imageRUNNER ADVANCE C5240
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Untitled Document
| Model Name | ImageRUNNER ADVANCE C5240 |
| Type | Color Digital Multifunction Imaging System Letter: Up To 40/35 Ppm Legal: Up To 20/18 Ppm Ledger: Up To 20/18 Ppm |
| Functions | Standard: Copy, Print (UFR II), Scan, Send, Store Optional: Print (PCL, Adobe® PostScript® 3™), Fax (Up To 4 Lines) |
| Operation Panel | 8.4" SVGA Full-Color TFT Screen |
| Image Server Memory | Standard: 2GB RAM Maximum: 2.5GB RAM |
| Hard Disk Drive | Standard: 160GB Maximum: 1TB |
| Mirroring Hard Disk Drive | Optional (160GB, 1TB), Method: RAID1 |
| Network Interface Connection | Standard: 1000Base-T/100Base-TX/10Base-T |
| Other Interface | Standard: USB 2.0 (Host) X 2, USB 2.0 (Device) Optional: Device Port [USB 2.0 (Host) X 2], Serial Interface, Copy Control Interface |
| Max Mailboxes Supported | 100 User Inboxes, 1 Memory RX Inbox, 50 Confidential Fax InboxesApprox. |
| Max Pages Stored | 6,000 Maximum Pages Stored |
| Available Disk Space | 15GB (Standard HDD) Approx. 629GB (1TB HDD) |
| Common Protocol | SMB Or WebDAV |
| Supported Client Pc | Windows® (Windows 2000/XP/Windows Vista®) |
| Max Number Of Concurrent Connections | SMB: 32, WebDAV: 12 (Active Sessions) |
| Advanced Box Features | Disabling Advanced Box, Storage Filtering, Authentication For Advanced Box Log-In, Search Function, Sort Function, Printing A PDF File With A Password, ImageWARE Secure Audit Manager Support |
| Standard | USB Memory |
| Optional | SD, SDHC, CompactFlash, Memory Stick, Microdrive |
| Network Twain Scan | Standard |
| Network Scan Utility | Color Network ScanGear |
| Standard Paper Capacity | Dual 550-Sheet Paper Cassettes, 100-Sheet Stack Bypass |
| Optional | Dual 550 Sheet Paper Cassettes, 2,700-Sheet Paper Deck |
| Maximum Paper Capacity | 5,000 Sheets |
| Output Paper Capacity | (20 Lb. Bond): Standard: 250 Sheets (Inner Tray) Maximum: 3,250 Sheets (W/Staple Finisher Or Booklet Finisher) |
| Cassette | 12" X 18",* 11" X 17",* Legal, Letter, Letter-R, Statement-R, Executive, Custom Size (5-1/2" X 7-1/8" To 12" X 18") |
| Bypass | 12" X 18", 11" X 17", Legal, Letter, Letter-R, Statement, Statement-R, Executive, Custom Size (3-7/8" X 5-1/2" To 12-5/8" X 18") Paper Deck: Letter |
| Other Option | Envelope Feeder Attachment (COM10 No.10, Monarch, DL, ISO-C5)** Tab Feeding Attachment Kit** |
| Cassette | 14 Lb. Bond To 80 Lb. Cover (52 To 220g/M²) |
| Bypass | 14 Lb. Bond To 140 Lb. Index (52 To 256g/M²) |
| Paper Size | Standard Automatic Trayless Duplexing (Executive To 12" X 18") |
| Paper Weight | 14 Lb. Bond To 80 Lb. Cover (52 To 220g/M²) |
| Special Media Support | Thin, Plain 1 [17 Lb. Bond To 21 Lb. Bond (64g/M² To 81g/M²], Plain 2 [22 Lb. Bond To 28 Lb. Bond (82g/M² To 105g/M²)], Recycled, Color, Pre-Punched, Bond, Heavy 1 [29 Lb. Bond To 60 Lb. Cover (106g/M² To 163g/M²)], Heavy 2 [61 Lb. Cover To 80 Lb. Cover (164g/M² To 220g/M²)], Heavy 3 [82 Lb. Cover To 140 Lb. Index (221g/M² To 256g/M²)], Tracing, Coated, Labels, Transparency, Tab, Letterhead, And Envelopes |
