imageRUNNER ADVANCE 6555i III
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The imageRUNNER ADVANCE 6555i III is registered EPEAT Gold.
- 10.1" intuitive touchscreen with smartphone-like usability.
- A unique, customized experience tailored to individual preferences using My ADVANCE.
- Supports mobile solutions and integration with many popular cloud services like Google Drive15.
- Scan and convert documents to searchable digital files in a variety of file formats.
- Integration with Canon and various third-party software with embedded application platform.
- Advanced standard security feature set to help safeguard sensitive information and assist in regulatory compliance.
- Integrates with existing, third-party Security Information and Event Management (SIEM) systems to help provide real-time comprehensive insights into potential threats to the network and printers.
- Technology to verify that the device boot process, firmware, and applications initialize at startup, without any alterations or tampering by malicious third parties. During operation, McAfee Embedded Control utilizes a whitelist to protect against malware and tampering of firmware and applications.*
- Security policy settings can be controlled with a dedicated password, configured from a central location, and exported to other supported devices.
- Control access to the device and specific features, using a host of flexible authentication methods - PIN code, user name/password, or card access.
* These features are available on third generation imageRUNNER ADVANCE 3rd edition models only. McAfee Embedded Control requires Unified Firmware Platform v3.9.
- Canon's signature reliability and engine technologies help keep productivity high and minimize the impact on support resources.
- Outstanding imaging technologies and toner allow for consistently striking images, thanks to Canon's V2 color profile.
- Designed to achieve maximum uptime with status notifications that help keep supplies replenished and intuitive maintenance videos for consumables replacement.
- imageRUNNER ADVANCE models have received many awards and recognition from leading industry analysts, often referencing strong reliability.
- Designed for quick, easy deployment.
- Remote diagnostics and parts life management for proactive maintenance and rapid fixes.
- Easy and intuitive to monitor device status and consumable levels, turn off devices remotely, observe meter readings, manage settings, and implement security policies.
- Common firmware and regular updates with Unified Firmware Platform (UFP) for continuous improvements and consistency across a fleet.
- Track and assess print, copy, scan, and fax usage and allocate costs to departments or projects.
- Apply print policies and restrict usage by user to help reduce unnecessary printing and contribute to cost efficiency.
- Standard cloud-based solution provides a centralized dashboard with up-to-the-minute insights into printer activity.
- Upgrade to uniFLOW server or cloud-based solutions for full accounting and reporting for compatible Canon and third-party devices, pull printing, job routing, and powerful scan workflows.
- A combination of fusing technologies and low-melting-point toner minimizes power requirements and helps achieve low energy consumption.
- Encourage environmentally conscious work practices by enabling multiple settings that can help save paper and energy.
- ENERGY STAR® certified and rated EPEAT® Gold.14
- Some types of tracing paper cannot be used.
- Time from device power-on, until copy ready (not print reservation).
- Time from exiting Sleep mode to when printing is operational.
- Time from device power-on to when key operations can be performed on the touch panel.
- Includes Main Unit, ADF, and Consumables.
- PDF print from Websites is supported.
- EPS can be printed directly only from the Remote User Interface.
- Requires the optional PCL International Font Set-A1.
- Requires the optional Barcode Printer Kit-D1.
- Other operating systems and environments including AS/400, UNIX, Linux and Citrix may be supported. Some of these solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative.
- No charge for this solution; however activation is required.
- Standby Reference Value: measured one unit.
- 0.9 W sleep mode not available in all circumstances due to certain settings.
- For current EPEAT rating (Gold/Silver/Bronze), please visit www.cla.canon.com/cla/en/epeat.
- Subscription to a third-party cloud service required. Subject to third-party cloud service providers’ terms and conditions.
