imageRUNNER 1643i
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The imageRUNNER 1643i is registered EPEAT Gold.
Workflow Efficiency
Security
Efficient Performance
Fleet Management
Quality and Reliability
Sustainability
- For current EPEAT rating (Gold/Silver/Bronze), please visit https://www.cla.canon.com/cla/en/epeat.
- Time from device power-on until copy ready (not print reservation).
- Includes consumables.
- No charge for this solution, however activation is required.
- 0.9 W sleep mode not available in all circumstances due to certain settings.
- Attached to Main Unit.
| Model Name | ImageRUNNER 1643i |
| Type | Monochrome A4 Laser Multifunctional |
| Functions | Print, Copy, Scan, Send |
| Operation Panel | 5" TFT LCD WVGA Color Touch Panel |
| Imaging System | Canon Dual Custom Processor (Shared) |
| Image Server Memory | 1.0 GB RAM |
| Network Interface Connection | 1000Base-T/100Base-TX/10-Base-T, Wireless LAN (IEEE 802.11 B/G/N), NFC (Only 1643iF), Wi-Fi Direct Connection |
| Other Interface | USB 2.0 (Host) X2, USB 2.0 (Device) X1 |
| Max Mailboxes Supported | LDAP (50)/Local (300)/Speed Dial (281) |
| Common Protocol | File: FTP (TCP/IP), SMB (TCP/IP) Email: SMTP, POP3 |
| Max Number Of Concurrent Connections | One |
| Standard | USB |
| Network Twain Scan | Standard |
| Network Scan Utility | ScanGear MF |
| Max Copy Reservation | Up To 600 X 600 |
| Scanning Resolution | Up To 600 X 600 |
| Printing Resolution | 600 × 600 |
| Letter | Up To 45 Ppm |
| Legal | Up To 36 Ppm |
| First Copy Time | As Fast As 6.0 Seconds (Via Platen) |
| Multiple Copies | Up To 999 |
| Magnification | 25% - 400% (1% Increments) From Platen Glass |
| Preset Reductions | 25%, 50%, 64%, 78% |
| Preset Enlargements | 129%, 200%, 400% |
| Acceptable Originals | Sheet, Book, 3-Dimensional Objects |
| Maximum Original Size | Up To 8-1/2" X 1 |
| Standard Paper Capacity | 550-Sheet Paper Cassette |
| Optional | 550-Sheet PAPER FEEDER PF-C1 (Up To 3) |
| Manual Bypass | 100-Sheet Stack Bypass |
| Maximum Paper Capacity | 2,300 Sheets |
| Output Paper Capacity | Maximum: 250 Sheets |
| Cassettes | Letter, Legal, Statement, Executive |
| Bypass | Letter, Legal, Statement, Executive, Custom Size (3" X 5" To 8-1/2" X 14"), Envelope (C5/DL/ COM-10/Monarch) |
| Cassette | 16 Lb. Bond To 32 Lb. Bond (60 To 120 G/M2) |
| Bypass | 16 Lb. Bond To 73 Lb. Cover (60 To 199 G/M2) |
| Duplexing | Duplexing Automatic Document Feeder |
| Paper Size | 4-1/8" X 5" To 8-1/2" X 14" |
| Paper Weight | Simplex: 13 Lb. To 28 Lb. Bond (50 To 105 G/M2) Duplex: 17 Lb. To 28 Lb. Bond (64 To 105 G/M2) |
| Warm Up Time | From Power On: 14 Seconds Or Less2 From Sleep Mode: 4 Seconds Or Less |
| Power Requirements | 120-127 V, 60 Hz, 7.1 A |
| Power Consumption | Maximum: 1,500 W Sleep Mode: 0.9W Or Less5 |
| Plug | NEMA 5-15P |
| Dim | 18-7/8" X 23-1/2" X 17-3/4" (480 Mm X 595 Mm X 452 Mm) |
| Installation Space | 27-3/8" X 43-1/2" (694 Mm X 1105 Mm) |
| Weight | Approx. 41.9 Lb. (19 Kg) 3 |
| Basic Copy Features | Preset R/E Ratios By Area, Paper Setting, Favorite Setting, Two-Sided, Density Adjustment, Original Type Selection |
| Special Copy Features | Two-Sided Original, Sort, Job Build, N On 1, Different Size Originals, Density Adjustment, Original Type Selection, Sharpness, Erase Frame, Copy ID Card |
| Standard S | Authentication: Department ID Authentication And Embedded Universal Login Manager With UinFLOW Online/Online Express,4 IP/ Mac Address Filtering, IPSEC, TLS Encrypted Communication, SNMP V3.0, IEEE 802.1X, IPv6, SMTP Authentication, POP Authentication Before SMTP, Secure Print, Encrypted PDF, Device Signature |
| Optional | Authentication: UniFLOW |
| Environmental Features | ENERGY STAR&Reg; Certified Rated EPEAT&Reg; Gold1 |
| Estimated Toner Yield | (Estimated Yield @ 5% Coverage) 20,500 Images |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
