imageRUNNER ADVANCE C3325i
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Untitled Document
| Model Name | ImageRUNNER ADVANCE C3325i |
| Type | Color Digital Multifunction Imaging System |
| Functions | Standard: Copy, Print (UFR II, PCL 5c/6, Adobe® PostScript® 3™), Scan, Send Optional: Fax (Up To 2 Lines) |
| Operation Panel | 7" WVGA Full-Color TFT Screen |
| Image Server Memory | Standard: 2 GB RAM Maximum: 2 GB RAM |
| Hard Disk Drive | Standard: 215 GB Maximum: 215 GB |
| Network Interface Connection | Standard: 1000Base-TX/100Base-TX/10Base-T Optional: Wireless LAN (IEEE 803.1x Via Third-Party Adapter) |
| Other Interface | Standard: USB 2.0 (Host) X 2, USB 2.0 (Device) Optional: Device Port [USB 2.0 (Host) X 2], Copy Control Interface |
| Advanced Box Features | Store To Remote Advanced Box: Supported Print/View From Remote Advanced Box: Supported Standard: USB Memory, Mail Box Simple |
| Standard | Department ID Management, Single Sign On-H, Access Management System (Device And Function Level Log-In), Secured Print, Trusted Platform Module, IPV6, Restricting Features (Restricting The Send Function, Restricting New Addresses On Address Book), SSL Encrypted Communication, SNMPv1/V3, MAC/IP Address Filtering, SMTP Authentication, POP Authentication Before SMTP, HDD Format, HDD Initialize (Up To 9x ), HDD Erase (Up To 3x), HDD Lock, IPsec, Adobe® LiveCycle® Rights Management ES2.5 Integration |
| Optional | Removable HDD, HDD Encryption, HDD Data Erase Scheduler, Encrypted Secure Print, Encrypted PDF, Document Scan Lock, Secure Watermark, IEEE 2600.1 Common Criteria Certification † † |
| Network Twain Scan | Standard |
| Network Scan Utility | Color Network ScanGear |
| Scanning Resolution | Up To 600 X 600 Dpi |
| First Copy Time | As Fast As 5.9 Seconds (BW), 8.2 Seconds (Color) |
| Multiple Copies | 1 To 999 |
| Copy Exposure | Automatic Or Manual (9 Levels) |
| Magnification | 25% - 400% (1% Increments) |
| Preset Reductions | 25%, 50%, 64%, 73%, 78% |
| Preset Enlargements | 121%, 129%, 200%, 400% |
| Acceptable Originals | (Glass) Sheet, Book, 3-Dimensional Objects [Up To 4.4 Lb. (2 Kg)] |
| Maximum Original Size | Up To 11" X 17" |
| Standard Paper Capacity | Up To 100 Sheets (20 Lb. Bond) |
| Maximum Paper Capacity | Paper Sources (20 Lb. Bond) Standard: Two 550-Sheet Paper Cassettes 100-Sheet Stack Bypass Optional: Dual 550-Sheet Paper Cassettes Maximum: 2,300 Sheets |
| Output Paper Capacity | (20 Lb. Bond) Standard: 250 Sheets (Inner Tray) Maximum: 2,100 Sheets (W/Staple Finisher Or Booklet Finisher) |
| Cassette | 14 Lb. Bond To 80 Lb. Cover (52 To 220 G/M2) |
| Bypass | 14 Lb. Bond To 140 Lb. Index (52 To 256 G/M2) |
| Duplexing | Paper Size: Standard Automatic Trayless Duplexing (Executive To 12" X 18") Paper Weight: 14 Lb. Bond To 80 Lb. Cover (220 G/M2) |
| Paper Size | Cassette 1: Statement, Letter, Executive, Envelope (ISO-C5), Custom Size (5-1/2" X 7-1/8" To 11-3/4" X 8-1/2") Cassette 2: 12" X 18", 11" X 17", Legal, Letter, Letter-R, Statement, Executive, Folio, Custom Size (5-1/2" X 7-1/8" To 12" X 18"), Envelopes (COM10 No.10, Monarch, DL) Cassettes 3/4: 12" X 18", 11" X 17", Legal, Letter, Letter-R, Statement, Executive, Folio, Custom Size (5-1/2" X 7-1/8" To 12" X 18") Bypass: 12" X 18", 12-5/8" X 17-11/16", 11" X 17", Legal, Letter, Letter-R, Statement, Statement-R, Executive, Folio, Custom Size (3-7/8" X 5-1/2" To 12-5/8" X 18"), Envelopes (COM10 No.10, Monarch, DL, ISO-C5) |
