imageRUNNER ADVANCE 525iF III
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The imageRUNNER ADVANCE 525iF III is registered EPEAT Gold.
- 10.1" intuitive touchscreen with smartphone-like usability.
- A unique, customized experience tailored to individual preferences using My ADVANCE.
- Supports mobile solutions and integration with many popular cloud services like Google Drive16.
- Scan and convert documents to searchable digital files in a variety of file formats.
- Integration with Canon and various third-party software with embedded application platform.
- Advanced standard security feature set to help safeguard sensitive information and assist in regulatory compliance.
- Integrates with existing, third-party Security Information and Event Management (SIEM) systems to help provide real-time comprehensive insights into potential threats to the network and printers.
- Technology to verify that the device boot process, firmware, and applications initialize at startup, without any alterations or tampering by malicious third parties. During operation, McAfee Embedded Control utilizes a whitelist to protect against malware and tampering of firmware and applications.*
- Security policy settings can be controlled with a dedicated password, configured from a central location, and exported to other supported devices.
- Control access to the device and specific features, using a host of flexible authentication methods - PIN code, user name/password, or card access.
* These features are available on third generation imageRUNNER ADVANCE 3rd edition models only. McAfee Embedded Control requires Unified Firmware Platform v3.9.
- Canon's signature reliability and engine technologies help keep productivity high and minimize the impact on support resources.
- Outstanding imaging technologies and toner allow for consistently striking images, thanks to Canon's V2 color profile.
- Designed to achieve maximum uptime with status notifications that help keep supplies replenished and intuitive maintenance videos for consumables replacement.
- imageRUNNER ADVANCE models have received many awards and recognition from leading industry analysts, often referencing strong reliability.
- Designed for quick, easy deployment.
- Remote diagnostics and parts life management for proactive maintenance and rapid fixes.
- Easy and intuitive to monitor device status and consumable levels, turn off devices remotely, observe meter readings, manage settings, and implement security policies.
- Common firmware and regular updates with Unified Firmware Platform (UFP) for continuous improvements and consistency across a fleet.
- Track and assess print, copy, scan, and fax usage and allocate costs to departments or projects.
- Apply print policies and restrict usage by user to help reduce unnecessary printing and contribute to cost efficiency.
- Standard cloud-based solution provides a centralized dashboard with up-to-the-minute insights into printer activity.
- Upgrade to uniFLOW server or cloud-based solutions for full accounting and reporting for compatible Canon and third-party devices, pull printing, job routing, and powerful scan workflows.
- A combination of fusing technologies and low-melting-point toner minimizes power requirements and helps achieve low energy consumption.
- Encourage environmentally conscious work practices by enabling multiple settings that can help save paper and energy.
- ENERGY STAR® certified and rated EPEAT® Gold.14
- Heavy paper (95 to 110 lb. Cover) can be supported as follows: Standard format paper size (excluding SRA3), Custom size (3-7/8" x 5-1/2" to 12" x 18"), Free size (3-7/8" x 5-1/2" to 12" x 18").
- Time from device power-on, until copy ready (not print reservation).
- Time from exiting Sleep mode to when printing is operational.
- Time from device power-on to when key operation can be performed on the touch screen.
- Includes main unit and either Cassette Feeding Unit-AP1 or Cabinet Type-R.
- Includes main unit and either Cassette Feeding Unit-AP1 or Cabinet Type-R and Staple/Booklet Finisher-AA1.
- Includes main unit, DADF, consumables, and Cassette Feeding Unit-AP1.
- PDF print from Web sites is supported.
- Requires the optional PCL International Font Set-A1.
- Requires the optional Barcode Printer Kit-D1.
- Other operating systems and environments, including AS/400, UNIX, Linux and Citrix, may be supported. Some solutions are chargeable. SAP Device Types are available via the SAP Market Place. For more information, contact your sales representative.
- No charge for this solution; however activation is required.
- 0.8 W sleep mode not available in all circumstances due to certain settings.
- For current EPEAT rating (Gold/Silver/Bronze), please visit www.cla.canon.com/cla/en/epeat.
