imageRUNNER ADVANCE C256iF III
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The imageRUNNER ADVANCE C256iF III is registered EPEAT Gold.
- 10.1" intuitive touchscreen with smartphone-like usability.
- A unique, customized experience tailored to individual preferences using My ADVANCE.
- Supports mobile solutions and integration with many popular cloud services like Google Drive14.
- Scan and convert documents to searchable digital files in a variety of file formats.
- Integration with Canon and various third-party software with embedded application platform.
- Advanced standard security feature set to help safeguard sensitive information and assist in regulatory compliance.
- Integrates with existing, third-party Security Information and Event Management (SIEM) systems to help provide real-time comprehensive insights into potential threats to the network and printers.
- Technology to verify that the device boot process, firmware, and applications initialize at startup, without any alterations or tampering by malicious third parties. During operation, McAfee Embedded Control utilizes a whitelist to protect against malware and tampering of firmware and applications.*
- Security policy settings can be controlled with a dedicated password, configured from a central location, and exported to other supported devices.
- Control access to the device and specific features, using a host of flexible authentication methods - PIN code, user name/password, or card access.
* These features are available on third generation imageRUNNER ADVANCE 3rd edition models only. McAfee Embedded Control requires Unified Firmware Platform v3.9.
- Canon's signature reliability and engine technologies help keep productivity high and minimize the impact on support resources.
- Outstanding imaging technologies and toner allow for consistently striking images, thanks to Canon's V2 color profile.
- Designed to achieve maximum uptime with status notifications that help keep supplies replenished and intuitive maintenance videos for consumables replacement.
- imageRUNNER ADVANCE models have received many awards and recognition from leading industry analysts, often referencing strong reliability.
- Designed for quick, easy deployment.
- Remote diagnostics and parts life management for proactive maintenance and rapid fixes.
- Easy and intuitive to monitor device status and consumable levels, turn off devices remotely, observe meter readings, manage settings, and implement security policies.
- Common firmware and regular updates with Unified Firmware Platform (UFP) for continuous improvements and consistency across a fleet.
- Track and assess print, copy, scan, and fax usage and allocate costs to departments or projects.
- Apply print policies and restrict usage by user to help reduce unnecessary printing and contribute to cost efficiency.
- Standard cloud-based solution provides a centralized dashboard with up-to-the-minute insights into printer activity.
- Upgrade to uniFLOW server or cloud-based solutions for full accounting and reporting for compatible Canon and third-party devices, pull printing, job routing, and powerful scan workflows.
- A combination of fusing technologies and low-melting-point toner minimizes power requirements and helps achieve low energy consumption.
- Encourage environmentally conscious work practices by enabling multiple settings that can help save paper and energy.
- ENERGY STAR® certified and rated EPEAT® Gold.13
- Time from device power-on, until copy ready (not print reservation).
- Time from exiting Sleep mode to when printing is operational.
- Time from device power-on to when key operation can be performed on the touch screen.
- Includes consumables.
- PDF print from Web sites is supported.
- Requires the optional PCL International Font Set-A1.
- Requires the optional Barcode Printer Kit-D1.
- Other operating systems and environments including AS/400, UNIX, Linux and Citrix may be supported. Some of these solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative.
- Detect Feeder Multi Sheet Feed is supported.
- No charge for this solution; however activation is required.
- Reference value (measured one unit).
- 0.8 W sleep mode not available in all circumstances due to certain settings.
- For current EPEAT rating (Gold/Silver/Bronze), please visit www.cla.canon.com/cla/en/epeat.
- Subscription to a third-party cloud service required. Subject to third-party cloud service providers’ terms and conditions.
