imagePROGRAF iPF850 MFP M40
- Complete Scan-to-Copy / File / Share Solution
- Includes M40 Scanner, Printer, High Capacity Stacker, SmartWorks MFP Software Computer, Touch-Screen Monitor and MFP Stand
- 44-inch iPF850 Two Roll Printer with 5-Color Pigment/Dye Reactive ink set
- SmartWorks MFP Software
- Direct Print & Share, Canon's cloud portal software solution for file sharing
- Colortrac Scanner with power cord, USB 3.0 Cable and USB 2.0 Cable (for printer to PC connection)
- Scanner Stand
- Direct Print & Share Cloud Portal Software
- Touch Screen Monitor
- iPF850 Printer with Stand & Portable Media Basket
- 2 - 2" Roll Holder with 3" Core Adapters
- A2 Cut Sheet Heavyweight Coated Paper (5 pieces)
- 1 Print Head
- 1 Maintenance Cartridge (installed)
- 5 Ink Tanks (C, M, Y, BK, MBK)
- Ethernet Card (built in)
- USB 2.0 High-Speed Interface for printer
- User Manual CD for printer
- Quick Start Guide
- Reference Guide
- Menu Map
- Power Cord for printer
- Registration Card for printer
- PosterArtist Lite
- User Software CD with:
- imagePROGRAF Printer Driver
- Printer Driver Extra Kit (FreeLayout, imageRUNNER Enlargement Copy modules)
- imagePROGRAF Status Monitor
- Media Configuration Tool
- Print Plug-in for Microsoft Word
- Accounting Manager
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
This Multi-Function Product's advanced M40 scanner adds versatility to the product capabilities with the ability to scan documents up to 2mm thick. The scanner has the ability to scan documents up to 315" in length as a PDF or JPEG file, and up to 590" in length as a TIFF file. The SmartWorks MFP software simplifies the entire Scan-to-Print, File, and Share process for users of all experience levels. The iPF850 MFP M40 also offers Canon's Direct Print & Share software1, a cloud-portal software solution that enables the viewing, sharing and printing of files from virtually anywhere in the world, a Shortcut Print button for drag and drop printing through hot folder technology, and is compatible with almost any cloud server that's WebDAV compliant. The solution is also equipped for mobile printing through use of the imagePROGRAF Print Utility2 app for iPad®, available as a free download on the App Stores℠.
With true 600dpi optical resolution, CIS scanning technology for incredible line definition and accuracy, and room for documents up to 41" wide (40" image width) by any length, the iPF850 MFP M40 is a versatile imaging solution. And with dynamic preview and a large, simple-to-use touch-screen interface, one-click scanning/copying has never been easier and comes standard with the ability to scan to PDF, JPEG and TIFF file formats. The iPF850 MFP M40 provides the versatility and flexibility needed to be used in a wide variety of industries and applications, all in one captivating package.
A versatile system built for the way you work, the imagePROGRAF iPF850 MFP M40 includes†:
- M40 Scanner
- iPF850 44-inch printer
- Two-media roll system
- High Capacity Stacker
- SmartWorks MFP software
- Touch screen monitor
- MFP stand
Features
- 1200 dpi optical resolution, 9600 dpi maximum resolution
- Image scanning of up to 40" wide, fits documents 42" wide
- Scanning speed of up to 13 inches per second monochrome, 3 inches per second color
- USB 3.0 interface, 75 Mbytes / sec transfer rate
- Scan documents up to 2.0 mm thick
- Face up / Front load / Rear exit
- Straight paper path
The M40 scanner contains a single component image sensor that is the full width of the scanner and has long life LED Bi-directional illumination. Full width image capture, as opposed to time delayed scanning of separate sections, means less risk of misalignment of scan data. LED's require virtually no warm up time and provide a wide and consistent color gamut, with low power consumption and there is less potential for shadowing at creases or folds. A single driven hold up roller provides even pressure across the scan width which means originals are less susceptible to folds or creases.
