OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The Canon imageRUNNER ADVANCE 8500 Series is an intuitive, high performance solution for enterprise-level offices and central reprographics departments (CRDs). This black-and-white multifunction printer can be your organization's essential device for streamlining overall workflow efficiency and helping to improve productivity in a high-volume workplace. Built on the core values of Canon's Third Generation imageRUNNER ADVANCE platform,* the imageRUNNER ADVANCE 8500 Series operates on intelligent information management principles.
Designed for high volume offices and CRDs, the imageRUNNER ADVANCE 8505i multifunction printer is capable of meeting diverse needs, with high quality output and precision staple/booklet finishing options. Serving high-volume offices and in-plants, the imageRUNNER ADVANCE 8500 Series is designed to not only meet the needs of dedicated operators but it can also serve busy multi-user environments, with an intuitive user interface. Together these benefits can improve uptime and help facilitate business continuity.
* Canon's Third Generation imageRUNNER ADVANCE core values include Workflow Efficiency, Cost Management, Security, Device and Fleet Management Efficiency, Quality and Reliability, and Sustainability.
| Model Name | ImageRUNNER ADVANCE 8505 |
| Type | Monochrome Laser Multifunctional |
| Functions | Standard: Print, Copy, Scan, Send, Store Optional: Fax |
| Operation Panel | 10.4" TFT LCD WSVGA Color Upright Panel |
| Imaging System | Canon Dual Custom Processor (Shared) |
| Image Server Memory | 3.0 GB RAM |
| Hard Disk Drive | Standard: 250 GB Maximum: 1 TB |
| Mirroring Hard Disk Drive | Optional (250 GB, 1 TB), Method: Raid1 |
| Network Interface Connection | 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 B/G/N) |
| Other Interface | Standard: USB 2.0 X2 (Host), USB 3.0 X1 (Host), USB 2.0 X1 (Device) Optional: Serial Interface, Copy Control Interface |
| Max Mailboxes Supported | 100 User In-Boxes, 1 Memory RX In-Box, 50 Confidential Fax In-Boxes |
| Max Pages Stored | 30,000 Maximum Pages Stored |
| Available Disk Space | Approx. 16GB (Standard HDD) Approx. 480GB (Optional 1TB HDD) |
| Common Protocol | Communication Protocol: SMB Or WebDAV |
| Supported Client Pc | Windows (Windows Vista/7/8/8.1/10) |
| Max Number Of Concurrent Connections | SMB: 64 WebDAV: 3 (Active Sessions) |
| Advanced Box Features | Disabling Advanced Box, Storage Filtering, Authentication For Advanced Box Log-In, Search Function, Sort Function, Printing A PDF File With A Password, ImageWARE Secure Audit Manager Support |
| Standard | Standard: USB |
| Scanning Resolution | 600 X 600 Dpi, 400 X 400 Dpi, 300 X 300 Dpi, 200 X 400 Dpi, 200 X 200 Dpi, 200 X 100 Dpi, 150 X 150 Dpi, 100 X 100dpi |