| Warm Up Time | From Power On: 31 Seconds, From Sleep: 15 Seconds Quick Startup Mode: 7 Seconds*** |
| Power Requirements | 120V AC, 60Hz, 15A |
| Power Consumption | Maximum: 1.5kW Sleep Mode: 0.8W |
| Plug | NEMA 5-15P |
| Dim | 36-5/8" X 24-3/8" X 28" (931mm X 620mm X 712mm) |
| Installation Space | 33-1/2" X 28" (850mm X 712mm) |
| Weight | Approx. 333 Lb. (151kg)† |
| Scan Resolution | Up To 600 X 600 Dpi |
| Acceptable Originals | (Glass): Sheet, Book, 3-Dimensional Objects [Up To 4.4 Lb. (2kg)] |
| Maximum Original Size | Up To 11" X 17" |
| Basic Copy Features | First Copy Time: BW: 5.4 Seconds, Color: 8.1 Seconds Multiple Copies: 1 To 999 Copy Exposure: Automatic Or Manual (9 Levels) Magnification: 25% - 400% (1% Increments) Preset Reductions: 25%, 50%, 64%, 73%, 78% Preset Enlargements: 121%, 129%, 200%, 400% |
| Standard | Department ID Management, Single Sign On-H, Access Management System (Device And Function Level Log-In)&Diams&Diams, Secured Print, Trusted Platform Module, User Access Control Of Advanced Box, Mail Box Password Protection, IPV6, Restricting Features (Restricting The Send Function, Restricting New Addresses On Address Book), SSL Encrypted Communication, SNMPv1/V3, MAC/IP Address Port Filtering, SMTP Authentication, POP Authentication Before SMTP, HDD Erase (Up To 3x), HDD Initialize (Up To 9x), HDD Lock, IPSec, Adobe LiveCycle Rights Management ES2.5 Integration |
| Optional | Removable HDD, HDD Encryption, HDD Mirroring, Encrypted Secure Print, Encrypted PDF, Document Scan Lock, Secure Watermark, IEEE 2600.1 Common Criteria Certification |
| Environmental Features |
| Estimated Toner Yield | (Estimated Yield @ 5% Coverage): Black: 36,000 Images, Color (C,M,Y): 27,000 Images |
| Acceptable Originals | 11" X 17", Legal, Letter, Letter-R, Statement, Or Statement-R |
| Scan Method | Duplex Automatic Document Feeder |
| Scanning Speed | (BW/Color; Letter): Simplex: Up To 51/51 Ipm (300 Dpi)/ Up To 46/46 Ipm (600 Dpi) Duplex: Up To 19.6/19.6 Ipm (300 Dpi)/ Up To 17.5/17.5 Ipm (600 Dpi) |
| Capacity | (20 Lb. Bond): 100 Sheets |
| Paper Weight | 1-Sided Scanning: 11 Lb. Bond To 58 Lb. Cover (42 To 157g/M²) 2-Sided Scanning: 13 Lb. Bond To 58 Lb. Cover (50 To 157g/M²) |
| Description | Cassette Feeding Unit-AD2 |
| Paper Capacity | 550 Sheets X 2 Cassettes [20 Lb. Bond (80g/M²)] |
| Paper Size | 12" X 18", 11" X 17", Legal, Letter, Letter-R, Statement-R, Executive, And Custom Size [5-1/2" X 7-1/8" To 12" X 18" (139.7mm X 182mm To 304.8mm X 457.2mm)] |
| Power Source | From The Main Unit |
| Power Consumption | Approximately 30W |
| Dimensions | 9-7/8" X 24-3/8" X 27-5/8" (251mm X 620mm X 700mm) |
| Weights | Approximately 61.7 Lb. (28kg) |
| Description | Paper Deck Unit-B2 |
| Number Of Cassettes | 1 |
| Paper Capacity | 2,700 Sheets [20 Lb. Bond (80g/M²)] |
| Paper Size | Letter |
| Paper Weight | 14 Lb. Bond To 60 Lb. Cover (52 To 163g/M²) |
| Power Source | From Main Unit |
| Power Consumption | Approximately 45W |
| Dimensions | 18-5/8" X 14-5/8" X 23-3/4" (473mm X 372mm X 603mm) |
| Weights | Approximately 81.6 Lb. (37kg) |
| Description | Envelope Feeder Attachment-D1** |