- Scan lengths of up to 315" (26 ft) for PDF and JPG files, and up to 590" (49 ft) for TIFF files
- Ability to add custom presets with one-touch retrieval for those often-used settings
- New image enhancements for white point adjust, black point adjust, sharpen, mirror, and invert
- Full integration with Canon Digital Print & Share cloud software1
Users have more control over their workflow with access to editing functions such as invert, mirror, and black and white point adjustments. Custom presets help users control the scanner and increase control over printer settings.
- Scan to multipage PDF and PDF/A
- Ability to open and print non SmartWorks MFP PDF files (through Direct Print & Share)
- RGB Color Adjustment capabilities in preview mode
- Auto crop feature that removes printer margins from a scan to create a true 1:1 ratio
Your server must be compatible with a webDAV enabled cloud account, including but not limited to, Google, Carbonite or Rackspace, to take advantage of the cloud functionality. Storage capacity and any pricing thereof is based on the third-party cloud provider's current offering, at its sole discretion. Your cloud account is subject to the third-party cloud provider's terms and conditions. Neither Canon Inc. nor Canon U.S.A., Inc. represents or warrants any third party product, service or feature referenced here under.
- Job Cost (ink, Media and variable cost inputted by user)
- Ink Consumed per Job*
- Media Consumed per Job
- Job Completion time
- And more
The Real Preview feature helps ensure that the print setting and the layout on the roll paper is correct by providing real time preview, allowing users to change the print setting even after clicking on "print." The Free Layout feature enables nesting and custom layouts of images or files of various types (available for both Windows® and Macintosh® drivers).
The imageRUNNER Enlargement Copy feature built-in to the printer driver lets users transfer data from their Color imageRUNNER device with Universal Send to the imagePROGRAF printer - all with the touch of a button - enabling users to easily create posters from hard copy documents.
At a Glance:
- Easy-to-use preset document profiles (examples are Poster, CAD, Photo)
- Automatic print quality options dependent on print application and media
- Real Preview that lets users change document and printer settings after clicking "print"
- Page nesting feature with Free Layout for Windows® and Macintosh®
- imageRUNNER Enlargement Copy feature - with a hot folder solution to print Color imageRUNNER PDFs directly
- Economy Print Mode
- Borderless printing
- Easy setting/Advanced setting
- Optimized module for AutoCAD
New features include:
- Direct Print & Share cloud portal support
- A file format to allow for easy sharing of poster files
†The imagePROGRAF iPF MFP M40 systems contain multiple components, some of which are manufactured by third parties. To the extent that such third party offerings come with limited warranties, such limited warranties are hereby passed to the purchaser, and Canon shall have no obligation or any liability with respect to such third party offerings.
1. Your server must be compatible with a webDAV enabled cloud account, including but not limited to, Google, Carbonite or Rackspace, to take advantage of the cloud functionality. Storage capacity and any pricing thereof is based on the third-party cloud providers current offering, at its sole discretion. Your cloud account is subject to the third-party cloud provider's terms and conditions. Neither Canon Inc. nor Canon U.S.A., Inc. represents or warrants any third party product, service or feature referenced hereunder.
2. Available on AppStore℠. Compatible with iPad® 2 or later, running iOS 6.1 or later. Data charges may apply. Printed output will be same size as original file. Mobile device and large format printer must utilize the same network. Printer must be connected to the same router that mobile device is connected to via wireless capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients. In order to print from imagePROGRAF Print Utility, user must open their PDF file in another, supported iPad® app. Then, the user would select "Open in" and choose the print utility app.
3. For imagePROGRAF Printer Driver. For printing from PostScript applications such as Adobe Illustrator or QuarkXpress, please use a PostScript compatible RIP package.
4. The starter ink tanks initially packaged with the printer are not the same capacity as the replacement ink tanks specified here.
5. The maximum printable length varies depending on the application, OS, and RIP used.
6. The imagePROGRAF iPF MFP M40 systems contain multiple components, some of which are manufactured by third parties. To the extent that such third party offerings come with limited warranties, such limited warranties are hereby passed to the purchaser, and Canon shall have no obligation or any liability with respect to such third party offerings.