| Printing Resolution | 1200 Dpi X 1200 Dpi, 600 Dpi X 600 DpiStandard Page Description Languages UFR II, PCL® 6, Adobe® PS® 3* *PCL6/PS3 Optional For 230V Model Direct Print Available From USB, Advanced Box, Remote UI, And Web Access5 Supported File Types PDF, TIFF, JPEG, EPS,6 XPS Printing From Mobile And Cloud A Range Of Software And MEAP-Based Solutions Are Available To Provide Printing From Mobile Devices Or Internet-Connected Devices And Cloud-Based Services Depending On Your Requirements. Fonts PCL Fonts: 93 Roman, 10 Bitmap Fonts, 2 OCR Fonts, Andalé Mono WT J/K/S/T (Japanese, Korean, Simplified And Traditional Chinese)7 PS Fonts: 136 Roman Operating System8 UFRII: Server 2003/Server 2003 R2Vista/ Server 2008/Windows 7/Server 2008 R2/Windows 8/Server 2012/Windows 8.1/Server 2012 R2/Windows 10, MAC OS X (10.5.8 Or Later) PCL: Server 2003/Server 2003 R2Vista/ Server 2008/Windows 7/Server 2008 R2/Windows 8/Server 2012/Windows 8.1/Server 2012 R2/Windows 10 PS: Server 2003/Server 2003 R2Vista/ Server 2008/Windows 7/Server 2008 R2/Windows 8/Server 2012/Windows 8.1/Server 2012 R2/Windows 10, MAC OS X (10.5.8 Or Later) Print Features Suspend Job Timeout, Subset Finishing (PS Only), Profile Settings, Secured Print, Watermark, Page Border, Header/Footer, Page Layout, Two-Sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/ Orientations, Offsetting, Printing On Transparencies, Front/Back Covers, Toner Reduction, Poster Printing |
| Letter | Up To 105 Ppm |
| Letter R | Up To 81 Ppm |
| Legal | Up To 63 Ppm |
| Ledger | Up To 53 Ppm |
| First Copy Time | As Fast As 2.7 Seconds |
| Multiple Copies | Up To 9,999 Copies |
| Copy Exposure | Automatic Or Manual (9 Levels) |
| Magnification | 25%-400% (1% Increments) |
| Preset Reductions | 25%, 50%, 64%, 73%, 78% |
| Preset Enlargements | 121%, 129%, 200%, 400% |
| Standard Paper Capacity | (LTR, 20 Lb. Bond): Standard: Dual 1,500-Sheet Paper Drawers, Dual 550-Sheet Paper Cassettes, 100-Sheet Stack Bypass |
| Optional | 3,500-Sheet Paper Deck (POD DECK LITE-C1 Or PAPER DECK UNIT-E1) |
| Maximum Paper Capacity | (LTR, 20 Lb. Bond): 7,700 Sheets |
| Output Paper Capacity | (LTR, 20 Lb. Bond): With External Finishers (-V1): 3,500 Sheets With External Finishers (-X1): 4,250 Sheets With External Finishers (-W1 PRO): 5,000 Sheets |
| Cassettes | Paper Drawers (1/2): Letter, A3, A4 Paper Cassettes (3/4): 13" X 19", 12-5/8" X 17-11/16", 12" X 18", 11" X 17", A3, A4, Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" X 7-1/8" To 13" X 19-1/4") |
| Bypass | 13" X 19", 12-5/8" X 17-11/16", 12" X 18", 11" X 17", A3, A4, Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (4 X 5-7/8" To 13" X 19-1/4"), Free Size (4" X 7-1/4" To 13" X 19-1/4") |
| Other Option | POD DECK LITE-C1: 13" X 19", 12-5/8" X 17-11/16", 12" X 18", 11" X 17", A3, A4, Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" X 7-1/8" To 13" X 19-1/4" PAPER DECK UNIT-E1: Letter, A4 |
| Cassette | 14 Lb. Bond To 80 Lb. Cover (52 To 220 G/M2)Supported Media Types: Paper Drawers (1/2): Thin, Plain, Recycled, Color, Heavy, Pre-Punched, Letterhead, Bond Paper Cassettes (3/4): Thin, Plain, Recycled, Color, Heavy, Pre-Punched, Letterhead, Bond, Tab1 |
