imageRUNNER ADVANCE 4051
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
With outstanding versatility and performance, the imageRUNNER ADVANCE 4051 model meets the needs of workgroup or enterprise office environments. This digital monochrome model rapidly scans, prints, copy, fax and distribute documents with precision and ease. Advanced management tools and multiple in-line finishing options help produce professional documents with ease. The imageRUNNER ADVANCE 4051 model features a range of collaboration tools, streamlined one-step operations for complicated tasks, and the power to perform multiple jobs concurrently.
The imageRUNNER ADVANCE 4051 model delivers output speeds of up to 51 ppm in black and white (letter), and scanning at speeds of up to 51/51 ipm (simplex, 300dpi, BW/Color). Offering standard Color Universal Send, UFR II Printing, and a range of paper handling and finishing options, the imageRUNNER ADVANCE 4051 model is intelligent value at its best.
ADVANCED DESIGN:
- Advanced imageCHIP system architecture uses two processors to deliver outstanding multitasking performance.
- Large embedded control panel provides easier viewing.
- Two menus streamline your workflow. The Main Menu gives you instant access to system functions, while the Quick Menu powers productivity by allowing you to combine and access routine tasks at the touch of a button.
- A universal design that's not only appealing to the eye but also easy and comfortable to operate.
- Soft curves and natural soothing color palette create harmony between innovation and your work environment.
ADVANCED WORKFLOW:
- Rapidly convert paper documents to digital files with the 100-sheet capacity, auto duplex document feeder with color scanning support at speeds of up to 51 ipm (simplex, 300 dpi).
- A choice of modular in-line accessories makes it simple to produce professionally finished documents, including a choice of a staple finisher or booklet finisher, both with 50-sheet multiposition stapling, 2/3 hole punching, and an internal finisher with optional 2/3 hole punching.
- Advanced Box, Canon's new built-in document sharing solution enhances the ability of multiple users to collaborate. Files can be stored in Advanced Box shared folders and accessed from multiple locations including a PC or other networked imageRUNNER ADVANCE systems.
- Whether from the imageRUNNER ADVANCE model or at your own desk, you can have direct access to the functions that make your work easier with the imageRUNNER ADVANCE Desktop utility.
- The Workflow Composer utility reduces multi-step and frequently performed operations to the touch of one button that can be placed on the Quick Menu.
- Universal Send provides an expanded range of file formats including High Compression PDF/XPS, Adobe PDF Reader Extensions, Searchable PDF and Encrypted PDF.
- Transform the way you access files with Canon Cloud Portal for imageRUNNER ADVANCE. Connect directly to Microsoft SharePoint Online or Google Docs cloud services without the need for extra hardware or software.
- Canon's UFR II print technology is standard with this model, optional Adobe PostScript 3 and PCL 5e/6 are also supported.
- Scan to or print from a USB thumb drive or optional memory media.
- Enter data more comfortably with the optional USB keyboard.
ADVANCED CONTROL:
- Canon offers a number of security features for document security, data security, mail server security, logging/auditing security and authentication.
- Access Management System allows you to limit device access by user, group or role and you can even limit access for only specific functions such as Send.
- With Document Scan Lock and Tracking you can embed hidden tracking information in a document to restrict unauthorized copying or scanning and to track the origin.
- Adobe LiveCycle Rights Management ES 2.5 Integration protects access to documents throughout their duration. After documents are scanned, specify security policies and select authorized recipients.
- The Trusted Platform Module allows you to safeguard vulnerable settings such as passwords with a new security chip featuring tamper-resistant hardware.
- Disguise information before it's written to the hard drive, and permanently remove it by overwriting when the job is complete with data encryption and erase options.
- The Remote User Interface gives you centralized control for any individual device right from your desktop, so that you can check supply levels, monitor jobs and stay completely informed.
- The imageWARE Enterprise Management Console offers one central point of control for all systems across your organization. This web-based utility makes it easy to install and manage multiple Canon and third-party networked devices.
- The imageRUNNER ADVANCE Series makes it easier to track, manage and influence user behavior. From analyzing color output by employee or client to encouraging double sided printing, you can ensure that resources are employed optimally and costs are allocated accurately.
ADVANCED PERFORMANCE:
- Reduce costs and increase performance with the ability to streamline your workflow.
- Outstanding image quality for striking results.
