imagePROGRAF TX-4000 MFP T36
- imagePROGRAF TX-4000
- TX Stacker
- Printer Stand
- 2"/3" Core Media Spool (Adaptors Included)
- US AC Power Cable
- Tools and Screws
- Print Head PF-06
- Maintenance Cartridge (Installed)
- 5 Ink Tanks (330 ml: MBK/C/M/Y/BK)
- Sample Heavyweight Coated Paper (A2/5 Sheets)
- Ethernet Card (built-in)
- USB 2.0 High-speed Interface
- USB Connection Sheet
- iWR Service Terms Leaflet
- User Manual
- Quick Setup Guide
- User Software CD for Windows (Printer Driver Utilities)
- PosterArtist Lite CD
- User Registration Card
- T36 Scanner with power cord, USB 3.0 Cable:
- Power Supply
- Ethernet
- Stand
- (2) Paper Edge Guides
- (3) Document Return Guides
- All-in-One Touch Screen Computer
- USB Drive with SmartWorks MFP software, Scanner User Manual and Quick Start Guide
- Calibration Target
- T36 Scanner Quick Start Guide
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The Accounting Manager serves as a powerful feature, used for accurate management of printing costs and other information that is increasingly important in today's economic environment.
With the Accounting Manager feature you can track how much ink and paper is being consumed when printing in large format. Costs can be assigned to ink and paper to determine expenses based on your own "Cost of goods". Each individual ink tank can have its own cost associated to it, as well as a variety of different paper types. The user can also input a variable cost that will be added to the total of the print cost. The data is exportable to a .csv format for Microsoft Excel® so the data can be used for billing purposes. This feature will allow you to determine the cost of each print based on your actual cost.
The TX Unified Printer Driver8 allows users to print to any imagePROGRAF TX Series device, without any need to install additional drivers for each model. This makes it a hassle-free installation process for multiple devices within the same environment.
The Windows® and Macintosh® drivers incorporate simplified page setup options, one-touch borderless printing, expanded color settings, and much more into a printer driver that is intuitive and easy-to-operate while still giving even the most advanced users the tools needed to stay productive.
The Real Preview feature lets users ensure that the print setting and the layout on the roll paper is correct by providing real time preview, allowing users to change the print setting even after clicking on "print." The Free Layout feature enables nesting and custom layouts of images or files of nearly any type (available for both Windows® and Mac® driver).
- Secure Communication:
- 802.1x Authentication
- SNMPv3
- SSL/TLS
- IPSec
- Functionality Restrictions:
- Panel Lock by Remote UI
- Remote UI Multilevel
- Hide IP From Panel
- Panel Access Control
- Job Storage and PIN Printing
- Secure Storage:
- Self Encrypting Hard Disk
- Secure Disc Erase (Conforms to U.S. Department of Defense standard DoD5220.22-M)
- Secure File Erase*
- The following functions can be disabled in administrator mode:
- Direct USB Thumb Drive Printing
- Internet Connection
- FTP and Telnet communication protocols
- Job Log Look-up
* Available 2018 with firmware update.
A computer is included with the MFP T36 system:
| The T36 scanner incorporates a SingleSensor Technology Assembly3, which helps provide consistent and better color accuracy with more detail in the shadows and highlights than a staggered CIS array scanner. T36 Scanner Features:
| SmartWorks MFP gives you the tools you'll need to quickly and easily scan to print/file/share large format technical documents. With a simple to use interface and unique scan-it-once ability, SmartWorks MFP allows for efficient batch scanning and helps create quality scanned images that are produced in a short amount of time. Scan to PDF, TIFF and JPEG file formats. SmartWorks MFP software is now more efficient than ever before. Features:
| The TX-4000 MFP T36 is an affordable solution for providing fast, high-quality, large format image capture-to-output. Designed to be more than just its parts, it is the versatility of the product that makes it stand out. This multi-component system gives the user the opportunity to be more productive by being able to print and scan at the same time. The open architecture of the computer can be used to load additional programs, among other things. The printer’s ability to print on a wide variety of media lends itself to uses in many departments and applications as well. A flexible system built for the way you work, the imagePROGRAF TX-4000 MFP T36 includes:
This Product has not been authorized as required by the rules of the Federal Communications Commission. This Product is not, and may not be, offered for sale or lease, or sold or leased, until such authorization is obtained.
CANON and imagePROGRAF are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. All referenced product names, and other marks, are trademarks of their respective owners. Not responsible for typographical errors. *Prices, specifications and availability are subject to change without notice. Actual prices are set by individual dealers and may vary. All printout images and effects are simulated.
† The imagePROGRAF TX Series systems contain multiple components, some of which are manufactured by third parties. To the extent that such third party offerings come with limited warranties, such limited warranties are hereby passed to the purchaser, and Canon shall have no obligation or any liability with respect to such third party offerings.
