imagePROGRAF iPF8400SE
- 44-inch Large Format Printer
- 6-Color LUCIA EX Ink Set
- Optimized Poster Printing Mode
- Sub-ink Tank System and Large Capacity Ink Tanks
- Fast Economy Printing
- Main Unit with Stand and Basket
- 2" Roll Holder with 3" Core Adapters
- 1 Print Head
- 1 Maintenance Cartridge, (installed)
- 6, 330ml Ink Tanks (C, M, Y, BK, MBK, R)
- A2 Sized Heavyweight Coated Paper Cut Sheets (5)
- Ethernet Card (built in)
- USB 2.0 High Speed Interface
- Quick Setup Guide (Poster)
- Printer Reference Guide (Booklet)
- Power Cord
- Registration Card
- User Software CD with:
- imagePROGRAF Printer Driver
- Media Configuration Tool
- Accounting Manager
- Print Plug-in for Microsoft Office
- Printer Driver Extra Kit
- imagePROGRAF Status Monitor
- Direct Print & Share
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
- Job Cost (ink, Media and variable cost inputted by user)
- Ink Consumed per Job*
- Media Consumed per Job
- Job Completion time
- And more
- Media weight and thickness
- Ink drying
- Automatic cutting settings
- Borderless printing
- Paper feed amount
- Print-head height
- Vacuum strength
- Maximum ink usage
2. The maximum printable length varies depending on the application, OS, and RIP used.
†† You must open a Google Cloud account to take advantage of the cloud functionality. Storage capacity and any pricing thereof is based on Google's current offering and is at Google's discretion. Your Google Cloud account is subject to Google's terms and conditions, which is subject to change at Google's discretion. Neither Canon, Inc., nor Canon U.S.A., Inc. represents or warrants any third party product, service or feature referenced hereunder.
| Printer Type | 6-Color 44-Inch Printer |
| Nozzle Text | Total: 15,360 C, M, Y, BK, MBK, R: 2,560 Nozzles Each |
| Nozzle Pitch | 1,200 Dpi Non-Firing Nozzle Detection And Compensation |
| Resolution Text | 2,400 X 1,200 Dpi (Max) |
| Os Compatibility | Windows® (XP/Vista/7/8), Macintosh® (OSX) |
| Standard Interfaces | USB 2.0 High-Speed 10/100 Base-T/TX |
| Ink Droplet Size | 4 Picoliter |
| Ink Capacity | 330 And 700ml Per Color Available |
| Ink Type | LUCIA EX Ink (Pigment Based) |
| Color Set | Cyan, Magenta, Yellow, Black, Matte Black, Red |
| Buffer Ram | 384 MB |
| Media Width | Cut Sheet: 8" - 44" Roll: 10" - 44" |
| Media Thickness | Front Loading Manual Feed: 0.07 - 0.8mm (2.8 - 31.4mil) Roll: 0.07 - 0.8mm (2.8 - 31.4mil) |
| Maximum Roll Print Length | 59 Feet (18 Meters)2 |
| Maximum Media Roll Diameter | 5.9" (150mm) |
| Borderless Printing Width | 515mm (JIS B2), 1,030mm (JIS B0), 594mm (ISO A1), 841mm (ISO A0), 10", 14", 17", 24", 36", 42", 44" |
| Paper Feed Method | Roll Feed: One Roll, Front Output Front Loading Manual Feed: One Sheet, Front Output |
| Languages | GARO (Canon Proprietary) |
| Noise Level Approx | Operation: 50 DB (A) Or Less Standby: 35 DB (A) Or Less Acoustic Power: Approx. 6.8 Bels Or Less |
| Physical Dimensions | 45.0" (H) X 74.5" (W) X 28.9" (D) |
| Weight | Approximately 258lbs. With Stand |
| Power Source | AC-100-240V (50-60Hz) |
| Power Consumption | Maximum: 190W Or Less Standby 5W Or Less Power Off: .5W Or Less (Compliant With Executive Order) |
| Operating Environment | Temperature: 59°-86° F (15°-30° C) Relative Humidity: 10-80% (No Condensation) |
| Item | Print Head (PF-05), Maintenance Cartridge (MC-08), Durable Rotary Media Cutter (CT-06), Ink Tanks (PFI-306, PFI-706) |
| Software Included | Canon Printer Driver, Printer Driver Extra Kit (Free Layout, Color ImageRUNNER Enlargement Copy, Advanced Preview), PosterArtist Lite (PC Only), Print Plug-In For Microsoft® Word/Excel/PowerPoint, Accounting Manager (PC Only), Direct Print & Share, Optimized Module For AutoCAD (PC Only) |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
