imagePROGRAF iPF785 MFP M40
- Complete Scan-to-Print / File / Share Solution
- Includes M40 Scanner, Printer, SmartWorks MFP Software, Computer, Touch-screen Monitor and MFP Stand
- 36-inch iPF785 printer with 5-Color Pigment/Dye Reactive ink set
- Direct Print & Share, Canon's cloud portal software solution for file sharing
- imagePROGRAF Print Utility, Canon's mobile printing app for iPad
- Optional SmartWorks MFP Plus software available
- Colortrac Scanner with power cord, USB 3.0 Cable and USB 2.0 Cable (for printer to PC connection)
- Scanner Stand
- SmartWorks MFP Software
- Touch-Screen Monitor
- iPF785 Printer with Stand & Basket
- 2" Roll Holder with 3" Core Adapters
- Sample Media Cut Sheet
- 1 Print Head
- 1 Maintenance Cartridge (installed)
- 5 Ink Tanks (C, M, Y, BK, MBK)
- Ethernet Card (built in)
- USB 2.0 High-Speed Interface for printer
- User Manual CD for printer
- Quick Start Guide
- Reference Guide
- Menu Map
- Power Cord for printer
- Registration Card for printer
- PosterArtist Lite
- User Software CD with:
- imagePROGRAF Printer Driver
- Printer Driver Extra Kit (FreeLayout, imageRUNNER Enlargement Copy modules)
- imagePROGRAF Status Monitor
- Media Configuration Tool
- Print Plug-in for Microsoft Word
- Accounting Manager
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
- M40 Scanner
- iPF785 36-inch printer
- SmartWorks MFP software
- Touch screen monitor
- MFP stand
- 1200 dpi optical resolution, 9600 dpi maximum resolution
- Image scanning of up to 40" wide, fits documents 42" wide
- Scans documents up to 315” (26 ft) in length as a JPEG or PDF file, and up to 590" (49 ft) in length as a TIFF file
- Scanning speed of up to 13 inches per second monochrome, 3 inches per second color
- USB 3.0 interface, 75 Mbytes / sec transfer rate
- Scan documents up to 2.0 mm thick
- Face up / Front load / Rear exit
- Straight paper path
- Scan lengths of up to 315" (26 ft) for PDF and JPG files, and up to 590" (49 ft) for TIFF files
- Ability to add custom presets with one-touch retrieval for those often-used settings
- New image enhancements for white point adjust, black point adjust, sharpen, mirror, and invert
- Full integration with Canon Digital Print & Share cloud software
- Scan to multipage PDF and PDF/A
- Ability to open and print non SmartWorks MFP PDF files (through Direct Print & Share)
- RGB Color Adjustment capabilities in preview mode
- Auto crop feature that removes printer margins from a scan to create a true 1:1 ratio
- Job Cost (ink, Media and variable cost inputted by user)
- Ink Consumed per Job*
- Media Consumed per Job
- Job Completion time
- And more
- Easy-to-use preset document profiles (examples are Poster, CAD, Photo)
- Automatic print quality options dependent on print application and media)
- Real Preview that lets users change document and printer settings after clicking "print")
- Page nesting feature with Free Layout for Windows® and Macintosh®)
- imageRUNNER Enlargement Copy feature - with a hot folder solution to print Color imageRUNNER PDFs directly )
- Economy Print Mode)
- Borderless printing)
- Easy setting/Advanced setting)
- Optimized module for AutoCAD)
- Direct Print & Share cloud portal support
- New file format to allow for easy sharing of poster files
- Your server must be compatible with a webDAV enabled cloud account, including but not limited to, Google, Carbonite or Rackspace, to take advantage of the cloud functionality. Storage capacity and any pricing thereof is based on the third-party cloud provider’s current offering, at its sole discretion. Your cloud account is subject to the third-party cloud provider's terms and conditions. Neither Canon Inc. nor Canon U.S.A., Inc. represents or warrants any third party product, service or feature referenced hereunder.
- Available on AppStore. Compatible with iPad 2 or later, running iOS 6.1 or later. Data charges may apply. Printed output will be same size as original file. Mobile device and large format printer must utilize the same network. Printer must be connected to the same router that mobile device is connected to via wireless capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients. In order to print from imagePROGRAF Print Utility, user must open their PDF file in another, supported iPad app. Then, the user would select "Open in" and choose the print utility app.
