imageRUNNER ADVANCE C350iF
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Untitled Document
| Model Name | ImageRUNNER ADVANCE C350iF |
| Type | Color Digital Multifunction Imaging System |
| Functions | Copy, Print (UFR II, PCL 5c/6, Adobe® PostScript® 3™), Fax (Up To 1 Line), Scan, Send |
| Operation Panel | 7" WVGA Full-Color TFT Screen |
| Image Server Memory | Standard: 2 GB RAM Maximum: 2 GB RAM |
| Hard Disk Drive | Standard: 80 GB Maximum: 80 GB |
| Network Interface Connection | Ethernet 10/100/1000Base-TX |
| Other Interface | USB 2.0 X3 (Host), USB 2.0 (Device) |
| Advanced Box Features | Store To Remote Advanced Box: Supported Print/View From Remote Advanced Box: Supported |
| Standard | Store To USB Memory |
| Network Twain Scan | Standard: Network WIA Scan |
| Network Scan Utility | Color Network ScanGear 2 |
| Letter | Up To 36/36 Ppm |
| Legal | Up To 29/29 Ppm |
| First Copy Time | As Fast As 5.9 Seconds (BW) And 7.4 Seconds (Color) |
| Multiple Copies | 1 To 999 |
| Copy Exposure | Automatic Or Manual (9 Levels) |
| Magnification | 25 - 400% (1% Increments) |
| Preset Reductions | 25%, 50%, 64%, 78% |
| Preset Enlargements | 129%, 200%, 400% |
| Standard Paper Capacity | (20 Lb. Bond): 550-Sheet Paper Cassette 100-Sheet Stack Bypass |
| Optional | 1 X 550-Sheet Paper Cassette 3 X 550-Sheet Paper Cassette |
| Maximum Paper Capacity | 2,300 Sheets |
| Output Paper Capacity | (21 Lb. Bond): Standard:250 Sheets Maximum: 500 Sheets (Non-Stapled With Staple Finisher-S1 Attached) |
| Cassettes | Legal, Letter, Statement, Executive, Custom Size [(3-7/8" X 7-1/2" To 8-1/2" X 14") (98.4 Mm X 190.5 Mm To 216 Mm X 355.6 Mm)], And Envelopes (COM10, Monarch, DL, ISO-C5)* |
| Bypass | Legal, Letter, Statement, Executive, Custom Size [(3-7/8" X 5-7/8" To 8-1/2" X 14") (98.4 Mm X 148 Mm To 216 Mm X 355.6 Mm)], And Envelopes (COM10, Monarch, DL, ISO-C5) |
| Cassette | 16 Lb. Bond To 60 Lb. Cover (60 To 163 G/M2) |
| Bypass | 16 Lb. Bond To 80 Lb. Cover (60 To 220 G/M2) |
| Paper Size | Standard Automatic Trayless Duplexing (Statement To Legal) |
| Paper Weight | Up To 60 Lb. Cover (163 G/M2) |
| Warm Up Time | From Power On: 34 Seconds From Sleep Mode: 10 Seconds Quick Startup Mode: 10 Seconds** |
| Power Requirements | 120 V, 60 Hz, 7.5 A |
| Power Consumption | Maximum: 1.5 KW Sleep Mode: 1 W |
| Plug | NEMA 5-15 |
| Dim | 24" X 20-1/8" X 24-1/2" (610 Mm X 511 Mm X 621 Mm) |
| Installation Space | 33-1/2" X 24-1/2" ( 852 Mm X 621 Mm) (When The Multipurpose Tray Is Extended) |
| Weight | Approx. 99.2 Lb. (45 Kg)*** |
| Scan Resolution | Up To 600 X 600 Dpi |
| Acceptable Originals | (Glass): Sheet, Book, 3-Dimensional Objects [Up To 4.4 Lb. (2 Kg)] |
| Maximum Original Size | Legal (8-1/2" X 14") |
| Basic Copy Features | Preset R/E Ratios By Area, Finishing, Two-Sided, Exposure Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel, Standard Keys, Reset, Job Duration Display, Reserved Copying, ID Management, Counter Check |
| Special Copy Features | ID Card Copy, Shift, Frame Erase, Scan Image Check, Mode Memory, Recall, Sharpness, Secure Watermark, Page Numbering, Copy Set Numbering, Watermark And Date |
