| Model Name
ImageRUNNER 2422L |
| Type
Monochrome Digital Multifunction Imaging System Functions Standard: Copy, Print (UFR II LT), Scan Operation Panel: 5-Line Display |
| Image Server Memory
Standard: 64MB RAM
Network Interface Connection(Optional) Ethernet 10/100Base-TX Other Interface Standard: USB 2.0 (Host)X1, USB 2.0 (Device)X1
| Letter
Up To 22 Ppm |
| First Copy Time
7.9 Seconds Or Less (Letter) ) |
| Multiple Copies
1 To 99 Copy Exposure Automatic Or Manual (9 Levels) |
| Magnification
25% - 400% (1% Increments) |
| Standard Paper Capacity
250-Sheet Paper Cassette 80 Sheet Stack Bypass Tray Optional: 3 X 250-Sheet Cassettes |
| Maximum Paper Capacity
1,080 Sheets Output Paper Capacity (20 Lb. Bond): Standard: 250 Sheets (Inner Tray)
| Cassette
Cassette: 11" X 17", Legal, Letter, Letter-R, Statement-R, Executive, Envelopes (COM10 No.10/Monarch/DL/ISO-B5/ISO-C5)
| Bypass
11" X 17", Legal, Letter, Letter-R, Statement-R, Executive, Envelopes, Custom Size |
| Cassette
17 Lb. Bond To 24 Lb. Bond (64g/M² To 90g/M²) |
| Bypass
17 Lb. Bond To 34 Lb. Bond (64g/M² To 128g/M²) |
| Warm Up Time
From Power On: 13 Seconds Or Less From Sleep Mode: 1 Second Or Less |
| Power Requirements
120 V AC, 50/60 Hz ; 220 - 240 V AC, 50/60 Hz PlugPower Consumption Maximum: Approx. 1.373 KW (230V) / 1.406kW (120V); Sleep Mode: 4.5 W Or Less |
| Dim
622 Mm X 638 Mm X 580.4 Mm (One Drawer With A Platen Cover Attached) 622 Mm X 676 Mm X 672 Mm (One Drawer With A Feeder Attached) Installation Space (W X D) 1,247 Mm* × 1,249 Mm (The Optional Finisher-U2 And Document Tray-J1 Attached.) * The Width Is 1,018 Mm When No Options Are Attached. |
| Weight
Approximately 37.9 Kg (One Drawer With A Platen Cover Attached) Approximately . 43.9 Kg (One Drawer With A Feeder Attached) |
| Estimated Toner Yield
8,300 Sheets Equivalent (A4, 6% Coverage) |
| Estimated Drum Yield
55,000 Sheets |
| Description
DADF-P2 |
| Acceptable Originals
LTR, 11" X 17", STMT, LTRR, STMTR, LGL
| Capacity
50 Sheets (80 G/M²) |
| Paper Weights
Original: 52 G/M² To 105 G/M² |
| Description
Cassette Feeding Unit-S1 |
| Paper Capacity
250 Sheets X 1 Drawer (80 G/M²) |
| Paper Sizes
LTR, 11" X 17", STMT, LTRR, STMTR, LGL |
| Description
Cassette Feeding Unit-T1 * |
| Paper Capacity
250 Sheets X 2 Drawers (80 G/M²) |
| Paper Sizes
| Description
Finisher-U2 * |
| Paper Weights
64 G/M² To 128 G/M² |
| Paper Size
LTR, LTRR, 11" X 17", LGL |
| Sort Mode
Stacking Capacity: 770 Sheets |
| Staple Capacity
50 Sheets (Corner Staple Only) |
| Description
Inner 2 Way Tray-E2 |
| Top Tray
Capacity Tray A LTR: 100 Sheets (80 G/M²) Other Sizes: 50 Sheets (80 G/M²) |
| Lower Tray
Capacity Tray B LTR: 250 Sheets (80 G/M²) Other Sizes: 100 Sheets (80 G/M²) |