| Paper Capacity | 50 Sheets (Or 30mm In Height) |
| Paper Size | COM10 No.10, Monarch, DL, ISO-C5Feeding Speed: 10 Cpm |
| Dimensions | 3-1/4" X 17-1/4" X 12-1/8" (81mm X 439mm X 307mm) |
| Weights | Approximately 2.6 Lb. (1.2kg) |
| Description | Inner 2-Way Tray-F1Δ |
| Total Output Capacity | Top Tray: 250 Sheets (20 Lb. Bond) Lower Tray: 100 Sheets (20 Lb. Bond)Number Of Trays: 2 |
| Paper Size | 12" X 18", 12-5/8" X 17-11/16", 11" X 17", Legal, Letter, Letter-R, Statement, Statement-R, Executive, Custom Size [3-7/8" X 5-9/16" To 12-5/8" X 18" (99mm X 139.7mm To 320mm X 457.2mm)], And Envelopes |
| Paper Weight | 14 Lb. Bond To 140 Lb. Index (52 To 256g/M²) |
| Dimensions | 3" X 16-3/4" X 16" (76mm X 427mm X 407mm) |
| Weight | Approximately 1.3 Lb. (574g) |
| Description | Inner Finisher-E1Δ |
| Paper Size | 12" X 18", 12-5/8" X 17-11/16", 11" X 17", Legal, Letter, Letter-R, Statement, Statement-R, Executive, Custom Size (3-7/8" X 5-9/16" To 12-5/8" X 18"), And Envelopes |
| Number Of Trays | Up To 2 Trays (With Inner Finisher Additional Tray-A1) |
| Total Output Capacity | Without Inner Finisher Additional Tray-A1: 500 Sheets |
| Top Tray | (With Inner Finisher Additional Tray-A1): 100 Sheets (Letter) |
| Lower Tray | (With Inner Finisher Additional Tray-A1): 200 Sheets (Letter) |
| Staple Positions | Corner Stapling (11" X 17", Legal, Letter, Letter-R) Double Stapling (11" X 17", Legal, Letter, Letter-R) |
| Stapling Capacity | Letter And Executive: 50 Sheets (14 To 21 Lb. Bond) 30 Sheets (22 To 28 Lb. Bond) 2 Sheets (29 Lb. Bond To 140 Lb. Index) 11" X 17", Legal And Letter-R: 30 Sheets (14 To 21 Lb. Bond) 20 Sheets (22 To 28 Lb. Bond) 2 Sheets (28 Lb. Bond To 140 Lb. Index)Paper Capacity Of Staple Mode: Top Tray: 3/8" In Height Lower Tray: 30 Sets (Or 2-1/2" In Height) |
| Type Of Staple | Staple-J1 (5,000 X 3) |
| Power Consumption | Approximately 40W |
| Dimensions | 9-1/4" X 34-1/8" X 21-1/4" [234mm X 865mm X 540mm (When The Auxilary Tray Is Extended)] |
| Weight | Approximately 28.7 Lb. (13kg) |
| Description | Staple Finisher-J1Δ |
| Paper Size | 12" X 18", 12-5/8" X 17-11/16", 11" X 17", Legal, Letter, Letter-R, Statement, Statement-R, Executive, Custom Size [3-7/8" X 5-9/16" To 12-5/8" X 18" (99 X 139.7mm To 320mm X 457.2mm)], And Envelopes |
| Paper Type | Thin, Plain, Recycled, Color, Pre-Punched, Bond, Heavy, Tracing, Letterhead, Coated, Labels, Transparency, And Envelopes |
| Number Of Trays | 2 |
| Total Output Capacity | 3,000 Sheets (Letter, Statement-R, Executive) |
| Top Tray | 1,300 Sheets (Letter, Statement-R, Executive) 650 Sheets (11" X 17", Legal, Letter-R) |
| Lower Tray | 1,700 Sheets (Letter, Statement-R, Executive) 650 Sheets (11" X 17", Legal, Letter-R) |
| Staple Positions | Corner Stapling: (11" X 17", Legal, Letter, Letter-R, Executive) Double Stapling: (11" X 17", Legal, Letter, Letter-R, Executive) |