| Bypass | 14 Lb. Bond To 140 Lb. Index (52 To 256 G/M2)Supported Media Types: Thin, Plain, Recycled, Color, Heavy, Pre-Punched, Bond, Transparency, Labels, Letterhead, Tab, Tracing2POD DECK LITE-C1: Thin, Plain, Recycled, Color, Heavy, Pre-Punched, Letterhead, Bond, Transparency, Labels, Tab PAPER DECK UNIT-E1: Thin, Plain, Recycled, Color, Heavy, Pre-Punched, Letterhead, Bond |
| Duplexing | 14 Lb. Bond To 80 Lb. Cover (52 To 220 G/M2) |
| Warm Up Time | From Power On: 60 Seconds Or Less From Sleep Mode: 60 Seconds Or Less3 |
| Power Requirements | 220-240 V AC, 50/60 Hz, 10A |
| Power Consumption | Maximum: Approx. 2.4 KW Standby: Approx. 222 Wh Energy Saver Mode: Approx. 193.1 Wh Sleep Mode: Approx. 0.9 W Or Less9 Typical Electricity Consumption (TEC) Rating: 10.7 KWh |
| Plug | CEE 7/7 |
| Dim | 58-3/8" X 30-3/8" X 49-1/4" (1481mm X 770 Mm X 1252 Mm) |
| Installation Space | Fully Configured: 161-3/8" X 63-5/8" (4098 Mm X 1617 Mm) (POD DECK LITE-C1 + BOOKLET FINISHER-W1 PRO + DOCUMENT INSERTION UNIT-N1 + PAPER FOLDING UNIT-J1 + BOOKLET TRIMMER-D1) |
| Weight | Approx. 529 Lb. (240 Kg)4 |
| Basic Copy Features | Preset Reduction/Enlargement Ratios By Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel |
| Special Copy Features | Book To Two Pages, Two-Sided Original, Finishing, Booklet, Job Build, N On 1, Add Cover, Insert Sheets, Different Size Originals, Density Adjustment, Original Type Selection, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Gutter, Print & Check, Negative/Positive, Repeat Images, Merge Job Blocks, Job Done Notice, Mirror Image, Print On Tab, Store In Mail Box, Superimpose Image, Cascade Copy, Copy ID Card, Detect Feeder Multi Sheet Feed, Free Size Original |
| Standard S | Authentication: Universal Login Manager, User Authentication, Department ID Authentication, (Device And Function Level Log-In), Access Management System Optional: UniFLOW Data Standard: Trusted Platform Module (TPM), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption (FIPS140-2 Validated) Optional: Hard Disk Drive Mirroring, Hard Disk Drive Removal, IEEE 2600.2 Common Criteria Certification, Data Loss Prevention (Requires UniFLOW) Network Standard: IP/Mac Address Filtering, IPsec, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication Before SMTP Document Standard: Secure Print, Adobe LiveCycle® Rights Management ES2.5 Integration Optional: Encrypted PDF, Encrypted Secure Print, User And Device Signatures, Secure Watermarks, Document Scan Locking |
| Environmental Features |
| Toner | GPR-37 Black Toner |
| Estimated Toner Yield | 70,000 Copies |
| Description | Color Platen And Single-Pass Duplexing Automatic Document Feeder |
| Acceptable Originals | Sheet, Book, 3-Dimensional Objects [Up To 4.4 Lb. (2 Kg)] |
| Bw Originals | 13 Lb. Bond To 80 Lb. Cover (50 To 220 G/M2) |
| Color Originals | 17 Lb. Bond To 80 Lb. Cover (64 To 220 G/M2) |
| Scan Method | Color Network ScanGear2 For Both Twain And WIA Supported OS: Windows Vista/7/8/8.1/10Windows Server 2003/Server 2003 R2/Server 2008/Server 2008 R2/ Server 2012/Server 2012 R2Scan Resolution 600 X 600 Dpi, 400 X 400 Dpi, 300 X 300 Dpi, 200 X 400 Dpi, 200 X 200 Dpi, 200 X 100 Dpi, 150 X 150 Dpi, 100 X 100dpi Scan To Mobile Devices And Cloud-Based Services A Range Of Solutions Is Available To Provide Scanning To Mobile Devices Or And Cloud-Based Services Depending On Your Requirements. |
