imagePROGRAF iPF770 MFP L36ei
- 36" Large Format Printer with Scanner
- Scan to USB Flash Drive
- Easy-to-use scan-to-copy/file system for low-volume and entry-level users
- L36ei Scanner:
- Hardware
- Power Supply
- Power Cord
- Ethernet Cable
- (2) Mounting Brackets
- Calibration Target
- Document Return Guides
- (2) Table-top Feet
- CD for Lei Scan App Software
- Lei Scanner Guide
- iPF770 Printer
- 2" Roll Holder with 3" Core Adapters
- 1 Print Head
- 1 Maintenance Cartridge, (installed)
- 6 Starter Ink Tanks (C, M, Y, BK, MBK, MBK)
- A2 Cut Sheet Heavyweight Coated Paper (5 pieces)
- Ethernet Card (built in)
- USB 2.0 High Speed Interface
- Quick Setup Guide (Poster)
- Power Cord
- Registration Card
- PosterArtist Lite CD
- User Software CD with Software
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
CANON and imagePROGRAF are registered trademarks of Canon Inc. in the United States and may also be registered trademarks or trademarks in other countries. All referenced product names, and other marks, are trademarks of their respective owners. Not responsible for typographical errors. *Prices, specifications and availability are subject to change without notice. Actual prices are set by individual dealers and may vary. All printout images and effects are simulated.
- Your server must be compatible with a webDAV enabled cloud account, including but not limited to, Google, Carbonite or Rackspace, to take advantage of the cloud functionality. Storage capacity and any pricing thereof is based on the third-party cloud provider's current offering, at its sole discretion. Your cloud account is subject to the third-party cloud provider's terms and conditions. Neither Canon Inc. nor Canon U.S.A., Inc. represents or warrants any third party product, service or feature referenced hereunder.
- Available on AppStoreSM. . Compatible with iPad 2 or later, running iOS 6.1 or later. Data charges may apply. Printed output will be same size as original file. Mobile device and large format printer must utilize the same network. Printer must be connected to the same router that mobile device is connected to via wireless capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients. In order to print from imagePROGRAF Print Utility, user must open their PDF file in another, supported iPad app. Then, the user would select "Open in" and choose the print utility app.
- SingleSensor Technology Assembly means that multiple sensors are contained in one assembly device.
- A1 plain paper, cut speed: fast mode.
- For imagePROGRAF Printer Driver. For printing from PostScript applications such as Adobe Illustrator or QuarkXpress, please use a PostScript compatible RIP package. For a list of Canon recommended RIP packages, please consult with Canon Alliance and Industry Market list of RIP vendors.
- For AutoCAD or AutoCAD LT 2000. 2000i, 2002, 2004, 2005, 2006, 2007, 2008 - 2015.
- The starter ink tanks initially packaged with the printer are not the same capacity as the replacement ink tanks specified here.
- The maximum printable length varies depending on the application, OS, and RIP used.
The imagePROGRAF MFP Lei systems contain multiple components, some of which are manufactured by third parties. To the extent that such third party offerings come with limited warranties, such limited warranties are hereby passed to the purchaser, and Canon shall have no obligation or any liability with respect to such third party offerings.
| Printer Type | 5-Color 36-Inch Printer |
| Nozzle Text | Total: 15,360 MBK: 5,120 Nozzles C, M, Y, BK: 2,560 Nozzles Each |
| Nozzle Pitch | 1,200 Dpi Non-Firing Nozzle Detection And Compensation |
| Os Compatibility | Windows® (XP/Vista/7/8.1/10) Mac (OS10.6.8-10.10x) |
| Standard Interfaces | USB 2.0 High-Speed 10/100/1000 Base-T/TX |
| Ink Droplet Size | 4 Picoliter |
| Ink Capacity | 130ml Per Color7 |
| Ink Type | Dye/Pigment Reactive Ink |
| Color Set | Dye: Cyan, Magenta, Yellow, Black Pigment: Matte Black |
| Buffer Ram | 256 MB |
| Hard Drive | N/A |
| Media Width | Cut Sheet - 8"- 36" (203.2mm - 914mm) Roll Feed - 10" - 36" (254mm - 914mm) |
| Media Thickness | 0.07-0.8mm (2.8-31.4mil) |
| Maximum Roll Print Length | Roll Feed - 59' (18 Meters)8 Cut Sheet - 63" (1.6 Meters) |
| Maximum Media Roll Diameter | 5.9" (150mm) |
| Borderless Printing Width | 10", 14", 17", 24" B2 (20.28"/515 Mm), A1 (23.38"/594mm), B1(728mm), A0(841mm), 36" |
| Paper Feed Method | Roll Feed: One Roll, Top-Loading, Front Output Cut Sheet: One Sheet, Top Loading, Front Output |
| Languages | GARO (Canon Proprietary), HP-GL/2, HP-RTL |
| Noise Level Approx | Operation: 47 DB (A) Or Less Standby: 35 DB (A) Or Less Acoustic Power: 6.4 Bels |
| Physical Dimensions | 42" (H) X 51" (W) X 34" (D) (With Basket Open) |
| Weight | Approximately 139 Lbs. With Stand |
| Power Source | AC-100-240V (50-60Hz) |
| Power Consumption | Maximum: 140W Or Less Standby 5W Or Less Power Off: 0.5W Or Less (Compliant With Executive Order) |
| Operating Environment | Temperature: 59°-86° F (15°-30° C) Relative Humidity: 10-80% (No Condensation) |
| Item | Print Head (PF-04) |
| Item | Maintenance Cartridge (MC-10) |
| Item | Ink Tanks (PFI-107: C, M, Y, BK, MBK) |
| Software Included | Canon Printer Driver, Printer Driver Extra Kit (Free Layout, Color ImageRUNNER Enlargement Copy, Advanced Preview), Direct Print & Share, ImagePROGRAF Print Utility2, PosterArtist Lite (PC Only), Print Plug-In For Microsoft® Word/Excel/PowerPoint (PC Only), Status Monitor, Media Configuration Tool, Optimized Module For AutoCAD6 Scanner Type: Contact Image Sensor (CIS) Technology Scan Accuracy: +/- 0.20% Speed: 3 Ips Monochrome, 1 Ips Color (Copy, Standard Mode) Optical Resolutions: 600 Dpi Max Resolutions: 600 Dpi Max. Document Size Width: 38 Inch Document Width (36 Inch Image Width) Length: 109 Inch Thickness: 0.5mm Standard Interface: (Scan To USB) USB 2.0 / (Scan To Network) Gigabit Ethernet |
| Print Resolution | 2,400 X 1,200 Dpi (Max) |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
