imageRUNNER ADVANCE C5540i II
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The versatile imageRUNNER ADVANCE C5540i II multifunction system is suited to meet the high-quality printing requirements essential for business productivity, with intuitive usability, sophisticated authentication features, remarkable speed, and amazing color output. The imageRUNNER ADVANCE C5540i II model contains a 150-sheet single pass duplex feeder, is capable of print speeds at up to 40 ppm in color and black and white on letter/A4 paper, with scan speeds as fast as 160 ipm. Expect a copy, print and scan experience built to complement every stage of the document lifecycle while helping to support your organization’s seamless workflow, and environmental goals.
- Subscription to a third-party cloud service required. Subject to third-party cloud service providers' terms and conditions.
- Requires additional option.
Note: Canon products offer certain security features, yet many variables can impact the security of your devices and data. Canon does not warrant that use of its features will prevent security issues. Nothing herein should be construed as legal or regulatory advice concerning applicable laws; customers must have their own qualified counsel determine the feasibility of a solution as it relates to regulatory and statutory compliance. - Available 2Q 2018.
- For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net.
- Some types of tracing paper cannot be used.
- Time from device power-on to when copy jobs can be programmed.
- Includes main unit and either Cassette Feeding Unit-AM1, High Capacity Cassette Feeding Unit-A1, or Cabinet Type-N.
- Includes main unit, consumables, and Cassette Feeding Unit-AM1.
- PDF print from Web sites is supported.
- EPS can be printed directly only from the Remote User Interface.
- Requires the optional PCL International Font Set-A1.
- Requires the optional Barcode Printer Kit-D1.
- Other operating systems and environments including AS/400, UNIX, Linux and Citrix may be supported. Some of these solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative.
- 0.8 W sleep mode not available in all circumstances due to certain settings.
- GPR-55L Toner also available for Color (C, M, Y). Yield (estimated @ 5% coverage) is 26,000 images.
- Used for corner/double stapling only. 2 cartridges per case. 5,000 staples per cartridge.
- Used for booklet finishing only. 3 cartridges per case. 2,000 staples per cartridge.
| Model Name | ImageRUNNER ADVANCE C5540i II |
| Type | Color Laser Multifunctional |
| Functions | Standard: Print, Copy, Scan, Send, Store Optional: Fax |
| Operation Panel | 10.1" TFT LCD WSVGA Color Flat-Panel |
| Image Server Memory | 4.0 GB RAM |
| Hard Disk Drive | Standard: 250 GB Maximum: 1 TB |
| Mirroring Hard Disk Drive | Optional (250 GB, 1 TB) Method: Raid1 |
| Network Interface Connection | 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 B/G/N) |
| Other Interface | Standard: USB 2.0 X2 (Host), USB 3.0 X1 (Host), USB 2.0 X1 (Device) Optional: Serial Interface, Copy Control Interface |
| Advanced Box Features | Disabling Advanced Box, Storage Filtering, Authentication For Advanced Box Log-In, Search Function, Sort Function, Printing A PDF File With A Password, ImageWARE Secure Audit Manager Support |
| Scanning Resolution | 600 X 600 Dpi, 400 X 400 Dpi, 300 X 300 Dpi, 200 X 400 Dpi, 200 X 200 Dpi, 200 X 100 Dpi, 150 X 150 Dpi, 100 X 100 Dpi |