- For imagePROGRAF Printer Driver. For printing from PostScript applications such as Adobe Illustrator or QuarkXpress, please use a PostScript compatible RIP package. For a list of Canon recommended RIP packages, please consult with Canon Alliance and Industry Market list of RIP vendors.
- The starter ink tanks initially packaged with the printer are not the same capacity as the replacement ink tanks specified here.
- The maximum printable length varies depending on the application, OS, and RIP used.
- The imagePROGRAF iPF MFP M40 systems contain multiple components, some of which are manufactured by third parties. To the extent that such third party offerings come with limited warranties, such limited warranties are hereby passed to the purchaser, and Canon shall have no obligation or any liability with respect to such third party offerings.
- SingleSensor Technology Assembly means that multiple sensors are contained in one assembly device.
| Printer Type | 5-Color 36-Inch Printer |
| Nozzle Text | Total: 15,360 MBK: 5,120 Nozzles C, M, Y, BK: 2,560 Nozzles Each |
| Nozzle Pitch | 1,200 Dpi Non-Firing Nozzle Detection And Compensation |
| Resolution Text | 2,400 X 1,200 Dpi (Max) |
| Os Compatibility | Windows® (XP/Vista/7/8) Macintosh® (OSX 10.6.8-10.9X) |
| Standard Interfaces | USB 2.0 High-Speed 10/100/1000 Base-T/TX |
| Ink Droplet Size | 4 Picoliter |
| Ink Capacity | 130ml Or 300ml Per Color4 |
| Ink Type | Dye/Pigment Reactive Ink |
| Color Set | Dye: Cyan, Magenta, Yellow, Black Pigment: Matte Black |
| Buffer Ram | 32GB |
| Hard Drive | 320GB |
| Media Width | Cut Sheet - 8"- 36" (203.2mm – 914mm) Roll Feed – 10” – 36” (254mm – 914mm) |
| Media Thickness | 0.07-0.8mm (2.8-31.4mil) |
| Maximum Roll Print Length | Roll Feed - 59’ (18 Meters) 5 Cut Sheet – 63” (1.6 Meters) |
| Maximum Media Roll Diameter | 5.9" (150mm) |
| Borderless Printing Width | 10", B4, A3, 14", A2, 17", B2 (20.28”/515 Mm), A1 (23.38”/594mm), 24”, A0 (33.11”/841mm), B1, 36” |
| Paper Feed Method | Roll Feed: One Roll, Top-Loading, Front Output Cut Sheet: One Sheet, Top Loading, Front Output |
| Languages | GARO (Canon Proprietary) |
| Noise Level Approx | Operation: 48 DB (A) Or Less .Standby: 35 DB (A) Or Less Acoustic Power: Approx. 6.5 Bels |
| Physical Dimensions | 42" (H) X 51" (W) X 35" (D) (When Basket Is Open) 42" (H) X 51" (W) X 43" (D) (When Basket Is Extended For Flatbed Stacking)Box Dimensions: 31" (H) X 56" (W) X 46" (D) |
| Weight | Approximately 150lbs. With StandBox Weight: Approximately 249 Lbs |
| Power Source | AC-100-240V (50-60Hz) |
| Power Consumption | Maximum: 140W Or Less Standby 5W Or Less Power Off: .5W Or Less (Compliant With Executive Order) |
| Operating Environment | Temperature: 59°-86° F (15°-30° C) Relative Humidity: 10-80% (No Condensation) |
| Item | Print Head: PF-04, Maintenance Cartridge: MC-10, Ink Tanks: PFI-107 (130ml: C, M, Y, BK, MBK), PFI-207 (300ml: C, M, Y, BK, MBK) |
| Warranty | Scanner Type: Contact Image Sensor (CIS) Technology. Scan Accuracy: +/- 0.1% Speed: 13 Ips Monochrome, 3 Ips Color At 200 Dpi Optical Resolutions:1200 Dpi (Available Resolutions 100, 200, 300, 400, 600, 1200) Max. Resolutions:1200 Dpi Max. Document Size: Width: 42" Document Width (40" Image Width) Length: 315" (JPG/PDF), 598"(TIFF) Thickness 0.079" (2mm) |
| Software Included | Canon Printer Driver, Printer Driver Extra Kit (Free Layout, Color ImageRUNNER Enlargement Copy, Advanced Preview), Direct Print & Share, ImagePROGRAF Print Utility2, PosterArtist Lite (PC Only), Print Plug-In For Microsoft® Word/Excel/PowerPoint (PC Only), Status Monitor, Media Configuration Tool, Optimized Module For AutoCAD |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