- Retrieve information from other imageRUNNER ADVANCE models on the network to help eliminate extra hardware or to easily collaborate.
- Reduce downtime with the ability to replace toner on the fly.
- If incorrect paper size or stack for a job is unavailable, the system can begin the next job without delay.
- New level of connector and link support through Canon's innovative MEAP platform.
- With 1200 x 1200 dpi print resolution produces fine lines and crisp text, even at small font sizes.
- Innovative technologies, including Canon's QF toner, produces clear, detailed images with a smooth, high-quality finish.
ADVANCED RESPONSIBILITY:
- Canon's life cycle assessment system helps to reduce C02 emissions by focusing on each stage of the product life cycle, including manufacturing, energy use, and logistics.
- Compact with less packaging for efficient transportation.
- Designed with recycled plastic and bio-based plastic for certain components.
- Meets Energy Star standards.
- The combination of Canon's fusing technologies and QF toner helps reduce overall energy consumption by minimizing heat and power requirements.
- Power consumption for sleep mode is 1W or less.
- Meets and exceeds ROHS directive.
| Model Name | ImageRUNNER ADVANCE 4051 |
| Type | Digital Multifunction Imaging SystemFunctions: Standard: Copy, Print (UFR II), Scan, Send, Store Optional: Print (PCL, Adobe® PostScript® 3™), Fax (Up To 4 Lines)Operation Panel: 8.4" SVGA Full-Color, TFT ScreenScan Specifications Network TWAIN Scan: Standard Network Scan Utility: Color Network ScanGear |
| Image Server Memory | Standard: 1.25GB RAM Maximum: 1.75GB RAMHard Disk Drive: Standard: 80GB Maximum: 250GBMirroring Hard Disk Drive: Optional (80GB, 250GB); Method: RAID1Network Interface Connection: Standard: 10/100/1000Base-TX Other Interface: Standard: USB 2.0 (Host)X2, USB 2.0 (Device) Optional: Device Port [USB 2.0 (Host)X2], Copy Control Interface |
| Max Mailboxes Supported | 100 User Inboxes, 1 Memory RX Inbox, 50 Confidential Fax InboxesMaximum Pages Stored: 6,000Advanced Box Available Disk Space: Approximately 10GB (Standard HDD) / 113GB (250GB HDD) Communication Protocol: SMB Or WebDAV Supported Client PC: Windows (Windows 2000/XP/7/Windows Vista) Maximum Number Of Concurrent Connections: SMB: 32 / WebDAV: 12 (Active Sessions) Advanced Box Features: Disabling Advanced Box, Storage Filtering, Authentication For Advanced Box Log-In, Search Function, Sort Function, Printing A PDF File With A Password, ImageWARE Secure Audit Manager SupportMemory Media Standard: USB Memory Optional: SD, SDHC, CompactFlash®, Memory Stick, Microdrive |
| Letter | Up To 51 Ppm |
| Legal | Up To 25 Ppm |
| Ledger | Up To 25 Ppm |
| First Copy Time | (Letter): 3.7 Seconds |
| Multiple Copies | 1 To 999 |
| Magnification | From Platen Glass: 25% - 400% (1% Increments) From ADF: 25% - 200% (1% Increments) |
| Preset Reductions | 25%, 50%, 64%, 73%, 78% |
