imagePROGRAF iPF9400S
- 60-inch Large Format Printer
- 8-Color LUCIA EX Ink Set
- Borderless printing up to 60"
- Multi-sensor for color density detection
- Fast Economy Printing
- Main Unit with Stand
- 2" Roll Holder with 3" Core Adapters
- 2 Print Heads
- 1 Maintenance Cartridge, (installed)
- 8, 330ml Ink Tanks (BK, MBK, C, M, Y, PC, PM, GY)
- Sample Roll Heavyweight Coated Paper
- Ethernet Card (built in)
- USB 2.0 High Speed Interface
- User Manual CD
- Quick Setup Guide (Poster)
- Printer Reference Guide (Booklet)
- Power Cord
- Registration Card
- User Software CD with:
- imagePROGRAF Printer Driver
- Print Plug-in for Adobe Photoshop
- Media Configuration Tool
- Accounting Manager
- Print Plug-in for Microsoft Office
- Printer Driver Extra Kit
- imagePROGRAF Status Monitor
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
An extremely versatile solution, the 60" imagePROGRAF iPF9400S printer is ideal for those who need quality large format output and maximum productivity. Built for the photography, proofing and production markets, the iPF9400S printer delivers high quality imaging while increasing overall productivity. An incredibly large color spectrum is produced by the 8-Color LUCIA EX pigment ink set, which also provides better scratch resistance and smoother gradations. The new Multi-sensor included with this printer provides improved color density detection and allows for a full calibration to be completed within 15 minutes, with the ability to use non-Canon branded media. Borderless printing of up to 60" is now possible with this printer and the new economy print mode allows for quality printing with limited ink usage. In highest print mode, the order of ink application and layering is optimized to maintain the highest print quality with fewer passes, making this mode twice as fast compared to previous models. Ideal for production grade printing environments, the iPF9400S is up to 40% faster than then 12-Color line of imagePROGRAF Graphic Arts printers. Achieve maximum productivity with large 330ml or 700ml ink tanks and a unique sub-ink tank system for replacing ink on-the-fly without stopping the printer. The iPF9400S is also equipped with a large 250GB hard drive, geared to increase productivity in high volume printing and streamlined workflows, while allowing for faster processing of large files as well as the ability to reprint jobs directly from the printer.
To expand printing options and capabilities, the iPF9400S printer comes bundled with an assortment of Software Solutions such as an Accounting Manager which tracks printing costs and a Print Plug-in for Microsoft Office. The enhanced Print Plug-in for Adobe Photoshop includes a new Adjustment Pattern Setting which allows for multiples of an image to be printed at once with different color values implemented and displayed. The iPF9400S has the ability to print on many types of substrates including glossy, vinyl, recycled and chlorine free media to meet the needs of a variety of applications. To improve versatility, the iPF9400S has a media configuration tool which allows customers to not only utilize existing Canon-branded media, but also with third party media. By combining Canon's technological achievements, the iPF9400S is an excellent solution for portraits, advertisements, retail signage and contract proofs.
- Adjustment Pattern Setting
- Adobe CMM support
- Proof printing support
- Support for commercial profile creation tools
- Media weight and thickness
- Ink drying
- Automatic cutting settings
- Paper feed amount
- Print-head height
- Vacuum strength
- Maximum ink usage
- Job Cost (ink, Media and variable cost inputted by user)
- Ink Consumed per Job*
- Media Consumed per Job
- Job Completion time
- And more *Ink usage is estimate, and error tolerance is ±15%
- And more
1. For imagePROGRAF Printer Driver. For printing from PostScript applications such as Adobe Illustrator or QuarkXpress, please use a PostScript compatible RIP package. For a list of Canon recommended RIP packages, please consult with Canon Alliance and Industry Market list of RIP vendors.
2. The maximum printable length varies depending on the application, OS, and RIP used.
| Printer Type | 8-Color 60-Inch Printer |
| Nozzle Text | Total: 20,480 All Colors: 2,560 Nozzles Each |
| Nozzle Pitch | 1,200 Dpi |
| Nozzle Recovery System | Non-Firing Nozzle Detection And Compensation |
| Resolution Text | 2,400 X 1,200 Dpi (Max) |
| Os Compatibility | Windows® (XP/Vista 32/64bit/Windows 7 32/64bit) Macintosh® (OSX) |
| Standard Interfaces | USB 2.0 High-Speed 10/100/1000 Base-T/TX |
| Ink Droplet Size | 4 Picoliter |
| Ink Capacity | 330ml Per Color2 (Optional 700ml) |
| Ink Type | LUCIA EX Ink (Pigment Based) |
| Color Set | Cyan, Photo Cyan, Magenta, Photo Magenta, Yellow, Black, Matte Black, Gray |
| Buffer Ram | 640 MB |
| Hard Drive | 250 GB |
| Media Width | Cut Sheet: 8" - 60" Roll: 10" - 60" |
| Media Thickness | Front Loading Manual Feed: 0.07 - 0.8mm (2.8 - 31.4mil) Roll: 0.07 - 0.8mm (2.8 - 31.4mil) |
| Maximum Roll Print Length | 59 Feet (18 Meters)2 |
| Maximum Media Roll Diameter | 5.9" (150mm) |
| Borderless Printing Width | 515mm (JIS B2), 1,030mm (JIS B0), 594mm (ISO A1), 841mm (ISO A0), 10", 14", 17", 24", 36", 42", 44", 50", 60" |
| Paper Feed Method | Roll Feed: One Roll, Front Output Front Loading Manual Feed: One Sheet, Front Output |
| Languages | GARO (Canon Proprietary) |
| Noise Level Approx | Operation: 68 DB (A) Or Less Standby: 35 DB (A) Or Less |
| Physical Dimensions | 45" (H) X 90.5" (W) X 30.2" (D) |
| Weight | Approximately 355 Lbs. With Stand |
| Power Source | AC-100-240V (50-60Hz) |
| Power Consumption | Maximum: 190W Or Less Standby: 6W Or Less Power Off: .5W Or Less (Compliant With Executive Order) |
| Operating Environment | Temperature: 59°-86° F (15°-30° C) Relative Humidity - 10-80% (No Condensation) |
| Item | Print Head (PF-05) Maintenance Cartridge (MC-08) Durable Rotary Media Cutter (CT-06) Ink Tanks (PFI-306, PFI-706) |
| Software Included | Canon Printer Driver, Printer Driver Extra Kit (Free Layout, Color ImageRUNNER Enlargement Copy, Advanced Preview), Print Plug-In For Adobe Photoshop, Print Plug-In For Microsoft® Word/Excel/PowerPoint (PC Only), Accounting Manager |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