| Printing Resolution | 1200 Dpi X 1200 Dpi, 600 Dpi X 600 Dpi |
| Letter | (LTR/A4) Up To 40 Ppm |
| Letter R | Up To 24 Ppm |
| Legal | Up To 23 Ppm |
| Ledger | Up To 22 Ppm |
| First Copy Time | (LTR/A4): As Fast As 4.9 Seconds (BW)/ 7.4 Seconds (Color) |
| Multiple Copies | Up To 9,999 Copies |
| Color Mode | Automatic-Color Select (Full Color/Grayscale), Automatic-Color Select (Full Color/Black-And-White), Full Color, Grayscale, And Black-And-White |
| Copy Exposure | Automatic Or Manual (9 Levels) |
| Magnification | 25%-400% (1% Increments) |
| Preset Reductions | 25%, 50%, 64%, 73%, 78% |
| Preset Enlargements | 121%, 129%, 200%, 400% |
| Standard Paper Capacity | (LTR, 20 Lb. Bond): 1,200 Sheets |
| Maximum Paper Capacity | (LTR, 20 Lb. Bond): 6,350 Sheets |
| Output Paper Capacity | (LTR, 20 Lb. Bond): Standard: 250 Sheets Maximum: 3,450 Sheets (With External Finisher And Copy Tray) |
| Cassette | Paper Cassette 1: Letter, A4, Executive, Statement-R, Envelope [No.10 (COM10), DL, ISO-C5], Custom Size (3-7/8" X 5-7/8" To 11-3/4" X 8-1/2") Paper Cassette 2: 12" X 18", 11" X 17", Legal, Letter, A4, Letter-R, Executive, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom Size (3-7/8" X 7-1/8" To 12" X 18") |
| Bypass | 12" X 18", 11" X 17", Legal, Letter, A4, Letter-R, Executive, Statement, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Envelope Custom Size (3-7/8" X 3-7/8" To 12-5/8" X 18"), Custom Size (3-7/8" X 5-1/2" To 12-5/8" X 18"), Free Size (3-7/8" X 5-1/2" To 12-5/8" X 18") Cassette Feeding Unit-AM1: 12" X 18", 11" X 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (3-7/8" X 7-1/8" To 12" X 18") High Capacity Cassette Feeding Unit-A1: Letter Paper Deck Unit-F1: Letter |
| Cassette | 14 Lb. Bond To 140 Lb. Index (52 To 256 G/M2) |
| Bypass | 14 Lb. Bond To 110 Lb. Cover (52 To 300 G/M2) |
| Paper Weight | 14 Lb. Bond To 80 Lb. Cover (52 To 220 G/M2) |
| Warm Up Time | From Power On: 30 Seconds From Sleep Mode: 10 Seconds Quick Startup Mode: 4 Seconds6 |
| Power Requirements | 120-127V AC 60 Hz,10A 220-240V AC 50/60 Hz, 6A |
| Power Consumption | Maximum: Approx. 1.8 KWh (120V /230V) Standby: Approx. 66.2 W (120V) 67.9 W (230V) Sleep Mode: Approx. 0.8 W14 (120V /230V) Typical Electricity Consumption (TEC) Rating: 1.6 KWh (120V / 230V) |
| Plug | NEMA 5-15P (120V) CEE 7/7 (230V) |
| Dim | 24-3/8" X 29-1/4" X 37-3/8"(620 Mm X 742 Mm X 950 Mm)7 |
| Installation Space | Basic: Stack Bypass + Cassette Drawers Open: 37-1/8" X 46-3/8" (943 Mm X 1,176 Mm)7 |
| Weight | Approx. 313.1 Lb. (142 Kg)8 |
| Basic Copy Features | Preset Reduction/Enlargement Ratios By Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel |
| Special Copy Features | Book To Two Pages, Two-Sided Original, Finishing, Booklet, Job Build, N On 1, Add Cover, Insert Sheets, Different Size Originals, Density Adjustment, Original Type Selection, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Gutter, Print & Check, Negative/Positive, Repeat Images, Merge Job Blocks, Job Done Notice, Mirror Image, Print On Tab, Store In Mail Box, Superimpose Image, Copy ID Card, Detect Feeder Multi Sheet Feed, Free Size Original, Color Balance, Adjust One-Touch Color, Area Designation |
| Toner | GPR-55 Toner15 |
| Estimated Toner Yield | (Estimated @ 6% Coverage): Black: 69,000 Images Color (C,M,Y):15 60,000 Images |
