imagePROGRAF PRO-6000S
- New LUCIA PRO 8-color ink set
- Newly developed 1.28-inch print head with anti-clogging technology
- Driven by the new L-COA PRO high speed image processing engine
- Multifunction Roll System comes standard
- USB drive and Wi-Fi compatible
- Up to 2X faster than previous 8-color models
- imagePROGRAF PRO-6000S
- Multifunction Roll Unit with Tools (Separate Box)
- Stand (legs, basket & tools)
- US AC Power Cable
- Print Head PF-10
- Starter ink tanks (PBK/PC/PM/GY -190ml ) (MBK/C/M/Y – 330ml)
- 2" Roll Holder with 3” Core Adapters
- Quick Guide
- Safety and Environmental Sheet
- Setup Guide
- Printer Stand Setup Guide
- Important Information Sheet
- Print Head Alignment Sheet
- USB Connection Sheet
- Software Discs (Windows Drivers)
- Sample media (5 sheets of Heavy Weight Coated HG paper A2 size)
- User Registration Card
- Canon USA Media Compatibility Sheet
- iWR Service Terms Leaflet
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
This new ink set helps:
- Enhance red color performance
- Reduce graininess
- Enhance dark area reproduction
To enhance print performance, the 8-colors utilize all 12 ink channels in the print head. The LUCIA PRO ink is arranged in a mirror layout on the print head, symmetrically arranging the most important colors: C, M, Y, and MBK. This layout allows for the same ejection order of the four key colors during the bidirectional printing process resulting in denser ink placement and faster prints speeds.
This new print head is wider than previous imagePROGRAF print heads requiring models to only have one instead of two. Having only one print head means a more compact printer that achieves faster print speeds while maintaining high print quality.
Dual –Roll Feeding: The dual-roll feeding mechanism enables users to load a second roll of a different media type and size so that users can simultaneously switch from printing on matte to gloss paper without pausing their work to reload. Additionally, the second roll can be used to support high-volume printing be enabling two rolls of the same media to be fed to the printer.
Bi-Directional Rewinding: The Multifunction Roll System may also be configured by the operator as a take-up unit to rewind longer printouts. The user can choose to rewind media with the printed surface on the outside or the inside of the roll, thereby supporting “bi-directional rewinding”.
- Catch Basket
- Flatbed Stacking
- Slope (can be used to display a print)
Settings that can be configured using media parameter adjustment features include:
- Media weight and thickness
- Ink drying
- Automatic cutting settings
- Borderless printing
- Paper feed amount
- Print-head height
- Vacuum strength
- Maximum ink usage
The Real Preview feature lets users ensure that the print setting and the layout on the roll paper is correct by providing real time preview, allowing users to change the print setting even after clicking on "print." The Free Layout feature enables nesting and custom layouts of images or files of nearly any type (available for both Windows and Mac driver).
- Job Cost (ink, Media and variable cost inputted by user)
- Ink Consumed per Job*
- Media Consumed per Job
- Job Completion time
- And more
- Wireless printing requires a working network with wireless 802.11b/g or 802.11n capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
* The starter ink tanks initially packaged with the printer are not the same capacity as the replacement ink tanks specified here.
