imageRUNNER ADVANCE 6555i II
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
* Canon's Third Generation imageRUNNER ADVANCE core values include Workflow Efficiency, Cost Management, Security, Device and Fleet Management, Quality and Reliability and Sustainability.
- Subscription to a third-party cloud service required. Subject to third-party cloud service providers' terms and conditions.
- Requires additional option.
Note: Canon products offer certain security features, yet many variables can impact the security of your devices and data. Canon does not warrant that use of its features will prevent security issues. Nothing herein should be construed as legal or regulatory advice concerning applicable laws; customers must have their own qualified counsel determine the feasibility of a solution as it relates to regulatory and statutory compliance. - Available 2Q 2018.
- For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net.
| Model Name | Imagerunner Advance 6555i Ii |
| Type | Monochrome Laser Multifunctional |
| Functions | Standard: Print, Copy, Scan, Send, Store Optional: Fax |
| Operation Panel | Standard: 10.1" Tft Lcd Wsvga Color Flat- Panel Optional 10.4" Tft Lcd Svga Color Upright-Panel |
| Image Server Memory | 3.0 Gb Ram |
| Hard Disk Drive | Standard: 250 GbMaximum: 1 Tb |
| Mirroring Hard Disk Drive | Optional (250 Gb, 1 Tb), Method: Raid1 |
| Network Interface Connection | 1000base-T/100base-Tx/10base-T, Wireless Lan (Ieee 802.11 B/G/N) |
| Other Interface | Standard: Usb 2.0 X2 (Host), Usb 3.0 X1 (Host), Usb 2.0 X1 (Device) Optional: Serial Interface, Copy Control Interface |
| Max Mailboxes Supported | 100 User In-Boxes, 1 Memory Rx In-Box, 50 Confidential Fax In-Boxes |
| Max Pages Stored | 30,000 Maximum Pages Stored |
| Available Disk Space | Approx. 16 Gb (Standard Hdd), Approx. 480 Gb (1 Tb Hdd) |
| Common Protocol | Smb Or Webdav |
| Supported Client Pc | Windows (Windows Vista/7/8/8.1/10) |
| Max Number Of Concurrent Connections | Smb: 64 Webdav: 3 (Active Sessions) |
| Advanced Box Features | Disabling Advanced Box, Storage Filtering, Authentication For Advanced Box Log-In, Search Function, Sort Function, Printing A Pdf File With A Password, Imageware Secure Audit Manager Support |
| Printing Resolution | 1200 Dpi X 1200 Dpi Reading: 600 Dpi X 600 Dpi Standard Page Description Languages Ufr Ii, Pcl®6, Adobe® Ps® 3 Direct Print Available From Usb, Advanced Box, Remote Ui, And Web Access5 Supported File Types Pdf, Tiff, Jpeg, Eps,6 Xps Printing From Mobile And Cloud A Range Of Software And Meap-Based Solutions Are Available To Provide Printing From Mobile Devices Or Internet-Connected Devices And Cloud-Based Services Depending On Your Requirements. Fonts Pcl Fonts: 93 Roman, 10 Bitmap Fonts, 2 Ocr Fonts, Andalé Mono Wt J/K/S/T (Japanese, Korean, Simplified And Traditional Chinese)7 Ps Fonts: 136 Roman Operating System8 Ufrii: Server 2003/Server 2003 R2vista/Server 2008/Windows 7/Server 2008 R2/ Windows 8/Server 2012/Windows 8.1/ Server 2012 R2/Windows 10, Mac Os X (10.5.8 Or Later) Pcl: Server 2003/Server 2003 R2vista/ Server 2008/Windows 7/Server 2008 R2/Windows 8/Server 2012/Windows 8.1/Server 2012 R2/Windows 10 Ps: Server 2003/Server 2003 R2vista/Server 2008/Windows 7/Server 2008 R2/ Windows 8/Server 2012/Windows 8.1/ Server 2012 R2/Windows 10, Mac Os X (10.5.8 Or Later) Print Features Suspend Job Timeout, Subset Finishing (Ps Only), Profile Settings, Secured Print, Watermark, Page Border, Header/Footer, Page Layout, Two-Sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/ Orientations, Offsetting, Printing On Transparencies, Front/Back Covers, Toner Reduction, Poster Printing |
| Letter | Up To 55 Ppm |
| Letter R | Up To 43 Ppm |
| Legal | Up To 39 Ppm |
| Ledger | Up To 32 Ppm |
| First Copy Time | As Fast As 3.3 Seconds. |
| Multiple Copies | Up To 9,999 Copies |
| Copy Exposure | Automatic Or Manual (9 Levels) |
| Magnification | 25%-400% (1% Increments) |
| Preset Reductions | 25%, 50%, 64%, 73%, 78% |
| Preset Enlargements | 121%, 129%, 200%, 400% |
| Standard Paper Capacity | (Ltr, 21 Lb. Bond): 4,200 Sheets Dual 1,500-Sheet Paper Drawers, Dual 550-Sheet Paper Cassettes |
| Manual Bypass | 100-Sheet Stack Bypass |
| Maximum Paper Capacity | 7,700 Sheets |
| Output Paper Capacity | (Ltr, 20 Lb. Bond): With Copy Tray: 250 Sheets With External Finishers: 3,500 SheetsFinishing Capabilities With External Finishers: Collate, Group, Offset, Staple, Booklet, Hole Punch, Document Insertion, C And Z Folding |
| Cassette | 14 Lb. Bond To 80 Lb. Cover (52 To 220 G/M2) |
| Bypass | 14 Lb. Bond To 140 Lb. Index (52 To 256 G/M2) |
| Duplexing | 14 Lb. Bond To 80 Lb. Cover (52 To 220 G/M2) |
| Warm Up Time | From Power On: 30 Seconds From Sleep Mode: 30 Seconds |
| Dim | 26-3/8" X 30-5/8" X 48" (670 Mm X 779 Mm X 1220 Mm) |
| Installation Space | Basic: Stack Bypass Extended+ Cassette Drawers Open + Copy Tray: 60-3/8" X 53-1/4" (1533 Mm X 1353 Mm) Fully Configured: Booklet Finisher + Paper Deck + Insertion And Folding Unit + Puncher Unit + Cassette Drawers Open: 94-3/4" X 53-1/4" (2407 Mm X 1353 Mm) |
| Weight | Approx. 515.9 Lb. (234 Kg)4 |
| Basic Copy Features | Preset Reduction/Enlargement Ratios By Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel |
| Special Copy Features | Book To Two Pages, Two-Sided Original, Finishing, Booklet, Job Build, N On 1, Add Cover, Insert Sheets, Different Size Originals, Density Adjustment, Original Type Selection, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Gutter, Print & Check, Negative/Positive, Repeat Images, Merge Job Blocks, Job Done Notice, Mirror Image, Print On Tab, Store In Mail Box, Superimpose Image, Cascade Copy, Copy Id Card, Detect Feeder Multi Sheet Feed, Free Size OriginalScan Specifications Type: Color Platen And Single-Pass Duplexing Automatic Document Feeder Document Feeder Paper Capacity: 300 Sheets (20 Lb. Bond) Document Feeder Supported Media