| Standard S | Department ID Management, Single Sign On-H, Access Management System (Device And Function Level Log-In), Secured Print, Trusted Platform Module, IPv6, Restricting Features (Restricting The Send Function, Restricting New Addresses On Address Book), Send To Myself (Only), Send To My Personal Folder (Only), SSL Encrypted Communication, SNMPv1/V3, MAC/IP Address Filtering, IEEE 802.1x (Wired/Wireless), SMTP Authentication, POP Authentication Before SMTP, HDD Initialize (Up To 9x) HDD Erase (Up To 3x), HDD Lock, IPsec, Adobe® LiveCycle® Rights Management ES2.5 Integration |
| Optional | HDD Encryption, HDD Erase Scheduler, Encrypted Secured Print, Encrypted PDF, Secure Watermark, IEEE 2600.1 Common Criteria Certification,♦ ImageWARE Secure Audit Manager Express, UniFLOW, AA-Print, Universal Login Manager |
| Environmental Features |
| Estimated Toner Yield | BW: 19,000 Images Color (C,M,Y): 21,500 Images |
| Description | Document Feeder |
| Acceptable Originals | Paper Size: Legal, Letter, StatementPaper Weights: 1-Sided Scanning (Single Sheet): 13 Lb. Bond To 34 Lb. Bond (50 To 128 G/M2) 1-Sided Scanning (Multiple Sheets): 13 Lb. Bond To 28 Lb. Bond (50 To 105 G/M2), 2-Sided Scanning: 17 Lb. Bond To 28 Lb. Bond (64 To 105 G/M2) |
| Scan Method | Duplexing Automatic Document Feeder |
| Scanning Speed | Simplex: 36 Ipm (300 Dpi)/23 Ipm (600 Dpi) Duplex: 11 Ipm (300 Dpi)/9 Ipm (600 Dpi) |
| Capacity | (20 Lb. Bond): 50 Sheets |
| Description | Cassette Feeding Unit-AG1 |
| Paper Capacity | 550 Sheets [21 Lb. Bond (80 G/M2)] |
| Paper Size | Legal, Letter, Statement, Executive, Custom Size [3-7/8" X 7-1/2" To 8-1/2" X 14" (98.4 Mm X 190.5 Mm To 216 Mm X 355.6 Mm)] |
| Paper Weight | 16 Lb. Bond To 60 Lb. Cover (60 To 163 G/M2) |
| Power Source | From The Main Unit |
| Power Consumption | Approx. 25 W |
| Dimensions | 16-3/4" X 20-1/8" X 20" (425 Mm X 511 Mm X 508 Mm) |
| Weights | Approx. 33.1 Lb. (15 Kg) |
| Description | Cassette Feeding Unit-AH1 |
| Paper Capacity | 550 Sheets X 3 Cassettes [21 Lb. Bond (80 G/M2) |
| Paper Size | Legal, Letter, Statement, Executive, And Custom Size [3-7/8" X 7-1/2" To 8-1/2" X 14" (98.4mm X 190.5mm To 216mm X 355.6mm)] |
| Power Consumption | Approx. 35W |
| Dimensions | 16-3/4" X 20-1/8" X 20" (425mm X 511mm X 508mm) |
| Weights | Approx. 41.9 Lb (19kg) |
| Description | Staple Finisher-S1 |
| Paper Size | Legal, Letter, Statement, Executive, Custom Size [3-7/8" X 5-7/8" To 8-1/2" X 14" (98.4mm X 148mm To 216mm X 355.6mm)], And Envelopes |
| Paper Weight | 16 Lb. Bond To 80 Lb. Cover (60 To 220g/M2) |
| Number Of Trays | 1 |
| Total Output Capacity | No Finishing, Collate, Group Mode: 500 Sheets [Or 2-7/8" (73.5mm) In Height] Collate + Offset, Group + Offset Mode: 500 Sheets [Or 2-7/8" (73.5mm) In Height] Staple Mode: 20 Sets [Or 2-7/8" (73.5mm) In Height] |
| Staple Capacity | 30 Sheets |
| Staple Positions | Corner Stapling (Legal, Letter, Executive) |
| Type Of Staple | Staple-P1 (5,000 X 2) |
| Power Source | Approx. 37W |
| Power Consumption | From The Main Unit |
| Dimensions | 11-7/8" X 23-1/4" X 18-1/8" [301mm X 589mm X 459mm] |
| Weight | Approx. 30.9 Lb. (14 Kg) |
| Applicable Line | Standard:1 Maximum: 1 |
| Modem Speed | Super G3: 33.6 Kbps G3: 14.4 Kbps |
| Data Compression | MH, MR, MMR, JBIG |
| Resolution | 400 X 400 Dpi, 200 X 400 Dpi, 200 X 200 Dpi, 200 X 100 Dpi |
| Scanning Recording Size | Statement To Legal |
