imagePROGRAF iPF815 MFP
- Complete Scan-to-Copy / File / E-mail Solution
- Scanner, Printer, Computer, Touch-screen Monitor and MFP Stand
- 44-inch Large Format Printing System with 160GB Hard Drive
- Advanced SmartWorks MFP Software
- Standard Scan File Formats: PDF, JPEG, TIFF
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
1. For imagePROGRAF Printer Driver. For printing from PostScript applications such as Adobe Illustrator or QuarkXpress, please use a PostScript compatible RIP package. For a list of Canon recommended RIP packages, please consult with Canon Alliance and Industry Market list of RIP vendors.
2. The maximum printable length varies depending on the application, OS, and RIP used.
3. For AutoCAD or AutoCAD LT 2005, 2006, 2007, 2008, 2009, 2010, 2011.
| Printer Type | 5-Color 44-Inch Printer |
| Nozzle Text | Total: 15, 360 MBK: 5,120 Nozzles C, M, Y, BK: 2,560 Nozzles Each |
| Nozzle Pitch | 1,200 Dpi |
| Nozzle Recovery System | Non-Firing Nozzle Detection And Compensation |
| Resolution Text | 2,400 X 1,200 Dpi (Max) |
| Os Compatibility | Windows® (2000/XP/Vista 32/64bit) Macintosh® (OS 10) |
| Standard Interfaces | USB 2.0 High-Speed 10/100 Base-T/TX |
| Ink Droplet Size | 4 Picoliter |
| Ink Capacity | 330ml Per Color (Optional 700ml)2 |
| Ink Type | Dye/Pigment Reactive Ink |
| Color Set | Dye: Cyan, Magenta, Yellow, Black Pigment: Matte Black |
| Buffer Ram | 32 GB Dedicated File Processing Memory, 384MB RAM |
| Hard Drive | 160 GB |
| Media Width | Cut Sheet: Cut Sheet: 8" - 44" Roll Feed: 10" - 44" |
| Media Thickness | Front Loading Manual Feed: 0.07 - 0.8mm (2.8 - 31.4mil) Roll: Roll: 0.07 - 0.8mm (2.8 - 31.4mil) |
| Maximum Roll Print Length | 59 Feet (18 Meters)3 |
| Maximum Media Roll Diameter | 5.9" (150mm) |
| Borderless Printing Width | 10", 14", 17", 24" B2 (20.28"/515 Mm), A1 (23.38"/594mm), A0 (33.11"/841mm), 36" |
| Paper Feed Method | Front Loading Roll Feed: One Roll, Front OutputAutomatic Sheet Feeder Front Loading Manual Feed: One Sheet, Front Output |
| Languages | GARO (Canon Proprietary), HP-GL/2, HP-RTL |
| Operating Environment | Temperature: 59°-86° F (15°-30° C) Relative Humidity: 10-80% (No Condensation) |
| Warranty | Scanner Type: Contact Image Sensor (CIS) Technology. Scan Accuracy: +/- 0.1% Speed: 13 Ips Monochrome, 3 Ips Color At 200 Dpi Optical Resolutions:1200 Dpi (Available Resolutions 100, 200, 300, 400, 600, 1200) Max. Resolutions:1200 Dpi Max. Document Size: Width: 42" Document Width (40" Image Width) Length: 315" (JPG/PDF), 598"(TIFF) Thickness 0.079" (2mm) |
| Software Included | Canon Printer Driver, Digital Photo Front-Access, Printer Driver Extra Kit (Free Layout, Color ImageRUNNER Enlargement Copy, Advanced Preview), HDI Driver For AutoCAD4, PosterArtist Lite (PC Only), Print Plug-In For Microsoft® Word/Excel/PowerPoint (PC Only) |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