Sizes: 11" X 17", Legal, Letter, Letter-R, Statement, Statement-R, A4, A3 Document Feeder Supported Media Weights: Bw Original: 13 Lb. Bond To 80 Lb. Cover (50 To 220 G/M2) Cl Original: 17 Lb. Bond To 80 Lb. Cover (64 To 220 G/M2) Platen Acceptable Originals: Sheet, Book, 3-Dimensional Objects [Up To 4.4 Lb. (2 Kg)] Pull Scan Spec Color Network Scangear2 For Both Twain And Wia Supported Os: Windows Vista/7/8/8.1/10 Windows Server 2003/Server 2003 R2/ Server 2008/Server 2008 R2/Server 2012/Server 2012 R2 Scan Resolution 600 X 600 Dpi, 400 X 400 Dpi, 300 X 300 Dpi, 200 X 400 Dpi, 200 X 200 Dpi, 200 X 100 Dpi, 150 X 150 Dpi, 100 X 100dpi Scan To Mobile Devices And Cloud-Based Services: A Range Of Solutions Is Available To Provide Scanning To Mobile Devices And Cloud-Based Services Depending On Your Requirements. Scan Speed (Letter): Single-Sided Scanning (Bw): 120 Ipm (300 Dpi)/120 Ipm (600 Dpi) Single-Sided Scanning (Color): 120 Ipm (300 Dpi)/60 Ipm (600 Dpi) Double-Sided Scanning (Bw): 240 Ipm (300 Dpi)/150 Ipm (600 Dpi) Double-Sided Scanning (Color): 220 Ipm |
| Standard S | Authentication Standard: Universal Login Manager*, User Authentication, Department Id Authentication, (Device And Function Level Log-In), Access Management System Optional: Uniflow *Universal Login Manager Is Standard For 120v Models, Installed By Request For 230v Models. Data Standard: Trusted Platform Module (Tpm), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption(Fips140-2 Validated) Optional: Hard Disk Drive Mirroring, Hard Disk Drive Removal, Ieee 2600.2 Common Criteria Certification, Data Loss Prevention (Requires Uniflow) Network Standard: Ip/Mac Address Filtering, Ipsec, Tls Encrypted Communication, Snmp V3.0, Ieee 802.1x, Ipv6, Smtp Authentication, Pop Authentication Before Smtp Document Standard: Secure Print, Adobe Livecycle® Rights Management Es2.5 Integration Optional: Encrypted Pdf, Encrypted Secure Print, User And Device Signatures, Secure Watermarks, Document Scan Locking |
| Environmental Features | Operating Environment Temperature: 50 To 86 ºf Humidity: 20 To 80 % Rh (No Condensation) Power Requirements 120-127 V Ac, 60 Hz, 16 A 220-240 V Ac, 50/60hz, 10a. Plug Nema 5-20p (120v) Cee 7/7 (230v). Power Consumption Maximum: Approx. 2.1 Kw (120v) 2.4 Kw (230v) Standby: Approx. 238 Wh (120v) 261 Wh (230v) Energy Saver Mode: Approx. 192 Wh (120v) 236 Wh (230v) Sleep Mode: Approx. 0.9 W Or Less9 Typical Electricity Consumption (Tec) Rating: 5.2 Kwh (120v) 4.9 Kwh (230v) Standards
| Toner | Gpr-38 Black Toner |
| Estimated Toner Yield | 56,000 Copies |
| Description | Paper Deck Unit-E1 |
| Paper Capacity | 3,500 Sheets [21 Lb. Bond (80 G/M2)] |
| Paper Size | Letter, A4 |
| Paper Weight | 14 Lb. Bond To 140 Lb. Index (52 To 256 G/M2) |
| Power Source | From The Main Unit |
| Power Consumption | Approx. 44 W |
| Dimensions | 14-1/4" X 24-7/8" X 22-1/2" (363 Mm X 630 Mm X 572 Mm) |
| Weights | Approx. 75.0 Lb. (34 Kg) |
| Description | Pod Deck Lite-C1 |