| Scanning Speed | (Letter): Single-Sided Scanning (BW): 120 Ipm (300 Dpi)/120 Ipm (600 Dpi) Single-Sided Scanning (Color): 120 Ipm (300 Dpi)/60 Ipm (600 Dpi) Double-Sided Scanning (BW): 240 Ipm (300 Dpi)/150 Ipm (600 Dpi) Double-Sided Scanning (Color): 220 Ipm (300 Dpi)/60 Ipm (600 Dpi) |
| Capacity | 300 Sheets (20 Lb. Bond) |
| Different Size Originals | 11" X 17", A3, A4, Legal, Letter, Letter-R, Statement, Statement-R |
| Description | PAPER DECK UNIT-E1 |
| Paper Capacity | 3,500 Sheets [21 Lb. Bond (80 G/M2)] |
| Paper Size | A4, Letter |
| Paper Weight | 14 Lb. Bond To 140 Lb. Index (52 To 256 G/M2) |
| Power Source | From The Main Unit |
| Power Consumption | From The Main Unit |
| Dimensions | 14-1/4" X 24-7/8" X 22-1/2" (363 Mm X 630 Mm X 572 Mm) |
| Weights | Approx. 75.0 Lb. (34 Kg) |
| Description | POD DECK LITE-C1 |
| Paper Size | 13" X 19", 12-5/8" X 17-11/16", 12" X 18", 11"X17", A3, A4, Legal, Letter, Letter-R, Executive, Statement-R, And Custom Size (5-1/2" X 7-1/8" To 13" X 19-1/4") |
| Power Source | 220-240 V AC, 50/60 Hz, 1.2 A |
| Power Consumption | Approx. 480 W |
| Dimensions | 25-7/8" X 27" X 22-1/2" (656 Mm X 686 Mm X 570 Mm) |
| Weights | Approx. 149.9 Lb. (68 Kg) |
| Description | STAPLE FINISHER-V111 |
| Number Of Trays | 3 |
| Top Tray | Letter/Executive/Statement-R 250 Sheets, 13" X 19", 12-5/8" X 17-11/16", 12" X 18 11" X 17"/Legal/Letter-R 125 Sheets |
| Middle Tray | Letter/Executive/Statement-R 250 Sheets, 13" X 19", 12-5/8" X 17-11/16", 12" X 18" 11" X 17"/Legal/Letter-R 125 Sheets |
| Lower Tray | Letter/Executive/Statement-R 3,000 Sheets, 13" X 19", 12-5/8" X 17-11/16", 12" X 18" 11" X 17"/Legal/Letter-R 1,500 Sheets |
| Staple Capacity | Corner Staple And Double Staple: Letter/ Executive: 65 Sheets [24 Lb. Bond (90 G/M2)] 11" X 17"/ Legal/ Letter-R: 30 Sheets [24 Lb. Bond (90 G/M2)]Staple-Free Staple: 11"X17"/ Letter: 5 Sheets [14 To 17 Lb. Bond (52 To 64 G/M2)] 4 Sheets [17.3 To 21.7 Lb. Bond (65 To 81.4 G/M2)]3 Sheets [21.7 To 28 Lb. Bond (81.5 To 105 G/M2)]Staple On Demand: 65 Sheets [24 Lb. Bond (90 G/M2)] |
| Staple Positions | Corner, Double |
| Power Consumption | Approx. 176 W (Including 2/3 Hole Puncher-A1) |
| Dimensions | 20-5/8" X 24-1/2" X 43-1/4" (525 Mm × 623 Mm × 1099 Mm)12 |
| Weight | Approx. 77.2 Lb. (35 Kg) |
| Description | STAPLE FINISHER-X1 |
| Top Tray | Letter/A4/Executive/Statement-R 1,500 Sheets 13" X 19"/12-5/8" X 17-11/16"/12" X 18"/ 11" X 17"/Legal/A3/Letter-R 750 Sheets |
| Middle Tray | Letter/A4/Executive/Statement-R 250 Sheets 11" X 17"/Legal/A3/Letter-R 125 Sheets |
| Lower Tray | Letter/A4 2,500 Sheets Executive/Statement-R 1,500 Sheets 13" X 19"/12-5/8" X 17-11/16"/ 12" X 18"/ 11" X 17"/Legal/ A3/Letter-R 750 Sheets |
| Staple Capacity | Letter/ Executive: 100 Sheets [21 Lb. Bond (80 G/M2)] 11" X 17"/ Legal/A3/ Letter-R: 50 Sheets [21 Lb. Bond (80 G/M2)] |