††SingleSensor Technology Assembly means that multiple sensors are contained in one assembly device.
1. Your server must be compatible with a webDAV enabled cloud account, including but not limited to, Google, Carbonite or Rackspace, to take advantage of the cloud functionality. Storage capacity and any pricing thereof is based on the third-party cloud providers current offering, at its sole discretion. Your cloud account is subject to the third-party cloud provider's terms and conditions. Neither Canon Inc. nor Canon U.S.A., Inc. represents or warrants any third party product, service or feature referenced hereunder.
| Printer Type | 5-Color 44-Inch Printer |
| Nozzle Text | Total: 15,360 MBK: 5,120 Nozzles C, M, Y, BK: 2,560 Nozzles Each |
| Nozzle Pitch | 1200 Dpi Non-Firing Nozzle Detection And Compensation |
| Resolution Text | 2400×1200dpi (Max) |
| Os Compatibility | Windows® 7, 8.1, 10 (32/64bit) Windows® Server 2008 R2, 2012, 2012 R2, 2016 (64bit) |
| Standard Interfaces | USB 2.0 High-Speed 10/100/1000 Base-T/TX |
| Ink Droplet Size | 5 Picoliter |
| Ink Capacity | 160 Ml, 330ml Or 700ml Per Color |
| Ink Type | Pigment Ink |
| Color Set | Pigment: Matte Black, Black, Cyan, Magenta, Yellow |
| Buffer Ram | 128 GB (Virtual) 2 GB (Physical) |
| Hard Drive | 500 GB |
| Media Width | Cut Sheet - 8"- 44" Roll Feed - 8" - 44" |
| Media Thickness | 0.07-0.8mm (2.8-31.4mil) Roll: 0.07 - 0.8 Mm (2.8 - 31.4mil) |
| Maximum Roll Print Length | Roll Feed - 59' (18 Meters)2 |
| Maximum Media Roll Diameter | 6.7" (170mm) |
| Borderless Printing Width | 8”, 10", 12”, 14", 16” 17", 20”, 24", 30”, 36", 42”, 44” B4 (10.12"/257 Mm), A3 (11.69"/297 Mm), A3+ (12.95"/329 Mm), A2 (16.54"/420 Mm), B2 (20.28"/515 Mm), A1 (23.39"/594 Mm), B1 (28.66"/ 728 Mm), A0 (33.11"/841 Mm), B0 (40.55”/1030 Mm) |
| Paper Feed Method | Roll Feed: One Roll, Front-Loading, Front Output Front Loading Manual Feed: One Roll, Front Output |
| Languages | SGRaster, HPGL/2, HP-RTL, PDF, JPEG |
| Noise Level Approx | Operation: 51 DB (A) Or Less Standby: 35 DB (A) Or Less Acoustic Power: 6.9 Bels Or Less |
| Physical Dimensions | 46.0" X 62.7" X 46.8" (Main Unit And TX Stacker) |
| Weight | Approx.277 Lbs (Roll Holder Included, No Inks, No Print Heads) |
| Power Source | AC-100-240V (50-60Hz) |
| Power Consumption | Maximum: 107W Or Less Standby 3.6W Or Less Power Off: 0.3W Or Less (Compliant With Executive Order) |
| Operating Environment | 59°-86° F (15°-30° C) Relative Humidity: 10-80% (No Condensation) |
| Item | Print Head (PF-06) Maintenance Cartridge (MC-30) Ink Tanks (PFI-110/PFI-310/PFI-710) |
| Software Included | TX Unified Printer Driver8, Accounting Manager, Apple AirPrint9, Canon Print Service, Device Management Console, Direct Print & Share2, Free Layout Tool, Media Configuration Tool, PosterArtist Lite For Windows, Printer Driver Extra Kit For Windows/Mac (Free Print Utility Layout, Advanced Preview), Optimized Driver For AutoCAD, Print Plug-In For Microsoft® Word/Excel/PowerPoint® For Windows, Quick Utility Toolbox SCANNER SPECIFICATIONS Scanner Type: Contact Image Sensor (CIS) Technology Scan Accuracy: +/- 0.1% Speed: 13 Ips Monochrome, 6 Ips Color Optical Resolutions: 1200dpi (Adjustable From 100 Dpi To 2,400 Dpi) Max. Resolutions: 9600dpi Interpolated Max. Document Size: Width: 38 Inch Document Width (36 Inch Image Width) / Length 315" (JPG Or PDF) 598" (TIFF) Thickness: 0.079in (2mm) Standard Interface: USB 3.0 (PC Connector Compatible With USB 2.0 And USB 3.0 Sockets) |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
