imagePROGRAF iPF815 MFP M40
- Complete Scan-to-Copy / File / Share Solution
- Includes M40 Scanner, Printer, SmartWorks MFP Software, Touch-screen Monitor and MFP Stand
- 44-inch iPF815 printer with 5-Color Pigment/Dye Reactive ink set
- SmartWorks MFP Software
- Direct Print & Share, Canon's cloud portal software solution for file sharing
- Colortrac Scanner with power cord, USB 3.0 Cable and USB 2.0 Cable (for printer to PC connection)
- Scanner Stand
- Direct Print & Share Cloud Portal Software
- Touch-Screen Monitor
- iPF815 Printer with Stand & Basket
- 2" Roll Holder with 3" Core Adapters
- Sample Media Roll
- 1 Print Head
- 1 Maintenance Cartridge (installed)
- 6 Starter Ink Tanks (C, M, Y, BK, MBK, MBK)
- Ethernet Card (built in)
- USB 2.0 High-Speed Interface for printer
- User Manual CD for printer
- Quick Start Guide
- Reference Guide
- Menu Map
- Power Cord for printer
- Registration Card for printer
- PosterArtist Lite
- User Software CD with:
- imagePROGRAF Printer Driver
- Printer Driver Extra Kit (FreeLayout, imageRUNNER Enlargement Copy modules)
- imagePROGRAF Status Monitor
- Media Configuration Tool
- Print Plug-in for Microsoft Word
- Accounting Manager
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
- M40 Scanner
- iPF815 44-inch printer
- SmartWorks MFP software
- Touch screen monitor
- MFP stand
- 1200 dpi optical resolution, 9600 dpi maximum resolution
- Image scanning of up to 40" wide, fits documents 42" wide
- Scanning speed of up to 13 inches per second monochrome, 3 inches per second color
- USB 3.0 interface, 75 Mbytes / sec transfer rate
- Scan documents up to 2.0 mm thick
- Face up / Front load / Rear exit
- Straight paper path
- New user interface for easy navigation
- Ability to add custom presets with one-touch retrieval for those often-used settings
- New image enhancements for white point adjust, black point adjust, sharpen, mirror, and invert
- Full integration with Canon Digital Print & Share cloud software
- Job Cost (ink, Media and variable cost inputted by user)
- Ink Consumed per Job*
- Media Consumed per Job
- Job Completion time
- And more
- Easy-to-use preset document profiles (examples are Poster, CAD, Photo)
- Automatic print quality options dependent on print application and media
- Real Preview that lets users change document and printer settings after clicking "print"
- Page nesting feature with Free Layout for Windows® and Macintosh®
- imageRUNNER Enlargement Copy feature - with a hot folder solution to print Color imageRUNNER PDFs directly
- Economy Print Mode
- Borderless printing
- Easy setting/Advanced setting
- Optimized module for AutoCAD
1. For imagePROGRAF Printer Driver. For printing from PostScript applications such as Adobe Illustrator or QuarkXpress, please use a PostScript compatible RIP package. For a list of Canon recommended RIP packages, please consult with Canon Alliance and Industry Market list of RIP vendors.
2. The starter ink tanks initially packaged with the printer are not the same capacity as the replacement ink tanks specified here.
3. The maximum printable length varies depending on the application, OS, and RIP used.
4. For AutoCAD or AutoCAD LT 2000. 2000i, 2002, 2004, 2005, 2006, 2007, 2008.
CANON and IMAGEPROGRAF are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. All referenced product names, and other marks, are trademarks of their respective owners. Not responsible for typographical errors. *Prices, specifications and availability are subject to change without notice. Actual prices are set by individual dealers and may vary. All printout images and effects are simulated.
† The imagePROGRAF iPF MFP M40 systems contain multiple components, some of which are manufactured by third parties. To the extent that such third party offerings come with limited warranties, such limited warranties are hereby passed to the purchaser, and Canon shall have no obligation or any liability with respect to such third party offerings.
†† You must open a Google Cloud account to take advantage of the cloud functionality. Storage capacity and any pricing thereof is based on Google’s current offering and is at Google's discretion. Your Google Cloud account is subject to Google's terms and conditions, which is subject to change at Google's discretion. Neither Canon, Inc., nor Canon U.S.A., Inc. represents or warrants any third party product, service or feature referenced hereunder.
SingleSensor Technology Assembly means that multiple sensors are contained in one assembly device.
†††† Canon U.S.A., Inc. has determined which HP devices compete directly with Canon imagePROGRAF devices based on the selling price as well as printing width. The facts, product statistics and specifications about HP products contained in this document were obtained from Cierant. Neither Canon, Inc., nor Canon U.S.A., Inc. represents or warrants any third party product, service or feature referenced hereunder.
© 2015 Canon U.S.A., Inc. All rights reserved.
| Printer Type | 5-Color 44-Inch Printer |
| Nozzle Pitch | 1,200 Dpi |
| Nozzle Recovery System | Non-Firing Nozzle Detection And Compensation |
| Os Compatibility | Windows® (2000/XP/Vista 32/64bit) Macintosh® (OS 10) |
| Standard Interfaces | USB 2.0 High-Speed 10/100 Base-T/TX |
| Ink Droplet Size | 4 Picoliter |
| Ink Capacity | 330ml Per Color (Optional 700ml)2 |
| Color Set | Dye: Cyan, Magenta, Yellow, Black Pigment: Matte Black |
| Buffer Ram | 32 GB Dedicated File Processing Memory, 384MB RAM |
| Hard Drive | 160 GB |
| Media Width | Cut Sheet: Cut Sheet: 8" - 44" Roll Feed: 10" - 44" |
| Media Thickness | Front Loading Manual Feed: 0.07 - 0.8mm (2.8 - 31.4mil) Roll: Roll: 0.07 - 0.8mm (2.8 - 31.4mil) |
| Maximum Roll Print Length | 59 Feet (18 Meters)3 |
| Maximum Media Roll Diameter | 5.9" (150mm) |
| Borderless Printing Width | 10", 14", 17", 24" B2 (20.28"/515 Mm), A1 (23.38"/594mm), A0 (33.11"/841mm), 36" |
| Paper Feed Method | Front Loading Roll Feed: One Roll, Front OutputAutomatic Sheet Feeder Front Loading Manual Feed: One Sheet, Front Output |
| Operating Environment | Temperature: 59°-86° F (15°-30° C) Relative Humidity: 10-80% (No Condensation) |
| Warranty | Scanner Type: Contact Image Sensor (CIS) Technology. Scan Accuracy: +/- 0.1% Speed: 13 Ips Monochrome, 3 Ips Color At 200 Dpi Optical Resolutions:1200 Dpi (Available Resolutions 100, 200, 300, 400, 600, 1200) Max. Resolutions:1200 Dpi Max. Document Size: Width: 42" Document Width (40" Image Width) Length: 315" (JPG/PDF), 598"(TIFF) Thickness 0.079" (2mm) |
| Software Included | Canon Printer Driver, Digital Photo Front-Access, Printer Driver Extra Kit (Free Layout, Color ImageRUNNER Enlargement Copy, Advanced Preview), HDI Driver For AutoCAD4, PosterArtist Lite (PC Only), Print Plug-In For Microsoft® Word/Excel/PowerPoint (PC Only) |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
