imagePROGRAF PRO-6100
- imagePROGRAF PRO-6100
- Multifunction Roll Unit with Tools (Separate Box)
- Stand
- Tools and Screws
- US AC Power Cable
- Print Head PF-10
- 330ml Starter Ink Tanks (MBK/BK/C/M/Y/PC/PM/GY/PGY/R/B/CO)
- 2" Roll Holder with 3" Core Adapters
- Quick Set-up Guide
- Safety and Environmental Sheet
- Setup Guide
- Printer Stand Setup Guide
- Print Head Alignment Sheet
- USB Connection Sheet
- Software Discs (Windows Drivers)
- Sample media (5 sheets of Heavy Weight Coated HG paper A2 size)
- Call Center Notice Card (USA)
- User Registration Card
- Printer and Print Head Warranty Cards (USA and Canada)
- Canon USA Media Compatibility Sheet
- iWR Service Terms leaflet
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The 60-inch imagePROGRAF PRO-6100 printer is designed to exceed expectations for image quality and color consistency in a large format printer. The use of a 1.28-inch wide 12-channel integrated compact print head, LUCIA PRO ink set plus Chroma Optimizer, a high-precision mechanical platform and the L-COA PRO high-speed image processing engine achieves a balance between exceptional print quality and speed.
The imagePROGRAF PRO-6100 has been designed to include intelligent technology for advanced media handling, increased security features, borderless printing and improved operational design.
Bring your prints to life with the imagePROGRAF PRO Series.
The LUCIA PRO ink set adopts 11-color pigment inks and a Chroma Optimizer. Designed specifically to meet the demands of even the most critical photographer, the LUCIA PRO ink formulation includes microencapsulated colorants that enable smooth gradients, an expanded color gamut, and deeper color expression. This system helps you achieve stunning color reproduction, image clarity, and enhanced darker areas. A first for the Canon large format printers is the addition of a Chroma Optimizer. Used when printing on glossy and semi-glossy paper, this acts as a clear coat, improving color performance and gloss characteristics enriching the dark areas of a print.
This new ink set helps:- Enhance gloss uniformity
- Improve scratch resistance
- Enhance dark area reproduction
- Reduce graininess
The PF-10, a 1.28"-wide print head with 18,432 nozzles equipped with anti-clogging FINE technology, generates fast print speeds while reducing the possibility of clogging. Ink ejection conditions are precisely checked by 27 sensors, and if a clog is detected, another nozzle will provide back-up.
This print head is wider than previous imagePROGRAF print heads requiring models to only have one instead of two. Having only one print head means a more compact printer that achieves faster print speeds while maintaining high print quality.
The Multifunction Roll System, standard with the PRO-6100, utilizes Canon's new intelligent media handling. This system a versatile media handling solution system that enables either a second roll of media to be loaded on the printer, or the unit can be configured as a bi-directional media Take-up unit.
Dual-Roll Feeding: The dual-roll feeding mechanism enables users to load a second roll of a different media type and size so that users can simultaneously switch from printing on matte to gloss paper without pausing their work to reload. Additionally, the second roll can be used to support high-volume printing be enabling two rolls of the same media to be fed to the printer.
Bi-Directional Rewinding: The Multifunction Roll System may also be configured by the operator as a take-up unit to rewind longer printouts. The user can choose to rewind media with the printed surface on the outside or the inside of the roll, thereby supporting “bi-directional rewinding”.
The imagePROGRAF PRO-6100 features a multipositional basket that can be freely adjusted to enable various output positions and options:
- Catch Basket
- Flatbed Stacking
- Slope (can be used to display a print)
Creating large format prints is now easier with the introduction of Professional Print & Layout for imagePROGRAF large format printers. This software offers features that streamline your printing workflow. Compatible with Canon Digital Photo Professional® software, Adobe Photoshop® software, and Adobe Lightroom® software, Professional Print & Layout offers versatility never before seen with Canon Large Format printing.