| Preset Enlargements | 121%, 129%, 200%, 400%Basic Copy Features Preset R/E Ratios By Area, Finishing, Two-Sided, Density/Exposure Adjustment, Original Type Selection, Interrupt Mode, Sample Set, Setting Confirmation/ Cancel, Standard Keys, Reset, Guide Display, Job Duration Display, Reserved CopyingSpecial Copy Features: Two-Page Separation, Booklet, Job Build, N On 1, Add Cover, Sheet Insertion, Different-Size Original, Transparency Cover Sheets, Page Numbering, Copy Set Numbering, Sharpness, Erase Frame, Watermark, Print Date, Shift, Gutter, Print & Check, Negative/Positive, Repeat Images, Merge Job Block, Job Done Notice, Mirror Image, Store In Mail Box, Superimpose Image, Favorite Setting, Previous Settings, Secure Watermark (Optional) |
| Maximum Original Size | Up To 11" X 17" (279mm X 431mm) |
| Standard Paper Capacity | (20 Lb. Bond): Dual 550-Sheet Cassettes 80-Sheet Stack Bypass Optional: Dual 550-Sheet Cassettes 2,700-Sheet Paper Deck Maximum: 4,980 Sheets |
| Maximum Paper Capacity | (20 Lb. Bond): 3,100 Sheets (With Staple Finisher Or Booklet Finisher) Standard: 250 Sheets (Inner Tray) |
| Cassette | Cassette 1: Legal, Letter, Letter-R, Statement-R, Executive Cassettes 2/3/4: 11" X 17", Legal, Letter, Letter-R, Statement-R, Executive, Custom Size [5-1/2" X 7-1/8" To 11-3/4" X 17" (140mm X 182mm To 297mm X 431mm)] |
| Bypass | 11" X 17", Legal, Letter, Letter-R, Statement-R, Executive, Custom Size [3-7/8" X 5-7/8" To 11-3/4" X 17" (99mm X 148mm To 297mm X 431mm)]Other Option: Envelope Feeder Attachment*** (COM10 No. 10, Monarch, DL, ISO-C5, ISO-B5) |
| Cassette | 16 Lb. Bond To 34 Lb. Bond |
| Bypass | 14 Lb. Bond To 80 Lb. Cover |
| Duplexing | Paper Size: Standard Automatic Trayless Duplexing (Up To 11" X 17") Paper Weights: 14 Lb. Bond To 28 Lb. Bond (52 To 105g/M2) |
| Warm Up Time | From Power On: 38 Seconds Or Less From Sleep Mode: 10 Seconds Or Less |
| Exposure Control | Automatic Or Manual (9 Levels) |
| Power Requirements | 120V AC 60Hz 10.4A ; 230V AC 50 Hz 5.6A / NEMA 5-15P ; CEE7 Standard Sheet VIIPower Consumption: Maximum: 1,500W; Sleep Mode: 1W |
| Dim | 35-1/2" X 22-1/4" X 27-7/8" (909mm X 565mm X 708mm) Installation Space (W X D) (When The Multi-Purpose Tray Is Extended) 35-1/2" X 27-7/8" (909mm X 708mm) |
| Weight | Approximately 172 Lb. (77.9kg)〉Image Reader Unit Scan Resolution Up To 600 X 600 Dpi〉〉 Acceptable Originals: (Glass) Sheet, Book, 3-Dimensional Objects Maximum Original Size: Up To 11" X 17" (279mm X 431mm)" Security Features Standard: Department ID Management, Single Sign-On H, Access Management System*** (Device And Function Level Log-In), Secure Print, Trusted Platform Module, User Access Control Of Advanced Box, Mail Box Password Protection, IPV6, Restricting Features (Restricting The Send Function, Restricting New Addresses On Address Book), SSL Encrypted Communication, SNMP V1/V3, MAC/IP Address Filtering, SMTP Authentication, POP Authentication Before SMTP, HDD Format, IPSec, Adobe® LiveCycle® Rights Management ES2.5 Integration Optional: Removable HDD, HDD Erase, HDD Encryption, HDD Mirroring, Encrypted Secure Print, Encrypted PDF, Document Scan Lock,Δ Secure Watermark, IEEE 2600.1 Common Criteria Certification†Environmental Information
| Estimated Toner Yield | (Estimated Toner Yield @ 6% Coverage): 34,200 Images |
| Description | Document Feeder (Optional) |
| Acceptable Originals | 11" X 17", Legal, Letter, Letter-R, StatementScan Method: Duplexing Automatic Document Feeder |