| Description | Cassette Feeding Unit-AM1 |
| Capacity | 550 Sheets X 2 Cassettes [20 Lb. Bond (80 G/M2)] |
| Paper Weight | 14 Lb. Bond To 140 Lb. Index (52 To 256 G/M2) |
| Different Size Originals | 12" X 18", 11" X 17", Legal, Letter, A4, Letter-R, Executive, Statement-R, And Custom Size [3-7/8" X 7-1/8" To 12" X 18" (98.0 X 182.0 To 304.8 X 457.2 Mm)] |
| Power Source | From The Main Unit |
| Dimensions | 24-3/8" X 27-5/8" X 9-7/8" (620 Mm X 700 Mm X 251 Mm) |
| Weight | Approx. 49.6 Lb. (22.5 Kg) |
| Description | High-Capacity Cassette Feeding Unit-A1 |
| Capacity | 2,450 Sheets [20 Lb. Bond (80 G/M2)] |
| Different Size Originals | Letter, A4 |
| Weight | 66.1 Lb. (30 Kg) |
| Description | Paper Deck Unit-F1 |
| Paper Capacity | 2,700 Sheets [20 Lb. Bond (80 G/M2)] |
| Paper Size | Letter, A4 |
| Dimensions | 15-3/4" X 24-7/8" X 17-3/8" (400 Mm X 630 Mm X 440 Mm) |
| Weights | 68.3 Lb. (31 Kg) |
| Description | Inner 2-Way Tray-J1 |
| Total Output Capacity | Upper Tray: 100 Sheets Lower Tray: 250 Sheets |
| Paper Size | 12" X 18", 11" X 17", Legal, Letter, A4, Letter-R, Executive, Statement, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Envelope Custom Size (3-7/8" X 3-7/8" To 12-5/8" X 18") Custom Size (3-7/8" X 5-1/2" To 12-5/8" X 18") |
| Paper Weight | 14 Lb. Bond To 110 Lb. Cover (52 To 300 G/M2) |
| Dimensions | 16-7/8" X 16" X 3" (427 Mm × 407 Mm × 76 Mm) |
| Weight | Approx. 1.3 Lb (0.6 Kg) |
| Description | Inner Finisher-H1 |
| Paper Weight | 14 Lb. Bond To 110 Lb. Index (52 To 300 G/M2) Acceptable Paper Weight: 14 Lb. Bond To 140 Lb. Cover (52 To 256 G/M2) |
| Number Of Trays | 2 |
| Top Tray | Letter/A4/Statement/Statement-R/Executive (45 Sheets), 12" X 18"/11" X 17"/Legal/Letter-R (45 Sheets) |
| Lower Tray | Letter/A4/Statement/Statement-R/Executive (500 Sheets), 12" X 18"/11" X 17"/Legal/Letter-R (250 Sheets) |
| Staple Capacity | Corner Staple And Double Staple: Letter/A4/Executive: 50 Sheets (14 To 24 Lb. Bond ) 11" X 17"/Legal/Letter-R: 30 Sheets (14 To 24 Lb. Bond ) Staple-Free Staple: 11"X17"/Letter/A4: 5 Sheets (14 To 17 Lb. Bond), 4 Sheets (17.3 To 21.7 Lb. Bond), 3 Sheets (21.7 To 28 Lb. Bond) |
| Staple Positions | Corner, Double |
| Dimensions | 29-1/4" X 29-1/4" X 8-7/8" (743 Mm × 742 Mm × 225 Mm) |
| Weight | Approx. 19 Lb (8.6 Kg) |
| Description | Staple Finisher-Y1 (External) |
| Paper Weight | Top Tray: 14 Lb. Bond To 140 Lb. Index (52 To 256 G/M2) Lower Tray: 14 Lb. Bond To 110 Lb. Cover (52 To 300 G/M2) |
| Top Tray | Letter/A4/Executive/Statement/Statement-R (3,000 Sheets), 12" X 18"/11" X 17"/Legal/Letter-R (1,500 Sheets) |
| Lower Tray | Letter/A4/Executive/Statement/Statement-R (250 Sheets), 12" X 18"/11" X 17"/Legal/Letter-R (125 Sheets) |
| Stapling Capacity | Corner Staple And Double Staple: Letter/A4/Executive: 50 Sheets [24 Lb. Bond (90 G/M2)] 11" X 17"/Legal/Letter-R: 30 Sheets [24 Lb. Bond (90 G/M2)] Staple-Free Staple: 11"X17"/Letter/A4: 5 Sheets [14 To 17 Lb. Bond ((52 To 64 G/M2)], 4 Sheets [17.3 To 21.7 Lb. Bond (65 To 81.4 G/M2)], 3 Sheets [21.7 To 28 Lb. Bond (81.5 To 105 G/M2)] |
| Description | Booklet Finisher-Y1 (External) |
| Number Of Trays | 3 |
| Lower Tray | Statement-R (250 Sheets), 12" X 18"/11" X 17"/Legal/Letter-R (125 Sheets) |