| Fax Features | Job Forwarding, Density Adjustment, Sharpness, Erase Frame, Job Build, Specifying The Sender's Name (When Sending Fax), Selecting The Telephone Line (When Sending Fax), Delayed Send, Preview, Job Done Notice, Original Type Selection, Two-Sided Original, Direct Send, On-Hook Dialing |
| Processor | Canon Dual Custom Processor (Shared) |
| Engine Resolution | 600 X 600 Dpi |
| Pdl Support | UFR II, PCL 5c/6, Adobe PostScript 3 |
| Print Controller Technology | UFR II, Adobe PostScript 3: Windows® (XP/Windows Vista®/7/8.1), Windows Server (2003/2008 /2008 R2/SBS 2011/2012/2012 R2), Windows Terminal Server (2003/2008/2008 R2/2012/2012 R2), Microsoft Clustering Server (2003/2008/2008 R2/2012/2012 R2), Citrix (Presentation Server 4.5, XenApp 5.0/6.0/6.5, XenDesktop 4.0/5.0/5.5/5.6/7.0), VMware (VSphere 4/5/5.1), SAP (PS3 Only), Macintosh® (OS X 10.5.8 Or Later)PCL 5c/6: Windows® (Windows XP/Windows Vista®/7/8.1) Windows Server (2003/2008/2008 R2/SBS 2011/2012/2012 R2), Windows Terminal Server (2003/2008/2008 R2/2012/2012 R2), Microsoft Clustering Server (2003/2008/2008 R2/2012/2012 R2), Citrix (Presentation Server 4.5, XenApp 5.0/6.0/6.5, XenDesktop 4.0/5.0/5.5/5.6/7.0), VMware (VSphere 4/5/5.1), SAPDirect Print Support Standard:TIFF, JPEG, PDF, EPS† Optional: XPS†† |
| Print Features | Suspend Job Timeout, Subset Finishing (PS Only), Profile Settings, Secured Print, Watermark, Page Border, Header/Footer, Page Layout, Two-Sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing On Transparencies, Front/Back Covers, Objective, Color/Black- And-White Auto Detect, Toner Reduction, Poster Printing, Form Overlay |
| Sending Method | E-Mail, I-Fax, File Server (FTP, SMB, WebDAV), Super G3 Fax |
| Color Mode | Auto Color Select (Color, Gray), Auto Color Select (Color, Black) Full Color, Grayscale, BW |
| Scan Resolution | BW: 600 X 600 Dpi, 400 X 400 Dpi, 300 X 300 Dpi, 200 X 400 Dpi, 200 X 200 Dpi, 200 X 100 Dpi, 150 X 150 Dpi, 100 X 100 Dpi Color:300 X 300 Dpi, 200 X 200 Dpi, 200 X 100 Dpi, 150 X 150 Dpi, 100 X 100 Dpi |
| Address Book Capacity | Max. 1,800 Destinations (Incl. 200 One-Touch Buttons) |
| Communication Protocol | File: FTP (TCP/IP), SMB (TCP/IP), WebDAV E-Mail/I-Fax: SMTP, POP3, I-Fax (Simple, Full) |
| File Format | Standard: TIFF, JPEG, PDF, PDF (Compact), PDF (Apply Policy), PDF (Optimize For Web), PDF/XPS (OCR), PDF-A-1b, XPS, XPS (Compact), OOXML (OCR) (.Pptx) Optional: PDF (Trace And Smooth), PDF (Encrypted), PDF/XPS (Digital Signature) |
| I Fax Data Format | BW: TIFF (MH, MR, MMR)Universal Send Features: Two-Sided Original, Original Type Selection, Density Adjustment, Sharpness, Erase Frame, Delayed Send, Preview, File Name, Subject/Message, Reply-To, Sender's Name (TTI), E-Mail Priority, Send To Myself, Send To My FolderOther Optional Accessories:
** If "Quick Startup Settings For Main Power" Is Set To On, It Takes 10 Seconds Until The Key Operation On The Touch-Panel Display Is Available After Turning On The Main Power. *** Including Consumables. † EPS Can Be Printed Directly Only From Remote User Interface. †† XPS Cannot Be Printed Directly From Web Access Software. ††† Requires ImageRUNNER ADVANCE Device With Advanced Box. ♦ Available Approximately Six Months After Launch. |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
