imageRUNNER ADVANCE 500iF
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
| Model Name | ImageRUNNER ADVANCE 500iF |
| Type | Color Digital Multifunction Imaging System |
| Functions | Copy, Print (UFR II, PCL 5e/6, Adobe® PostScript® 3™),Fax (Up To 2 Lines), Scan, Send, Store |
| Operation Panel | 7" WVGA Full-Color, TFT Screen |
| Image Server Memory | Standard: 1.5GB RAM Maximum: 1.5GB RAM |
| Hard Disk Drive | Standard: 80GB Maximum: 80GB |
| Network Interface Connection | Ethernet 10/100 Base-TX, Ethernet 1000 Base-TX |
| Other Interface | USB 2.0 X3 (Host), USB 2.0 (Device) |
Advanced Box
| Advanced Box Features | Store To Remote Advanced Box:♦ Supported Print/View From Remote Advanced Box:♦ Supported |
Memory Media
| Standard | USB Memory |
Scan Specifications
| Network Twain Scan | Standard |
| Network Scan Utility | Color Network ScanGear |
Output Sizes
| Cassettes | LGL, LTR, STMT, EXEC, Custom Size 5-1/2" X 8-1/4" To 8-1/2" To 14" (139.7mm X 210mm To 216mm X 355.6 Mm), And Envelopes (COM10, Monarch, DL, ISO-C5)* |
| Bypass | LGL, LTR, STMT, EXEC, Custom Size [3-7/8" X 5-1/2" To 8-1/2" X 14" (99mm X 139.7mm To 216mm X 355.6mm)], And Envelopes (COM10, Monarch, DL, ISO-C5) |
| Other Option | Envelope Feeder Attachment (COM10, Monarch, DL, ISO-C5)* |
Acceptable Paper Weights
| Cassette | 17 Lb. Bond To 28 Lb. Bond (64 To 105g/M2) |
| Bypass | 17 Lb. Bond To 34 Lb. Bond (64 To 128g/M2) |
Duplexing Props
| Duplexing | Standard Automatic Trayless Duplexing |
| Paper Size | Statement To Legal |
| Paper Weight | Up To 34 Lb. Bond (128g/M2) |
Dummy Header B
| Special Media Support | Plain 1 [17 Lb. Bond To 21 Lb. Bond (64 To 80g/M2)], Plain 2 [22 Lb. Bond To 24 Lb. Bond (81 To 90g/M2)], Recycled [17 Lb. Bond To 21 Lb. Bond (64 To 80g/M2)], Color [17 Lb. Bond To 24 Lb. Bond (64 To 90g/M2)], Heavy 1 [25 Lb. Bond To 28 Lb. Bond (91 To 105g/M2)], Heavy 2 [29 Lb. Bond To 34 Lb. Bond (106 To 128g/M2)], Transparency [40 Lb. Bond To 67 Lb. Cover (151 To 181g/M2)]**, Pre-Punched [20 Lb. Bond To 21 Lb. Bond (75 To 80g/M2)], Bond [20 Lb. Bond To 24 Lb. Bond (75 To 90g/M2)], Labels [40 Lb. Bond To 67 Lb. Cover (151 To 181g/M2)], Envelope |
| Warm Up Time | From Power On: 34 Seconds From Sleep Mode: 10 Seconds Or Less Quick Startup Mode: Within 7 Seconds Or Less*** |
| Power Requirements | 120V AC, 60Hz |
| Power Consumption | Maximum: 1.5 KW Sleep Mode: 1 W |
| Plug | 10.5A |
| Dim | 24-7/8" X 22-1/8" X 22-3/8" (633mm X 560mm X 567mm) |
| Installation Space | Without Staple Finisher-R1: 34-3/4" X 40-7/8" (881mm X 1035mm) With Staple Finisher-R1: 50-1/4" X 40-7/8" (1276mm X 1035mm) |
| Weight | Approximately 107 Lb. (48.7kg)Δ |
Image Reader
| Scan Resolution | Up To 600 X 600 Dpi |
| Acceptable Originals | (Glass): Sheet, Book, 3-Dimensional Objects [Up To 4.4 Lb. (2kg)] |
| Maximum Original Size | Legal (8-1/2" To 14") |
Dummy Header C
| Basic Copy Features | Preset R/E Ratios By Area, Finishing, Two-Sided, Exposure Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel, Standard Keys, Reset, Job Duration Display, Reserved Copying, ID Management, Counter Check |
| Special Copy Features | ID Card Copy, Shift, Frame Erase, Scan Image Check, Mode Memory, Recall, Sharpness, Secure Watermark, Page Numbering, Copy Set Numbering, Watermark And Date |
Security Features
| Standard S | Department ID Management, Single Sign On-H, Access Management System (Device And Function Level Log-In), Secured Print, Trusted Platform Module, IPv6, Restricting Features (Restricting The Send Function, Restricting New Addresses On Address Book), Send To Myself (Only), SSL Encrypted Communication, SNMPv1/V3, MAC/IP Address Filtering, IEEE 802.1x (Wired/Wireless), SMTP Authentication, POP Authentication Before SMTP, HDD Initialize (Up To 9x) HDD Erase (Up To 3x), HDD Lock, IPsec, Adobe® LiveCycle® Rights Management ES2.5 Integration |
| Optional | HDD Encryption, Encrypted Secure Print, Encrypted PDF, Secure Watermark, IEEE 2600.1 Common Criteria Certification♦♦ |
Dummy Header
| Environmental Features |
| Estimated Toner Yield | (Estimated Yield @ 6% Coverage): 15,200 Images |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