| Scanning Speed | (BW/Color; Letter): Simplex: 51/51 Ipm (300 Dpi) 51/30 Ipm (600 Dpi)〉〉 |
| Capacity | (20 Lb. Bond): 100 Sheets |
| Paper Weights | BW: 13 Lb. Bond To 34 Lb. Bond(50 To 128g/M²) Color: 17 Lb. Bond To 34 Lb. Bond (64 To 128g/M²) |
| Description | Cassette Feeding Unit-AF1 |
| Paper Capacity | 550 Sheets X 2 Cassettes |
| Paper Sizes | 11" X 17", Legal, Letter, Letter-R, Statement-R, Executive, And Custom Size [5-1/2" X 7-1/8" To 11-3/4" X 17" (140mm X 182mm To 297mm X 431mm)] |
| Paper Weights | 16 Lb. Bond To 34 Lb. Bond (60 To 128g/M2) |
| Power Source | From Main Unit Power Consumption: Approximately 30W (Maximum) |
| Dimensions | 9-3/4" X 22-1/4" X 25-5/8" (248mm X 565mm X 650mm)" |
| Weights | Approximately 61 Lb. (27.5kg) |
| Description | Paper Deck Unit-B2 |
| Number Of Cassettes | 1 |
| Paper Capacity | 2,700 Sheets |
| Paper Sizes | Letter |
| Power Source | From Main UnitPower Consumption: Approximately 35W (Maximum) |
| Dimensions | 22-1/2" X 23-5/8" X 24-1/2" (570mm X 601mm X 621mm) |
| Weights | Approximately 81.6 Lb. (37kg) |
| Description | Envelope Feeder Attachment-D1*** |
| Paper Capacity | 50 Sheets (Or 30mm In Height) |
| Paper Sizes | COM10 No.10, Monarch, DL, ISO-C5, ISO-B5Feeding Speed: 10 Cpm |
| Dimensions | 3-1/4" X 17-1/4" X 12-1/8" (81mm X 439mm X 307mm) |
| Weights | Approx. 2.6 Lb. (1.2kg) |
| Description | Inner 2-Way Tray-H1†† |
| Paper Weights | 14 Lb. Bond To 80 Lb. Cover (52 To 220g/M2) |
| Paper Size | 11" X 17", Legal, Letter, Letter-R, Statement-R, Executive, Custom Size [3-7/8" X 5-1/2" To 11-3/4" X 17" (99mm X 144mm To 297mm X 431mm)], And Envelopes |
| Number Of Trays | 2 |
| Top Tray | 250 Sheets (20 Lb. Bond) |
| Lower Tray | 100 Sheets (20 Lb. Bond) |
| Dimensions | 3" X 16-3/4" X 16" (76mm X 427mm X 407mm) |
| Weight | Approximately 1 Lb. (574g) |
| Description | Inner Finisher-D1 |
| Paper Size | 11" X 17", Legal, Letter, Letter-R, Statement-R, Executive, And Envelopes |
| Number Of Trays | Up To 2 Trays (With Inner Finisher Additional Tray-A1)Total Output Capacity: Without Inner Finisher Additional Tray-A1: 1,000 Sheets With Inner Finisher Additional Tray-A1: Top Tray: 100 Sheets (Letter) Lower Tray: 500 Sheets (Letter) |
| Lower Tray | 500 Sheets (Letter) |
| Staple Capacity | Letter, Executive: 50 Sheets (14 Lb. Bond To 22 Lb. Bond) 30 Sheets (23 Lb. Bond To 28 Lb. Bond) 2 Sheets (29 Lb. Bond To 80 Lb. Cover) 11" X 17", Legal And Letter-R: 30 Sheets (14 Lb. Bond To 22 Lb. Bond) 20 Sheets (23 Lb. Bond To 28 Lb. Bond) 2 Sheets (29 Lb. Bond To 80 Lb. Cover) |
| Staple Positions | Corner/Double Stapling: 11" X 17", Legal, Letter, Letter-R, Executive |
| Stapling Capacity | Upper Tray: 15 Sets (Or 3/8" Height) Lower Tray: 30 Sets (Or 4-7/8" Height)Type Of Staple: Staple-J1 (5,000 X 3) |
| Power Source | From Main UnitPower Consumption: Approximately 49W (Maximum) |
| Dimensions | 11-5/8" X 27-1/2" X 21-7/8" (295mm X 697mm 554mm) (When The Auxiliary Tray Is Extended) |
| Weight | Approximately 29.7 Lb. (13.5kg) (When The Optional Inner Finisher Additional Tray-A1 Is Attached) |
| Description | Staple Finisher-G1 |
| Paper Size | 11" X 17", Legal, Letter, Letter-R, Executive, Statement-R |
