imagePROGRAF TA-20
- imagePROGRAF TA-20
- 2" Core Media Spool
- US AC Power Cable
- Print Head PF-06
- Maintenance Cartridge (Installed)
- 6 Ink Tanks (55 ml each: MBK x2, C/M/Y/BK)
- Ethernet Card (built-in)
- USB 2.0 High-speed Interface
- USB Connection Sheet
- iWR Service Terms Leaflet
- User Manual
- Quick Setup Guide
- User Software CD for Windows (Printer Driver Utilities)
- User Registration Card
- Media Guide
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
- 802.1x: Helps ensure information is secure when passing over a network by providing authentication to devices attempting to connect to the network.
- SSL/TLS: Allows sensitive information being sent via an internet connection to be sent securely for data being passed between two systems
- IPSec: Authenticates and encrypts data passed over IP networks.
- Plain Paper, Fast (Q5) mode
- Canon products offer certain security features, yet many variables can impact the security of your devices and data. Canon does not warrant that use of its features will prevent security issues. Nothing herein should be construed as legal or regulatory advice concerning applicable laws; customers must have their own qualified counsel determine the feasibility of a solution as it relates to regulatory and statutory compliance. Some security features may impact functionality/performance; you may want to test these settings in your environment.
- Wireless printing requires a working network with wireless 802.11b/g or 802.11n capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
- Your server must be compatible with a WebDAV enabled cloud account, including but not limited to, Google, Carbonite or Rackspace, to take advantage of the cloud functionality. Storage capacity and any pricing thereof are based on the third-party cloud provider's current offering, at its sole discretion. Your cloud account is subject to the third-party cloud provider's terms and conditions.
| Printer Type | 5-Color 24-Inch Printer |
| Nozzle Text | Total: 15,360 MBK: 5,120 Nozzles C, M, Y, BK: 2,560 Nozzles Each |
| Nozzle Pitch | 1200 Dpi Non-Firing Nozzle Detection And Compensation |
| Resolution Text | 2400x1200dpi (Max) |
| Os Compatibility | Windows® 7, 8.1, 10 (32/64bit) Windows® Server 2008 R2, 2012, 2012 R2, 2016 (64bit) Macintosh OS X V10.10.5-V10.12x |
| Standard Interfaces | USB 2.0 High-Speed 10/100/1000 Base-T/TX Wireless LAN (IEEE 802.11 B/G/N) |
| Ink Droplet Size | Minimum 5 Picoliter |
| Ink Capacity | 55 Ml Per Color |
| Ink Type | Pigment Ink |
| Color Set | Pigment: Matte Black, Black, Cyan, Magenta, Yellow |
| Buffer Ram | 2 GB (Physical) |
| Media Width | Cut Sheet - 8"- 17" Roll Feed - 8" - 24" |
| Media Thickness | 0.07-0.8mm |
| Maximum Media Roll Diameter | 5.9" (150mm) |
| Borderless Printing Width | 8" - 24" |
| Paper Feed Method | Roll Feed: One Roll, Top-Loading, Front Output Cut Sheet: Top Loading, Front Output |
| Languages | SGRaster, HPGL/2, HP-RTL, JPEG |
| Noise Level Approx | Operation: 42 DB (A) Standby: 35 DB (A) Or Less Acoustic Power: 5.8 Bels |
| Physical Dimensions | 18" X 39" X 30" (H X W X D) |
| Weight | Approx.82 Lbs (Roll Holder Included, No Inks, No Print Heads) |
| Power Source | AC 100-240V (50-60Hz) |
| Power Consumption | Maximum: 52W Or Less Standby 3.6W Or Less Power Off: 0.3W Or Less (Compliant With Executive Order) |
| Operating Environment | Temperature: 59°-86° F (15°-30° C) Relative Humidity: 10-80% (No Condensation) |
| Item | Print Head (PF-06) |
| Item | Maintenance Cartridge (MC-31) |
| Item | Ink Tanks (PFI-030) |
| Item | Cutter Blade (CT-08) |
| Software Included | TA Unified Printer Driver, Accounting Manager, Apple AirPrint, Canon Print Service, Device Management Console, Direct Print & Share, Free Layout Tool, Free Layout Plus, ImagePROGRAF Printer Driver For Windows®/Mac®, Media Configuration Tool, Optimized Driver For AutoCAD, Canon PRINT Inkjet Selphy, Easy Photo Print Editor |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
