Available From USB Memory (TIFF, JPEG, PDF And XPS (Only LPR)) Available From USB Memory, LPR
Standard Paper Source
550-Sheet Paper Cassette, 100-Sheet Stack Bypass
Optional Paper Source
550-Sheet Paper Feeder PF-C1 (Up To 3)
Paper Output
150 Sheets Maximum (Letter, 20lb. Bond)
Paper Weight
Cassettes: 16 Lb. Bond To 32 Lb. Bond (60 To 120 G/M2) Bypass: 16 Lb. Bond To 73 Lb. Bond (60 To 199 G/M2)
Media Sizes
Cassettes: Letter, Legal, Statement, Executive Bypass: Letter, Legal, Statement, Executive Custom Size (3" X 5" To 8-1/2" X 14") Envelope (C5/DL/ COM-10/Monarch)
Media Types
Thin, Plain, Thick, Color, Recycled, Bond
Standard Interface
Network: 1000Base-T/100Base-TX/10-Base-T Other: USB 2.0 (Host) X3, USB 2.0 (Device) X1
Os Compatibility
Windows 10/8.1/7 (32/64 Bit), Windows Server (2019/2016/2012 R2 (64 Bit)/2012 (64 Bit)/ 2008 R2 (64 Bit) /2008 (32/64 Bit), Mac® (OS X 10.6 And Later => 10.9 ~ 10/14) Linux (Web Distribution)
Cable Included
Power Cord Plug (Main Unit): NEMA 5-15P (120V); CEE7/7 (230V)
Bundled Software
Printer Driver: UFR II, PCL 5/6, Adobe PS 3
Power Consumption
Maximum: Approx. 1370 W Sleep Mode: Approx. 0.9 W9
Power Requirements: 120-127 V, 60 Hz, 7.1 A 220-240 V, 50/60 Hz, 2.8 A
Typical Energy Consumption
0.50 KWh
Standards: ENERGY STAR® Certified Rated EPEAT Gold1
Dimensions
16-1/8”(W) X 14-13/16”(D) X 10-13/16”(H) (409 Mm(W) X 376 Mm(D) X 275 Mm(H))
Installation Space (W X D): 24-5/16” X 43-7/16” (617 Mm X 1104 Mm)
Unit Weight Without With Cartridge
Approx. 25.3 Lb. (11.5 Kg) With Consumables
Package Weight
Approx. 28.7 Lb. (13.0 Kg)
Cartridge Type
T06 Black Toner 20,500 Images (Estimated Yield @ ISO 19752 Coverage) NOTE: Toner Not Included In The Main Unit.
Lcd Display
5-Line LCD Panel
Security
Authentication: Standard: Department ID Authentication Optional: UniFLOW, UniFLOW Online
