imageRUNNER 2630
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Productivity
- Fast print outputs and first copy out time (FCOT)
- Customisation of on-screen applications increases workflow efficiency
- Scan and convert documents to searchable PDF, Microsoft Word or Power Point files
- Print Hold function for a convenient final adjustment of print setting before job release
- Smart media handling enables up to 30 paper types registration and automated size detection
- Space saving optional inner finisher with staple-free binding and integrated manual stapling
Security
- Verify system at start-up enables preventative security measures to protect device from unauthorised modifications
- Advanced device and cloud-based authentication options
- Central control of security settings reduces administrator burden
- Encrypted PDF, plus device and optional user signature PDF provide additional authentication security levels
- Secure PIN and Forced Hold Print enhance document confidentialit
- Further actions to counter malware attack on the network include third party SIEM system integration
- Ensure data privacy across your network with IPsec and port filtering
Control and Maintenance
- Centrally manage all devices on the network with cloud-based remote management options
- Remote Operators Software Kit provides alternative access to device, simulating control panel and hard keys on a network PC screen for remote operation of all system functions
- Compatibility with Canon’s uniFLOW software solutions allows for tracking and reporting of print jobs
- e-Maintenance can improve uptime through remote diagnostics, automated meter readings and consumables monitoring
User Experience
- Intuitive operation via a large colour touchscreen with smartphone like usability
- Advanced personalisation and customisation options tailored for user’s workflow needs
- Integrated Home UI enables choice of frequently used settings from a single men
- Innovative production processes, including welded frame, ensure lasting machine longevity and reliability
- Easy replacement of toner cartridge featuring anti-spill technology
- Compact design allows for a convenient office arrangement
Mobile Connectivity
- Wireless LAN and QR code connection options for working from tablets and smartphones
- Mobile compatible remote UI with optimised display layout allows users to change the settings of print jobs on the go
- Support for Mopria, Apple Air Print, Google Cloud Print and Windows 10 Print
- Canon’s PRINT Business app adds further functions to printing and scanning from mobile devices
- Status of the machine and consumables can be read from the connected mobile devices
| Model Name | ImageRUNNER 2630 |
| Type | A3 Monochrome Laser Multifunctional |
| Functions | Standard: Print, Copy, Scan, Send Optional: Fax |
| Operation Panel | Standard: 17.8 Cm/7 TFT LCD WSVGA Colour Touch Panel |
| Image Server Memory | 2.0GB RAM |
| Network Interface Connection | Standard: 1000Base-T/100Base-TX/10Base-T, Wireless LAN (IEEE 802.11 B/G/N) |
| Other Interface | Standard:USB 2.0 (Host) X3, USB 2.0 (Device) X1 |
| Standard | Standard: USB |
| Network Twain Scan | TWAIN/WIA Pull Scanning Available Send Functionality Available On All Models Scan To USB Memory Key: Available On All Models |
| Network Scan Utility | Scan To Mobile Devices And Cloud-Based Services: A Range Of Solutions Is Available To Provide Scanning To Mobile Devices Or Cloud-Based Services Depending On Your Requirements. |
| Scanning Resolution | Copy: 600 X 600 Send: (Push) Up To 600 X 600, (Pull) Up To 600 X 600 Fax: Up To 600 X 600 |
| Printing Resolution | Up To 1200 Dpi X 1200 Dpi |
| Letter | Up To 30 Ppm |
| Letter R | Up To 21 Ppm |
| Legal | Up To 15 Ppm |
| First Copy Time | Approx. 5.9 Seconds Or Less |
| Multiple Copies | Up To 9,999 Copies |
| Copy Exposure | Automatic Or Manual (9 Levels) |
| Magnification | 25%-400% (1% Increments) |
| Preset Reductions | 25%, 50%, 61%, 70%, 81%, 86% |
| Preset Enlargements | 115%, 122%, 141%, 200%, 400% |
