlled access with user authentication. This standard security feature from Canon helps prevent unauthorized access to sensitive information. The standard HDD Encryption function on the imageRUNNER ADVANCE C7570i device - which has been updated to obtain FIPS 140-2 validation - allows the device to automatically encrypt the data stored on the main unit's HDD to help limit unauthorized access to internal data. The imageRUNNER ADVANCE C7570i model is also compatible with additional standard and optional security features for more robust tracking and protection of sensitive data.
* ULM is not pre-installed in 230V modelsDevice and Fleet Management Efficiency
With the ability to synchronize settings across your third generation imageRUNNER ADVANCE fleet, administrators can efficiently manage their devices. The imageRUNNER ADVANCE C7570i supports management tools that allow multi-user workplace environments the ability to check status and consumables while being able to capture meter readings, as well as manage address books and drivers. Additionally, it can be combined with remote and centralized fleet management tools to help simplify maintenance across multiple devices. This device comes standard with genuine Adobe® PostScript® and PCL® support for integration with many enterprise applications and legacy systems.
* *PS is standard for 120V models only.Quality and Reliability
The imageRUNNER ADVANCE C7570i can provide businesses with quality output designed to meet the needs of high-volume, color-critical environments. With the imageRUNNER ADVANCE C7570i device, offices and walk-up multi-user environments are given the ability to create, copy and print consistently striking images with the device's outstanding image technology - like the Canon V2 color profile, up to 2400-dpi print resolution, with R-VCSEL red laser technology and a cooling system for the developer for that helps maintain image stability over time.
The third generation imageRUNNER ADVANCE platform can alert operators with status notifications so that they know when supplies need to be replenished, offers built-in intuitive user maintenance videos and allows automatic job rerouting (with optional solutions).
Sustainability
Canon's imageRUNNER ADVANCE C7570i device is designed to help high-volume offices and multi-user environments reduce energy and waste. The imageRUNNER ADVANCE C7570i model can help lower waste-related costs with features like default two-sided printing, Secure Print features, and the ability to preview and change settings at the device so they don't print unnecessarily. With sustainable features like this, it's no surprise that all models in the imageRUNNER ADVANCE series are ENERGY STAR®-certified and the imageRUNNER ADVANCE C7570i has received an EPEAT® Gold rating.*
* For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net.
| Model Name | ImageRUNNER ADVANCE C7570i |
| Type | Color Laser Multifunctional |
| Functions | Standard: Print, Copy, Scan, Send, Store Optional: Fax |
| Operation Panel | Standard: 10.1" TFT LCD WSVGA Color Touch-Panel Optional: 10.4" TFT LCD WSVGA Color Upright-Panel |
| Imaging System | Canon Dual Custom Processor (Shared) |
| Image Server Memory | 4.0 GB RAM |
| Hard Disk Drive | Standard: 250 GB Maximum: 1 TB |
| Mirroring Hard Disk Drive | Optional (250 GB, 1 TB) Method: Raid1 |
| Network Interface Connection | Standard: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 B/G/N) Optional: NFC, Bluetooth |
| Other Interface | Standard: USB 2.0 X2 (Host), USB 3.0 X1 (Host), USB 2.0 X1 (Device) Optional: Serial Interface, Copy Control Interface |
| Max Mailboxes Supported | 100 User In-Boxes, 1 Memory RX In-Box, 50 Confidential Fax In-Boxes |
| Max Pages Stored | 30,000 Maximum Pages Stored |
| Available Disk Space | Approx. 16 GB (Standard HDD) Approx. 480 GB (1 TB HDD) |
| Common Protocol | SMB Or WebDAV |
| Supported Client Pc | Windows (Windows Vista/7/8/8.1/10) |
