imageRUNNER 2202N
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Operating at speeds of up to 22-pages-per-minute (LTR), the imageRUNNER 2202N device provides digital copying and printing functions with network capability as standard.
This compact device is suitable for small businesses and workgroups with limited office space. The high yielding supplies and consumables help to keep costs to a minimum making it ideal as a productive solution with low cost of ownership.
Up to 22ppm, 7.9 seconds first copy out time
Up to 580 sheet maximum paper capacity
User-friendly interface with 5-line LCD
Compact design
Configurable to suit your requirements
Energy efficient
| Model Name | ImageRUNNER 2202N |
| Type | Monochrome Digital Multifunction Imaging System Functions Standard: Copy, Print (UFR II LT), Color Scan (Standard Network And USB) Operation Panel: 5-Line Display |
| Image Server Memory | Standard: 128MB RAM Network Interface Connection Ethernet 10/100Base-TX Other Interface Standard: USB 2.0 (Device)X1 |
| Letter | Up To 22 Ppm |
| First Copy Time | 7.9 Seconds Or Less (Letter) |
| Multiple Copies | 1 To 99 |
| Magnification | 25% - 400% (1% Increments) |
| Standard Paper Capacity | 250-Sheet Paper Cassette 80 Sheet Stack Bypass Tray Optional: 1 X 250-Sheet Cassette |
| Maximum Paper Capacity | 580 Sheets Output Paper Capacity (20 Lb. Bond): |
| Cassette | Standard: A3, B4, A4, B5, Ledger, Legal, Letter, Executive, Statement |
| Bypass | A3, B4, A4, B5, A5, Ledger, Legal, Letter, Executive, Statement, Envelopes, Custom Size |
| Cassette | 17 Lb. Bond To 24 Lb. Bond (64g/M² To 90g/M²) |
| Bypass | 17 Lb. Bond To 34 Lb. Bond (64g/M² To 128g/M²) |
| Warm Up Time | From Power On: 13 Seconds Or Less From Sleep Mode: 7.9 Seconds Or Less |
| Power Requirements | 120 V AC, 50/60 Hz ; 220 - 240 V AC, 50/60 Hz Power Consumption Maximum: Approx. 1.5kW; Sleep Mode: 2.0 W Or Less |
| Dim | 622 X 589 X 607 Mm (With DADF-AM1) Installation Space (W X D) 921 Mm X 1010 Mm |
| Weight | Approx. 29.7 Kg |
| Estimated Toner Yield | Approx. 10,200 Sheets Equivalent |
| Estimated Drum Yield | 66,000 Sheets |
| Description | DADF-P2 |
| Acceptable Originals | LTR, 11" X 17", STMT, LTRR, STMTR, LGL |
| Capacity | 50 Sheets (80 G/M²) |
| Paper Weights | Original: 52 G/M² To 105 G/M² |
| Description | Cassette Feeding Module-AB1 |
| Paper Capacity | 250 Sheets X 1 Drawer (80 G/M²) |
| Paper Sizes | LTR, 11" X 17", STMT, LTRR, STMTR, LGL |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