| Paper Size | 11"X17", Legal, Letter, Letter-R, Executive, Statement-R, And Custom Size (5-1/2" X 7-1/8" To 11-3/4" X 17"), A3, A4 |
| Dimensions | 25-7/8" X 27" X 22-1/2" (656 Mm X 686 Mm X 570 Mm) |
| Weights | Approx. 149.9 Lb. (68 Kg) |
| Description | Copy Tray-R1: |
| Total Output Capacity | 250 Sheets [21 Lb. Bond (80 G/M2)] |
| Dimensions | 16-1/2" X 15" X 6-7/8" (420 Mm X 382 Mm X 175 Mm) |
| Weight | Approx. 2.4 Lb. (1.1 Kg) |
| Description | Staple Finisher-V1 |
| Number Of Trays | 3 |
| Top Tray | Letter/Executive/Statement-R 250 Sheets, 11" X 17"/Legal/Letter-R 125 Sheets |
| Middle Tray | Letter/Executive/Statement-R 250 Sheets, 11" X 17"/Legal/Letter-R 125 Sheets |
| Lower Tray | Letter/Executive/Statement-R 3,000 Sheets, 11" X 17" 1,500 Sheets |
| Staple Capacity | Corner Staple And Double Staple: Letter/A4/Executive: 65 Sheets [24 Lb. Bond (90 G/M2)] 11" X 17"/A3 / Legal/ Letter-R: 30 Sheets [24 Lb. Bond (90 G/M2)] Staple-Free Staple: 11"X17"/ Letter/A4: 5 Sheets [14 To 17 Lb. Bond (52 To 64 G/M2)] 4 Sheets [17.3 To 21.7 Lb. Bond (65 To 81.4 G/M2)] 3 Sheets [21.7 To 28 Lb. Bond (81.5 To 105 G/M2)] Staple On Demand: 65 Sheets [24 Lb. Bond (90 G/M2)] |
| Staple Positions | Corner, Double |
| Power Consumption | Approx. 176 W (Including 2/3 Hole Puncher-A1) |
| Dimensions | 20-5/8" X 24-1/2" X 43-1/4" (525 Mm × 623 Mm × 1099 Mm) |
| Weight | Approx. 77.2 Lb. (35 Kg) |
| Description | Booklet Finisher-V1 |
| Saddle Stitch Tray | 11" X 17", Legal, Letter-R, Custom Size 7-3/4" X 10-5/8" To 12" X 18" |
| Paper Capacity Of Saddle Stitch Mode | 20 Sheets [22 Lb. Bond (81 G/M2)] [Including 1 Cover Sheet Up To 140 Lb. Index (256 G/M2)] |
| Staple Capacity | Corner Staple And Double Staple: Letter/A4/Executive: 65 Sheets [24 Lb. Bond (90 G/M2)] 11" X 17"/ A3/ Legal/ Letter-R: 30 Sheets [24 Lb. Bond (90 G/M2)]Staple-Free Staple: 11"X17"/ Letter: 5 Sheets [14 To 17 Lb. Bond (52 To 64 G/M2)] 4 Sheets [17.3 To 21.7 Lb. Bond (65 To 81.4 G/M2)] 3 Sheets [21.7 To 28 Lb. Bond (81.5 To 105 G/M2)] Staple On Demand: 65 Sheets [24 Lb. Bond (90 G/M2)] |
| Weight | Approx. 127.9 Lb. (58 Kg) |
| Description | 2/3 Hole Puncher-A112 |
| Paper Size | Two Holes 11" X 17", Legal, Letter, , A3, A4, Letter-R, Executive Three Holes 11" X 17", Letter, , A3, A4, Executive |
| Power Requirements | From The Main Unit |
| Description | Document Insertion Unit-P112 |
| Paper Size | 11' X 17", Legal, Letter, A3, A4, Letter-R, Executive |
| Paper Weight | 16 Lb. Bond To 140 Lb. Index (60 To 256 G/M2) |
| Number Of Trays | 1 Tray |
| Tray Capacity | 100 Sheets [21 Lb. Bond (80 G/M2)] |
| Power Requirements | 100-240 V Ac, 50/60 Hz |
| Power Consumption | 1.0 A/Approx. 100 W |
| Dimensions | 26-1/8" X 26-3/4" X 48-7/8" (662 Mm X 679 Mm X 1242 Mm) |
| Weight | Approx. 88.2 Lb. (40 Kg) |
| Description | Document Insertion/Folding Unit-J112 |
| Tray Capacity | 100 Sheets [21 Lb. Bond (80 G/M2)] Supported Fold Types: |
| Applicable Line | 1 |
