OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The compact and sustainably designed imageRUNNER ADVANCE C3525i II device runs on the intelligent imageRUNNER ADVANCE platform, designed to support businesses and their documents' lifecycles from start to finish. The device offers printing speeds of up to 25 ppm (BW/color) and supports media up to 11" x 17" in various weights while offering several available finishing options. The imageRUNNER ADVANCE C3525i II also comes standard with a single-pass duplex scanner for scan speeds of 160 ipm (300 dpi)/51 ipm (600 dpi) and the ability to convert and send documents digitally for efficient results.
- Subscription to a third-party cloud service required. Subject to third-party cloud service providers' terms and conditions.
- Requires additional option.
Note: Canon products offer certain security features, yet many variables can impact the security of your devices and data. Canon does not warrant that use of its features will prevent security issues. Nothing herein should be construed as legal or regulatory advice concerning applicable laws; customers must have their own qualified counsel determine the feasibility of a solution as it relates to regulatory and statutory compliance. - Available 2Q 2018.
- For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net.
- Time from device power-on to when copy jobs can be programmed.
- Includes main unit and either Cassette Feeding Unit-AP1 or Cabinet Type-R.
- ncludes main unit and either Cassette Feeding Unit-AP1 or Cabinet Type-R and Staple/Booklet Finisher-AA1.
- Includes main unit, ADF, consumables, and Cassette Feeding Unit-AP1.
- PDF print from Web sites is supported.
- Requires the optional PCL International Font Set-A1.
- Requires the optional Barcode Printer Kit-D1.
- Other operating systems and environments, including AS/400, UNIX, Linux and Citrix, may be supported. Some solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative.
- 0.8 W sleep mode not available in all circumstances due to certain settings.
- 120v only.
- GPR-53L Toner also available for Color (C, M, Y). Yield (estimated @ 5% coverage) is 8,500 images.
| Model Name | ImageRUNNER ADVANCE C3525i II |
| Type | Color Laser Multifunctional |
| Functions | Standard: Print, Copy, Scan, Send, Store Optional: Fax |
| Operation Panel | 25.6 Cm (10.1 Inch) TFT LCD WSVGA Color Touchpanel |
| Image Server Memory | 3.0 GB RAM |
| Hard Disk Drive | Standard: 250 GB |
| Network Interface Connection | 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 B/G/N) |
| Other Interface | Standard: USB 2.0 X1 (Host), USB 3.0 X1 (Host), USB 2.0 X1 (Device) Optional: Serial Interface, Copy Control Interface |
| Max Mailboxes Supported | 100 User In-Boxes, 1 Memory RX In-Box, 50 Confidential Fax In-Boxes |
| Max Pages Stored | 30,000 |
| Available Disk Space | Approx. 16 GB (Standard HDD) |
| Common Protocol | SMB Or WebDAV |
| Supported Client Pc | Windows (Windows Vista/7/8/8.1/10) |
| Max Number Of Concurrent Connections | SMB: 64 WebDAV: 3 (Active Sessions) |
| Advanced Box Features | Disabling Advanced Box, Storage Filtering, Authentication For Advanced Box Log-In, Search Function, Sort Function, Printing A PDF File With A Password, ImageWARE Secure Audit Manager Support |
| Standard | USB |
| Scanning Resolution | 600 X 600 Dpi, 400 X 400 Dpi, 300 X 300 Dpi, 200 X 400 Dpi, 200 X 200 Dpi, 200 X 100 Dpi, 150 X 150 Dpi, 100 X 100 Dpi |
| Printing Resolution | 1200 X 1200 Dpi |
| Letter | Up To 25 Ppm |
| Letter R | Up To 20 Ppm |
| Legal | Up To 15 Ppm |
| Ledger | Up To 15 Ppm |
| First Copy Time | Letter: As Fast As 5.9 Seconds (BW)/ 8.2 Seconds (Color) |
| Multiple Copies | Up To 999 Copies |
| Color Mode | Automatic-Color Select (Full Color/Grayscale), Automatic-Color Select (Full Color/Black-And-White), Full Color, Grayscale, And Black-And-White |
| Copy Exposure | Automatic Or Manual (9 Levels) |
| Magnification | 25%-400% (1% Increments) |