- GPR-53L Toner also available for Color (C, M, Y). Yield (estimated @ 5% coverage) is 8,500 images.
- Subscription to a third-party cloud service required. Subject to third-party cloud service providers’ terms and conditions.
- Requires Unified Firmware Platform v3.9.
| Model Name | Imagerunner Advance 525if Iii |
| Type | Monochrome Laser Multifunction |
| Functions | Print, Copy, Scan, Send, Fax |
| Operation Panel | 10.1" Wsvga Color Touch-Panel |
| Image Server Memory | 3.0 Gb Ram |
| Hard Disk Drive | 250 Gb |
| Network Interface Connection | Network: 1000base-T/100base-Tx/10base-T, Wireless Lan (Ieee 802.11 B/G/N) Optional: Nfc, Bluetooth Low Energy |
| Other Interface | Standard: Usb 2.0 X2 (Host), Usb 3.0 X1 (Host), Usb 2.0 X1 (Device) Optional: Copy Control Interface |
| Max Mailboxes Supported | 100 User In-Boxes, 1 Memory Rx In-Box, 50 Confidential Fax In-Boxes |
| Max Pages Stored | 30,000 Maximum Pages Stored |
| Available Disk Space | Approx. 16 Gb |
| Common Protocol | Smb Or Webdav |
| Supported Client Pc | Windows (Windows 7/8.1/10) |
| Max Number Of Concurrent Connections | Smb: 64 Webdav: 3 (Active Sessions) |
| Advanced Box Features | Authentication For Advanced Box Log-In, Sort Function, Printing A Pdf File With A Password, Imageware Secure Audit Manager Support |
| Standard | Standard: Usb |
| Scanning Resolution | 600 X 600, 400 X 400, 300 X 300, 200 X 400, 200 X 200, 200 X 100, 150 X 150, 100 X 100 |
| Printing Resolution | Data Processing Resolution: 600 X 600 Dpi (Default), Up To 1200 X 1200 Dpi Laser Resolution: 1200 X 600 Dpi, 600 X 600 Dpi |
| Letter | Up To 55 Ppm |
| Legal | Up To 45 Ppm |
| First Copy Time | As Fast As 5 Seconds |
| Multiple Copies | Up To 9,999 Copies |
| Magnification | 25%-400% (1% Increments) |
| Preset Reductions | 25%, 50%, 64%, 78% |
| Preset Enlargements | 129%, 200%, 400% |
| Acceptable Originals | Sheet, Book, 3-Dimensional Objects [Height Up To 1-1/4"; Weight Up To 4.4 Lb. (2 Kg)] |
| Standard Paper Capacity | 650 Sheets |
| Optional | 550-Sheet (Cassette Feeding Unit-Ar1), 2,650-Sheet (High Capacity Cassette Feeding Unit-D1), 550-Sheet (Cassette Module-Ag1), 75-Envelope (Envelope Cassette Module-A1) |
| Manual Bypass | 100-Sheet Stack Bypass |
| Maximum Paper Capacity | 3,300 Sheets |
| Output Paper Capacity | Standard Model: 500 Sheets Finisher Model: 1,000 Sheets |
| Cassettes | Letter, Executive, Statement, Custom Size (3-7/8" X 5-7/8" To 8-1/2" X 11-3/4") |
| Bypass | Legal, Letter, Executive, Statement, Envelope [No.10 (Com10), Monarch, Dl, Iso-C5], Custom Size (3" X 5" To 8-1/2" X 14") |
| Other Option | Cassette Feeding Unit-Ar1 (Optional): Legal, Letter, Executive, Statement, Custom Size: 3-7/8" X 5-7/8" To 8-1/2" X 14" High Capacity Cassette Feeding Unit-D1 (Optional) Upper: Legal, Letter, Executive, Statement, Custom Size: 3-7/8" X 5-7/8" To 8-1/2" X 14" Lower: Legal, Letter Cassette Module-Ag1 (Optional): Legal, Letter, Executive, Statement, Custom Size: 3-7/8" X 5-7/8" To 8-1/2" X 14" Envelope Cassette Module-A1: No.10 (Com10), Monarch, Dl, Iso-C5 |
| Cassette | 16 Lb. Bond To 36 Lb. Bond (60 To 135 G/M2) |