- Requires Unified Firmware Platform v3.9.
| Model Name | ImageRUNNER ADVANCE C256iF III |
| Type | Color Laser Multifunctional |
| Functions | Print, Copy, Scan, Send, Store, Fax (Line One Standard, Line Two Optional) |
| Operation Panel | 10.1" TFT LCD WSVGA Color Flat-Panel |
| Image Server Memory | 3.0 GB RAM |
| Hard Disk Drive | 250 GB |
| Network Interface Connection | 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 B/G/N), Optional: NFC, Bluetooth Low Energy |
| Other Interface | Standard: USB 2.0 X1 (Host), USB 3.0 X1 (Host), USB 2.0 X1 (Device) Optional: Serial Interface, Copy Control Interface |
| Max Mailboxes Supported | 100 User In-Boxes, 1 Memory RX In-Box, 50 Confidential Fax In-Boxes |
| Max Pages Stored | 30,000 Maximum Pages Stored |
| Available Disk Space | Approx. 16 GB |
| Common Protocol | SMB Or WebDAV |
| Supported Client Pc | Windows (Windows 7/8.1/10) |
| Max Number Of Concurrent Connections | SMB: 64 WebDAV: 3 (Active Sessions) |
| Advanced Box Features | Authentication For Advanced Box Log-In, Sort Function, Printing A PDF File With A Password, ImageWARE Secure Audit Manager Support |
| Standard | Standard: USB |
| Letter | Up To 26 Ppm |
| Legal | Up To 21 Ppm |
| First Copy Time | As Fast As 6.9 Seconds (BW)/ 9.4 Seconds (Color) |
| Multiple Copies | Up To 999 Copies |
| Copy Exposure | Automatic Or Manual (9 Levels) |
| Magnification | 25%-400% (1% Increments) |
| Preset Reductions | 25%, 50%, 64%, 78% |
| Preset Enlargements | 129%, 200%, 400% |
| Acceptable Originals | Sheet, Book, 3-Dimensional Objects [Height: Up To 1-1/4" (30 Mm), Weight: Up To 4.4 Lb. (2kg)] |
| Standard Paper Capacity | 550-Sheet Paper Cassette, 100-Sheet Stack Bypass |
| Optional | 550-Sheet Paper Cassette (CASSETTE MODULE-AE1), 550-Sheet Paper Cassette With Cabinet (CASSETTE FEEDING UNIT-AJ1), Triple 550-Sheet Paper Cassettes (CASSETTE FEEDING UNIT-AK1) |
| Maximum Paper Capacity | 2,300 Sheets |
| Output Paper Capacity | Standard: 250 Sheets Maximum: 500 Sheets (With STAPLE FINISHER-Z1) |
| Cassettes | Paper Cassette 1: Legal, Letter, Executive, Statement, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Custom Size (3-7/8" X 7-1/2" To 8-1/2" X 14") |
| Bypass | Legal, Letter, Executive, Statement, Envelope [No.10 (COM10), Monarch, DL, ISO-C5], Envelope Custom Size (3-7/8" X 5-7/8" To 8-1/2" X 14"), Custom Size (3-7/8" X 5-7/8" To 8-1/2" X 14") |
| Other Option | Cassette Module-AE1: Legal, Letter, Executive, Statement, Custom Size (3-7/8" X 7-1/2" To 8-1/2" X 14") Cassette Feeding Unit-AJ1: Legal, Letter, Executive, Statement, Custom Size (3-7/8" X 7-1/2" To 8-1/2" X 14") Cassette Feeding Unit-AK1: Legal, Letter, Executive, Statement, Custom Size (3-7/8" X 7-1/2" To 8-1/2" X 14") |
| Cassette | Cassettes: 16 Lb. Bond To 60 Lb. Cover (60 To 163 G/M2) Stack Bypass: 16 Lb. Bond To 80 Lb. Cover (60 To 220 G/M2) Duplexing: 16 Lb. Bond To 60 Lb. Cover (60 To 163 G/M2) |
| Warm Up Time | From Power On: Approx. 10 Seconds1 From Sleep Mode: Approx. 10 Seconds2 Quick Startup Mode: Approx. 4 Seconds3 |
| Power Requirements | 120-127V, AC 60 Hz,6.9 A 220-240V, AC 50/60 Hz,3.9 A |