| Number Of Trays | 2Total Output Capacity: 3,000 Sheets (Letter, Statement-R, Executive)Top Tray: 1,300 Sheets (Letter, Executive) 650 Sheets (11" X 17", Legal, Letter-R, Statement-R)Lower Tray: 1,700 Sheets (Letter, Executive) 650 Sheets (11" X 17", Legal, Letter-R, Statement-R) |
| Top Tray | 1,300 Sheets (Letter, Executive) 650 Sheets (11" X 17", Legal, Letter-R, Statement-R) |
| Lower Tray | 1,700 Sheets (Letter, Executive) 650 Sheets (11" X 17", Legal, Letter-R, Statement-R) |
| Staple Capacity | Letter, Executive: 50 Sheets 11" X 17", Legal, Letter-R: 30 Sheets |
| Stapling Capacity | Top Tray: 1,300 Sheets/30 Sets (Letter, Executive) 650 Sheets/30 Sets (11" X 17", Legal, Letter-R) Lower Tray: 1,700 Sheets/30 Sets (Letter, Executive) 650 Sheets/30 Sets (11" X 17", Legal, Letter-R)Type Of Staple: Staple-J1 (5,000 X 3) |
| Power Source | From Main UnitPower Consumption: Approximately 85W (Maximum) |
| Dimensions | 43-1/4" X 25-1/2" X 25-1/2" (1097mm X 648mm X 648mm) (When The Auxiliary Tray Is Extended) |
| Weight | Approximately 101 Lb. (46kg) |
| Description | Booklet Finisher-G1 |
| Number Of Trays | 2Total Output Capacity: 3,000 Sheets (Letter, Statement-R, Executive)Top Tray: 1,300 Sheets (Letter, Statement-R, Executive) 650 Sheets (11" X 17", Legal, Letter-R)Lower Tray: 1,700 Sheets (Letter, Statement-R, Executive) 650 Sheets (11" X 17", Legal, Letter-R) |
| Saddle Stitch Tray | 16 Sheets (16 Lb. Bond To 22 Lb. Bond) (11" X 17", Legal, Letter-R) 10 Sheets (22 Lb. Bond To 28 Lb. Bond) (11" X 17", Legal, Letter-R)Paper Capacity Of Saddle-Stitch Mode: 25 Booklets (5-Sheet Booklets) |
| Staple Capacity | Letter And Executive: 50 Sheets (14 Lb. Bond To 22 Lb. Bond / 30 Sheets (23 Lb. Bond To 28 Lb. Bond / 2 Sheets (29 Lb. Bond To 80 Lb. Cover) 11" X 17", Legal And Letter-R: 30 Sheets (14 Lb. Bond To 22 Lb. Bond) / 20 Sheets (23 Lb. Bond To 28 Lb. Bond) / 2 Sheets (29 Lb. Bond To 80 Lb. Cover) |
| Staple Positions | Corner/Double Stapling: 11" X 17", Legal, Letter, Letter-R, Executive Saddle-Stitch: 11" X 17", Legal, Letter-R |
| Stapling Capacity | Top Tray: 1,300 Sheets/30 Sets (Letter, Executive) 650 Sheets/30 Sets (11" X 17", Legal, Letter-R) Lower Tray: 1,700 Sheets/30 Sets (Letter, Executive) 650 Sheets/30 Sets (11" X 17", Legal, Letter-R)Type Of Staple: Staple-J1 (5,000 X 3) Staple Cartridge-D1 (2,000 X 3) |
| Power Source | From Main UnitPower Consumption: Approximately 113W (Maximum) |
| Dimensions | 43-1/4" X 30-1/8" X 25-1/2" (1097mm X 766mm X 646mm) (When The Auxiliary Tray Is Extended) |
| Weight | Approximately 165 Lb. (75kg)Inner 2/3-Hole Puncher-A1* Acceptable Punch Paper Weight: 14 Lb. Bond To 80 Lb.Cover Acceptable Punch Paper Size: 11" X 17", Legal, Letter, Letter-R Punch Type: 2 Holes: Legal, Letter-R 3 Holes: 11" X 17", Letter Distance Between Punch Holes: 2 Holes: 2-3/4" (70mm) 3 Holes: 4-1/4" (108mm) Punch Waste Tray Capacity: Approximately 1,500 Sheets (21 Lb. Bond) Power Source: From Main Unit Power Consumption: Approximately 37W (Maximum) Dimensions (H X W X D): 8-1/2" X 5-5/8" X 20-7/8" (216mm X 144mm X 531mm) Weight: Approximately 15.2 Lb. (6.9kg) External 2/3-Hole Puncher-B2ºº Acceptable Punch Paper Weight: 14 Lb. Bond To 80 Lb.Cover Acceptable Punch Paper Size: 11" X 17", Legal, Letter, Letter-R Punch Type: 2 Holes: Legal, Letter-R 3 Holes: 11" X 17", Letter Distance Between Punch Holes: 2 Holes: 2-3/4" (70mm) 3 Holes: 4-1/4" (108mm) Punch Waste Tray Capacity: Approximately 3,000 Sheets (21 Lb. Bond) Power Source: From The Main Unit Dimensions (H X W X D): 35-3/4" X 4-1/4" X 24-1/2" (908mm X 107mm X 623mm) Weight: Approximately 15.9 Lb. (7.2kg) |