| Power Source | 100-240 V AC, 50/60 Hz, 2.8 A |
| Power Consumption | Approx. 311 W (Including Puncher Unit-BS1) |
| Dimensions | 25-3/4" X 30-1/8" X 41" (654 Mm × 765 Mm × 1040 Mm)12 |
| Weight | Approx. 141.1 Lb. (64 Kg) |
| Description | STAPLE FINISHER-W1 PRO |
| Number Of Trays | 2 |
| Top Tray | 13" X 19"/12-5/8" X 17-11/16"/ 12" X 18"/ 11" X 17"/Legal/Letter/Letter-R/ Executive 1,000 Sheets |
| Middle Tray | If The High-Volume Stack Mode Is Set To "OFF" Letter/A4/Executive 2,000 Sheets, 13" X 19"/12-5/8" X 17-11/16"/ 12" X 18"/ 11" X 17"/Legal/A3/Letter-R 1,000 Sheets If The High-Volume Stack Mode Is Set To "ON" Letter/A4/Executive 4,000 Sheets, Letter-R 2,000 Sheets, 11" X 17"/ Legal/A3 1,500 Sheets 13" X 19"/12-5/8" X 17-11/16"/ 12" X 18" 1,000 Sheets |
| Staple Capacity | Letter/ Executive: 100 Sheets [21 Lb. Bond (80 G/M2)] Legal/ Letter-R: 50 Sheets [21 Lb. Bond (80 G/M2)] |
| Power Source | 220-240 V AC, 50/60 Hz, 8A |
| Power Consumption | Approx. 500 W |
| Dimensions | 31-1/2" X 31-1/4" X 48-3/4" (800 Mm × 792 Mm × 1239 Mm)12 |
| Weight | Approx. 286.6 Lb. (130 Kg) |
| Description | BOOKLET FINISHER-V111 |
| Top Tray | Letter/Executive/Statement-R 250 Sheets 13" X 19"/12-5/8" X 17-11/16"/ 12" X 18"/ 11" X 17"/Legal/Letter-R125 Sheets |
| Middle Tray | Letter/Executive/Statement-R 250 Sheets, 13" X 19"/12-5/8" X 17-11/16"/ 12" X 18"/11" X 17"/Legal/Letter-R 125 Sheets |
| Lower Tray | Letter/Executive/Statement-R 3,000 Sheets 13" X 19"/12-5/8" X 17-11/16"/12" X 18"/ 11" X 17"/ Legal/Letter-R 1,500 Sheets |
| Paper Capacity Of Saddle Stitch Mode | 20 Sheets [22 Lb. Bond(81 G/M2)] [Including 1 Cover Sheet Up To 140 Lb. Index (256 G/M2)]Paper Size 12 X 18, 11" X 17", Legal, Letter-R, Custom Size (7-3/4" X 10-5/8" To 12" X 18") |
| Staple Capacity | Letter/ Executive: 65 Sheets [24 Lb. Bond (90 G/M2)] 11" X 17"/ Legal/ Letter-R: 30 Sheets [24 Lb. Bond (90 G/M2)]Staple-Free Staple: 11"X17"/ Letter: 5 Sheets [14 To 17 Lb. Bond (52 To 64 G/M2)] 4 Sheets [17.3 To 21.7 Lb. Bond (65 To 81.4 G/M2)] 3 Sheets [21.7 To 28 Lb. Bond (81.5 To 105 G/M2)]Staple On Demand: 65 Sheets [24 Lb. Bond (90 G/M2)] |
| Weight | Approx. 127.9 Lb. (58 Kg) |
| Description | BOOKLET FINISHER-X1 |
| Top Tray | Letter/A4/Executive/Statement-R 1,500 Sheets 13" X 19"/12-5/8" X 17-11/16"/ 12" X 18"/ 11" X 17"/Legal/A3/Letter-R 750 Sheets |
| Lower Tray | Letter/A4 2,500 Sheet Executive/Statement-R 1,500 Sheets 13" X 19"/12-5/8" X 17-11/16"/ 12" X 18"/ 11" X 17"/ Legal/Letter-R 750 Sheets |
| Paper Capacity Of Saddle Stitch Mode | 20 Sheets [22 Lb. Bond (81 G/M2)] [Including 1 Cover Sheet Up To 140 Lb. Index (256 G/M2)]Paper Size 13" X 19"/12-5/8" X 17-11/16"/ 12" X 18"/ 11" X 17"/Legal/Letter-R, Custom Size (8-1/4" X 11" To 13" X 19-1/4") |
| Staple Capacity | Letter/ Executive: 100 Sheets [21 Lb. Bond (90 G/M2)] 11" X 17"/ Legal/ Letter-R: 50 Sheets [21 Lb. Bond (80 G/M2)] |
| Staple Positions | One Point At Front, One Point At Back, Two Points In Center |
