imageRUNNER ADVANCE 4545i II
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The imageRUNNER ADVANCE 4545i II offers print speeds of 45 ppm in black & white and the ability to scan up to 160 ipm (300 dpi) in black and white or color through a single-pass duplexing document feeder. The imageRUNNER ADVANCE 4545i II model offers several optional finishing features, including staple-free stapling, traditional stapling and hole-punching, and is designed to meet a range of printing needs with an easy-to-operate and customizable user interface.
- Subscription to a third-party cloud service required. Subject to third-party cloud service providers' terms and conditions.
- Requires additional option.
Note: Canon products offer certain security features, yet many variables can impact the security of your devices and data. Canon does not warrant that use of its features will prevent security issues. Nothing herein should be construed as legal or regulatory advice concerning applicable laws; customers must have their own qualified counsel determine the feasibility of a solution as it relates to regulatory and statutory compliance. - Available 2Q 2018.
- For current EPEAT rating (Gold/Silver/Bronze), please visit www.epeat.net.
| Model Name | Imagerunner Advance 4545i Ii |
| Type | Monochrome Laser Multifunctional |
| Functions | Standard: Print, Copy, Scan, Send, Store Optional: Fax |
| Operation Panel | 10.1" Tft Lcd Wsvga Color Touch-Panel |
| Imaging System | Canon Dual Custom Processor (Shared) |
| Image Server Memory | 3.0 Gb Ram |
| Hard Disk Drive | Standard: 250 Gb Maximum: 1 Tb |
| Mirroring Hard Disk Drive | Optional (250 Gb, 1 Tb) Method: Raid1 |
| Network Interface Connection | Standard: 1000base-T/100base-Tx/10base-T, Wireless Lan (Ieee 802.11 B/G/N) |
| Other Interface | Standard: Usb 2.0 X2 (Host), Usb 3.0 X1 (Host), Usb 2.0 X1 (Device) Optional: Serial Interface, Copy Control Interface |
| Available Disk Space | Approx. 16 Gb (Standard Hdd) Approx. 480 Gb (1 Tb Hdd) |
| Advanced Box Features | Disabling Advanced Box, Storage Filtering, Authentication For Advanced Box Log-In, Search Function, Sort Function, Printing A Pdf File With A Password, Imageware Secure Audit Manager Support |
| Standard | Usb |
| Scanning Resolution | 600 X 600 Dpi, 400 X 400 Dpi, 300 X 300 Dpi, 200 X 400 Dpi, 200 X 200 Dpi, 200 X 100 Dpi, 150 X 150 Dpi, 100 X 100dpi |
| Printing Resolution | 1200 Dpi X 1200 Dpi |
| Letter | Up To 45 Ppm (A4 Up To 45 Ppm) |
| Letter R | Up To 32 Ppm |
| Legal | Up To 25 Ppm |
| Ledger | Up To 22 Ppm |
| First Copy Time | (Letter, A4): As Fast As 3.8 Seconds |
| Multiple Copies | Up To 999 Copies |
| Copy Exposure | Automatic Or Manual (9 Levels) |
| Magnification | 25%-400% (1% Increments) |
| Preset Reductions | 25%, 50%, 64%, 73%, 78% |
| Preset Enlargements | 121%, 129%, 200%, 400% |
| Acceptable Originals | Sheet, Book, 3-Dimensional Objects [Up To 4.4 Lb. (2 Kg)] |
| Standard Paper Capacity | (Ltr, A4 20 Lb. Bond): 1,180 Sheets |
| Optional | (Ltr, A4 20 Lb. Bond): Two 550-Sheet Paper Cassettes (Cassette Feeding Unit-An1), 2,450-Sheet Paper Deck (High Capacity Cassette Feeding Unit-B1), 2,700-Sheet Paper Deck (Paper Deck Unit-F1) |
| Manual Bypass | 80-Sheet Stack Bypass |
| Maximum Paper Capacity | (Ltr, A4 20 Lb. Bond): 6,330 Sheets |
| Output Paper Capacity | (Ltr, A4 20 Lb. Bond): Standard: 250 Sheets Maximum: 3,350 Sheets (With External Finishers) |
| Cassettes | Paper Cassette (1): Legal, Letter, A4, Letter-R, Executive, Statement-R, Custom Size (5-1/2" X 7-1/8" To 11-3/4" X 15-3/8") Paper Cassette (2): 11" X 17", Legal, Letter, A4, Letter-R, Executive, Statement-R, Custom Size (5-1/2" X 7-1/8" To 11-3/4" X 15-3/8") |
| Bypass | 11" X 17", Legal, Letter, A4, Letter-R, Executive, Statement-R, Envelope [No.10 (Com10), Monarch, Dl, Iso-C5], Custom Size (3-7/8" X 5-7/8" To 11-3/4" X 17") |
| Cassette | 16 Lb. Bond To 34 Lb. Bond (60 To 128 G/M2) |
| Bypass | 14 Lb. Bond To 80 Lb. Cover (52 To 220 G/M2) |
| Duplexing | 16 Lb. Bond To 28 Lb. Cover (60 To 105 G/M2) |
| Warm Up Time | From Power On: 24 Seconds Or Less From Deep Sleep Mode: 10 Seconds Or Less Quick Startup Mode: 4 Seconds4 |
| Power Requirements | 120-127v Ac, 60 Hz, 9.3a 220-240v, 50/60 Hz, 5.2a |
| Power Consumption | Maximum Approx. 1.5 Kwh Standby: Approx. 38 W Sleep Mode: Approx. 0.9 W Typical Electricity Consumption (Tec) Rating: 2.2 Kwh (120v), 2.3 Kwh (230v) |
| Plug | Nema 5-15p (120v) Cee 7/7 (230v) |
| Dim | 23-1/8" X 29-1/8" X 47" (587 Mm X 740 Mm X 1,193 Mm)5 |
| Installation Space | Basic [With Adf (Stack Bypass And Cassette Drawers Open)]: 35" X 46-1/2" (889 Mm X 1,182 Mm) Fully Configured [With Adf+Paper Deck Unit-F1+ Booklet Finisher-Y1 (Cassette Drawers Open)]: 71-3/8" X 50-3/8" (1,811 Mm X 1,280 Mm) |
| Weight | Approx. 240.7 Lb. (109.2 Kg)6 |
| Basic Copy Features | Preset Reduction/Enlargement Ratios By Area, Paper Setting, Previous Settings, Favorite Settings, Finishing, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel |
| Special Copy Features | Book To Two Pages, Two-Sided Original, Finishing, Booklet, Job Build, N On 1, Add Cover, Insert Sheets, Different Size Originals, Density Adjustment, Original Type Selection, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Secure Watermark, Print Date, Shift, Gutter, Print & Check, Negative/Positive, Repeat Images, Merge Job Blocks, Job Done Notice, Mirror Image, Store In Mail Box, Superimpose Image, Copy Id Card, Detect Feeder Multi Sheet Feed, Free Size Original |
| Toner | Gpr-57 Toner Bk |
| Estimated Toner Yield | (Estimated @ 6% Coverage): 42,100 Copies |
GPR-57 Toner
Estimated Toner Yield: 42,100 Copies/Bottle (Estimated yield at 6% Coverage)
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
