imagePROGRAF TM-300 MFP T36
- All-in-One 36" Multi-Function Large Format System
- 5-Color LUCIA TD Pigment Ink System
- Quiet Operation
- Wi- Fi® Enabled
- T36 Scanner Box
- T36 Scanner with power cord
- All-in-One Touch Screen Computer
- USB 3.0 Cable
- Power Supply
- Ethernet Cable
- AIO Support Arm
- Mount Brackets
- (2) Paper Edge Guides
- (3) Document Return Guides
- USB Drive with SmartWorks MFP software, Scanner User Manual and Quick Start Guide
- Calibration Target
- T36 Scanner Quick Start Guide
- imagePROGRAF TM-300
- Catch Basket
- Printer Stand
- 2"/3" Core Media Spool (Adaptors Included)
- US AC Power Cable
- Tools and Screws
- Print Head PF-06
- Maintenance Cartridge (Installed)
- 5 Ink Tanks (130 ml: MBK, 90 ml: C/M/Y/BK)
- Sample Heavyweight Coated Paper (A2/2 Sheets)
- Ethernet Card (built-in)
- USB 2.0 High-speed Interface
- USB Connection Sheet
- iWR Service Terms Leaflet
- User Manual
- Quick Setup Guide
- User Software CD for Windows (Printer Driver Utilities)
- PosterArtist Lite CD
- Media Guide
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The 36-inch imagePROGRAF TM-300 MFP T36 is a Scan-To-Copy/File/Share integrated solution from Canon that includes the TM-300 large format printer, T36 scanner and All-In-One computer with SmartWorks software. With increased scan speeds and advanced software capability compared to our predecessor large format printer models, this solution has everything needed to copy, scan, archive and share maps, drawings, renderings and posters.
The TM-300 MFP T36 Scan-To-Copy/File/Share system is designed to provide fast, high-quality, large format image capture-to-output. More than just the sum of its parts, it is the versatility of the product that helps make it stand out. This multi-component system gives the user the opportunity to be more productive by being able to print and scan at the same time. The open architecture of the computer can be used to load additional programs, among other things. The printer's ability to print on a wide variety of media lends itself to uses in many departments and applications as well.
The imagePROGRAF TM-300 MFP T36 includes:- TM-300 36-inch Printer
- T36 Scanner
- 15.6" All-In-One touchscreen computer
- Computer Stand
- Catch Basket
SmartWorks MFP software gives you the tools you need to quickly and easily scan to print/file/share large format technical documents. With a simple to use interface and scan-it-once ability, this software allows for efficient batch scanning and helps create quality scanned images that can be produced in a short amount of time. You can scan to PDF, TIFF and JPEG file formats. SmartWorks MFP software is more efficient than ever before.
Features:- Scan-to-Multipage PDF
- Scan lengths of up to 315" (26 ft) for PDF and JPEG files, and up to 598" (50 ft) for TIFF files
- Ability to add custom presets with one-touch retrieval for those often-used settings
- Image enhancements for white point adjust, black point adjust, sharpen, mirror, and invert
- Fine detail scan feature
- Enhanced administrator rights
- Full integration with Canon Direct Print & Share cloud software2
The T36 scanner incorporates a SingleSensor Technology Assembly1, which helps provide consistent and better color accuracy with more detail in the shadows and highlights than a staggered CIS array scanner.
Features:- 1200 dpi maximum optical resolution, 9600 dpi maximum resolution
- Image scanning of up to 36" wide, fits documents up to 38" wide
- Scanning speed of up to 13" per second monochrome, and up to 6" per second color
- USB 3.0 interface, 75 Mbytes / sec transfer rate
- Scan a document up to 2.0 mm thick
- Face up / Front load / Rear exit
- Straight paper path
- Additional programs can be added to the computer
- Files can be moved via a USB storage device
- Files can be shared over a network via the Ethernet card
Built for high productivity and increased flexibility this stacker handles documents of mixed sizes, including ARCH C, ARCH D, or ARCH E/E1sizes, and stacks them up to 100 sheets. The variety of configurations the TX Stacker can be positioned makes prints easily accessible to pick up for on-the-go printing. When not in use the TX Stacker can be folded up to conserve space.
Secure Communication
- 802.1x Authentication
- SNMPv3
- SSL/TLS
- IPSec
Functionality Restrictions
- Panel Lock by Remote UI
- Remote UI Multilevel
- Hide IP From Panel
- Panel Access Control
- Job Storage and PIN Printing
Secure Storage
- Secure Disc Erase (Conforms to U.S. Department of Defense standard DoD5220.22-M)
The following functions can be disabled in administrator mode:
- Internet Connection
- FTP and Telnet communication protocols
- Job Log Look-up
- SingleSensor Technology Assembly means that multiple sensors are contained in one assembly device.
- Your server must be compatible with a webDAV enabled cloud account, including but not limited to, Google, Carbonite or Rackspace, to take advantage of the cloud functionality. Storage capacity and any pricing thereof is based on the third-party cloud provider's current offering, at its sole discretion. Your cloud account is subject to the third-party cloud provider's terms and conditions.
- Plain Paper, Fast (Q5) mode.
- Canon products offer certain security features, yet many variables can impact the security of your devices and data. Canon does not warrant that use of its features will prevent security issues. Nothing herein should be construed as legal or regulatory advice concerning applicable laws; customers must have their own qualified counsel determine the feasibility of a solution as it relates to regulatory and statutory compliance. Some security features may impact functionality/performance; you may want to test these settings in your environment.