| Paper Weight | Cassettes: 14 Lb. Bond To 80 Lb. Cover (52 To 220 G/M2) Bypass: 14 Lb. Bond To 140 Lb. Index (52 To 256 G/M2) |
| Warm Up Time | From Power On: Approximately 34 Seconds From Sleep: Approximately 10 Seconds Quick Startup Mode: Within 7 Seconds* |
| Power Requirements | 120 V AC, 60 Hz, 7.5 A 220-240V AC, 50/60Hz, 4.0A |
| Power Consumption | Maximum: 120-127V :1.5kW 220-240V :1.5kW Sleep Mode: 120V/230V: 8W |
| Dim | (H X W X D) 34-5/8" X 22-1/4" X 27-5/16" (878 Mm X 565 Mm X 693 Mm) |
| Installation Space | (W X D) 35-1/4" X 44" (894 Mm X 1117 Mm) (When The Multi-Purpose Tray Is Extended.) |
| Weight | Approximately 163.4 Lb. (74.1 Kg)** |
| Scan Resolution | Up To 600 X 600 Dpi |
| Acceptable Originals | Sheet, Book, 3-Dimensional Objects [Up To 4.4 Lb. (2 Kg)] |
| Basic Copy Features | Preset R/E Ratios By Area, Finishing, Two-Sided, Exposure Adjustment, Original Type Selection, Interrupt Mode, Sample Set, Setting Confirmation/Cancel, Standard Keys, Reset, Guide Display, Job Duration Display, Reserved Copying, ID Management, Counter Check |
| Special Copy Features | Two-Page Separation, Cover/Sheet Insertion, Booklet, Transparency Interleaving, Shift, Margin, Frame Erase, Image Combination, Different Size Original, Job Build, Job Done Notice, Scan Image Check, Mode Memory, Recall, Negative/ Positive Inversion, Image Repeat, Mirror Image, Sharpness, Secure Watermark, Page Numbering, Copy Set Numbering, Watermark And Date, Document Scan Lock, Area Designation, ID Card Copy |
| Standard | USB Memory, Mail Box Simple |
| Environmental Features |
| Toner | (Estimated Yield @ 5% Coverage) Black: 36,000 Color: 19,000 |
| Description | Image Reader Unit |
| Acceptable Originals | (Glass) Sheet, Book, 3-Dimensional Objects [Up To 4.4 Lb. (2 Kg)] Maximum Original Size: Up To 11" X 17" Scan Resolution: Up To 600 X 600 Dpi |
| Description | Document Feeder |
| Acceptable Originals | Paper Sizes: 11" X 17", Legal, Letter, Letter-R, Statement, Or Statement-R Paper Weights: 13 Lb. Bond To 34 Lb. Bond (50 To 128 G/M2) |
| Scan Method | Duplex Automatic Document Feeder |
| Scanning Speed | Simplex: Up To 55 Ipm (300 Dpi) Up To 30 Ipm (600 Dpi) Duplex: Up To 27.5 Ipm (300 Dpi) Up To 15 Ipm (600 Dpi) |
| Description | Cassette Feeding Unit-AL1 |
| Paper Capacity | 550 Sheets X 2 Cassettes [20 Lb. Bond (80 G/M2)] |
| Paper Size | 12" X 18", 11" X 17", Legal, Letter, Letter-R, Statement-R, Executive, And Custom Size [5-1/2" X 7-1/8" To 12"X 18" (139.7 Mm X 182 Mm To 304.8 Mm X 457.2 Mm)] |
| Paper Weight | 14 Lb. Bond To 80 Lb. Cover (52 To 220 G/M2) |
| Power Source | From The Main Unit |
| Power Consumption | Approximately 30 W |
| Dimensions | 9-13/16" X 22-1/4" X 24-1/4" (248 Mm X 565 Mm X 615 Mm) |
| Weights | Approximately 35.5 Lb. (16.1 Kg) |
| Description | Cabinet Type-J |
| Weight | 42 Lb. (19.05 Kg) |
| Description | Inner 2-Way Tray-J1 |