- Requires Unified Firmware Platform v3.9.
| Model Name | Imagerunner Advance 6555i Iii |
| Type | Monochrome Laser Multifunctional |
| Functions | Standard: Print, Copy, Scan, Send, Store Optional: Fax |
| Operation Panel | Standard: 10.1" Tft Lcd Wsvga Color Flat- Panel Optional 10.4" Tft Lcd Svga Color Upright-Panel |
| Image Server Memory | 3.0 Gb Ram |
| Hard Disk Drive | Standard: 250 Gb Maximum: 1 Tb |
| Mirroring Hard Disk Drive | Optional (250 Gb, 1 Tb), Method: Raid1 |
| Network Interface Connection | Standard: 1000base-T/100base-Tx/10base-T, Wireless Lan (Ieee 802.11 B/G/N) Optional: Nfc, Bluetooth Low Energy |
| Other Interface | Standard: Usb 2.0 X2 (Host), Usb 3.0 X1 (Host), Usb 2.0 X1 (Device) Optional: Serial Interface, Copy Control Interface |
| Max Mailboxes Supported | 100 User In-Boxes, 1 Memory Rx In-Box, 50 Confidential Fax In-Boxes, |
| Max Pages Stored | 30,000 Maximum Pages Stored |
| Available Disk Space | Approx. 16 Gb (Standard Hdd) Approx. 480 Gb (With Optional 1 Tb Hdd) |
| Common Protocol | Smb Or Webdav Supported |
| Supported Client Pc | Windows (Windows 7/8.1/10) |
| Max Number Of Concurrent Connections | Smb: 64 Webdav: 3 (Active Sessions) |
| Advanced Box Features | Authentication For Advanced Box Log-In, Sort Function, Printing A Pdf File With A Password, Imageware Secure Audit Manager Support |
| Standard | Standard: Usb |
| Scanning Resolution | 600 X 600, 400 X 400, 300 X 300, 200 X 400, 200 X 200, 200 X 100, 150 X 150, 100 X 100 |
| Printing Resolution | 1200 X 1200, 600 X 600 |
| Letter | Up To 55 Ppm |
| Letter R | Up To 43 Ppm |
| Legal | Up To 39 Ppm |
| Ledger | Up To 32 Ppm |
| First Copy Time | As Fast As 3.3 Seconds |
| Multiple Copies | Up To 9,999 Copies |
| Copy Exposure | Automatic Or Manual (9 Levels) |
| Magnification | 25%-400% (1% Increments) |
| Preset Reductions | 25%, 50%, 64%, 73%, 78% |
| Preset Enlargements | 121%, 129%, 200%, 400% |
| Acceptable Originals | Sheet, Book, 3-Dimensional Objects [Height: Up To 2" (50 Mm), Weight: Up To 4.4 Lb. (2 Kg)] Max. Platen Scanning Size: 11-3/4" X 17" (297 Mm X 431.8 Mm) |
| Standard Paper Capacity | Dual 1,500-Sheet Paper Drawers, Dual 550-Sheet Paper Cassettes |
| Optional | 3,500-Sheet Paper Deck (Pod Deck Lite-C1 Or Paper Deck Unit-E1) |
| Manual Bypass | 100-Sheet Stack Bypass |
| Maximum Paper Capacity | 7,700 Sheets |
| Output Paper Capacity | With Copy Tray: 250 Sheets With External Finishers: 3,500 Sheets |
| Cassettes | Paper Drawers (1/2): Letter Paper Cassettes (3/4): 11" X 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" X 7-1/8" To 11-3/4" X 19-1/4") |
| Bypass | 11" X 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (4" X 5-7/8" To 11-3/4" X 19-1/4"), Free Size (4" X 7-1/8" To 11-3/4" X 19-1/4") |
| Other Option | Pod Deck Lite-C1: 11" X 17", Legal, Letter, Letter-R, Executive, Statement-R, Custom Size (5-1/2" X 7-1/8" To 11-3/4" X 19-1/4") Paper Deck Unit-E1: Letter |
| Cassette | Paper Decks/Cassettes: 14 Lb. Bond To 80 Lb. Cover (52 To 220 G/M2) |
| Bypass | 14 Lb. Bond To 140 Lb. Index (52 To 256 G/M2) |
| Paper Weight | 14 Lb. Bond To 80 Lb. Cover (52 To 220 G/M2) |
| Warm Up Time | From Power On: Approx. 30 Seconds2 From Sleep Mode: Approx. 30 Seconds3 Quick Startup Mode: Approx. 4 Seconds4 |
| Power Requirements | 120-127v, Ac 60 Hz,16 A 220-240v, Ac 50/60 Hz, 10 A |