| Preset Reductions | 25%, 50%, 64%, 73%, 78% |
| Preset Enlargements | 121%, 129%, 200%, 400% |
| Standard Paper Capacity | (LTR, 20 Lbs. Bond): 1,200 Sheets |
| Maximum Paper Capacity | (LTR, 20 Lbs. Bond): 2,300 Sheets |
| Output Paper Capacity | (LTR, 20 Lbs. Bond): 250 Sheets Maximum: 3,450 Sheets (With External Finisher And Copy Tray) |
| Cassettes | Paper Cassette 1: Letter, Executive, Statement-R, Envelope [No.10 (COM10), DL, ISO-C5], Custom Size (5-1/2" X 7-1/8" To 11-3/4" X 8-1/2") Paper Cassette 2: 12" X 18", 11" X 17", Legal, Letter, Letter-R, Executive, Statement-R, Envelope [No.10 (COM10), Monarch, DL], Custom Size (5-1/2" X 7-1/8" To 12" X 18") |
| Bypass | 12" X 18", 11" X 17", Legal, Letter, Letter-R, Executive, Statement, Statement-R, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Envelope Custom Size (3-7/8" X 3-7/8" To 12-5/8" X 18"), Custom Size (3-7/8" X 5-1/2" To 12-5/8" X 18"), Free Size (3-7/8" X 5-1/2" To 12-5/8" X 18") |
| Other Option | Cassette Feeding Unit-AP1: 12" X 18", 11" X 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" X 7-1/8" To 12" X 18") |
| Cassette | 14 Lb. Bond To 80 Lb. Cover (52 To 220 G/M2) |
| Bypass | 14 Lb. Bond To 110 Lb. Cover (52 To 300 G/M2) |
| Duplexing | Single-Pass Duplexing Automatic Document Feeder |
| Paper Size | Letter, Executive, Statement-R, Envelope |
| Paper Weight | 14 Lb. Bond To 80 Lb. Cover (52 To 220 G/M2) |
| Warm Up Time | From Power On: 34 Seconds From Sleep Mode: 10 Seconds Quick Startup Mode: 10 Seconds5 |
| Power Requirements | 120-127V AC 60 Hz,7.5 A 220-240V AC 50/60Hz, 4.0A |
| Power Consumption | Maximum: Approx. 1.5 KWh Standby: Approx. 44.1 W Sleep Mode: Approx. 0.8 W13 Typical Electricity Consumption (TEC) Rating: 1.0 KWh (120V) 0.9kWh (230V) |
| Plug | NEMA 5-15P (120V) CEEE7/7 (230V) |
| Dim | 22-1/4" X 29-1/4" X 45-1/5"(565 Mm X 742 Mm X 1148 Mm)6 |
| Installation Space | Basic: Stack Bypass + Cassette Drawers Open: 38-1/2" X 44-1/4" (978 Mm X 1123 Mm)6 Fully Configured: 63-3/4" X 44-1/4" (1620 Mm X 1123 Mm)7 |
| Weight | Approx. 213.9 Lb. (97 Kg)8 |
| Basic Copy Features | Preset Reduction/Enlargement Ratios By Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel |
| Special Copy Features | Book To Two Pages, Two-Sided Original, Finishing, Booklet, Job Build, N On 1, Add Cover, Insert Sheets, Different-Size Originals, Density Adjustment, Original Type Selection, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Gutter, Print & Check, Negative/Positive, Repeat Images, Job Done Notice, Mirror Image, Copy ID Card, Detect Feeder Multi Sheet Feed, Free Size Original, Adjust One-Touch Color, Color Balance, Area Designation |
| Standard S | Authentication Standard: Universal Login Manager, User Authentication, Department ID Authentication, Access Management System, Device And Function Level Log-In Optional: UniFLOW Data Standard: Trusted Platform Module (TPM), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption(FIPS140-2 Validated) Optional: Hard Disk Drive Removal, IEEE 2600.2 Common Criteria Certification, Data Loss Prevention (Requires UniFLOW) Network Standard: IP/Mac Address Filtering, IPsec, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication Before SMTP Document Standard: Secure Print, Adobe LiveCycle® Rights Management ES2.5 Integration Optional: Encrypted PDF, Encrypted Secure Print, User And Device Signatures, Secure Watermarks, Document Scan Locking |
| Environmental Features | ENERGY STAR® Certified Rated EPEAT® Gold14 |
| Toner | GPR-53 Toner15 |
| Estimated Toner Yield | (Estimated @ 5% Coverage): Black: 36,000 Images Color (C,M,Y): 19,000 Images |
| Description | Single-Pass Duplexing Automatic Document Feeder |
| Acceptable Originals | Sheet, Book, 3-Dimensional Objects [Up To 4.4 Lb. (2 Kg)] |
| Bw Originals | 13 Lb. Bond To 58 Lb. Cover (50 To 157 G/M2) |
| Color Originals | 17 Lb. Bond To 58 Lb. Cover (64 To 157 G/M2) |
