imagePROGRAF iPF8300S
- 44-inch Large Format Printer
- 8-Color LUCIA EX ink set
- Built-in Calibration
- 160GB Hard Drive
- Accounting Manager
- Main Unit with Stand & Basket
- 2" Roll Holder with 3" adapters
- 2 Print Heads
- 1 Maintenance Cartridge, (Installed)
- 8, 330ml Ink Tanks (BK/MBK/C/M/Y/PC/PM/GY)
- Sample Roll Heavyweight Coated Paper
- Media Swatch Kit
- Ethernet Card (built in)
- USB 2.0 High Speed Interface
- User Manual CD
- Quick Start Guide
- Reference Guide
- Menu Map
- Power Cord
- Registration Card
- PosterArtist Lite
- User Software CD with:
- imagePROGRAF Printer Driver
- Print Plug-in for Photoshop & Digital Photo Professional
- Print Plug-in for Microsoft Office
- Printer Driver Extra Kit
- Digital Photo Front-Access
- GARO Status Monitor
- Media Configuration Tool
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
- Wider color gamut
- Better scratch resistance
- Less graininess
- Smoother gradation
- Reduced bronzing
- Sharper blacks
- Proof printing support
- Enhanced image processing technology
- Support for commercial profile creation tools
- Full screen preview
- More print quality selections
- Categorized paper type view
- Roll paper layout view
- Bi-cubic enlargement
- Media weight and thickness
- Ink drying time for rolls
- Automatic cutting settings for rolls
- Borderless printing for rolls
- Paper feed amount
- Print-head height
- Vacuum strength
- Maximum ink usage
- Job Name
- Job Completion Time
- Ink consumption per job
- Print dimensions
- Media Type
- Media consumption area per job
- Easy-to-use preset document profiles (examples are Poster, CAD, Photo)
- Automatic print quality options dependent on print application and media
- Real Preview that lets users change document and printer settings after clicking "print"
- Page nesting feature with Free Layout for Windows and Mac
- imageRUNNER Enlargement Copy feature - with a hot folder solution to print Color imageRUNNER PDFs directly without opening in a PDF viewer
- Economy Print Mode
- Easy setting/Advanced setting
- Provides professionally designed templates to simplify poster creation
- Over 1GB of preloaded files in a wide variety of poster designs and artwork
- Auto Design Feature - Template Creation Engine
- Variable Data Printing
- Page Capture feature allows users to load desired data from other applications into a PosterArtist poster, such as Microsoft® Word®, Excel®, and Adobe® Acrobat®
- Import images directly from most digital cameras
- For imagePROGRAF Printer Driver: For printing from PostScript applications such as Adobe Illustrator or QuarkXpress, please use a PostScript compatible RIP package. For a list of Canon recommended RIP packages, please consult with Canon Alliance and Industry Market list of RIP vendors.
- The maximum printable length varies depending on the application, OS, and RIP used.
| Printer Type | 8-Color 44-Inch Printer |
| Nozzle Text | Total: 30,720 C, PC, PM, GY: 5,120 Nozzles Each BK, MBK, Y, M: 2,560 Nozzles Each |
| Nozzle Pitch | 1,200 Dpi |
| Nozzle Recovery System | Non-Firing Nozzle Detection And Compensation |
| Resolution Text | Color:2,400 X 1,200 Dpi (Max) |
| Os Compatibility | Windows XP/Server 2003/Server 2008/Vista/7 (32/64bit), Macintosh OSX 10.3.9-10.6 (32/64bit)1 |
| Standard Interfaces | USB 2.0 High-Speed 10/100/1000 Base-T/TX |
| Ink Compatibility | LUCIA EX Ink (Pigment-Based) |
| Ink Droplet Size | 4 Picoliter |
| Ink Capacity | 330ml Per Color (Optional 700ml) |
| Color Set | Cyan, Photo Cyan, Magenta, Photo Magenta, Yellow, Black, Matte Black, Gray |
| Buffer Ram | 384 MB |
| Hard Drive | 160GB |
| Media Width | Cut Sheet: 8" - 44" Roll: 10" - 44" |
| Media Thickness | Front Loading Manual Feed: 0.07 - 0.8mm (2.8 - 31.4mil) Roll: 0.07 - 0.8mm (2.8 - 31.4mil) |
| Maximum Roll Print Length | 59 Feet (18 Meters)2 |
| Maximum Media Roll Diameter | 5.9" (150mm) |
| Borderless Printing Width | 515 Mm (JIS B2), 1, 030 Mm (JIS B0), 594 Mm (ISO A1), 841 Mm (ISO A0), 10", 14", 17", 24", 36", 42", 44" |
| Paper Feed Method | Roll Feed: One Roll, Front Output Front Loading Manual Feed: One Sheet, Front Output |
| Languages | GARO (Canon Proprietary) |
| Noise Level Approx | Operation: 50 DB (A) Or Less Acoustic Power: 6.8 Bels |
| Physical Dimensions | 45" (H) X 74.5" (W) X 38.4" (D) |
| Weight | Approximately 316lbs. With Stand |
| Power Source | AC-100-120V (50-60Hz) |
| Power Consumption | Maximum: 190W Or Less Standby: 6W Or Less Power Off: 1W Or Less (Compliant With Executive Order) |
| Operating Environment | Temperature: 59°-86° F (15°-30° C) Relative Humidity - 10-80% (No Condensation) |
| Item | Print Head (PF-05) Maintenance Cartridge (MC-08) Durable Rotary Media Cutter (CT-06) Ink Tanks (PFI-304, PFI-704) |
| Software Included | Canon Printer Driver, PosterArtist Lite, Accounting Manager, Print Plug-In For Adobe Photoshop, Print Plug-In For Digital Photo Professional, Print Plug-In For Microsoft Office, Digital Photo Front-Access, Printer Driver Extra Kit (Free Layout, ImageRUNNER Linking Function) |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
