| Model Name
ImageRUNNER 1025 |
| Type
Monochrome Digital, Multifunction Imaging System |
| Imaging System
Laser Dry Electrostatic Transfer |
| Developing System
| Fixing System
RAPID Fusing System |
| Image Server Memory
128MB RAM |
| Max Copy Reservation
5 Jobs |
| Scanning Resolution
600 X 600 Dpi |
| Printing Resolution
1200 X 600 Dpi |
| Halftone
256 Levels |
| Letter
Up To 25 Ppm (LTR) - Up To 24 Ppm (LTR) When Feeding From Stack Bypass |
| First Copy Time
Less Than 8 Seconds (From Platen Glass) |
| Multiple Copies
1 To 99 |
| Magnification
50% To 200% (In 1% Increments) Preset Reduction/Enlargement: 50%, 64%, 78%, 100%, 129%, 200% |
| Maximum Original Size
Legal |
| Standard Paper Capacity
1 X 500-Sheet Paper Cassette (21 Lb. Bond / 80 G/M²) 1 X 100-Sheet Stack Bypass |
| Manual Bypass
(21 Lb.Bond / 80 G/M²) |
| Maximum Paper Capacity
1,100 Sheets |
| Cassette
17 Lb. To 24 Lb. Bond / 56 G/M² To 128 G/M² |
| Bypass
15 Lb. To 34 Lb. Bond / 64 G/M² To 90 G/M² |
| Duplexing
Standard |
| Warm Up Time
Less Than 19 Seconds 1.5 Second (From Energy Saver Mode)* |
| Exposure Control
Automatic Or Manual (9 Levels) |
| Power Requirements
120V AC, 60Hz Power Consumption: 848W (Maximum) |
| Dim
17-7/8" X 20-1/2" X 18" (453mm X 520mm X 457mm) |
| Weight
(Including Drum Unit, Excluding Toner Cartridge): Approximately 53.1 Lb. (24.1 Kg |
| Estimated Toner Yield
Approximately 8,400 Images At 6% Coverage |
| Drum
OPC |
| Description
Cassette Feeding Module-N2 (Optional) |
| Capacity
1 X 500 - Sheet Paper Cassette (21 Lb. Bond / 80 G/M²) |
| Paper Weights
17 Lb. To 24 Lb. . Bond / 64 G/M2 To 90 G/M² Paper Size: Legal/B4, Letter/A4 |
| Dimensions
6-1/4" X 20-1/2" X 17-3/8" (158mm X 520mm X 440mm) |
| Weight
Approximately 11.46 Lb. (5.2kg) |
| Description
Cabinet-VI |
| Dimensions
20-5/8" X 20-1/2" X 19" (525mm X 520mm X 481mm) |
| Weights
27.9 Lb. . (13 Kg) |
| Description
Super G3 Fax Functionality†† |
| Applicable Line
Public Switched Telephone Network (PSTN) Connection Lines: One Effective Image Size: Statement, Letter, Legal |
| Transmission Speed
Approximately 3 Seconds/Page†††33,600 Bps (Maximum) |
| Data Compression
MH, MR, MMR, JBIG Error Correction: Yes (ECM) |
| One Touch Speed Dialing Locations
23 Destinations |
| Coded Speed Dialing Locations
177 Destinations Group Dials: 199 Destinations Image Memory: Approximately 1,000 Pages◊ |
| Processor
Canon Custom Processor - Shared |
| Standard Memory
Shared With Main Unit - 128MB RAM |
| Pdl Support
UFR II LT (Standard),** PCL 5e/6** (Optional With PCL Printer Kit-AB1) |
