imagePROGRAF iPF765 MFP
- 36-inch Large Format Printer
- Integrated Stacker Basket and MFP Stand
- 250 GB Hard Drive
- 2 24" x 36" prints per minute
- Password Protected Interface Lock
- Colortrac Scanner with power cord & USB 2.0 Cable
- Scanner Stand
- SmartWorks MFP Software
- Computer
- Touch-Screen Monitor
- iPF765 Printer with Stand & Basket
- 2" Roll Holder with 3" Core Adapters
- Sample Media Cut Sheet
- 1 Print Head
- 1 Maintenance Cartridge (installed)
- 5 Ink Tanks (C, M, Y, BK, MBK)
- Ethernet Card (built in)
- USB 2.0 High-Speed Interface
- User Manual CD
- Quick Start Guide
- Reference Guide
- Menu Map
- Power Cord
- One Year Warranty Card
- Registration Card
- PosterArtist Lite
- User Software CD with:
- imagePROGRAF Printer Driver
- Printer Driver Extra Kit (FreeLayout, imageRUNNER Enlargement Copy modules)
- imagePROGRAF Status Monitor
- Media Configuration Tool
- Print Plug-in for Microsoft Word
- Accounting Manager
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The Canon imagePROGRAF iPF765 MFP 36" large format imaging system is designed to meet the speed and precision requirements for AEC, CAD, MCAD, ECAD, and applications, with outstanding ease-of-operation to handle all-purpose, office projects. The scanner stand now connects directly to the printer stand to create a one piece structure and now has options for the position of the monitor. The iPF765 MFP provides a fast and effective system for copying, archiving and distributing maps, drawings, renderings, site and facilities management plans, design and layout proofs, posters and more.
With true 600dpi optical resolution, CIS scanning technology for incredible line definition and accuracy, and room for documents up to 41" wide (40" image width) by any length*, the iPF765 MFP is a versatile imaging solution. And with dynamic preview and a large, simple-to-use touch-screen interface, one-click scanning/copying has never been easier. Comes standard with the ability to scan to PDF, JPEG and TIFF file formats.
An environmentally-conscious design with fully front-accessible operations allows for outstanding ease-of-use and flush wall installation in any environment. From loading paper to navigating through an intuitive control panel, the iPF765 MFP simplifies your workflow. An increased hard drive capacity on the iPF765 MFP streamlines the printing workflow by bearing the processing workload on the printer to increase overall print processing times. And with a sub-ink tank system and Gigabit Ethernet support, the iPF765 MFP provides the versatility and flexibility needed to be used in a wide variety of industries and applications, all in one captivating package.
- Job Cost (ink, Media and variable cost inputted by user)
- Ink Consumed per Job*
- Media Consumed per Job
- Job Completion time
- And more
*Ink usage is estimate, and error tolerance is ±15%
- Easy-to-use preset document profiles (examples are Poster, CAD, Photo)
- Automatic print quality options dependent on print application and media
- Real Preview that lets users change document and printer settings after clicking "print"
- Page nesting feature with Free Layout for Windows and Mac
- imageRUNNER Enlargement Copy feature - with a hot folder solution to print Color imageRUNNER PDFs directly without opening in a PDF viewer
- Economy Print Mode
- Borderless printing
- Easy setting/Advanced setting
- Optimized module for AutoCAD
1. For imagePROGRAF Printer Driver. For printing from PostScript applications such as Adobe Illustrator or QuarkXpress, please use a PostScript compatible RIP package. For a list of Canon recommended RIP packages, please consult with Canon Alliance and Industry Market list of RIP vendors.
2. The starter ink tanks initially packaged with the printer are not the same capacity as the replacement ink tanks specified here.
3. The maximum printable length varies depending on the application, OS, and RIP used.
| Printing Method | 5-Color 36-Inch Printer |
| Nozzle Text | Total: 15,360 MBK: 5,120 Nozzles C, M, Y, BK: 2,560 Nozzles Each Nozzle Pitch: 1,200 Dpi Non-Firing Nozzle Detection And Compensation |
| Resolution Text | 2,400 X 1,200 Dpi (Max) |
| Ink Compatibility | Dye/Pigment Reactive InkInk Capacity: 130ml Per Color2 |
| Ink Droplet Size | 4 Picoliter Color Set: Dye: Cyan, Magenta, Yellow, Black Pigment: Matte Black |
| Buffer Ram | 256MB Hard Drive: 250MB |
| Paper Sizes | Media Width: Cut Sheet: 8" - 36" Roll: 10" - 36" Media Thickness: Top Loading Manual Feed: 0.07 - 0.8mm (2.8 - 31.4mil)Roll: 0.07 - 0.8mm (2.8 - 31.4mil) Maximum Roll Print Length: 59 Feet (18 Meters)2 Maximum Media Roll Diameter: 5.9 |
| Automatic Sheet Feeder | Top Loading Roll Feed: One Roll, Front Output Top Loading Manual Feed: One Sheet, Front Output Languages: GARO (Canon Proprietary) |
| Scanner Type | Contact Image Sensor (CIS) Technology - Requires No Stitching Or Maintenance Adjustment. |
| Scanning Element | Scan Accuracy: +/- 0.1% Speed: 10.1 Ips (Monochrome) 1.67 Ips (Color) |
| Max Resolution Text | 600dpi |
| Max Document Size | Width: 41 Inch Document Width Length: 96 Inches Thickness: 0.012in (0.3mm) |
| Os Compatibility | Windows® (XP/Vista/7) Macintosh® (OS10.4.11-10.7) |
| Standard Interface | USB 2.0 High-Speed 10/100/1000 Base-T/TX |
| Software Included | PosterArtist Lite, Accounting Manager, Canon Printer Driver, Printer Driver Extra Kit (Free Layout, ImageRUNNER Linking Function) SmartWorks MFP |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