| Bypass | 16 Lb. Bond To 74 Lb. Cover (60 To 199 G/M2) |
| Duplexing | 16 Lb. Bond To 32 Lb. Bond (60 To 120 G/M2) |
| Power Requirements | 120-127 V Ac 60 Hz, 9.7 A 220-240 V, 50/60 Hz, 4.8 A |
| Power Consumption | Maximum: Approx. 1,500 W Standby: Approx. 29.77 W13 Sleep Mode: Approx. 1.0 W14 Typical Electricity Consumption (Tec) Rating:15 2.1 Kwh |
| Plug | Nema 5-15p(120 V) Cee 7/7(230 V) |
| Dim | Standard Model: 20-1/4" X 23-5/8" X 24-1/4" (513 Mm X 601 Mm X 617 Mm) Finisher Model: 20-1/4" X 23-5/8" X 32-1/8” (513 Mm X 601 Mm X 814 Mm) Dimensions (W X D X H) With Paper Feeding Unit Or High Capacity Paper Feeding Standard Model: 25-1/4" X 26-3/8" X 42-1/4" (642 Mm X 668 Mm X 1073mm) Finisher Model: 25-1/4" X 26-3/8" X 50” (642 Mm X 668 Mm X 1270 Mm) |
| Installation Space | 41-3/8" X 32-3/8" (1,052 Mm X 823 Mm) |
| Weight | Standard Model: Approx. 81.6 Lb. (37 Kg) Finisher Model: Approx. 101.4 Lb. (46 Kg)4 |
| Basic Copy Features | Preset Reduction/Enlargement Ratios By Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel |
| Special Copy Features | Two-Sided Original, Finishing, Job Build, N On 1, Different Size Originals,10 Density Adjustment, Original Type Selection, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Job Done Notice, Copy Id Card, Skip Blank Pages, Multi Sheet Feed Detection |
| Standard S | Authentication: Universal Login Manager, Uniflow Online Express,13 User Authentication, Department Id Authentication, Access Management System, Device And Function Level Log-In Data: Trusted Platform Module (Tpm), Hard Disk Password Lock, Hard Disk Drive Erase, Mail Box Password Protection, Hard Disk Drive Encryption (Fips140-2 Validated), Mcafee Embedded Control17 Network: Encrypted Secure Print, Ip/Mac Address Filtering, Ipsec, Tls Encrypted Communication, Snmp V3.0, Ieee 802.1x, Ipv6, Smtp Authentication, Pop Authentication Before Smtp, S/Mime, Siem Integration Document: Secure Watermark, Secure Print, Forced Hold Printing, Adobe Livecycle Rights Management Es2.5 Integration, Encrypted Pdf, Encrypted Secure Print, Device Signatures |
| Optional | Authentication: Uniflow Data: Ieee 2600 Common Criteria Certification, Data Loss Prevention (Requires Uniflow) Document: User Signature |
| Environmental Features | Energy Star® Certified Rated Epeat® Gold16 |
| Toner | T03 Black (All-In-One Toner Cartridge)17 |
| Estimated Toner Yield | 51,500 Images18 |
| Applicable Line | 1 |
| Modem Speed | Super G3: 33.6 Kbps G3: 14.4 Kbps |
| Data Compression | Mh, Mr, Mmr, Jbig |
| Resolution | 400 X 400, 200 X 400, 200 X 200, 200 X 100 |
| Scanning Recording Size | Statement To Legal |
| Maximum Memory | Up To 30,000 Pages |
| Memory Backup | Yes |
| One Touch Speed Dialing Locations | Max. 200 |
| Coded Speed Dialing Locations | Max. 199 Sequential Broadcast: Max. 256 Addresses |
| Fax Features | Original Type Selection, Two-Sided Original, Density For Scanning, Sharpness, Erase Frame, Job Build, Sender's Name (Tti), Selecting The Telephone Line, Direct Send, Delayed Send, Preview, Job Done Notice, Tx Report, Multi Sheet Feed Detection Download Specifications ↓ |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