| Paper Size | 12" X 18", 12-5/8" X 17-11/16", 11" X 17", Legal, Letter, Letter-R, Statement, Statement-R, Executive, Custom Size [3-7/8" X 5-1/2" To 12-5/8" X 18" (99 Mm X 139.7 Mm To 320 Mm X 457.2 Mm)], And Envelopes |
| Paper Weight | 14 Lb. Bond To 140 Lb. Index (64 To 256 G/M2) |
| Number Of Trays | 2 |
| Total Output Capacity | 350 Sheets |
| Top Tray | 250 Sheets (20 Lb. Bond) |
| Lower Tray | 100 Sheets (20 Lb. Bond) |
| Dimensions | 3" X 16-3/4" X 16-1/16" (76 Mm X 427 Mm X 407 Mm) |
| Weight | 1.3 Lb. (574 G) |
| Description | Inner Finisher-G1 |
| Paper Size | Staple Mode 12" X 18", 11" X 17", Legal, Letter, Letter-R, Statement, Statement-R, Executive, Custom Size [3-7/8" X 5-1/2" To 12-5/8" X 18" (99 Mm X 139.7 Mm To 320 Mm X 457.2 Mm)], And Envelopes Staple-Free Mode Letter, Executive, Legal, Letter-R, 11" X 17" |
| Paper Weight | Staple Mode 14 Lb. Bond To 140 Lb. Index (52 To 256 G/M2) Staple-Free Mode 14 Lb. Bond To 28 Lb. Bond |
| Total Output Capacity | 600 Sheets |
| Top Tray | 100 Sheets (Letter) |
| Lower Tray | 500 Sheets (Letter) |
| Paper Capacity Of Saddle Stitch Mode | Top Tray: Not Supported For Staple Lower Tray Letter And Executive: 30 Sets (Or 2-1/16" In Height) 11x17, Legal, And Letter-R: 30 Sets (Or 1-1/16" In Height) With Different Paper Sizes: 30 Sets (Or 1-1/16" In Height) Type Of Staple: Staple-P1 (5,000 X 2) |
| Staple Positions | Staple Mode Corner Stapling (All 4 Corners):11" X 17", Legal, Letter, Letter-R, Executive Double Stapling:11" X 17", Legal, Letter, Letter-R, Executive Staple-Free Mode Corner (All 4 Corners) |
| Stapling Capacity | Staple Mode Letter And Executive: 50 Sheets (14 To 21 Lb. Bond) 30 Sheets (22 To 28 Lb. Bond) 2 Sheets (29 Lb. Bond To 140 Lb. Index) 11" X 17", Legal, And Letter-R: 30 Sheets (17 To 21 Lb. Bond) 20 Sheets (22 To 28 Lb. Bond) 2 Sheets (29 Lb. Bond To 140 Lb. Index) Staple-Free Mode 5 Sheets (14 To 17 Lb. Bond)4 Sheets (18 To 21 Lb. Bond)3 Sheets (22 To 28 Lb. Bond) Staple On Demand 40 Sheets (20 Lb. Bond) |
| Dimensions | 7-7/16" X 23-13/16" X 20-11/16" 188 Mm X 604 Mm X 525 Mm (When The Auxiliary Tray Is Extended) Installation Space (W X D) 40-7/16" X 27-5-16" (1,026 Mm X 693 Mm) (When The Multi-Purpose Tray Is Extended) |
| Weight | 15.9 Lb. (7.2 Kg) |
| Description | Staple Finisher-U1 † † † |
| Paper Weight | 14 Lb. Bond To 140 Lb. Index (52 To 256 G/M2) |
| Total Output Capacity | 2,100 Sheets (Letter, Statement, Statement-R, Executive) |
| Top Tray | 1,000 Sheets (Letter, Statement, Statement-R, Executive) 500 Sheets (12" X 18", 11" X 17", Legal, Letter-R) |
| Middle Tray | 100 Sheets |
| Lower Tray | 1,000 Sheets (Letter, Statement, Statement-R, Executive) 500 Sheets (12" X 18", 11" X 17", Legal, Letter-R) |
| Paper Capacity Of Saddle Stitch Mode | Letter And Executive: 50 Sets (Or 5-3/4" In Height) 11" X 17", Legal, And Letter-R: 50 Sets (Or 2-7/8" In Height) With Different Paper Sizes: 50 Sets (Or 2-7/8" In Height) |
| Staple Positions | Corner Stapling (All 4 Corners):11" X 17", Legal, Letter, Letter-R, Executive Double Stapling:11" X 17", Legal, Letter, Letter-R, Executive |