| Scan Method | Color Network ScanGear2 For Both Twain And WIA Supported OS: Windows Vista/7/8/8.1/10/ Server 2008/Server 2008 R2/ Server 2012/Server 2012 R2 Scan To Mobile Devices And Cloud-Based Services: A Range Of Solutions Is Available To Provide Scanning To Mobile Devices And Cloud-Based Services Depending On Your Requirements. |
| Scanning Speed | Single-Sided Scanning (BW/Color): 80 Ipm (300 Dpi)/51 Ipm (600 Dpi) Double-Sided Scanning (BW/Color): 160 Ipm (300 Dpi)/51 Ipm (600 Dpi) |
| Capacity | 150 Sheets (20 Lb. Bond) |
| Different Size Originals | 11" X 17", Legal, Letter, Letter-R, Statement, Statement-R |
| Applicable Line | 1 |
| Modem Speed | Super G3: 33.6 Kbps G3: 14.4 Kbps |
| Data Compression | MH, MR, MMR, JBIG |
| Resolution | 400 X 400 Dpi, 200 X 400 Dpi, 200 X 200 Dpi, 200 X 100 Dpi |
| Scanning Recording Size | Statement-R To 11" X 17" |
| Maximum Memory | Up To 30,000 Pages |
| Memory Backup | Yes |
| Coded Speed Dialing Locations | Speed Dials: Max 200 Group Dials/ Destinations: Max. 199 Dials Sequential Broadcast: Max. 256 Addresses |
| Fax Features | Sharpness, Copy Ratio, Erase Frame, Job Build, Specifying The Sender's Name (When Sending Fax), Sender's Name (TTI), Select Line, Selecting The Telephone Line (When Sending Fax), Direct Send, Delayed Send, Preview, Finished Stamp, Job Done Notice, TX Report, Multi Sheet Feed Detection |
| Type | PDF, TIFF, JPEG, EPS, XPS |
| System | UFRII/PS: Server 2003/Server 2003 R2/Windows Vista®/Server 2008/Windows® 7/Server 2008 R2/Windows 8/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016, MAC OS X (10.7 Or Later) PCL: Server 2003/Server 2003 R2/Windows Vista/Server 2008/Windows 7/Server 2008 R2/Windows 8/Server 2012/Windows 8.1/Server 2012 R2/Windows 10/Server 2016 |
| Print Resolution | 1200 X 1200 Dpi |
| Pdl Support | UFR II, PCL®6, Adobe® PS® 3 |
| Postscript Fonts | 136 Roman |
| Pcl Fonts | 93 Roman, 10 Bitmap Fonts, 2 OCR Fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified And Traditional Chinese)10, Barcode Fonts11 |
| Print Features | Border, Header/Footer, Page Layout, Two-Sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing On Transparencies, Front/Back Covers, Toner Reduction, Poster Printing Direct Print: Available From USB, Advanced Box, Remote UI, And Web Access9 Printing From Mobile And Cloud-Based Services: A Range Of Software And MEAP-Based Solutions Are Available To Provide Printing From Mobile Devices Or Internet-Connected Devices And Cloud-Based Services Depending On Your Requirements. |
| Description | Original Type Selection,Two-Sided Original, Book To Two Pages, Different-Size Originals, Density Adjustment, Sharpness, Copy Ratio, Erase Frame, Job Build, Direct Send, Delayed Send, Preview, Finished Stamp, Job Done Notice, File Name, Subject/Message, Reply-To, E-Mail Priority, TX Report, Original Content Orientation, Skip Blank Originals, Multi Sheet Feed Detection |
| Sending Method | E-Mail/Internet Fax (SMTP), SMB, FTP, WebDAV, Mail Box, Super G3 Fax (Optional), IP Fax (Optional) |
| Address Book Capacity | LDAP (2,000)/Local (1,600)/Speed Dial (200) |
| Communication Protocol | FTP, SMB, WebDAV |
| File Format | Standard: TIFF, JPEG, PDF(Compact, Searchable, Apply Policy, Optimize For Web, PDF A/1-B), XPS (Compact, Searchable), Office Open XML (PowerPoint®, Word) Optional: PDF (Trace & Smooth, Encrypted), PDF/XPS (Digital Signature) |
| I Fax Data Format | SMTP, POP3, I-Fax (Simple, Full) |
| Sending Size | 600 X 600 Dpi, 400 X 400 Dpi, 300 X 300 Dpi, 200 X 400 Dpi, 200 X 200 Dpi, 200 X 100 Dpi, 150 X 150 Dpi, 100 X 100 Dpi |
- 120v only.
GPR-53L Cyan
Estimated Toner Yield: 8,500 Copies/Bottle (Estimated @ 5% Coverage)
GPR-53L Yellow
GPR-53 Toner Magenta
Estimated Toner Yield: 19,000 Copies/Bottle (Estimated @ 5% Coverage)
GPR-53 Toner Black
Estimated Toner Yield: 36,000Copies/Bottle (Estimated @ 5% Coverage)
GPR-53L Magenta
GPR-53 Toner Yellow
GPR-53 Toner Cyan
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