| Standard Paper Capacity | 1,200 Sheets (A4, 80gsm) |
| Maximum Paper Capacity | 2,300 Sheets (With Cassette Feeding Unit-AN1) |
| Output Paper Capacity | Standard: 250 Sheets Maximum: 545 Sheets (With Inner Finisher-J1) |
| Cassettes | Upper Cassette 1: Standard Size: A4, A4R, A5R, B4, B5, B5R Custom Size: Min. 139.7 X 182.0 Mm Up To 297.0 X 390.0 Mm Lower Cassette 2: |
| Bypass | Standard Size: A3, A4, A4R, A5, A5R, A6R, B4, B5, B5R, Envelopes [No. 10(COM 10), Monarch, ISO-C5, DL] Custom Size/Free Size: Min. 98.0 X 148.0 To 297.0 X 431.8 Mm |
| Cassette | 60 To 128 Gsm |
| Bypass | 52 To 220 Gsm (Thin: Vertical Grain Paper Feed Only: 52 To 59 Gsm) |
| Duplexing | 60 To 105 Gsm |
| Warm Up Time | 12 Seconds Or Less* *Time From Device Power-On Until Copy Ready (Not Print Reservation) From Sleep Mode: 10 Seconds Or Less 4 Seconds Or Less* *Time From Device Power-On To When Key Operations Can Be Performed On The Touch Panel Display. |
| Power Requirements | 110-120V, 60Hz, 7.0A 220-240V, 50/60 Hz , 5.2 A |
| Power Consumption | Maximum: Approx. 1500W Standby: Approx. 20W Sleep Mode: Approx. 0.6 W Plugin Off: Approx. 0.09W Typical Electricity Consumption (TEC)*: 1.5 KWh *As Per US ENERGY STAR® Version 2.0 |
| Plug | NEMA 5-15P (120V) CEE7/7 (230V) |
| Dim | 586 X 713 X 910 Mm |
| Installation Space | 1363 X 1273 Mm* *With Cassette Open + 100 Mm Gap Around The Main Body |
| Weight | Approx. 73.6 Kg Without Toner |
| Basic Copy Features | Preset R/E Ratios By Area, Paper Setting, Previous Setting, Favourite Setting, Two-Sided, Density Adjustment, Original Type Selection, Interrupt Mode, Setting Confirmation/Cancel |
| Special Copy Features | Book To Two Pages, Two-Sided Original, Finishing, Booklet, Job Build, N On 1, Different Size Originals, Density Adjustment, Original Type Selection, Sharpness, Erase Frame, Shift, Gutter, Job Done Notice, Copy ID Card, Free Size Original |
| Standard S | Authentication: Universal Login Manager (Device And Function Level Log-In), UniFLOW Online Express*, User Authentication, Department ID Authentication, Access Management System Network: IP/Mac Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication Before SMTP, S/ MIME Document: Secure Print, Encrypted PDF, Encrypted Secure Print, Device Signature |
| Optional | Authentication: My Print Anywhere Secure Print (Requires UniFLOW), Picture Login Data: Data Loss Prevention (Requires UniFLOW) Document: User Signature |
| Environmental Features | Operating Environment Temperature: 10 To 30 ºC (50 To 86 ºF) Humidity: 20 To 80 % RH (Relative Humidity) |
| Toner | GPR-62 Toner Black |
| Estimated Toner Yield | 30,000 A4 Impressions (Estimated Yield @ 6% Coverage) |
| Description | Standard Document Feeder |
| Acceptable Originals | Platen: Sheet, Book (Height: Up To 40mm) Document Feeder Media Weight : 1-Sided Scanning: 38 To 128 Gsm (BW/CL)* 2-Sided Scanning: 38 To 128 Gsm (BW/CL)* * Only 1-Sheet Feeding Is Supported In 38-52 And 105-128 Gsm. (Feeding Is Guaranteed But Geometric Distortion Correction Is Not Guaranteed) |
| Scanning Speed | 1-Sided Scanning: 35/25 (300 Dpi), 25 (BW; 600 Dpi) 2-Sided Scanning:12/8 (300 Dpi), 8 (BW; 600 Dpi) |
| Capacity | 50 Sheets |
| Applicable Line | 1 |
| Modem Speed | Super G3: 33.6 Kbps G3: 14.4 Kbps |
| Data Compression | MH, MR, MMR, JBIG |
| Resolution | 400 X 400 Dpi, 200 X 400 Dpi, 200 X 200 Dpi, 200 X 100 Dpi |
| Scanning Recording Size | A3, A4, A4R, A5*1, A5R*1, B4, B5*2, B5R*1 *1 Sent As A4 *2 Sent As B4 |
| Memory | Up To 30,000 Pages |
| Memory Backup | Yes |
| One Touch Speed Dialing Locations | Max. 200 Dials |
| Coded Speed Dialing Locations | Max. 199 Dials Sequential Broadcast: Max. 256 Addresses |
| Fax Features | Original Type Selection, Two-Sided Original, Book To Two Pages, Different-Size Originals, Density (For Scanning), Sharpness, Erase Frame, Job Build, Sender's Name (TTI), Direct Send, Delayed Send, Preview, Finished Stamp, Job Done Notice, TX Report |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