| Description | Fax Board |
| Applicable Line | 4 |
| Modem Speed | Super G3: 33.6 Kbps G3: 14.4 Kbps |
| Data Compression | MH, MR, MMR, JBIGResolution (Dpi): 400 X 400, 200 X 400, 200 X 200, 200 X 100Sending/Recording Size: Statement To 11" X 17"Fax Features: Job Forwarding, Different-Size Originals, Adjusting Overall Density For Scanning, Sharpness, Copy Ratio, Erase Frame, Job Build, Specifying The Sender's Name (When Sending Fax), Selecting The Telephone Line (When Sending Fax), Delayed Send, Preview, Finished Stamp, Job Done Notice, Original Type Selection, Two-Sided Original, Book To Two Pages |
| Description | Canon Dual Custom Processor (Shared) |
| Standard Memory | 1.25GB RAM |
| Maximum Memory | 1.75GB RAM |
| Hard Disk | Standard: 80GB Maximum: 250GBEngine Resolution: 1200 X 1200 Dpi |
| Pdl Support | Standard: UFR II Optional: PCL 5e, PCL 6, Adobe PostScript 3 |
| Print Controller Technology | UFR II, PostScript3: Windows® (XP/Windows Vista®/Windows 7/Server 2003/Server 2008/Server 2008 R2, Small Business Server 2011), Windows Terminal Servers (Windows 2000/ Server 2003/Server 2008/Server 2008 R2), Microsoft® Failover Cluster (Windows 2000 Server/Server 2003/ Server 2003 R2/Server 2008/Server 2008 R2), Small Business Server 2011, Citrix (Presentation Server 4.5, XenApp 5.0/6.0, XenDesktop 2.0/2.1/3.0/4.0/5.0), Macintosh® (OS X 10.4.9 Or Later), VMware (VSphere 4), SAP (UFR II Only) PCL 5e/6: Windows (Windows 2000/XP/ Windows Vista/Windows 7/Server 2003/Server 2008/Server 2008 R2, Small Business Server 2011), Windows Terminal Servers (Windows 2000/Server 2003/Server 2008/ Server 2008 R2), Small Business Server 2011, Microsoft® Failover Cluster (Windows 2000 Server/ Server 2003/Server 2003 R2/ Server 2008/Server 2008 R2), Citrix (Presentation Server 4.5, XenApp 5.0/6.0, XenDesktop 2.0/2.1/3.0/4.0/5.0), VMware (VSphere 4), SAPDirect Print Support Standard: TIFF, JPEG, EPS〉〉〉 Optional: PDF, XPS〉〉〉 |
| Other Features | Suspend Job Timeout, Subset Finishing (PS Only), Profile Settings, Secure Print, Watermark, Page Border, Header/Footer, Page Layout, Two-Sided Printing, Collating, Booklet Printing, Grouping, Mixed Paper Sizes/ Orientations, Printing On Transparencies, Front/Back Covers, Objective, Toner Reduction, Poster Printing |
| Sending Method | E-Mail, I-Fax, File Server (FTP, SMB, WebDAV), Mail Box, Super G3 Fax (Optional)Color Mode: Auto Color Select (Color, Gray), Auto Color Select (Color, Black), Full Color, Grayscale, B/WScan Resolution:〉〉 (Dpi) 600 X 600, 400 X 400, 300 X 300, 200 X 400, 200 X 200, 200 X 100, 150 X 150, 100 X 100 |
| Address Book Capacity | Max. 1,800 Destinations (Incl. 200 One-Touch Buttons) |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