| Modem Speed | Super G3: 33.6 Kbps G3: 14.4 Kbps |
| Data Compression | Mh, Mr, Mmr, Jbig |
| Resolution | 400 X 400 Dpi, 200 X 400 Dpi, 200 X 200 Dpi, 200 X 100 Dpi |
| Scanning Recording Size | Statement-R To 11" X 17" |
| Memory | Up To 6,000 Pages |
| Memory Backup | Yes |
| One Touch Speed Dialing Locations | Max. 199 DialsSequential Broadcast Max. 256 Addresses |
| Fax Features | Original Type Selection, Two-Sided Original, Book To Two Pages, Different-Size Originals, Density For Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Specifying The Sender's Name (When Sending Fax), Sender's Name (Tti), Selecting The Telephone Line (When Sending Fax), Direct Send, Delayed Send, Preview, Finished Stamp, Job Done Notice, Tx Report, Detect Feeder Multi Sheet Feed. |
| Description | Imagepass-Y1 (External) |
| Processor | Intel Pentium G850 2.9 Ghz |
| System | Fiery Fs150pro |
| Standard Memory | 4 Gb |
| Hard Disk | 500 Gb |
| Print Resolution | 1200 Dpi X 1200 Dpi, 600 Dpi X 600 DpiStandard Page Description Languages*: Pcl, Adobe Ps 3, Appe * Pcl Is Standard For 120v And 230 Models. Ps Is Standard For 120v Model And Optional For 230v Models. |
| Pcl Fonts | Ps: 138 Adobe Ps Fonts Pcl: 113 Pcl Fonts |
| Interface Connections | 2 X Ethernet (1000base-T/100base-T/10base-T), Usb X 5 (Front X 1, Rear X 4) |
| Protocols Supported | Tcp/Ip (Lpd/Port 9100/Ipp/Smb/Ftp), Atp/ Ddp (Appletalk)/Direct Mobile Printing/Printme Cloud Printing |
| Print Controller Technology | Windows Xp 32 And 64bit/Windows Vista 32 And 64 Bit/Windows 8 32 And 64 Bit/Windows 8.1 32 And 64 Bit/Windows Server 2008 32 And 64 Bit/Windows Server 2008 R2 64 Bit Only/Windows Server 2012 64bit Only/Windows Server 2012 R2 64bit Only/Mac Os (10.6 Or Higher)Fiery Print Controller Options: Fiery Impose, Fiery Compose, Fiery Impose And Compose, Removable Hard Disk Drive, Integration Interface And Stand (19" Display, Keyboard, Mouse, And Furniture Stand), Fiery Imageviewer |
| Print Features | Fiery Print Controller Features: Hot Folders, Secure Erase , Paper Catalog Kit, Vdp-A1 Kit, Virtual Printer |
| Dimensions | 13-5/8" X 5-1/2" X 12-5/8" (345 Mm X 140 Mm X 320 Mm) |
| Sending Method | E-Mail/Internet Fax (Smtp), Smb, Ftp, Webdav, Mail Box, Super G3 Fax (Optional), Ip Fax (Optional) |
| Color Mode | Automatic-Color Select (Full Color/Grayscale), Automatic-Color Select (Full Color/Black-And-White), Full Color, Grayscale, And Black-And-White |
| Address Book Capacity | Ldap (2,000)/Local (1,600)/Speed Dial (200) |
| Communication Protocol | File: Ftp, Smb, Webdav E-Mail/I-Fax: Smtp, Pop3, I-Fax (Simple, Full) |
| File Format | Standard: Tiff, Jpeg, Pdf(Compact, Searchable, Apply Policy, Optimize For Web, Pdf A/1-B), Xps(Compact, Searchable), Office Open Xml (Powerpoint, Word) Optional: Pdf(Trace & Smooth, Encrypted), Pdf/Xps (Digital Signature) |
