/content/cla/en/cla-test/cla-testing/haibd4-testing
/content/cla/en/cla-test/cla-testing/support/p/Software-Applications/1259B003
imageRUNNER 1435iF+
The imageRUNNER 1435iF+ helps maximize resources, boost productivity and make managing easier for small businesses and corporate workgroups.
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Small businesses and corporate workgroups depend on solutions that help maximize resources, boost productivity, and are easy to manage. The cost-efficient imageRUNNER 1435+ Series does all that and more. With fast output, scanning, faxing, and high reliability, these multifunction devices let you accomplish a lot in a small space.
The imageRUNNER 1435iF+ is registered EPEAT Silver.
Workflow Efficiency
Whether you're a small business or part of a workgroup the imageRUNNER 1435+ Series models can boost operational efficiency. Scan and email documents to clients and colleagues or conveniently scan to/print from a USB memory stick. The ID Card Copy feature easily copies cards and other small, two-sided documents onto the same page. Extend your document management capabilities when you scan using the standard PDF (OCR) format. These models enable mobile workers and offices with the ability to scan to/print from select mobile devices.
Security
Safeguard information and help ensure security compliance with the imageRUNNER 1435+ Series. Canon's uniFLOW solution lets users securely retrieve documents from any networked device. With the now standard Send PDF Security Set, users can send encrypted PDFs and add a digital device signature to PDF files. TX Archiving automatically forwards a copy of a fax to an administrator-defined destination. And with no hard disks in these models, there are no latent images.
Efficient Performance
Designed with your bottom line in mind, the Canon imageRUNNER 1435+ Series helps minimize costs and maximize reliability, while the robust design helps ensure long, dependable operation. Canon's uniFLOW® software helps control costs by managing, tracking, and charging back usage. And simple-to-replace, high-yield consumables help keep work moving while achieving a lower cost per page.
Fleet Management
An ideal replacement for single-function printers or older models, the imageRUNNER 1435+ Series easily integrates into your network of imageRUNNER devices to streamline and simplify management and maintenance. Even receive alerts when supplies or service calls are needed with imageWARE Enterprise Management Console and plug-ins.
Quality and Reliability
With a first-copy-out time as fast as 6.9 seconds and output up to 37 ppm, the imageRUNNER 1435+ Series is a quick performer. Scan documents in black and white and color to email addresses or networked locations. The highly visible, 5-line display simplifies use. The standard 600-sheet capacity can be increased to 1,100 sheets to handle many jobs without interruption.
Sustainability
The imageRUNNER 1435+ Series meets ENERGY STAR® standards and has a low TEC (Total Energy Consumption) rating. EPEAT® rated, these models follow Canon's stringent Green Procurement policy and environmental commitments.
| Type | Digital Multifunction Imaging System |
| Functions | Copy, Print, Scan, Send, Fax |
| Operation Panel | 5-Line Lcd |
| Image Server Memory | Ram 512 Mb; Standard Usb Port |
| Network Interface Connection | Standard: 1000base-T, 100base-Tx, 10base-T Other: Usb2.0 X1 (Host), Usb1.1 X1(Host), Usb (Device) |
| Network Twain Scan | Standard |
| Network Scan Utility | Scangear Mf |
| Scanning Resolution | Up To 600 X 600 Dpi |
| Printing Resolution | 600 X 600 Dpi; 1200 X 600 Dpi (Enhanced) |
| First Copy Time | As Fast As 6.9 Seconds First-Print-Out-Time (Letter) As Fast As 5.0 Seconds |
| Multiple Copies | 1 To 999 |
| Copy Exposure | Automatic Or Manual (17 Levels) |
| Magnification | 25% - 400% (1% Increments) From Platen Glass |
| Preset Reductions | 25%, 50%, 64%, 78% |
| Preset Enlargements | 129%, 200%, 400% |
| Standard Paper Capacity | 500-Sheet Cassette |
| Optional | 500-Sheet Cassette |
| Manual Bypass | 100-Sheet Bypass |
| Maximum Paper Capacity | 1,100 Sheets |
| Output Paper Capacity | (20 Lb. Bond) Maximum: 100 Sheets |
| Cassette | Letter, Legal |