Features include:- Create and save custom layouts
- Nesting of images
- Import multiple images and make batch edits that apply to all
- Create “Favorites” settings
- Crop images
Recognizing the expanding array of media options for large format printers and to further improve the versatility of these new imagePROGRAF models, Canon has developed a Media Configuration Tool, which allows customers to not only utilize Canon-branded media, but provides the ability to make adjustments to printer settings to enhance the precision and quality of output achieved with third party media.
Settings that can be configured using media parameter adjustment features include:- Media weight and thickness
- Ink drying
- Automatic cutting settings
- Borderless printing
- Paper feed amount
- Print-head height
- Vacuum strength
- Maximum ink usage
In today's printing environment, it is more important than ever to understand how much ink and media each print job is costing your business. Both Mac® and Microsoft® compatible, Accounting Manager serves as a powerful feature, used for accurately managing your print costs. With the Accounting Manager feature you can track how much ink and paper is being consumed when printing in large format of up to 50 printers! Each individual ink tank can have its own cost associated to it, as well as a variety of different paper types. Costs can be assigned to ink and paper to determine expenses based on your own 'Cost of Goods'. The user can also input a variable cost that will be added to the total of the print cost. The data is exportable to a .csv format for Microsoft Excel so the data can be used for billing purposes. This feature will allow you to determine the cost of each print based on your actual cost.
Features include:- Job Cost (ink, Media and variable cost inputted by user)
- Ink Consumed per Job*
- Media Consumed per Job
- Job Completion time
- And more
This Windows® and Macintosh® drivers incorporate simplified page setup options, one-touch borderless printing, expanded color settings, and much more into a printer driver that is intuitive and easy-to-operate while still giving even the most advanced users the tools needed to stay productive.
The Real Preview feature lets users ensure that the print setting and the layout on the roll paper is correct by providing real time preview, allowing users to change the print setting even after clicking on "print." The Free Layout feature enables nesting and custom layouts of images or files of nearly any type (available for both Windows and Mac driver).
- Professional Print & Layout software is compatible with Adobe Photoshop CS5/CS6/CC/CC (2014)/CC (2015), Adobe Photoshop Lightroom 3/4/5/6, and Canon Digital Professional 3.12 or later.
- Wireless printing requires a working network with wireless 802.11b/g or 802.11n capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
- For imagePROGRAF Printer Driver. For printing from PostScript applications such as Adobe Illustrator or QuarkXpress, please use a PostScript compatible RIP package. For a list of Canon recommended RIP packages, please consult with Canon Alliance and Industry Market list of RIP vendors.
- Your server must be compatible with a webDAV enabled cloud account, including but not limited to, Google, Carbonite or Rackspace, to take advantage of the cloud functionality. Storage capacity and any pricing thereof is based on the third-party cloud providers current offering, at its sole discretion. Your cloud account is subject to the third-party cloud provider's terms and conditions. Neither Canon Inc. nor Canon U.S.A., Inc. represents or warrants any third party product, service or feature referenced hereunder.