| Max Number Of Concurrent Connections | SMB: 64 WebDAV: 3 (Active Sessions) |
| Advanced Box Features | Disabling Advanced Box, Storage Filtering, Authentication For Advanced Box Log-In, Search Function, Sort Function, Printing A PDF File With A Password, ImageWARE Secure Audit Manager Support |
| Standard | Standard: USB |
| Printing Resolution | 2400 Dpi X 2400 Dpi |
| Letter | Up To 70/65 Ppm / A4 Up To 70/65 Ppm |
| Letter R | Up To 52/48 Ppm |
| Legal | Up To 41/38 Ppm |
| Ledger | Up To 35/32 Ppm |
| First Copy Time | As Fast As 4.8 Seconds (BW)/ 5.9 Seconds (Color) |
| Multiple Copies | Up To 9,999 Copies |
| Copy Exposure | Automatic Or Manual (9 Levels) |
| Magnification | 25%-400% (1% Increments) |
| Preset Reductions | 25%, 50%, 64%, 73%, 78% |
| Preset Enlargements | 121%, 129%, 200%, 400% |
| Acceptable Originals | Sheet, Book, 3-Dimensional Objects [Up To 4.4 Lb. (2 Kg)] |
| Maximum Original Size | Paper Drawers (1/2): Letter, A4 Paper Cassettes (3/4): 13" X 19", 12" X 18", 11" X 17", Legal, Letter, A4, Letter-R, Executive, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom Size (5-1/2" X 7-1/8" To 13" X 19-1/4"), Envelope Custom Size (3-7/8" X 5-7/8" To 13" X 19-1/4") Stack Bypass: 13" X 19", 12" X 18", 11" X 17", Legal, Letter, A4, Letter-R, Executive, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom Size (4" X 5-7/8" To 13" X 19-1/4"), Envelope Custom Size (3-1/2" X 3-7/8" To 13" X 19-1/4"), Free Size (4" X 7-1/8" To 13" X 19-1/4") |
| Standard Paper Capacity | 3,550 Sheets |
| Maximum Paper Capacity | 9,300 Sheets |
| Output Paper Capacity | 250 Sheets (With Copy Tray-R2), 3,500 Sheets (With External Finisher-V2), 4,250 Sheets (With External Finisher-X1) |
| Cassette | Paper Drawers: 14 Lb. Bond To 80 Lb. Cover (52 To 220 G/M2) Paper Cassettes: 14 Lb. Bond To 140 Lb. Index (52 To 256 G/M2) Stack Bypass: 14 Lb. Bond To 110 Lb. Cover (52 To 300 G/M2) Duplexing: 14 Lb. Bond To 80 Lb. Cover (52 To 220 G/M2) |
| Warm Up Time | From Power On: 30 Seconds Or Less From Deep Sleep Mode: 30 Seconds Or Less Quick Startup Mode: 4 Seconds1 |
| Power Requirements | 120-127 V AC, 60 Hz,10A 220-240 V AC, 50/60 Hz, 10A |
| Power Consumption | Maximum: Approx. 2.0 KWh Standby: Approx. 119.2 Wh (120V) 136.6 Wh (230V) Sleep Mode: Approx. 0.9 W Typical Electricity Consumption (TEC) Rating: 4.6 KWh (120V) 4.8 KWh (230V) |
| Plug | NEMA 6-15P (208V) CEE 7/7 (230V) |
| Dim | 27-1/8" X 37-1/8" X 48" (689 Mm X 941 Mm X 1,220 Mm) |
| Installation Space | Basic [With Booklet Finisher-V2 (Stack Bypass And Cassette Drawers Open)]: 75-3/8" X 60" (1,913 Mm X 1,524 Mm) Fully Configured [With Multi-Drawer Paper Deck-C1+Document Insertion Unit-N1+Multi Function Professional Puncher-A1+Document Insertion Unit-N1+ Booklet Finisher-X1 (Cassette Drawers Open)]: 150-3/8" X 60" (3,818 Mm X 1,524 Mm) |
| Weight | Approx. 595.2 Lb. (270 Kg)2 |
| Basic Copy Features | Preset Reduction/Enlargement Ratios By Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel |
| Special Copy Features | Book To Two Pages, Two-Sided Original, Finishing, Booklet, Job Build, N On 1, Add Cover, Insert Sheets, Different Size Originals, Density Adjustment, Original Type Selection, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Gutter, Print & Check, Negative/Positive, Repeat Images, Merge Job Blocks, Job Done Notice, Mirror Image, Print On Tab, Store In Mail Box, Superimpose Image, Copy ID Card, Detect Feeder Multi Sheet Feed, Free Size Original, Color Balance, Adjust One-Touch Color, Area Designation |
| Toner | GPR-56 Toner |
| Estimated Toner Yield | (Estimated @ 5% Coverage): Black: 82,000 Images Color (C,M,Y): 66,500 Images |
GPR-56 Toner Black
Estimated Toner Yield: 82,000 Copies/Bottle (Estimated @ 5% Coverage)
GPR-56 Toner Magenta
Estimated Toner Yield: 66,500 Copies/Bottle (Estimated @ 5% Coverage)
GPR-56 Toner Cyan
GPR-56 Toner Yellow
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