| Power Consumption | Approx. 384 W (Including Puncher Unit- BS1 And Booklet Trimmer-A1) |
| Dimensions | 30-1/4" X 30-1/8" X 41" (767 Mm × 765 Mm × 1040 Mm)12 |
| Weight | 242.5 Lb. (110 Kg) |
| Description | BOOKLET FINISHER-W1 PRO |
| Middle Tray | If The High Volume Stack Mode Is Set To "OFF" Letter/A4/Executive 2,000 Sheets, 13" X 19"/12-5/8" X 17-11/16"/ 12" X 18"/ Legal/A3/Letter-R 1,000 Sheets If The High Volume Stack Mode Is Set To "ON" Letter/A4/Executive 4,000 Sheets, Letter-R 2,000 Sheets, 11" X 17"/Legal/A3 1,500 Sheets, 13" X 19"/12-5/8" X 17- 11/16"/ 12" X 18" 1,000 Sheets |
| Paper Capacity Of Saddle Stitch Mode | 25 Sheets [21 Lb. Bond (80 G/M2)] (Including 1 Cover Sheet Up To 140 Lb. Index (256 G/M2))Paper Size: 13" X 19"/12-5/8" X 17-11/16"/ 12" X 18"/ 11" X 17"/Legal/Letter-R, Custom Size" (8-1/4" X 11" To 13" X 19-1/4") |
| Power Source | 220-240 V AC 50/60 Hz, 8A |
| Power Consumption | Approx. 800 W |
| Weight | 401.2 Lb. (182 Kg) |
| Description | 2/3 HOLE PUNCHER-A113 |
| Paper Size | Two Holes 11" X 17", Legal, Letter, A3, A4, Letter-R, Executive Three Holes 11" X 17", Letter, Executive |
| Power Requirements | From The Main Unit |
| Description | PUNCHER UNIT-BS114 |
| Paper Size | Two Holes Legal, Letter, Letter-R, Custom Size (7-1/8" X 7-1/8" To 11-3/4" X 17") Three Holes Letter, Executive, Custom Size (9-1/2" X 7-1/8" To 11-3/4" X 17") |
| Power Requirements | From The Finisher |
| Description | PUNCHER UNIT-BF115 |
| Paper Size | Two Holes Legal, Letter-R Three Holes 11" X 17", Letter, A3, A4, Executive |
| Description | MULTI FUNCTION PROFESSIONAL PUNCHER-A116 |
| Paper Size | 12"X18", 11"X17", Legal, Letter-R, Letter, Statement |
| Paper Weight | Bypass: 14 Lb. Bond To 140 Index. (52 To 256 G/M2) Punch: 20 Lb. Bond To 140 Index (75 To 256 G/M2)Supported Punch Dies (Optional): Plastic Comb (19-Hole), Twin Loop (21- Or 32-Hole), Color Coil (44-Hole), Velo Bind (11-Hole), Loose Leaf (3- Or 5-Hole) |
| Dimensions | 7-1/2" X 31-1/2" X 41" (445 Mm X 795 Mm X 1040 Mm) |
| Weight | 225 Lb. (102 Kg) |
| Description | INNER BOOKLET TRIMMER-A117 |
| Paper Size | 13" X 19", 12-5/8" X 17-11/16", 12"X18", 11"X17", Legal, A3, Letter-R, Custom Size (8-1/4"X11" To 13"X 19-1/4") |
| Paper Weight | 16 Lb. Bond To 140 Lb. Index (60 To 256 G/M2)Trim Capacity: 40 Sheets |
| Description | BOOKLET TRIMMER-D118 |
| Trim Amount | 0.08 To 0.78 ( 2 Mm To 20 Mm ) |
| Waste Tray Capacity | Approx. 1,500 SheetsBooklet Capacity: 30 Booklets |
| Dimensions | 62" X 30-3/8" X 41" (1575 Mm X 1040 Mm X 770 Mm) |
| Weight | Approx. 335.1 Lb. (152 Kg) |
| Description | DOCUMENT INSERTION UNIT-N116 |
| Paper Size | 13" X 19", 12-5/8" X 17-11/16", 12" X 18", 11' X 17", Legal, Letter, A3, A4, Letter-R, Executive, Custom Size (7-1/8" X 7-1/8" To 13" X 19-1/4") |
| Power Requirements | 100-240 V AC, 50/60 Hz, 1.0 A |
| Power Consumption | Approx. 120 W |
| Dimensions | 29-3/8" X 31-1/4" X 55-3/8" (746 Mm X 793 Mm X 1407 Mm) |
| Weight | Approx. 134.5 Lb. (61 Kg) |
| Description | PAPER FOLDING UNIT-J116 |