| Scan Density | 600 X 600 Dpi, 400 X 400 Dpi, 300 X 300 Dpi, 200 X 400 Dpi, 200 X 200 Dpi, 200 X 100 Dpi, 150 X 150 Dpi, 100 X 100dpiUniversal Send Features Original Type Selection,Two-Sided Original, Book To Two Pages, Different-Size Originals, Density Adjustment, Sharpness, Copy Ratio, Erase Frame, Job Build, Sender's Name (Tti), Select Line, Direct Send, Delayed Send, Preview, Finished Stamp, Job Done Notice, File Name, Subject/Message, Reply-To, E-Mail Priority, Tx Report, Original Content Orientation, Skip Blank Originals, Detect Feeder Multi Sheet FeedHardware Options Card Readers Micard Plus Proximity Card Reader Copy Card Reader-F1 Copy Card Reader Attachment-A3 Others Printer Cover-H1 Tab Feeding Attachment Kit-B1 Stamp Ink Cartridge-C1 Upright Control Panel-E1 Utility Tray-B1 Security Options Document Security Document Scan Lock Kit-B1 Secure Watermark-B1 Encrypted Secure Print Software-D1 Data Security Hdd Mirroring Kit-J1 2.5inch/250gb Hdd-N1 2.5inch/1tb Hdd-P1 Removable Hdd Kit-Al1 System And Controller Options Print Accessories Pcl International Font Set-A1 Barcode Printing Barcode Printing Kit-D1 Efi-Fiery Based Controller Imagepass-Y1 Removable Hard Disk Drive Kit-B4 Fiery Impose Fiery Compose Fiery Impose And Compose Fiery Image Viewer System Accessories Meap Web Access Connection Kit G3 Ip Fax Expansion Kit-B1 Accessories Super G3 Fax Board-As1 Remote Fax Kit-A1 Other Options Accessibility Accessories Adf Access Handle-A1 Voice Guidance Kit-G1 Voice Operation Kit-D1 Staples Staple Cartridge-X113 Staple Cartridge-Y1141 Tab Paper Can Be Fed From Paper Cassettes (3/4) When The Optional Tab Feeding Attachment Kit-B1 Is Installed. 2 Some Types Of Tracing Paper Cannot Be Used. 3 Warm-Up Time Shown For When "Quick Startup Settings For Main Power" Is Set To "Off". For Significantly Faster Warm-Up Set "Quick Startup Settings For Main Power" To "On". 4 Including The Toner Bottle. 5 Pdf Print From Websites Is Supported. 6 Eps Can Be Printed Directly Only From The Remote User Interface. 7 Requires The Optional Pcl International Font Set-A1. 8 Other Operating Systems And Environments Including As/400, Unix, Linux And Citrix May Be Supported. Some Of These Solutions Are Chargeable. Sap Device Types Are Available Via The Sap Market Place. For More Information, Contact Your Sales Representative. 9 0.9 W Sleep Mode Not Available In All Circumstances Due To Certain Settings. 10 For Current Epeat Rating (Gold/Silver/Bronze), Please Visit Www.Epeat.Net. 11 When The Extension Tray Is Not Extended. 12 Requires Either Staple Finisher-V1 Or Booklet Finisher-V1. 13 Used For Corner/Double Stapling Only, 3 Cartridges Per Case, 5,000 Staples Per Cartridge. 14 Used For Booklet Finishing Only, 2 Cartridges Per Case, 2,000 Staples Per Cartridge. |
Canon GPR-38 Black Toner
Estimated Toner Yield: 56,000 Copies/Bottle (Estimated @ 5% Coverage)
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Locating and Installing Your Download Cómo Localizar e Instalar su Descarga Localizando e Instalando seu Download
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