** The maximum printable length varies, depending on application, OS, and RIP used.
| Printer Type | 11-Color Plus Chroma Optimizer 60-Inch Printer |
| Nozzle Text | Total: 18,432 All Colors: 1,536 Nozzles |
| Nozzle Pitch | 600 Dpi X 2 Non-Firing Nozzle Detection And Compensation |
| Resolution Text | 2400×1200dpi (Max) |
| Os Compatibility | 32bit: Windows® (Vista/7/8, 8.1/10)< 64bit: Windows 7, Windows 8.1, Windows 10 Windows Server 2008R2 , Windows Server 2012/2012R2 Windows Server 2016 , Windows Server 2019 Mac (OS X 10.10.5 - OS10.11), (OS 10.12 - MacOS 10.14) |
| Standard Interfaces | USB 2.0 High-Speed 10/100/1000 Base-T/TX Wireless LAN (IEEE 802.11 B/G/N) USB Thumb Drive |
| Ink Droplet Size | Minimum 4 Picoliter |
| Ink Capacity | 160, 330, Or 700ml Per Color* |
| Ink Type | Pigment Based LUCIA PRO Ink |
| Color Set | Photo Black, Matte Black, Cyan, Magenta, Yellow, Photo Cyan, Photo Magenta, Gray, Photo Gray, Red, Blue, +Chroma Optimizer |
| Hard Drive | 500GB |
| Media Width | Cut Sheet - 8"- 60" Roll Feed - 8" - 60" |
| Media Thickness | Roll: 0.07 - 0.8 Mm (2.8 - 31.5mil) |
| Maximum Roll Print Length | Roll Feed - 59' (18 Meters)** |
| Maximum Media Roll Diameter | 6.7" (170mm) |
| Borderless Printing Width | All Sizes |
| Paper Feed Method | Roll Feed: Two Roll, Front-Loading, Front Output Manual Feed: Front-Loading, Front Output |
| Languages | Swift Graphic Raster (SGRaster) |
| Noise Level Approx | Operation: 50 DB (A) Or Less Accoustic Power: 6.7 Bels Or Less |
| Physical Dimensions | 46.0" (H) X 78.7" (W) X 38.7" (D) (With Basket Open) |
| Weight | Approx.368 Lbs (Roll Holder Included, No Inks, No Print Heads) |
| Power Source | AC 100-240V (50-60Hz) |
| Power Consumption | Maximum: 103 W Or Less Standby 3.6 W Or Less Power Off: 0.3 W Or Less |
| Operating Environment | Temperature: 59 - 86°F Relative Humidity: 10-80% (No Condensation) |
| Item | Print Head (PF-10) |
| Item | Maintenance Cartridge (MC-30) |
| Item | Ink Tanks (PFI-1100/PFI-1300/PFI-1700) |
| Software Included | ImagePROGRAF Printer Driver, Professional Print & Layout, Quick Utility Toolbox, Print Plug-In For Office, Accounting Manager, Device Management Console, Media Configuration Tool, Printer Driver Extra Kit (Free Layout And Advanced Preview), Print Plug-In For Microsoft Word/Excel/PowerPoint (PC Only), Gallery Wrap Feature, Direct Print & Share4 |
Maintenance Cartridge MC-30
PFI-1100 PBK
Photo Black Ink Tank 160ml
PFI-1100 M
Magenta Ink Tank 160ml
PFI-1100 PC
Photo Cyan Ink Tank 160ml
PFI-1100 GY
Gray Ink Tank 160ml
PFI-1300 GY
Gray Ink Tank 330ml
PFI-1300 MBK
Matte Black Ink Tank 330ml
PFI-1300 PC
Photo Cyan Ink Tank 330ml
PFI-1300 Y
Yellow Ink Tank 330ml
PFI-1700 M
Magenta Ink Tank 700ml
PFI-1700 PBK
Photo Black Ink Tank 700ml
PFI-1700 PM
Photo Magenta Ink Tank 700ml
PFI-1700 C
Cyan Ink Tank 700ml
PFI-1100 MBK
Matte Black Ink Tank 160ml
PFI-1100 C
Cyan Ink Tank 160ml
PFI-1100 Y
Yellow Ink Tank 160ml
PFI-1100 PM
Photo Magenta Ink Tank 160ml
PFI-1300 C
Cyan Ink Tank 330ml
PFI-1300 M
Magenta Ink Tank 330ml
PFI-1300 PBK
Photo Black Ink Tank 330ml
PFI-1300 PM
Photo Magenta Ink Tank 330ml
PFI-1700 GY
Gray Ink Tank 700ml
PFI-1700 MBK
Matte Black Ink Tank 700ml
PFI-1700 PC
Photo Cyan Ink Tank 700ml
PFI-1700 Y
Yellow Ink Tank 700ml
PosterArtist
- Template driven poster creation software
- Create professional-posters, banners and signage in just four easy steps
- Over 1500 royalty free images and clip art
- Over 200 professionally pre-designed templates
- Variable Data Printing
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Locating and Installing Your Download Cómo Localizar e Instalar su Descarga Localizando e Instalando seu Download
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