| Paper Size | C-Fold: Letter-R Z-Fold: 11" X 17", A3, Legal, Letter-R Accordion Z-Fold: Letter-R Double Parallel Fold: Legal, Letter-R Weight Half Fold: Letter-R |
| Paper Weight | C-Fold: 14 To 28 Lb. Bond (52 To 105 G/M2) Z-Fold: 14 To 28 Lb. Bond (52 To 105 G/M2) Accordion Z-Fold: 14 To 28 Lb. Bond (52 To 105 G/M2) Double Parallel Fold: 14 To 24 Lb. Bond (52 To 90 G/M2) Weight Half Fold: 14 To 28 Lb. Bond (52 To 105 G/M2) |
| Fold Type | C-Fold, Z-Fold, Accordion Z-Fold, Double-Parallel Fold, Half-Fold |
| Power Consumption | Approx. 150 W |
| Dimensions | 13-1/4" X 31-1/4" X 46-7/8" (336 Mm X 793 Mm X 1190 Mm) |
| Weight | Approx. 156.5 Lb. (71 Kg) |
| Applicable Line | 4 |
| Modem Speed | Super G3: 33.6 Kbps G3: 14.4 Kbps |
| Data Compression | MH, MR, MMR, JBIG |
| Resolution | 400 X 400 Dpi, 200 X 400 Dpi, 200 X 200 Dpi, 200 X 100 Dpi |
| Scanning Recording Size | Statement-R To 11" X 17 |
| Memory | Up To 6,000 Pages |
| Memory Backup | Yes |
| One Touch Speed Dialing Locations | Max. 200 |
| Coded Speed Dialing Locations | Max. 199 DialsSequential Broadcast Max. 256 Addresses |
| Fax Features | Original Type Selection, Two-Sided Original, Book To Two Pages, Different-Size Originals, Density For Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Specifying The Sender's Name (When Sending Fax), Sender's Name (TTI), Selecting The Telephone Line (When Sending Fax), Direct Send, Delayed Send, Preview, Finished Stamp, Job Done Notice, TX Report, Detect Feeder Multi Sheet Feed. |
| Description | ImagePASS-Y1 (External) |
| Processor | Intel Pentium G850 2.9 GHz |
| System | Fiery FS150Pro |
| Standard Memory | 4 GB |
| Hard Disk | 500 GB |
| Print Resolution | 1200 Dpi X 1200 Dpi, 600 Dpi X 600 DpiStandard Page Description Languages PCL, Adobe PS 3, APPE |
| Postscript Fonts | 138 Adobe PS Fonts |
| Pcl Fonts | 113 PCL Fonts |
| Interface Connections | 2 X Ethernet (1000Base-T/100Base-T/10Base-T), USB X 5 (Front X 1, Rear X 4) |
| Protocols Supported | TCP/IP (LPD/Port 9100/IPP/SMB/FTP), ATP/DDP (AppleTalk)/Direct Mobile Printing/PrintMe Cloud Printing |
| Print Controller Technology | Windows XP 32 And 64bit/Windows VISTA 32 And 64 Bit/ Windows 8 32 And 64 Bit/Windows 8.1 32 And 64 Bit/ Windows Server 2008 32 And 64 Bit/Windows Server 2008 R2 64 Bit Only/Windows Server 2012 64bit Only/Windows Server 2012 R2 64bit Only/MAC OS (10.6 Or Higher) |
| Other Features | Fiery Print Controller Options: FIERY IMPOSE, FIERY COMPOSE, FIERY IMPOSE AND COMPOSE, Removable Hard Disk Drive, Integration Interface And Stand (19" Display, Keyboard, Mouse, And Furniture Stand), Fiery ImageViewer |
| Print Features | Fiery Print Controller Features: Hot Folders, Secure Erase, Paper Catalog Kit, VDP-A1 Kit, Virtual Printer |
| Dimensions | 5-1/2" X 13-5/8" X 12-5/8" (140 Mm X 345 Mm X 320 Mm) |
| Sending Method | E-Mail/Internet Fax (SMTP), SMB, FTP, WebDAV, Mail Box, Super G3 Fax (Optional), IP Fax (Optional) |
| Color Mode | Automatic-Color Select (Full Color/Grayscale), Automatic-Color Select(Full Color/Black-And-White), Full Color, Grayscale, And Black-And-White |
