imagePROGRAF PRO-4000
- New LUCIA PRO 11-color ink set plus Chroma Optimizer
- Newly developed 1.28-inch print head with anti-clogging technology
- Driven by the new L-COA PRO high speed image processing engine
- Print Studio Pro printing solution software included
- USB drive and Wi-Fi compatible
- Optional Multifunction Roll System
- imagePROGRAF PRO-4000
- Stand (legs, basket & tools)
- US AC Power Cable
- Print Head PF-10
- 330ml Starter Ink Tanks (MBK/BK/C/M/Y/PC/PM/GY/PGY/R/B/CO)
- 2" Roll Holder with 3” Core Adapters
- Quick Guide
- Safety and Environmental Sheet
- Setup Guide
- Printer Stand Setup Guide
- Important Information Sheet
- Print Head Alignment Sheet
- USB Connection Sheet
- Software Discs (Windows Drivers, PosterArtist Lite – 32/64 bit)
- Sample media (5 sheets of Heavy Weight Coated HG paper A2 size)
- User Registration Card
- Canon USA Media Compatibility Sheet
- iWR Service Terms leaflet
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
- Print Studio Pro plug-in software is compatible with Adobe Photoshop CS5/CS6/CC/CC (2014)/CC (2015), Adobe Photoshop Lightroom 3/4/5/6, and Canon Digital Professional 3.12 or later.
- Wireless printing requires a working network with wireless 802.11b/g or 802.11n capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients.
* The starter ink tanks initially packaged with the printer are not the same capacity as the replacement ink tanks specified here.
** The maximum printable length varies, depending on application, OS, and RIP used.
| Printer Type | 11-Color Plus Chroma Optimizer 44-Inch Printer |
| Nozzle Text | Total: 18,432 All Colors: 1,536 Nozzles |
| Nozzle Pitch | 600 Dpi X 2 Non-Firing Nozzle Detection And Compensation |
| Resolution Text | 2400×1200dpi (Max) |
| Os Compatibility | 32bit: Windows® (Vista/7/8, 8.1/10) 64bit: Windows® (Vista/7/8, 8.1/10) Mac (OS X 10.7.5-10.11) |
| Standard Interfaces | USB 2.0 High-Speed 10/100/1000 Base-T/TX Wireless LAN (IEEE 802.11 B/G/N) |
| Ink Droplet Size | Minimum 4 Picoliter |
| Ink Capacity | 160ml, 330ml, Or 700ml Per Color |
| Ink Type | Pigment Based LUCIA PRO Ink |
| Color Set | Photo Black, Matte Black, Cyan, Magenta, Yellow, Photo Cyan, Photo Magenta, Gray, Photo Gray, Red, Blue, +Chroma Optimizer |
| Hard Drive | 320GB |
| Media Width | Cut Sheet - 8"- 44" Roll Feed - 8" - 44" |
| Media Thickness | Roll: 0.07 - 0.8 Mm (2.8 - 31.5mil) |
| Maximum Roll Print Length | Roll Feed - 59' (18 Meters) |
| Maximum Media Roll Diameter | 6.7" (170mm) |
| Borderless Printing Width | 10", 14", 17", B2 (20.3"/515 Mm), A1 (23.4"/594mm), A0 (33.11"841mm), 24", 36", B0 (40.6"/1,030mm), 42",44" |
| Paper Feed Method | (Roll Media Only) 10", 14", 17", B2 (20.3"/515 Mm), A1 (23.4"/594mm), 24" Roll Feed: One Roll, Front-Loading, Front Output Manual Feed: Front-Loading, Front Output |
| Languages | Language: Swift Graphic Raster (SGRaster) |
| Noise Level Approx | Operation: 48 DB (A) Or Less Accoustic Power: 6.4 Bels Or Less |
| Physical Dimensions | 46.0" (H) X 62.7" (W) X 38.7" (D) (With Basket Open) |
| Weight | Approx.271 Lbs (Roll Holder Included, No Inks, No Print Heads) |
| Power Source | AC 100-240V (50-60Hz) |
| Power Consumption | Maximum: 112 W Or Less Standby 1.8 W Or Less Power Off: 0.5 W Or Less |
| Operating Environment | Temperature: 59 - 86°F Relative Humidity: 10-80% (No Condensation) |
| Item | Print Head (PF-10) Maintenance Cartridge (MC-30) Ink Tanks (PFI-1100/PFI-1300/PFI-1700) |
| Software Included | ImagePROGRAF Printer Driver, Print Studio Pro, Quick Utility Toolbox, Print Plug-In For Office, Accounting Manager, Device Management Console, Media Configuration Tool, PosterArtist Lite (PC Only), Printer Driver Extra Kit (Free Layout And Advanced Preview), Print Plug-In For Microsoft Word/Excel/PowerPoint (PC Only) |
PFI-1300 PC
Photo Cyan Ink Tank 330ml
PFI-1300 Y
Yellow Ink Tank 330ml
PFI-1300 PM
Photo Magenta Ink Tank 330ml
PFI-1700 C
Cyan Ink Tank 700ml
PFI-1100 PM
Photo Magenta Ink Tank 160ml
PFI-1700 PC
Photo Cyan Ink Tank 700ml
PFI-1300 GY
Gray Ink Tank 330ml
PFI-1300 MBK
Matte Black Ink Tank 330ml
PFI-1100 GY
Gray Ink Tank 160ml
PFI-1100 PBK
Photo Black Ink Tank 160ml
PFI-1700 GY
Gray Ink Tank 700ml
PFI-1700 MBK
Matte Black Ink Tank 700ml
PFI-1700 Y
Yellow Ink Tank 700ml
Maintenance Cartridge MC-30
PFI-1300 C
Cyan Ink Tank 330ml
PFI-1300 M
PFI-1100 MBK
Matte Black Ink Tank 160ml
PFI-1700 PBK
Photo Black Ink Tank 700ml
PFI-1100 Y
Yellow Ink Tank 160ml
PFI-1300 PBK
Photo Black Ink Tank 330ml
PFI-1100 C
Cyan Ink Tank 160ml
PFI-1100 M
PFI-1100 PC
Photo Cyan Ink Tank 160ml
PFI-1700 M
Magenta Ink Tank 700ml
PFI-1700 PM
Photo Magenta Ink Tank 700ml
PosterArtist
- Template driven poster creation software
- Create professional-posters, banners and signage in just four easy steps
- Over 1500 royalty free images and clip art
- Over 200 professionally pre-designed templates
- Variable Data Printing
Print Head PF-10
Roll Holder Set RH2-45
2" or 3" core with supplied adapter
Cutter Blade CT-07
Replacement cutter blade.
Multifunction Roll System RU-41
Dual-Roll Feed or Bi-Directional Rewind that works with rolls up to 44" wide.
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