| Stapling Capacity | Letter And Executive: 50 Sheets (14 To 21 Lb. Bond) 30 Sheets (22 To 28 Lb. Bond) 2 Sheets (29 Lb. Bond To 140 Lb. Index)11" X 17", Legal And Letter-R: 30 Sheets (14 To 21 Lb. Bond) 20 Sheets (22 To 28 Lb. Bond) 2 Sheets (29 Lb. Bond To 140 Lb. Index)Paper Capacity Of Staple Mode: Top Tray: 1,300 Sheets/30 Sets (Letter, Executive), 650 Sheets/30 Sets (11" X 17", Legal, Letter-R) Lower Tray: 1,700 Sheets/30 Sets (Letter, Executive), 650 Sheets/30 Sets (11" X 17", Legal, Letter-R) |
| Power Consumption | Approximately 100W |
| Dimensions | 43-1/4" X 26-5/8" X 25-1/2" [1,097mm X 677mm X 646mm (When The Auxilary Tray Is Extended)] |
| Weight | Approximately 101 Lb. (46kg) |
| Description | Booklet Finisher-J1Δ |
| Paper Size | 12" X 18", 12-5/8" X 17-11/16", 11" × 17", Legal, Letter, Letter-R, Statement, Statement-R, Executive, Custom Size [3-7/8" X 5-9/16" To 12-5/8" X 18" (99 X 139.7mm To 320mm X 457.2mm)], And Envelopes |
| Paper Type | Plain, Heavy, Color, Recycled, Pre-Punched, Transparency, Tracing, Labels, Bond, Transparency, Envelopes |
| Paper Capacity Of Saddle Stitch Mode | 16 Sheets (14 To 20 Lb. Bond) 10 Sheets (22 To 28 Lb. Bond)Paper Capacity Of Saddle-Stitch Mode:25 Booklets (5-Sheet Booklets) |
| Staple Positions | Corner/Double Stapling: 11" X 17", Legal, Letter, Letter-R, Executive Saddle-Stitch: 11" X 17", Legal, Letter-R |
| Stapling Capacity | Letter And Executive: 50 Sheets (14 To 22 Lb. Bond) 30 Sheets (22 To 28 Lb. Bond) 2 Sheets (29 Lb. Bond To 140 Lb. Index) 11" X 17", Legal And Letter-R: 30 Sheets (14 To 21 Lb. Bond) 20 Sheets (22 To 28 Lb. Bond) 2 Sheets (29 Lb. Bond To 140 Lb. Index)Paper Capacity Of Staple Mode: Top Tray: 1,300 Sheets/30 Sets (Letter, Executive), 650 Sheets/30 Sets (11" X 17", Legal, Letter-R) Lower Tray: 1,700 Sheets/30 Sets (Letter, Executive), 650 Sheets/30 Sets (11" X 17", Legal, Letter-R) |
| Type Of Staple | Staple-J1 (5,000 X 3) Staple Cartridge-D3 (2,000 X 3) |
| Power Consumption | Approximately 123W |
| Dimensions | 43-1/4" X 31-1/8" X 25-1/2" [1097mm X 789mm X 646mm (When The Auxilary Tray Is Extended)] |
| Weight | Approximately 165 Lb. (75kg) |
| Description | External 2/3 Hole Puncher-B2 |
| Paper Size | 11" X 17", Legal, Letter, Letter-R |
| Paper Type | Thin, Plain, Heavy, Color, Recycled, Letterhead,Coated |
| Punch Type | 2 Holes: (Legal, Letter-R, Executive) 3 Holes: (11" X 17", Letter) |
| Tray Capacity | 2 Holes: 10,000 Sheets (21 Lb. Bond) 3 Holes: 3,000 Sheets (21 Lb. Bond) |
| Distance Between Punch Holes | 2 Holes: 2-3/4" (70mm) 3 Holes: 4-1/4" (108mm) |
| Power Requirements | From The Main Unit |
| Dimensions | 36x 4-1/4" X 24-1/4" (915mm X 107mm X 615mm) |
| Weight | Approximately 15.9 Lb. (7.2kg) |
| Applicable Line | 4 |
| Modem Speed | Super G3: 33.6 Kbps G3: 14.4 Kbps |
| Data Compression | MH, MR, MMR, JBIG |
| Resolution | 400 X 400 Dpi, 200 X 400 Dpi, 200 X 200 Dpi, 200 X 100 Dpi |
| Scanning Recording Size | Statement To 11" X 17" |
| Fax Features | Job Forwarding, Different-Size Originals, Adjusting Overall Density For Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Specifying The Sender's Name (When Sending Fax), Selecting The Telephone Line (When Sending Fax), Delayed Send, Preview, Finished Stamp, Job Done Notice, Original Type Selection, Two-Sided Original, Book To Two Pages |