| Scan Resolution | 600 X 600 Dpi, 400 X 400 Dpi, 300 X 300 Dpi, 200 X 400 Dpi, 200 X 200 Dpi,200 X 100 Dpi, 150 X 150 Dpi, 100 X 100dpi |
| Address Book Capacity | LDAP (2,000)/Local (1,600)/Speed Dial (200) |
| Communication Protocol | File: FTP, SMB, WebDAV E-Mail/I-Fax: SMTP, POP3, I-Fax (Simple, Full) |
| File Format | Standard: TIFF, JPEG, PDF (Compact, Searchable, Apply Policy, Optimize For Web, PDF A/1-B) Optional: PDF (Trace & Smooth, Encrypted), PDF/XPS (Digital Signature), PDF/XPS ( Searchable), Open XML ( Powerpoint, Word) Universal Send FeaturesOriginal Type Selection,Two-Sided Original, Book To Two Pages, Different-Size Originals, Density Adjustment, Sharpness, Copy Ratio, Erase Frame, Job Build, Sender's Name (TTI), Select Line, Direct Send, Delayed Send, Preview, Finished Stamp, Job Done Notice, File Name, Subject/Message, Reply-To, E-Mail Priority, TX Report, Original Content Orientation, Skip Blank Originals, Detect Feeder Multi Sheet Feed. Hardware Options Security Options Data Security System And Controller Options Other Options 2 Some Types Of Tracing Paper Cannot Be Used. 3 Warm-Up Time Shown For When "Quick Startup Settings For Main Power" Is Set To "OFF". For Significantly Faster Warm-Up Set "Quick Startup Settings For Main Power" To "ON". 4 Including The Toner Bottle. 5 PDF Print From Websites Is Supported. 6 EPS Can Be Printed Directly Only From The Remote User Interface. 7 Requires The Optional PCL International Font Set-A1. 8 Other Operating Systems And Environments Including AS/400, UNIX, Linux And Citrix May Be Supported. Some Of These Solutions Are Chargeable. SAP Device Types Are Available Via The SAP Market Place. For More Information, Contact Your Sales Representative. 9 0.9 W Sleep Mode Not Available In All Circumstances Due To Certain Settings. 10 For Current EPEAT Rating (Gold/Silver/Bronze), Please Visit Www.Epeat.Net. 11 Compatible Only With The ImageRUNNER ADVANCE 8585i Model. 12 When The Extension Tray Is Not Extended. 13 Requires Either Staple Finisher-V1 Or Booklet Finisher-V1. 14 Requires Either Staple Finisher-X1 Or Booklet Finisher-X1. 15 Requires Either Staple Finisher-W1 PRO Or Booklet Finisher-W1 PRO. 16 Requires Either Staple Finisher-X1, Booklet Finisher-X1, Staple Finisher-W1 PRO, Or Booklet Finisher-W1 PRO. 17 Requires Booklet Finisher-X1. 18 Requires Booklet Finisher-W1 PRO. 19 For Staple Finisher-V1 And Booklet Finisher-V1. Used For Corner/Double Stapling Only, 3 Cartridges Per Case, 5,000 Staples Per Cartridge. 20 For Booklet Finisher-V1. Used For Booklet Finishing Only, 2 Cartridges Per Case, 2,000 Staples Per Cartridge. 21 For Staple Finisher-X1, Booklet Finisher-X1, Staple Finisher-W1 PRO And Booklet Finisher-W1 PRO), 3 Cartridge Per Case, 5,000 Staples Per Cartridge 22 For Booklet Finisher-X1 And Booklet Finisher-W1 PRO, 2 Cartridges Per Case, 5,000 Staples Per Cartridge. |
GPR-37 Black Toner
Estimated Toner Yield: 70,000 Copies/Bottle (Estimated @ 5% Coverage)
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
