OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Untitled Document
| Model Name | ImageRUNNER ADVANCE C7270 |
| Type | Color Digital Multifunction Imaging System |
| Functions | Standard: Copy, Print (UFR II), Scan, Send, Store Optional: Print (PCL 5c/6, Adobe® PostScript® 3™), Fax (Up To 4 Lines) |
| Operation Panel | Standard: 8.4" SVGA Full-Color, TFT Screen Optional: 10.4" SVGA Full-Color, TFT Upright Screen |
| Image Server Memory | Standard: 2GB RAM Maximum: 2.5GB RAM |
| Hard Disk Drive | Standard: 160GB Maximum: 1TB |
| Mirroring Hard Disk Drive | Optional (160GB, 1TB), Method: RAID1 |
| Network Interface Connection | Standard: 10Base-T/100Base-TX/1000Base-T |
| Other Interface | Standard: USB 2.0 (Host) X2, USB 2.0 (Device) Optional: Device Port [USB 2.0 (Host) X2], Serial Interface, Copy Control Interface |
| Max Mailboxes Supported | 100 User Inboxes, 1 Memory RX Inbox, 50 Confidential Fax Inboxes |
| Max Pages Stored | 6,000 Maximum Pages Stored |
Advanced Box
| Available Disk Space | Approx. 15GB (Standard HDD), Approx. 629GB (1TB HDD) |
| Common Protocol | SMB Or WebDAV |
| Supported Client Pc | Windows (Windows 2000/XP/7/8/Windows Vista) |
| Max Number Of Concurrent Connections | SMB: 32, WebDAV: 12 (Active Sessions) |
| Advanced Box Features | Disabling Advanced Box, Storage Filtering, Authentication For Advanced Box Log-In, Search Function, Sort Function, Printing A PDF File With A Password, ImageWARE Secure Audit Manager Support |
Memory Media
| Standard | USB Memory |
| Optional | SD, SDHC, CompactFlash, Memory Stick, Microdrive |
Scan Specifications
| Network Twain Scan | Standard |
| Network Scan Utility | Color Network ScanGear |
Output Sizes
| Cassettes | 13" X 19", 12-5/8" X 17-11/16", 12" X 18", 11" X 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" X 7-1/8" To 13" X 19-1/4") Drawers: Letter |
| Bypass | 13" X 19", 12-5/8" X 17-11/16", 12" X 18", 11" X 17", Legal, Letter, Letter-R, Executive, Statement-R, Envelopes, Custom Size (4" X 5-7/8" To 13" X 19-1/4") |
Acceptable Paper Weights
| Cassette | 14 Lb. Bond To 80 Lb. Cover (52 To 220g/M²) |
| Bypass | 14 Lb. Bond To 110 Lb. Cover (52 To 300g/M²) |
Duplexing Props
| Duplexing | Standard Automatic Trayless Duplexing |
| Paper Size | Up To 13" X 19" |
| Paper Weight | 14 Lb. Bond To 80 Lb. Cover (52 To 220g/M²) |
Dummy Header B
| Special Media Support | Thin [14 Lb. Bond To 16 Lb. Bond (52 To 63g/M²)], Plain 1 [17 Lb. Bond To 21 Lb. Bond (64 To 81g/M²)], Plain 2 [22 Lb. Bond To 28 Lb. Bond (82 To 105g/M²)], Heavy 1 [29 Lb. Bond To 40 Lb. Bond (106 To 150g/M²)], Heavy 2 [56 Lb. Cover To 80 Lb. Cover (151 To 220g/M2)], Heavy 3 [82 Lb. Cover To 140 Lb. Index (221 To 256g/M2)], Heavy 4 [140 Lb. Index To 110 Lb. Cover (257 To 300g/M2)], Color, Recycled, Pre-Punched, Transparency, Tracing, Labels, Bond, Letterhead, Tab, Textured, Coated, Envelopes |
| Warm Up Time | From Power On: 31 Seconds Or Less From Sleep Mode: 30 Seconds Or Less Quick Startup Mode: 7 Seconds* |
| Power Requirements | 120V AC, 60Hz, 16A, 220-240V / 50/60Hz / 10A |
| Power Consumption | Maximum: 2kW Sleep Mode: 0.9W Or Less |
| Plug | NEMA 5-20P |
| Dim | Without The Upright Control Panel: 48-1/8" X 27-1/8" X 36-3/4" (1221mm X 689mm X 932mm) With The Upright Control Panel (To The Right Edge Of The Upright Control Panel In The Right-Most Position): 55-1/4" X 46-1/2" X 36-3/4" (1403mm X 1180mm X 932mm) |
| Installation Space | 52-7/8" X 36-3/4" (1344mm X 932mm) |
| Weight | Approx. 604 Lb. (274kg)** |
Image Reader
| Scan Resolution | Up To 600 X 600 Dpi |
| Acceptable Originals | (Glass): Sheet, Book, 3-Dimensional Objects [Up To 4.4 Lb. (2kg)] |
| Maximum Original Size | Up To 11" X 17" |
Dummy Header C
| Basic Copy Features | Preset R/E Ratios By Area, Finishing, Two-Sided, Exposure Adjustment, Original Type Selection, Interrupt Mode, Sample Set, Setting Confirmation/Cancel, Standard Keys, Reset, Guide Display, Job Duration Display, Reserved Copying |
| Special Copy Features | Two-Page Separation, Cover/Sheet Insertion, Booklet, Transparency Interleaving, Shift, Margin, Frame Erase, Image Combination, Different-Size Original, Job Build, Job Done Notice, Scan Image Check, Mode Memory, Recall, Negative/ Positive Inversion, Image Repeat, Mirror Image, Sharpness, Tab Paper Creation, Form Composition, Secure Watermark, Page Numbering, Copy Set Numbering, Watermark And Date, Job Block Combination, Store In User Inbox |
Security Features
| Standard S | Department ID Management, Single Sign-On H, Access Management System (Device And Function Level Log-In)◊, Secure Print, Trusted Platform Module, User Access Control Of Advanced Box, Mail Box Password Protection, IPv6, Restricting Features (Restricting The Send Function, Restricting New Addresses On Address Book), SSL Encrypted Communication, SNMPv1/V3, MAC/IP Address Filtering, SMTP Authentication, POP Authentication Before SMTP, HDD Erase (Up To 3x), HDD Initialize (Up To 9x), HDD Lock, IPsec, Adobe LiveCycle® Rights Management ES2.5 Integration |
| Optional | Removable HDD, HDD Encryption, HDD Mirroring, Encrypted Secure Print, Encrypted PDF, Document Scan Lock, Secure Watermark, IEEE 2600.1 Common Criteria Certification†† |
Dummy Header
| Environmental Features |
| Estimated Toner Yield | Black: 80,000 Images Color (C,M,Y): 52,000 Images |
GPR-33 Toners
- GPR-33 Toner Black
Estimated Toner Yield: 80,000Copies/Bottle (Estimated @ 5% Coverage) - GPR-33 Toner Cyan
Estimated Toner Yield: 52,000 Copies/Bottle (Estimated @ 5% Coverage) - GPR-33 Toner Magenta
Estimated Toner Yield: 52,000 Copies/Bottle (Estimated @ 5% Coverage) - GPR-33 Toner Yellow
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
