imagePROGRAF iPF825
- 44-inch Dual Roll Large Format Printer
- 5-Color Pigment/Dye Reactive ink set
- Two "D" sized Prints per minute on Plain Paper
- Accounting Manager
- Support for HP/GL2 and HP RTL
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
A 44-inch wide powerhouse printing system designed to enhance productivity for medium to large workgroups, with dual media rolls and high speed throughput, the imagePROGRAF iPF825 is a complete production printing solution. With incredible line accuracy, an 160GB hard drive, excellent media handling, and on-board support for HP-GL/2 and HP RTL files, the iPF825 is a complete and easy-to-use printing solution for any professional with a need for producing intricately detailed full-color renderings, CAD drawings, GIS maps and other large-format output.
Equipped with dual media rolls, the iPF825 eliminates the cause of many bottlenecks in busy printing environments. Automatically switch between different media type, sizes or use two rolls of the same paper for printing of large, consecutive runs.
Its built-in 160GB hard drive makes handling multiple complex jobs simple, especially in shared printer environments. Relieve workload from your computer, store and retrieve print jobs with the touch of a button, and utilize a Remote User Interface and password-protected mailboxes to keep your workgroup productive. The iPF825's Economy Print Mode helps lower cost per print while its sub-ink tank system enables on-the-fly ink replacement for continuous printing. Add a stacker and large format scanner and realize maximum productivity in any environment.
1. For imagePROGRAF Printer Driver. For printing from PostScript applications such as Adobe Illustrator or QuarkXpress, please use a PostScript compatible RIP package. For a list of Canon recommended RIP packages, please consult with Canon Alliance and Industry Market list of RIP vendors.
2. The maximum printable length varies depending on the application, OS, and RIP used.
3. For AutoCAD or AutoCAD LT 2005, 2006, 2007, 2008, 2009, 2010, 2011.
| Printer Type | 5-Color 44-Inch Dual Roll Printer |
| Nozzle Text | Total: 15,360 MBK: 5,120 Nozzles C, M, Y, BK: 2,560 Nozzles Each |
| Nozzle Pitch | 1,200 Dpi Non-Firing Nozzle Detection And Compensation |
| Resolution Text | 2,400 X 1,200 Dpi (Max) |
| Os Compatibility | Windows XP/Server 2003/Server 2008/Vista/7 (32/64bit), Macintosh OSX 10.3.9-10.6 (32 Bit), OS X 10.5-10.6 (64 Bit) |
| Standard Interfaces | USB 2.0 High-Speed 10/100 Base-T/TX |
| Ink Compatibility | 4 Picoliter |
| Ink Capacity | 330ml Per Color (Optional 700ml) |
| Ink Type | Dye/Pigment Reactive Ink |
| Color Set | Dye: Cyan, Magenta, Yellow, Black Pigment: Matte Black |
| Buffer Ram | 32 GB Dedicated File Processing Memory, 384MB RAM |
| Hard Drive | 160 GB |
| Media Width | Cut Sheet: 8" - 44" Roll: 10" - 44" |
| Media Thickness | Front Loading Manual Feed: 0.07 - 0.8mm (2.8 - 31.4mil) Roll: 0.07 - 0.8mm (2.8 - 31.4mil) |
| Maximum Roll Print Length | 59 Feet (18 Meters)2 |
| Maximum Media Roll Diameter | 5.9" (150mm) |
| Borderless Printing Width | (Roll Media Only): 10", 14", 17", B2 (20.3"/515 Mm), A1 (23.4" /594 Mm), A0 (33.1"/841 Mm), 24", 36", B0 (40.6"/1,030mm), 42" |
| Paper Feed Method | Roll Feed: Two Rolls, Front Output Front Loading Manual Feed: One Sheet, Front Output |
| Languages | GARO (Canon Proprietary), HP-GL/2, HP RTL |
| Noise Level Approx | Operation: 52 DB (A) Or Less Standby: 35 DB (A) Or Less Acoustic Power: 6.8 Belts |
| Physical Dimensions | 45.1" (H) X 74.6" (W) X 50.9" (D) |
| Weight | Approximately 416.7 Lbs. With Stand |
| Power Source | AC-100-120V (50-60Hz) |
| Power Consumption | Maximum: 190W Or Less Standby: 6W Or Less Power Off: 1W Or Less (Compliant With Executive Order) |
| Operating Environment | Temperature: 59°-86° F (15°-30° C) |
| Item | Print Head (PF-03) Maintenance Cartridge (MC-09) Ink Tanks (PFI-303/PFI-703) |
| Software Included | PosterArtist Lite, Accounting Manager, Canon Printer Driver, Digital Photo Front-Access, Printer Driver Extra Kit (Free Layout, ImageRUNNER Linking Function), HDI Driver For AutoCAD3 |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
