imageRUNNER 1025iF
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Operating at speeds of up to 25 pages per minute (LTR), the imageRUNNER 1025iF offers high-end capabilities for small businesses and workgroups.
The imageRUNNER 1025iF model provides full-color document distribution capabilities that incorporates Canon's proprietary PDF High Compression technology for efficient handling of color documents and image data on your network. Plus, the imageRUNNER 1025iF also offers powerful Super-G3 Fax technology to send and receive documents with speed and ease. The imageRUNNER 1025iF also supports advanced digital copying, automatic duplexing, full color scanning, network printing capabilities, as well as a standard 50-sheet Duplexing Automatic Document Feeder.
Offering innovative information-sharing tools at the touch a button, the imageRUNNER 1025iF device changes the way your small business or workgroup communicates.
Operating at up to 25 pages-per-minute (LTR), the imageRUNNER 1025iF is equipped with 256 MB RAM. Exceptional memory capacity provides users with high-speed image processing of data and simultaneous processing of each function.
With a scanning resolution of 600 x 600 dpi, and print/copy resolution of enhanced 1200 x 600 dpi, the imageRUNNER 1025iF delivers outstanding, exceptional image quality for the most faithful reproduction of text and images.
Standard TWAIN/WIA compliant color scanning enables users to convert hardcopy-based information into electronic format for storage or integration into your workflow.
Compact desktop design allows devices to be placed in areas with limited space. An integrated output tray saves space and organizes output for speedy distribution.
Standard automatic duplexing saves time and reduces paper cost by producing two-sided output without any manual intervention.
Designed with Canon's RAPID Fusing technology to significantly reduce energy consumption and improve productivity.
With a maximum paper capacity of 1,100 sheets, the imageRUNNER 1025iF device has been designed to meet the volume requirements of any small business or busy workgroup.
Standard UFR II LT printing to provide maximum flexibility and performance for busy workgroups and businesses. Optional PCL 5e/6 Printing Capabilities.
Cutting edge image processing technology enables high-speed image data processing and the simultaneous processing of multiple functions. Standard 10/100 BaseTX Ethernet and USB connectivity.
A suite of management features including Department ID mode for tracking/monitoring device usage and Remote UI for controlling system functions through a Web Browser.
Color-enabled document distribution allows users to communicate information more effectively; Includes support for PDF High Compression technology for efficient handling of color image data.
Super G3-Fax capabilities gives users the ability to transmit and receive documents with speed and ease.
50-sheet capacity Duplexing Automatic Document Feeder makes scanning multi-page and different-size originals quick and easy.
| Model Name | ImageRUNNER 1025iF |
| Type | Monochrome Digital, Multifunction Imaging System |
| Imaging System | Laser Dry Electrostatic Transfer |
| Developing System | Laser Dry Electrostatic Transfer |
| Fixing System | RAPID Fusing System |
| Image Server Memory | 256MB RAM |
| Max Copy Reservation | 5 Jobs |
| Scanning Resolution | 600 X 600 Dpi |
| Printing Resolution | 1200 X 600 Dpi |
| Halftone | 256 Levels |
| Letter | Up To 25 Ppm (LTR) - Up To 24 Ppm (LTR) When Feeding From Stack Bypass |
| First Copy Time | Less Than 8 Seconds (From Platen Glass) Less Than 12 Seconds (From DADF)* |
| Multiple Copies | 1 To 99 |
| Magnification | 50% To 200% (In 1% Increments) Preset Reduction/Enlargement: 50%, 64%, 78%, 100%, 129%, 200% |
| Maximum Original Size | Legal |
| Standard Paper Capacity | 1 X 500-Sheet Paper Cassette (21 Lb. Bond / 80 G/M² ) 1 X 100-Sheet Stack Bypass |
| Manual Bypass | (21 Lb. Bond / 80 G/M²) |
| Maximum Paper Capacity | 1,100 Sheets |
| Cassette | 17 Lb. To 24 Lb. Bond / 64 G/M² To 90 G/M² |
| Bypass | 15 Lb. To 34 Lb. Bond / 56 G/M² To 128 G/M² |
| Duplexing | Standard |
| Warm Up Time | Less Than 19 Seconds 1.5 Seconds (From Energy Saver Mode) |
| Exposure Control | Automatic Or Manual (9 Levels) |
| Power Requirements | 120V AC, 60Hz Power Consumption: 848W (Maximum) |
| Dim | 17-7/8" X 20-1/2" X 18" (453mm X 520mm X 457mm) |
| Weight | (Including Drum Unit, Excluding Toner Cartridge): Approximately 53.1 Lb. (24.1 Kg) |
| Estimated Toner Yield | Approximately 8,400 Images At 6% Coverage |
| Drum | OPC |
| Description | Duplexing Automatic Document FeederΔΔ |
| Acceptable Originals | Statement To Legal |
| Capacity | 50 Sheets (21 Lb. Bond / 80 G/M²) |
| Paper Weights | 13 Lb. To 34 Lb. Bond (One-Sided Scanning)13 Lb. To 28 Lb. Bond (Two-Sided Scanning) |
| Description | Cassette Feeding Module-N2 (Optional) |
| Capacity | 1 X 500 - Sheet Paper Cassette (21 Lb. Bond / 80 G/M²) |
| Paper Weights | 17 Lb. To 24 Lb. Bond / 64 G/M² To 90 G/M² Paper Size: Legal/B4, Letter/A4 |
| Dimensions | 6-1/4" X 20-1/2" X 17-3/8" (158mm X 520mm X 440mm) |
| Weight | Approximately 11.46 Lb. (5.2kg) |
| Description | Cabinet-VI |
| Dimensions | 20-5/8" X 20-1/2" X 19" (525mm X 520mm X 481mm) |
| Weights | 27.9 Lb. (13 Kg) |
| Description | Super G3 Fax Functionality†† |
| Applicable Line | Public Switched Telephone Network (PSTN) Connection Lines: One Effective Image Size: Statement, Letter, Legal |
| Transmission Speed | Approximately 3 Seconds/Page†††33,600 Bps (Maximum) |
| Data Compression | MH, MR, MMR, JBIG Error Correction: Yes (ECM) |
| One Touch Speed Dialing Locations | 23 Destinations |
| Coded Speed Dialing Locations | 177 Destinations Group Dials: 199 Destinations Image Memory: Approximately 1,000 PagesΔ |
| Processor | Canon Custom Processor - Shared |
| Standard Memory | Shared With Main Unit - 256MB RAM |
| Pdl Support | UFR II LT (Standard),** PCL 5e/6** (Optional With PCL Printer Kit-AB1) |
| Interface Connections | USB 2.0 Hi-Speed 10/100Base-TX*** Network OS: Windows® 2000/XP/Server 2003/Windows Vista® Macintosh®OS (10.2.8 To 10.4.6)† |
| Description | Sending Capabilities†† |
| Sending Method | E-Mail, I-Fax, Fax, File Server (FTP/SMB) Destinations One-Touch Dials: 23 Destinations Coded Dials: 177 Destinations Group Dials: 199 Destinations |
| File Format | Black And White: TIFF, PDF Color: JPEG, PDF (Compact) |