| Stapling Capacity | Letter And Executive: 50 Sheets (14 To 21 Lb. Bond) (52 To 81 G/M2) 30 Sheets (22 To 28 Lb. Bond) (82 To 105 G/M2) 2 Sheets (29 Lb. Bond To 140 Lb. Index) (106 To 220 G/M2) 11" X 17", Legal, And Letter-R: 30 Sheets (14 To 21 Lb. Bond) (64 To 81 G/M2) 20 Sheets (22 To 28 Lb. Bond) (82 To 105 G/M2) 2 Sheets (29 Lb. Bond To 140 Lb. Index) (106 To 220 G/M2) |
| Type Of Staple | Staple-J1 (5,000 X 3) |
| Dimensions | 38-1/4" X 26-1/8" X 25-1/2" [971 Mm X 662 Mm X 646 Mm (When The Auxiliary Tray Is Extended)] Installation Space 61-1/2" X 27-5/16" (1561 Mm X 693 Mm) (When The Multi-Purpose Tray Is Extended) |
| Weight | Approximately 89.3 Lb. (40.5 Kg) |
| Description | Booklet Finisher-U1 † † † |
| Paper Size | 12" X 18", 12-5/8" X 17-11/16", 11" × 17", Legal, Letter, Letter-R, Statement, Statement-R, Executive, Custom Size [3-7/8" X 5-9/16" To 12-5/8" X 18" (99 X 139.7 Mm To 320 Mm X 457.2 Mm)], And Envelopes |
| Total Output Capacity | 2,100 Sheets (Letter, Statement-R, Executive) |
| Top Tray | 1,000 Sheets (Letter, Statement-R, Executive) 500 Sheets (11" X 17", Legal, Letter-R) |
| Lower Tray | 1,000 Sheets (Letter, Statement-R, Executive) 500 Sheets ( 11" X 17", Legal, Letter-R) Staple-J1 (5,000 X 3) Staple Cartridge-D2 (2,000 X 3) For Saddle-Stitch |
| Saddle Stitch Tray | 16 Sheets (16 To 21 Lb. Bond) 10 Sheets (22 To 28 Lb. Bond) |
| Paper Capacity Of Saddle Stitch Mode | 25 Booklets (5-Sheet Booklets) Paper Capacity Of Staple Mode Letter And Executive: 50 Sets (Or 5-3/4" In Height) 11" X 17", Legal, And Letter-R: 50 Sets (Or 2-7/8" In Height) With Different Paper Sizes: 50 Sets (Or 2-7/8" In Height) |
| Staple Capacity | 11" X 17", Legal, Letter-R |
| Staple Positions | Corner/Double Stapling: 11" X 17", Legal, Letter, Letter-R, Executive Saddle-Stitch: 11" X 17", Legal, Letter-R |
| Stapling Capacity | Letter And Executive: 50 Sheets (18 To 22 Lb. Bond) (64 To 81 G/M2) 30 Sheets (22 To 28 Lb. Bond) (82 To 105 G/M2) 2 Sheets (29 Lb. Bond To 140 Lb. Index) (106 To 256 G/M2) 11" X 17", Legal, And Letter-R: 30 Sheets (14 To 21 Lb. Bond) (52 To 81 G/M2) 20 Sheets (22 To 28 Lb. Bond) (82 To 105 G/M2) 2 Sheets (29 Lb. Bond To 140 Lb. Index) |
| Type Of Staple | Staple-J1 (5,000 X 3) Staple Cartridge-D2 (2,000 X 3) For Saddle-Stitch |
| Dimensions | 38-1/4" X 30- 3/8" X 25-7/8" [971 Mm X 771 Mm X 656 Mm (When The Auxiliary Tray Is Extended)] Installation Space 65-3/4" X 27-5/16" (1670 Mm X 693 Mm) (When The Multipurpose Tray Is Extended) |
| Weight | Approximately 149 Lb. (67.5 Kg) |
| Description | Fax Specifications |
| Applicable Line | Maximum Number Of Connection Lines: 2 |
| Modem Speed | Super G3: 33.6 Kbps G3: 14.4 Kbps |
| Data Compression | MH, MR, MMR, JBIG |
| Resolution | 400 X 400 Dpi, 200 X 400 Dpi, 200 X 200 Dpi, 200 X 100 Dpi |
| Scanning Recording Size | Statement To 11" X 17" |
| Fax Features | Job Forwarding, Different-Size Originals, Adjusting Overall Density For Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Specifying The Sender's Name (When Sending Fax), Selecting The Telephone Line (When Sending Fax), Delayed Send, Preview, Finished Stamp, Job Done Notice, Original Type Selection, Two-Sided Original, Book To Two Pages |
| Description | Print Specifications |