| Power Consumption | Maximum: Approx. 2,032 W(120v), 2.400 W (220-240v) Standby: Approx. 237.3 W(120v), 260.4 W(220-240v) Sleep Mode: Approx. 0.9 W Typical Electricity Consumption (Tec) Rating: 5.2 Kwh (120v)/ 4.9 Kwh(230v) |
| Plug | Nema 5-20p (120v) Cee 7/7 (230v) |
| Dim | 26-3/8" X 30-5/8" X 48" (670 Mm X 779 Mm X 1220 Mm) |
| Installation Space | Basic: Stack Bypass Extended+ Cassette Drawers Open + Copy Tray: 60-3/8" X 53-1/4" (1533 Mm X 1353 Mm) Fully Configured: Booklet Finisher + Paper Deck + Insertion And Folding Unit + Puncher Unit + Cassette Drawers Open: 95-7/8" X 53-1/4" (2436 Mm X 1353 Mm) |
| Weight | Approx. 515.9 Lb. (234 Kg)5 |
| Basic Copy Features | Preset Reduction/Enlargement Ratios By Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel |
| Special Copy Features | Book To Two Pages, Two-Sided Original, Finishing, Booklet, Job Build, N On 1, Add Cover, Insert Sheets, Different Size Originals, Density Adjustment, Original Type Selection, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Gutter, Print & Check, Negative/Positive, Repeat Images, Merge Job Blocks, Job Done Notice, Mirror Image, Print On Tab, Store In Mail Box, Superimpose Image, Cascade Copy, Copy Id Card, Detect Feeder Multi Sheet Feed, Free Size Original, Skip Blank Originals |
| Standard S | Authentication: Universal Login Manager, Uniflow Online Express,13 User Authentication, Department Id Authentication, Access Management System, Device And Function Level Log-In Data: Trusted Platform Module (Tpm), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption (Fips140-2 Validated), Mcafee Embedded Control16 Network: Encrypted Secure Print, Ip/Mac Address Filtering, Ipsec, Tls Encrypted Communication, Snmp V3.0, Ieee 802.1x, Ipv6, Smtp Authentication, Pop Authentication Before Smtp, S/Mime, Siem Integration Document: Secure Watermark, Secure Print, Forced Hold Printing, Adobe Livecycle Rights Management Es2.5 Integration, Encrypted Pdf, Encrypted Secure Print, Device Signatures |
| Optional | Authentication: Uniflow Data: Hard Disk Drive Mirroring, Hard Disk Drive Removal, Ieee 2600.2 Common Criteria Certification, Data Loss Prevention (Requires Uniflow) Document: User Signature, Document Scan Lock |
| Environmental Features | Operating Environment Temperature: 50 To 86 ºf Humidity: 20 To 80 % Rh (Relative Humidity) Standards Energy Star® Certified Rated Epeat® Gold14 |
| Toner | Gpr-38 Toner |
| Estimated Toner Yield | (Estimated @ 6% Coverage): 56,000 Images |
| Applicable Line | 1 |
| Modem Speed | Super G3: 33.6 Kbps G3: 14.4 Kbps |
| Data Compression | Mh, Mr, Mmr, Jbig |
| Resolution | 400 X 400 Dpi, 200 X 400 Dpi, 200 X 200 Dpi, 200 X 100 Dpi |
| Scanning Recording Size | Statement-R To 11" X 17" |
| Memory | Up To 30,000 Pages |
| Memory Backup | Yes |
| One Touch Speed Dialing Locations | Max. 200 Dials |
| Coded Speed Dialing Locations | Max. 199 Dials Sequential Broadcast Max. 256 Addresses |
| Fax Features | Original Type Selection, Two-Sided Original, Book To Two Pages, Different-Size Originals, Density For Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Sender's Name (Tti), Selecting The Telephone Line, Direct Send, Delayed Send, Preview, Job Done Notice, Tx Report, Multi Sheet Feed Detection Download Specifications ↓ |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