7. SingleSensor Technology Assembly means that multiple sensors are contained in one assembly device.
| Printer Type | 5-Color 44-Inch Printer Scanner Type: Contact Image Sensor (CIS) Technology Scan Accuracy: +/- 0.1% Scan Speed: 13 Ips Monochrome, 3 Ips Color |
| Nozzle Pitch | 1,200 Dpi Non-Firing Nozzle Detection And Compensation Number Of Nozzles Total: 15,360 MBK: 5,120 Nozzles C, M, Y, BK: 2,560 Nozzles Each |
| Resolution Text | 2,400 X 1,200 Dpi (Max) Scanner Optical Resolutions: 1200dpi (Adjustable From 100 Dpi To 2,400 Dpi) Max. Resolutions: 9600dpi Interpolated |
| Os Compatibility | Windows® (XP 32bit/Vista/7/8/8.1) Macintosh® (OSX 10.6.8 - 10.10) |
| Standard Interfaces | USB 2.0 High-Speed 10/100/1000 Base-T/TX Scanner USB 3.0 And USB 2.0 High-Speed |
| Ink Droplet Size | 4 Picoliter |
| Ink Capacity | 330ml, 700ml Per Color4 |
| Ink Type | Dye/Pigment Reactive Ink |
| Color Set | Dye: Cyan, Magenta, Yellow, Black Pigment: Matte Black |
| Hard Drive | 320GB |
| Paper Sizes | Scanner: Width: 42 Inch Document Width (40 Inch Image Width) Length: 315" (JPG Or PDF), 590" (TIFF) |
| Media Width | Cut Sheet - 8"- 44" Roll Feed - 10” - 44” |
| Media Thickness | 0.07-0.8mm Scanner 0.079in (2mm) |
| Maximum Roll Print Length | Roll Feed - 59' Cut Sheet - 63" |
| Maximum Media Roll Diameter | 5.9" Or Less |
| Borderless Printing Width | 10", 14", 17", 24", 36", 42" (N/A When Stacker Is In Use) |
| Paper Feed Method | Roll Feed: Dual Roll, Front Loading, Front Output Cut Sheet: One Sheet, Front Loading, Front Output |
| Languages | GARO (Canon Proprietary) HP-GL/2, HP-RTL |
| Noise Level Approx | Operation: 60 DB (A) Or Less Standby: 35 DB (A) Or Less Acoustic Power: Approx. 7.5 Bels Or Less |
| Physical Dimensions | 75"(W)X 52"(D)X 45"(H) Box Dimensions Main Unit (With A Printer Stand, And Palette Included): 82"(W)X42"(D)X48"(H) Stacker, Lower Roll Unit, Lower Rail (Palette Included): 82"(W)X42"(D)X40"(H) |
| Weight | Approximately 470 Lbs Box Weight Main Unit (With A Printer Stand, And Palette Included): Approximately 384 Lbs Stacker, Lower Roll Unit, Lower Rail (Palette Included): Approximately 309 Lbs |
| Power Source | AC-100-240V (50-60Hz) |
| Power Consumption | Maximum: 200W Or Less Standby 5W Or Less Power Off: .5W Or Less (Compliant With Executive Order) |
| Operating Environment | Temperature: 59°-86° F (15°-30° C) Relative Humidity: 10-80% (No Condensation) Computer OEM Operating System: Windows 7 Monitor: Flat Panel Touch-Screen Display |
| Item | Print Head: PF-04 |
| Item | Maintenance Cartridge: MC-09, MC-10 |
| Item | Ink Tanks: PFI-307 (330ml: C, M, Y, BK, MBK) PFI-707 (700ml: C, M, Y, BK, MBK) |
| Software Included | Canon Printer Driver, Printer Driver Extra Kit (Free Layout, Color ImageRUNNER Enlargement Copy, Advanced Preview), Direct Print & Share, ImagePROGRAF Print Utility2, PosterArtist Lite (PC Only), Print Plug-In For Microsoft® Word/Excel/PowerPoint (PC Only), Status Monitor, Media Configuration Tool, Optimized Module For AutoCAD, SmartWorks MFP, Direct Print & Share |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