| Bypass | Letter, Legal, Statement, Executive, Custom Size (3" X 5" To 8-1/2" X 14"), Envelope (C5/Dl/ Com-10/Monarch) |
| Warm Up Time | From Power On: 20 Seconds Or Less From Sleep: 7.8 Seconds Or Less |
| Power Requirements | 120-127 V Ac, 60 Hz, 7.8 A |
| Power Consumption | Maximum: 1,500 W Sleep Mode: 2.0 W Or Less |
| Plug | Nema 5-15p |
| Dim | (H X W X D) 18-3/4" X 21-1/2" X 18" (475.3 Mm X 545 Mm X 457 Mm) |
| Installation Space | (W X D) 30-3/8" X 1 8" (772.1 Mm X 457 Mm) (When The Multi-Purpose Tray Is Extended) |
| Weight | Approx. 52.3 Lb. (23.74 Kg) Duplexing Automatic Document Feeder Paper Sizes: 5-1/2" X 5" To 8-1/2" X 14" Paper Weights: Simplex: 13 Lb. To 28 Lb. Bond (50 To 105 G/M2) Duplex: 17 Lb. To 28 Lb. Bond (64 To 105 G/M2) Scan Method: Duplexing Automatic Document Feeder Scanning Speed: Simplex: Up To 29 Ipm (Bw)/10 Ipm (Color) Duplex: Up To 10 Ipm (Bw)/6 Ipm (Color) Capacity: Up To 50 Sheets (20 Lb. Bond) Special Media Support: Standard: Usb Memory |
| Scan Resolution | Up To 600 X 600 Dpi |
| Acceptable Originals | (Glass) Sheet, Book, 3-Dimensional Objects Up To 4.4 Lb. (2 Kg) |
| Maximum Original Size | Up To 8-1/2" X 14" |
| Basic Copy Features | Preset R/E Ratios By Area, Two-Sided, Exposure Adjustment, Original Type Selection, Setting Confirmation/Cancel, Standard Keys, Reset, Id Management, Counter Check |
| Special Copy Features | Id Card Copy, Frame Erase, Mode Memory, Sharpness, Image Combination, Different Size Original |
| Standard | Department Id Management, Ipv6, Restricting Features (Restricting New Addresses On Address Book, Allow Fax Driver Tx, Restrict Recall, Confirm Entered Fax Numbers, Restrict Sequential Broadcast, Restrict Usb Interface), Memory Lock, Mac/Ip Address Filtering, Smtp Authentication Pop Authentication Before Smtp, Ieee802.1x, Authentication Feature For Send Operation (Ausend), Secured Print, Snmp V1/V3, Ssl Encrypted Communication, Fax Fowarding, Fax Destination Confirmation, Usb Block, Tls Support For E-Mail, Fax Tx Archive, Encrypted Pdf, Device Signature Pdf |
| Optional | Uniflow |
| Environmental Features |
| Estimated Toner Yield | 17,600 Images (Estimated Yield @ 6% Coverage) |
| Description | Cassette Module - Ac1 |
| Paper Capacity | 500-Sheet Cassette [20 Lb. Bond (80 G/M2)] |
| Paper Size | Legal, Letter |
| Paper Weight | 17 Lb. Bond To 24 Lb. Bond (64 To 90 G/M2) |
| Power Source | From The Main Unit |
| Power Consumption | Approximately 3.6 W |
| Dimensions | 6-1/8" X 20-1/2" X 17-3/4" (54.8 Mm X 520 Mm X 450.8 Mm) |
| Weights | Approximately 11 Lb. (5 Kg) |
| Description | Cabinet Type - K |
| Dimensions | 21-7/8" X 20-1/2" X 17-1/4" (554 Mm X 520 Mm X 439 Mm) |
| Weights | 40 Lb. (18.14 Kg) |
| Description | Fl Cassette - Aw1 |
| Description | Print Sepcifications |
| Processor | Canon Dual Custom Processor (Shared) |
| Engine Resolution | 600 X 600 Dpi; 1200 X 600 Dpi (Enhanced) |
| Pdl Support | Standard: Ufr Ii Lt, Pcl 5e/6, And Adobe Ps 3 Optional: Barcode Printing Kit |
| Other Features | Print Driver Supported Os Ufr Ii Lt, Pcl 5e/6, Adobe Ps 3, Windows® (Xp/Windows Vista®/7/8/8.1), Windows Server (2003/2003r2/2008 /2008 R2/ 2012/2012 R2), Windows Terminal Server (2003/2003r2/2008/2008 R2/2012/2012 R2), Microsoft Clustering Server 2003/2003r2/2008/ 2008 R2/2012/2012 R2),Microsoft App-V, Citrix (Presentation Server 4.5, Xenapp 5.0/6.0/6.5/7.5, Xendesktop 4.0/5.0/5.5/5.6/7.0/7.1/7.5), Vmware (Vsphere 4/5/5.1), Sap (Ps3, Pcl), Macintosh® (Os X 10.5.8 Or Later) (Ufr Ii Lt, Ps 3) Direct Print Support Standard: Tiff, Jpeg Standard: Pdf, Pcl 5e/6, Adobe Ps 3 |
| Print Features | Secured Print, Watermark, Page Border, Header/Footer, Page Layout, Two-Sided Printing, Collating, Booklet Printing, Grouping, Printing On Transparencies, Front/ Back Covers, Objective, Toner Reduction, Poster Printing |
| Description | Universal Send |
| Sending Method | E-Mail, Usb, File Server (Ftp, Smb) |
| Color Mode | Color, Bw |
| Scan Resolution | Color: 300 Dpi, 200 Dpi, 150 Dpi Bw: 300 Dpi, 150dpi |
| Address Book Capacity | Max. 300 Destinations (Incl. 19 One-Touch Buttons) |
| Communication Protocol | File: Ftp (Tcp/Ip), Smb (Tcp/Ip) E-Mail: Smtp, Pop3 |
ABOUT CANON
PRODUCT RESOURCES
ABOUT CANON
PRODUCT RESOURCES
Ⓒ 2026