| Processor | Canon Dual Custom Processor (Shared) |
| Standard Memory | 2GB RAM |
| Maximum Memory | 2.5GB RAM |
| Hard Disk | Standard: 160GB Maximum: 1TB |
| Engine Resolution | 1200 X 1200 Dpi |
| Pdl Support | Standard: UFR II Optional: PCL 5c, PCL 6, Adobe PS 3 |
| Print Controller Technology | UFR II, PCL 5c/6, Adobe PS 3: Windows® (XP/Windows Vista®/7), Windows Server (2003/ 2008/2008 R2/SBS 2011/2012), Windows Terminal Servers (Server 2003/Server 2008/Server 2008 R2/2012), Microsoft® Clustering Server (Server 2003/Server 2003 R2/Server 2008/Server 2008 R2), Citrix (Presentation Server 4.5, Xen App 5.0/6.0/6.5, Xen Desktop 4.0/5.0/5.5), Macintosh® (OS X 10.5.8 Or Later, UFR II And PS 3 Only), VMware, SAP (PS And PCL Only) |
| Print Features | Suspend Job Timeout, Subset Finishing (PS Only), Profile Settings, Secured Print, Watermark, Page Border, Header/Footer, Page Layout, Two-Sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing On Transparencies, Front/Back Covers, Black And White Printing, Objective, Color/Black-And-White Auto Detect, Toner Reduction, Poster PrintingDirect Print Support: Standard: TIFF, JPEG Optional: PDF, XPS††, EPS††† |
| Sending Method | E-Mail, I-Fax, File Server (FTP, SMB, WebDAV), Mail Box, Super G3 Fax (Optional) |
| Color Mode | Auto Color Select (Color, Gray), Auto Color Select (Color, Black), Full Color, Grayscale, BW |
| Scan Resolution | 600 X 600 Dpi, 400 X 400 Dpi, 300 X 300 Dpi, 200 X 400 Dpi, 200 X 200 Dpi, 200 X 100 Dpi, 150 X 150 Dpi, 100 X 100 Dpi |
| Address Book Capacity | Max. 1,800 Destinations (Incl. 200 One-Touch Buttons) |
| Communication Protocol | File: FTP (TCP/IP), SMB (TCP/IP), WebDAV E-Mail/I-Fax: SMTP, POP3, I-FAX (Simple, Full) |
| File Format | Standard: TIFF, JPEG, PDF, PDF (Compact), PDF (Apply Policy), PDF (Optimize For Web), PDF/XPS (OCR), PDF/A-1b, XPS, XPS (Compact), OOXML (OCR) (.Pptx And .Docx)♦♦ Optional: PDF (Trace & Smooth), PDF (Encrypted), PDF/XPS (Digital Signature), PDF (Reader Extensions) |
| I Fax Data Format | Color: .Tfx (JPEG) BW: .Tif (MH, MR, MMR)Universal Send Features: Two-Sided Original, Different-Size Originals, Original Type Selection, Book To Two Pages, Density Adjustment, Sharpness, Document Name, Copy Ratio, Erase Frame, Job Build, Delayed Send, Preview, Finished Stamp, Job Done Notice, File Name, Subject/Message, Reply-To, Sender's Name (TTI), E-Mail Priority * Not Available On Top Cassette. ** Can Be Set To Cassette 2 Only. Can Not Install Envelope Feeder Attachment And Tab Feeding Attachment At Same Time. *** If "Quick Startup Settings For Main Power" Is Set To ON, It Takes 7 Seconds Until The Key Operation On The Touch Panel Display Is Available After Turning On The Main Power. † Includes Consumables. †† XPS Cannot Be Printed Directly From The Web Access Software. ††† EPS Can Be Printed Directly Only From Remote User Interface Δ The Inner 2-Way Tray-F1, Inner Finisher-E1, Staple Finisher-J1, And Booklet Finisher-J1 Cannot Be Installed At The Same Time. ♦♦Standard In 120V Models; Optional In 230V Models |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