| Power Consumption | Maximum: Approx.1,500 W (120V-240V) Standby: Approx. 38.9 W (120V)/ 40.3W (230V) Sleep Mode: Approx. 0.8 W Typical Electricity Consumption (TEC) Rating: 0.7 KWh (120V/230V) |
| Plug | NEMA 5-15P (120V) CEE 7/7 (230V) |
| Dim | Standard (Desktop): 20-1/8" X 25-5/8" X 25-1/8" (511 Mm X 651 Mm X 639 Mm) With Cassette Feeding Unit- AJ1 Or AK1: 20-1/8" X 25-5/8" X 41-7/8” (511 Mm X 651 Mm X 1,064 Mm) |
| Installation Space | Basic: 33-1/2" X 35-3/4" (852 Mm X 908 Mm) With Staple Finisher-Z1: 55-3/8" X 35-3/4" (1,407 Mm X 908 Mm) |
| Weight | Standard (Desktop): Approx. 108 Lb. (49 Kg) With Cassette Feeding Unit- AJ1: Approx. 143.3 Lb. (65 Kg) With Cassette Feeding Unit- AK1: Approx. 149.9 Lb. (68 Kg) With Cassette Module AE-1: Approx. 130.1 Lb. (59 Kg) |
| Basic Copy Features | Preset Reduction/Enlargement Ratios By Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two- Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel |
| Special Copy Features | Two-Sided Original, Finishing, Job Build, N On 1, Density Adjustment, Original Type Selection, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Copy ID Card , Skip Blank Pages, Job Done Notice, Copy ID Card, Multi Sheet Feed Detection |
| Standard S | Authentication: Universal Login Manager, UniFLOW Online Express,13 User Authentication, Department ID Authentication, Access Management System, Device And Function Level Log-In Data: Trusted Platform Module (TPM), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption (FIPS140-2 Validated), McAfee Embedded Control15 Network: Encrypted Secure Print, IP/Mac Address Filtering, IPsec, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication Before SMTP, S/MIME, SIEM Integration Document: Secure Watermark, Secure Print, Forced Hold Printing, Adobe LiveCycle Rights Management ES2.5 Integration, Encrypted PDF, Encrypted Secure Print, Device Signatures |
| Optional | Authentication: UniFLOW Data: IEEE 2600.2 Common Criteria Certification, Data Loss Prevention (Requires UniFLOW) Document: User Signatures, Document Scan Lock |
| Environmental Features | Operating Environment Temperature: 50 To 86 ºF Humidity: 20 To 80 % RH (Relative Humidity) Standards ENERGY STAR® Certified Rated EPEAT® Gold13 |
| Toner | GPR-58 Toner |
| Estimated Toner Yield | (Estimated @ 5% Coverage): Black: 23,000 Images Color (C,M,Y): 18,000 Images |
| Applicable Line | 1 |
| Modem Speed | Super G3: 33.6 Kbps G3: 14.4 Kbps |
| Data Compression | MH, MR, MMR, JBIG |
| Resolution | 400 X 400 Dpi, 200 X 400 Dpi, 200 X 200 Dpi, 200 X 100 Dpi |
| Scanning Recording Size | Statement-R To 11" X 17" |
| Memory | Up To 30,000 Pages |
| Memory Backup | Yes |
| One Touch Speed Dialing Locations | Max. 200 Dials |
| Coded Speed Dialing Locations | Max. 199 Dials Sequential Broadcast Max. 256 Addresses |
| Fax Features | Original Type Selection, Two-Sided Original, Density For Scanning, Sharpness, Erase Frame, Job Build, Sender's Name (TTI), Direct Send, Delayed Send, Preview, Job Done Notice, TX Report, Multi Sheet Feed Detection Download Specifications ↓ |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