| Staple Capacity | Corner Staple And Double Staple: Letter/A4/Executive: 50 Sheets [24 Lb. Bond (90 G/M2)] 11" X 17"/Legal/Letter-R: 30 Sheets [24 Lb. Bond (90 G/M2)] Staple-Free Staple: 11"X17"/Letter/A4: 5 Sheets [14 To 17 Lb. Bond ((52 To 64 G/M2)], 4 Sheets [17.3 To 21.7 Lb. Bond (65 To 81.4 G/M2)], 3 Sheets [21.7 To 28 Lb. Bond (81.5 To 105 G/M2)] |
| Power Source | From The Main Unit/85.6 W |
| Dimensions | 25-1/8" X 24-1/2" X 45" (637 Mm × 623 Mm × 1142 Mm) |
| Weight | Approx. 125.7 Lb (57 Kg) |
| Description | Inner 2/3 -Hole Puncher-B1(Requires The Ineer Finisher-H1) |
| Paper Size | Two Holes: 11" X 17", Legal, Letter, A4, Letter-R, Executive Three Holes: 11" X 17", Letter, A4, Executive |
| Power Requirements | From The Main Unit |
| Description | 2/ 3 Hole Puncher -A1 (Requires Either The Staple Finisher-Y1or Booklet Finisher-Y1) |
| Applicable Line | 1 |
| Modem Speed | Super G3: 33.6 Kbps G3: 14.4 Kbps |
| Data Compression | MH, MR, MMR, JBIG |
| Resolution | 400 X 400 Dpi, 200 X 400 Dpi, 200 X 200 Dpi, 200 X 100 Dpi |
| Scanning Recording Size | Statement-R To 11" X 17" |
| Memory | Up To 30,000 Pages |
| Memory Backup | Yes |
| One Touch Speed Dialing Locations | Max. 200 |
| Coded Speed Dialing Locations | Max. 199 Dials |
| Fax Features | Original Type Selection, Two-Sided Original, Book To Two Pages, Different-Size Originals, Density For Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Specifying The Sender's Name (When Sending Fax), Sender's Name (TTI), Select Line, Selecting The Telephone Line (When Sending Fax), Direct Send, Delayed Send, Preview, Finished Stamp, Job Done Notice, TX Report, Detect Feeder Multi Sheet Feed |
| Description | ImagePASS-P1 (Embedded) |
| Processor | Intel Celeron G1820 2.7 GHz |
| System | Fiery FS200 |
| Standard Memory | 2 GB |
| Hard Disk | 500 GB |
| Print Resolution | 1200 Dpi X 1200 Dpi, 600 Dpi X 600 Dpi |
| Postscript Fonts | 138 Adobe PS Fonts |
| Pcl Fonts | 113 PCL Fonts |
| Interface Connections | 2 X Ethernet (1000Base-T/100Base-TX/10Base-T), USB X 3.0 X 2 (Rear X 2), USB X 2.0 X 4 (Rear X 4) |
| Protocols Supported | TCP/IP (LPR/Port 9100/IPP/SMB/FTP)/DNS |
| Print Controller Technology | Windows Vista (32 And 64 Bit)/Windows 8 (32 And 64 Bit)/Windows 8.1 (32 And 64 Bit)/Windows 7 (32 And 64 Bit)/Windows Server 2008 (32 And 64 Bit)/Windows Server 2008 R2 (64 Bit Only)/Windows Server 2012 (64 Bit Only)/Windows Server 2012 R2 (64 Bit Only)/MAC OS (10.7 Or Higher) |
| Print Features | Fiery Command Workstation 5, Paper Catalog, Fiery Spot On, Fiery Remote Scan |
| Dimensions | 11-1/4" X 3-5/8" X 11-5/8" (285 Mm X 93 Mm X 295 Mm) |
| Sending Method | E-Mail/Internet Fax (SMTP), SMB, FTP, WebDAV, Mail Box, Super G3 Fax (Optional), IP Fax (Optional) |
| Scan Resolution | 600 X 600 Dpi, 400 X 400 Dpi, 300 X 300 Dpi, 200 X 400 Dpi, 200 X 200 Dpi, 200 X 100 Dpi, 150 X 150 Dpi, 100 X 100 Dpi |
| Address Book Capacity | LDAP (2,000)/Local (1,600)/Speed Dial (200) |
| Communication Protocol | File: FTP, SMB, WebDAV E-Mail/I-Fax: SMTP, POP3, I-Fax (Simple, Full) |
| File Format | Standard: TIFF, JPEG, PDF(Compact, Searchable, Apply Policy, Optimize For Web, PDF A/1-B), XPS (Compact, Searchable), Office Open XML (PowerPoint, Word) Optional: PDF (Trace & Smooth, Encrypted), PDF/XPS (Digital Signature) |
GPR-55 Toner Black
GPR-55 Toner Magenta
GPR-55L Toner Cyan
GPR-55L Toner Yellow
GPR-55 Toner Cyan
GPR-55 Toner Yellow
GPR-55L Toner Magenta
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