| Processor | Canon Dual Custom Processor (Shared) |
| Standard Memory | 2 GB RAM |
| Maximum Memory | 2 GB RAM |
| Hard Disk | Standard: 215 GB Maximum: 215 GB |
| Engine Resolution | 1200 X 1200 Dpi (Max.) |
| Continuous Print Speed | Letter: Up To 25/25 Ppm Legal/11" X 17": Up To 15 Ppm |
| Pdl Support | Standard: UFR II, PCL 5c/6, Adobe PS 3 |
| Other Features | Print Driver Supported OS UFR II, PCL 5c/6, Adobe PS 3: Windows® (XP/Windows Vista®/7/8.1), Windows Server (2003/2003R2/2008 /2008 R2/ 2012/2012 R2), Windows Terminal Server (2003/2003R2/2008/2008 R2/2012/2012 R2), Microsoft Clustering Server 2003/2003R2/2008/ 2008 R2/2012/2012 R2), Citrix (Presentation Server 4.5, XenApp 5.0/6.0/6.5/7.5, XenDesktop 4.0/5.0/5.5/5.6/7.0/7.1/7.5), VMware (VSphere 4/5/5.1), SAP (PS3, PCL), Macintosh® (OS X 10.5.8 Or Later) Direct Print Support Standard: TIFF, JPEG, PDF, EPS,*** XPS † |
| Print Features | Suspend Job Timeout, Subset Finishing (PS Only), Profile Settings, Secured Print, Watermark, Page Border, Header/Footer, Page Layout, Two-Sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/Orientations, Offsetting, Printing On Transparencies, Front/Back Covers, Black-And-White Printing, Objective, Color/Black-And-White Auto Detect, Toner Reduction, Poster Printing |
| Description | Universal Send Specifications |
| Sending Method | E-Mail, I-Fax, File Server (FTP, SMB, WebDAV), Super G3 Fax (Optional) |
| Color Mode | Auto Color Select (Color, Gray), Auto Color Select (Color, Black), Full Color, Grayscale, BW |
| Address Book Capacity | Max. 1,800 Destinations (Incl. 200 One-Touch Buttons) |
| Communication Protocol | File: FTP (TCP/IP), SMB (TCP/IP), WebDAV E-Mail/I-Fax: SMTP, POP3, I-FAX (Simple, Full) |
| File Format | Standard: TIFF, JPEG, PDF (Compact, Searchable, Apply Policy, Optimize For Web, PDF A/1-B), XPS (Compact, Searchable), OOXML (.Pptx And .Docx) Optional: PDF (Trace & Smooth, Encrypted), PDF/XPS (Digital Signature) |
| I Fax Data Format | TIFF (MH, MR, MMR) |
| Sending Size | Universal Send Features Two-Sided Original, Different-Size Originals, Original Type Selection, Book To Two Pages, Density Adjustment, Sharpness, Document Name, Copy Ratio, Erase Frame, Job Build, Delayed Send, Preview, Finished Stamp, Job Done Notice, File Name, Subject/Message, Reply-To, Sender's Name (TTI), E-Mail Priority Other Optional Accessories
* If "Quick Startup Settings For Main Power" Is Set To ON, It Takes 7 Seconds Until The Key Operation On The Touch Panel Display Is Available After Turning On The Main Power. ** Includes Consumables. *** EPS Can Be Printed Directly Only From Remote User Interface. † XPS Cannot Be Printed Directly From The Web Access Software. † † Specified Configurations And Settings Need To Be Applied To The Device In Order To Achieve And Maintain IEEE 2600.1 Common Criteria Certification. Not Available At Launch. Contact Your Canon Authorized Dealer For More Information. † † † Requires Cassette Feeding Unit-AL1. Cannot Be Installed With Cabinet Type-J. Staple Finisher-U1 And Booklet Finisher-U1 Cannot Be Installed At The Same Time And Cannot Be Installed With Inner Finisher-G1. |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