** The maximum printable length varies, depending on application, OS, and RIP used.
| Printer Type | 8-Color 60-Inch Printer |
| Nozzle Text | Total: 18,432 All Colors: 1,536 Nozzles |
| Nozzle Pitch | 600 Dpi X 2 Non-Firing Nozzle Detection And Compensation |
| Resolution Text | 2400×1200dpi (Max) |
| Os Compatibility | 32bit: Windows® (Vista/7/8, 8.1/10) 64bit: Windows® (Vista/7/8, 8.1/10) Mac (OS X 10.7.5-10.11) |
| Standard Interfaces | USB 2.0 High-Speed 10/100/1000 Base-T/TX Wireless LAN (IEEE 802.11 B/G/N) |
| Ink Droplet Size | Minimum 4 Picoliter |
| Ink Capacity | 160ml, 330ml, Or 700ml Per Color |
| Ink Type | Pigment Based LUCIA PRO Ink |
| Color Set | Photo Black, Matte Black, Cyan, Magenta, Yellow, Photo Cyan, Photo Magenta, Gray |
| Hard Drive | 320GB |
| Media Width | Cut Sheet - 8"- 60" Roll Feed - 8" - 60" |
| Media Thickness | Roll: 0.07 - 0.8 Mm (2.8 - 31.5mil) |
| Maximum Roll Print Length | Roll Feed - 59' (18 Meters) |
| Maximum Media Roll Diameter | 6.7" (170mm) |
| Borderless Printing Width | 10", 14", 17", B2 (20.3"/515 Mm), A1 (23.4"/594mm), A0 (33.11"841mm), 24", 36", B0 (40.6"/1,030mm), 42",60" |
| Paper Feed Method | Roll Feed: One Roll, Front-Loading, Front Output Manual Feed: Front-Loading, Front Output |
| Languages | Swift Graphic Raster (SGRaster) |
| Noise Level Approx | Operation: 49 DB (A) Or Less Accoustic Power: 6.7 Bels Or Less |
| Physical Dimensions | 46.0" (H) X 78.7" (W) X 38.7" (D) (With Basket Open) |
| Weight | Approx.359 Lbs (Roll Holder Included, No Inks, No Print Heads) |
| Power Source | AC 100-240V (50-60Hz) |
| Power Consumption | Maximum: 113 W Or Less Standby 1.8 W Or Less Power Off: 0.5 W Or Less |
| Operating Environment | Temperature: 59 - 86°F Relative Humidity: 10-80% (No Condensation) |
| Item | Print Head (PF-10) Maintenance Cartridge (MC-30) Ink Tanks (PFI-1100/PFI-1300/PFI-1700) |
| Software Included | ImagePROGRAF Printer Driver, Quick Utility Toolbox, Accounting Manager, Device Management Console, Media Configuration Tool, PosterArtist Lite (PC Only), Printer Driver Extra Kit (Free Layout And Advanced Preview), Print Plug-In For Microsoft Word/Excel/PowerPoint (PC Only), Gallery Wrap Feature |
PFI-1300 PC
Photo Cyan Ink Tank 330ml
PFI-1300 Y
Yellow Ink Tank 330ml
PFI-1300 PM
Photo Magenta Ink Tank 330ml
PFI-1700 C
Cyan Ink Tank 700ml
PFI-1100 PM
Photo Magenta Ink Tank 160ml
PFI-1700 PC
Photo Cyan Ink Tank 700ml
PFI-1300 GY
Gray Ink Tank 330ml
PFI-1300 MBK
Matte Black Ink Tank 330ml
PFI-1100 GY
Gray Ink Tank 160ml
PFI-1100 PBK
Photo Black Ink Tank 160ml
PFI-1700 GY
Gray Ink Tank 700ml
PFI-1700 MBK
Matte Black Ink Tank 700ml
PFI-1700 Y
Yellow Ink Tank 700ml
Maintenance Cartridge MC-30
PFI-1300 C
Cyan Ink Tank 330ml
PFI-1300 M
PFI-1100 MBK
Matte Black Ink Tank 160ml
PFI-1700 PBK
Photo Black Ink Tank 700ml
PFI-1100 Y
Yellow Ink Tank 160ml
PFI-1300 PBK
Photo Black Ink Tank 330ml
PFI-1100 C
Cyan Ink Tank 160ml
PFI-1100 M
PFI-1100 PC
Photo Cyan Ink Tank 160ml
PFI-1700 M
Magenta Ink Tank 700ml
PFI-1700 PM
Photo Magenta Ink Tank 700ml
PosterArtist
- Template driven poster creation software
- Create professional-posters, banners and signage in just four easy steps
- Over 1500 royalty free images and clip art
- Over 200 professionally pre-designed templates
- Variable Data Printing
Print Head PF-10
Roll Holder Set RH2-65
2" or 3" core with supplied adapter
Cutter Blade CT-07
Replacement cutter blade.
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