- Wireless printing requires a working network with wireless 802.11b/g or 802.11n capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
- For imagePROGRAF Printer Driver. For printing from PostScript applications such as Adobe Illustrator or QuarkXpress, please use a PostScript compatible RIP package.
- AirPrint functionality requires an iPad, iPhone 3GS or later, or iPod touch 3rd generation or later device running iOS 4.2 or later, and an AirPrint-enabled printer connected to the same network as your iOS device. A printer connected to the USB port of your Mac, PC, AirPort Base station, or Time Capsule is not supported.
The imagePROGRAF TM Series MFP T36 systems contain multiple components, some of which are manufactured by third parties. To the extent that such third party offerings come with limited warranties, such limited warranties are hereby passed to the purchaser, and Canon shall have no obligation or any liability with respect to such third party offerings.
Canon, CanoScan and imagePROGRAF are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. Wi-Fi is a registered trademark of the Wi-Fi Alliance. Android is a trademark of Google Inc. Apple, AirPrint, iPad, iPhone, iPod touch, Mac and TimeCapsule are trademarks of Apple Inc., registered in the United States and other countries. Microsoft, Office, Windows, Outlook, Word, Excel and PowerPoint are either registered trademarks or trademarks of Microsoft Corporation in the United States and/or other countries. Autodesk, the Autodesk logo and AutoCAD are registered trademarks or trademarks of Autodesk, Inc., and/or its subsidiaries and/or affiliates in the USA and/or other countries. All referenced product names and trademarks are the property of their respective owners. Specifications and availability dates are subject to change without notice. Not responsible for typographical errors. Neither Canon Inc. nor Canon U.S.A., Inc. represents or warrants any third party product, service or feature referenced hereunder.
| Printer Type | 5-Color 36-Inch Printer |
| Nozzle Text | Total: 15,360 MBK: 5,120 Nozzles C, M, Y, BK: 2,560 Nozzles Each |
| Nozzle Pitch | 1,200 Dpi Non-Firing Nozzle Detection And Compensation |
| Os Compatibility | Windows® 7, 8.1, 10 (32/64bit)® Server 2008 R2, 2012, 2012 R2, 2016 (64bit) Macintosh OS X V10.10.5-V10.12x |
| Standard Interfaces | USB 2.0 High-Speed 10/100/1000 Base-T/TX Wireless LAN (IEEE 802.11 B/G/N) |
| Ink Droplet Size | 5 Picoliter |
| Ink Capacity | 130 Ml Or 300ml Per Color |
| Ink Type | Pigment Ink |
| Color Set | Pigment: Matte Black, Black, Cyan, Magenta, Yellow |
| Buffer Ram | 2 GB Physical |
| Media Width | Cut Sheet: 8" - 36" (203.2mm - 914.4mm) Roll Feed: 8" - 36" (203.2mm - 914.4mm) |
| Media Thickness | 0.07-0.8mm |
| Maximum Roll Print Length | Roll Feed - 59' (18 Meters) |
| Maximum Media Roll Diameter | 5.9" (150mm) |
| Borderless Printing Width | 8", 10", 12", 14", 16," 17", 20", 24", 36" B4 (10.12"/257 Mm), A3 (11.69"/297 Mm), A3+ (12.95"/329 Mm), A2 (16.54"/420 Mm), B2 (20.28"/515 Mm), A1 (23.39"/594 Mm), B1 (28.66"/ 728 Mm), A0 (33.11"/841 Mm) |
| Paper Feed Method | Roll Feed: One Roll, Top-Loading, Front Output Cut Sheet: Top Loading, Front Output |
| Languages | SGRaster, HPGL/2, HP-RTL, JPEG |
| Noise Level Approx | Operation: 44 DB (A) Standby: 35 DB (A) Or Less Acoustic Power: 6.0 Bels |
| Physical Dimensions | 42" X 51" X 35" (1066.8mm X 1295.4mm X 899mm |
| Weight | Approx.130 Lbs . (58.97 Kg.)Roll Holder Included, No Inks, No Print Heads |
| Power Source | AC-100-240V (50-60Hz) |
| Power Consumption | Maximum: 69W Or Less Standby 3.6W Or Less Power Off: 0.3W Or Less (Compliant With Executive Order) |
| Operating Environment | Temperature: 59°-86° F (15°-30° C) Relative Humidity: 10-80% (No Condensation) |
| Item | Print Head (PF-06) |
| Item | Maintenance Cartridge (MC-31) |
| Item | Ink Tanks (PFI-120/PFI-320) |
| Item | Cutter Blade (CT-08) |
| Warranty | Scanner Type: Contact Image Sensor (CIS) Technology Scan Accuracy: +/- 0.1% Speed: 13 Ips Monochrome, 6 Ips Color (Copy, Standard Mode) Optical Resolutions: 1200dpi (Adjustable From 100 Dpi To 2,400 Dpi) Max Resolutions: 9600dpi Interpolated Max. Document Size Width: 38" Document Width (36" Image Width) Length: 315" (JPG Or PDF), 598" (TIFF) Thickness: 0.079in (2mm) Standard Interface: USB 3.0 (PC Connector Compatible With USB 2.0 And USB 3.0 Sockets) |
| Software Included | TM Unified Printer Driver, Accounting Manager, Apple AirPrint, Canon Print Service, Device Management Console, Direct Print & Share, Free Layout Tool, Free Layout Plus, ImagePROGRAF Printer Driver For Windows®/Mac®, Media Configuration Tool, PosterArtist Lite For Windows, Optimized Driver For AutoCAD, Canon PRINT Inkjet Selphy, Easy Photo Print Editor‡ |
| Print Resolution | 2,400 X 1,200 Dpi (Max) |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
