imagePROGRAF TX-3000
- 36-inch TX-3000 large-format printer
- Print Head
- New 5-Color TD Pigment Ink Set
- Optional Multifunction Roll Unit Advanced Security Features
- imagePROGRAF TX-3000
- TX Stacker
- Stand
- 2"/3" Core Media Spool (Adaptors Included)
- US AC Power Cable
- Tools and Screws
- Print Head PF-06
- Maintenance Cartridge (Installed)
- 5 Ink Tanks (330 ml: MBK, 160 ml: C/M/Y/BK)
- Sample Heavyweight Coated Paper (A2/5 Sheets)
- Ethernet Card (built-in)
- USB 2.0 High-speed Interface
- USB Connection Sheet
- iWR Service Terms Leaflet
- User Manual
- User Registration Card
- Quick Setup Guide
- User Software CD for Windows (Printer Driver Utilities)
- PosterArtist Lite CD
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
Canon is pleased to announce the new 36-inch TX-3000 large-format printer. New Print Head. New 5-Color TD Pigment Ink Set. Optional Multifunction Roll Unit. Advanced Security Features.
Accounting Manager serves as a powerful feature, used for accurate management of printing costs and other information that is increasingly important in today's economic environment.
With the Accounting Manager feature you can track how much ink and paper is being consumed when printing in large format. Costs can be assigned to ink and paper to determine expenses based on your own "Cost of goods". Each individual ink tank can have its own cost associated to it, as well as a variety of different paper types. The user can also input a variable cost that will be added to the total of the print cost. The data is exportable to a .csv format for Microsoft Excel® so the data can be used for billing purposes. This feature will allow you to determine the cost of each print based on your actual cost.
The TX Unified Printer Driver5 allows users to print to any imagePROGRAF TX Series device, without any need to install additional drivers for each model. This makes it a hassle-free installation process for multiple devices within the same environment.
The Windows® and Macintosh® drivers incorporate simplified page setup options, one-touch borderless printing, expanded color settings, and much more into a printer driver that is intuitive and easy-to-operate while still giving even the most advanced users the tools needed to stay productive.
The Real Preview feature lets users ensure that the print setting and the layout on the roll paper is correct by providing real time preview, allowing users to change the print setting even after clicking on "print." The Free Layout feature enables nesting and custom layouts of images or files of nearly any type (available for both Windows® and Mac® driver).
- Secure Communication:
- 802.1x Authentication
- SNMPv3
- SSL/TLS
- IPSec
- Functionality Restrictions:
- Panel Lock by Remote UI
- Remote UI Multilevel
- Hide IP From Panel
- Panel Access Control
- Job Storage and PIN Printing
- Secure Storage:
- Self Encrypting Hard Disk
- Secure Disc Erase (Conforms to U.S. Department of Defense standard DoD5220.22-M)
- Secure File Erase*
- The following functions can be disabled in administrator mode:
- Direct USB Thumb Drive Printing
- Internet Connection
- FTP and Telnet communication protocols
- Job Log Look-up
* Available 2018 with firmware update.
1. Your server must be compatible with a webDAV enabled cloud account, including but not limited to, Google, Carbonite or Rackspace, to take advantage of the cloud functionality. Storage capacity and any pricing thereof is based on the third-party cloud providers current offering, at its sole discretion. Your cloud account is subject to the third-party cloud provider's terms and conditions. Neither Canon Inc. nor Canon U.S.A., Inc. represents or warrants any third party product, service or feature referenced hereunder.
| Printer Type | 5-Color 36-Inch Printer |
| Nozzle Text | Total: 15,360 MBK: 5,120 Nozzles C, M, Y, BK: 2,560 Nozzles Each |
| Nozzle Pitch | 1200 Dpi Non-Firing Nozzle Detection And Compensation |
| Resolution Text | (Up To) 2400×1200dpi (Max) |
| Os Compatibility | Windows® 7, 8.1, 10 (32/64bit) Windows® Server 2008 R2, 2012, 2012 R2, 2016 (64bit) |
| Standard Interfaces | USB 2.0 High-Speed 10/100/1000 Base-T/TX |
| Ink Droplet Size | 5 Picoliter |
| Ink Capacity | 160 Ml, 330ml Or 700ml Per Color |
| Ink Type | Pigment Ink |
| Color Set | Pigment: Matte Black, Black, Cyan, Magenta, Yellow |
| Buffer Ram | 128 GB (Virtual) 2 GB (Physical) |
| Hard Drive | 500 GB |
| Media Width | Cut Sheet - 8"- 36" Roll Feed - 8" - 36" |
| Media Thickness | 0.07-0.8mm (2.8-31.4mil) Roll: 0.07 - 0.8 Mm (2.8 - 31.4mil) |
| Maximum Roll Print Length | Roll Feed - 59' (18 Meters) |
| Maximum Media Roll Diameter | 6.7" (170mm) |
| Borderless Printing Width | 8”, 10", 12”, 14", 16” 17", 20”, 24", 30”, 36" B4 (10.12"/257 Mm), A3 (11.69"/297 Mm), A3+ (12.95"/329 Mm), A2 (16.54"/420 Mm), B2 (20.28"/515 Mm), A1 (23.39"/594 Mm), B1 (28.66"/ 728 Mm), A0 (33.11"/841 Mm) |
| Paper Feed Method | Roll Feed: One Roll, Front-Loading, Front Output Front Loading Manual Feed: One Roll, Front Output |
| Languages | SGRaster, HPGL/2, HP-RTL, PDF, JPEG |
| Noise Level Approx | Operation: 51 DB (A) Or Less Standby: 35 DB (A) Or Less Acoustic Power: 6.9 Bels Or Less |
| Physical Dimensions | 46.0" X 54.7" X 46.8" (Main Unit And TX Stacker) |
| Weight | Approx.257 Lbs (Roll Holder Included, No Inks, No Print Heads) |
| Power Source | AC-100-240V (50-60Hz) |
| Power Consumption | Maximum: 105W Or Less Standby 3.6W Or Less Power Off: 0.3W Or Less (Compliant With Executive Order) |
| Operating Environment | 59°-86° F (15°-30° C) Relative Humidity: 10-80% (No Condensation) |
| Item | Print Head (PF-06) Maintenance Cartridge (MC-30) Ink Tanks (PFI-110/PFI-310/PFI-710) |
| Software Included | TX Unified Printer Driver5, Accounting Manager, Apple AirPrint7, Canon Print Service, Device Management Console, Direct Print & Share6, Free Layout Tool, Media Configuration Tool, PosterArtist Lite For Windows, Printer Driver Extra Kit For Windows/Mac (Free Print Utility Layout, Advanced Preview), Optimized Driver For AutoCAD, Print Plug-In For Microsoft® Word/Excel/PowerPoint® For Windows, Quick Utility Toolbox |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
