imagePROGRAF iPF670E
- iPF670E Printer
- 2" Roll Holder
- 1 Print Head
- 1 Maintenance Cartridge, (installed)
- 6 Ink Tanks (C, M, Y, BK, MBK, MBK)
- Ethernet Card (built in)
- USB 2.0 High Speed Interface
- Quick Setup Guide (Poster)
- Power Cord
- One Year Warranty Card
- Registration Card
- Software Disc (Print Driver for Windows 64-bit)
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
- 24-inch Printer
- 5-Color Dye/Pigment Reactive Ink Set (including BK ink for glossy papers)
- 7X the amount of starter ink than comparable competitor models
- Sub-Ink Tank System & Hot Swap Ink Tanks
- Fast Printing – currently over 40% faster than its competitor models1
- Non-firing Nozzle Detection
At A Glance
1. Easy-to-use preset document profiles (examples are Poster, CAD, Photo)
2. Automatic print quality options dependent on print application and media
3. Real Preview that allows you to change the document and printer settings after clicking "print"
4. Page nesting feature with Free Layout for Windows and Mac
5. imageRUNNER Enlargement Copy feature - with a hot folder solution to print Color imageRUNNER PDFs directly without opening in a PDF viewer
6. Economy Print Mode
7. Borderless printing
8. Easy setting/Advanced setting
- Log Recording Time
- Job Name
- Client Job ID
- Client Job Submission Time
- Job Execution Time
- Job Completion Time
- Job Completion State
- Media Type
- Number of completed pages
- Media consumption area per job
- Direct Print & Share cloud portal support
- File format to allow for easy sharing of poster files
B.The maximum printable length varies depending on the application, OS, and RIP used.
* As of April 3, 2017, Actual prices are set by dealers and may vary.
1. A1 coated paper: standard mode.
2. Your server must be compatible with a webDAV enabled cloud account, including but not limited to, Google, Carbonite or Rackspace, to take advantage of the cloud functionality. Storage capacity and any pricing thereof is based on the third-party cloud provider's current offering, at its sole discretion. Your cloud account is subject to the third-party cloud provider's terms and conditions. Neither Canon Inc. nor Canon U.S.A., Inc. represents or warrants any third party product, service or feature referenced hereunder.
3. For imagePROGRAF Printer Driver. The Windows 64-bit driver comes standard with the printer. All other drivers must be downloaded from www.usa.canon.com. For printing from PostScript applications such as Adobe Illustrator or QuarkXpress, please use a PostScript compatible RIP package. For a list of Canon recommended RIP packages, please consult with Canon Alliance and Industry Market list of RIP vendors.
4. Available for download from usa.canon.com.
5. For AutoCAD 2008 ~ 2016 (32-bit/64-bit) or AutoCAD LT 2008 ~ 2016 (32-bit)/2009 ~ 2016 (64-bit).
| Printer Type | 5-Color 24-Inch Printer |
| Nozzle Text | Total: 15,360 MBK: 5,120 Nozzles C, M, Y, BK: 2,560 Nozzles Each |
| Nozzle Pitch | 1,200 Dpi Non-Firing Nozzle Detection And Compensation |
| Resolution Text | 2,400 X 1,200 Dpi (Max) |
| Os Compatibility | Windows® (Vista/7/8.1/10) Macintosh® (OSX 10.7.5-10.11X)A |
| Standard Interfaces | USB 2.0 High-Speed 10/100/1000 Base-T/TX |
| Ink Droplet Size | Maximum 4 Picoliter |
| Ink Capacity | 90ml Per Tank |
| Ink Type | Dye/Pigment Reactive Ink |
| Color Set | Dye: Cyan, Magenta, Yellow, Black Pigment: Matte Black |
| Buffer Ram | 256MB |
| Media Width | Roll Feed – 10" - 24" (254mm - 610mm) |
| Media Thickness | 0.07-0.8mm (2.8-31.4mil) |
| Maximum Roll Print Length | 59' (18 Meters) B |
| Maximum Media Roll Diameter | 5.9" (150mm) |
| Borderless Printing Width | 10", B4, A3, 14", A2, 17", B2 (20.28”/515 Mm), A1 (23.38”/594mm), 24" |
| Paper Feed Method | Roll Feed: One Roll, Top-Loading, Front Output |
| Languages | GARO (Canon Proprietary) |
| Noise Level Approx | Operation: 47 DB (A) Standby:35 DB (A) Or Less Acoustic Power: Approx. 6.4 Bels |
| Physical Dimensions | 42" (H) X 39" (W) X 34" (D) (When Basket Is Open) 20" (H) X 39" (W) X 27" (D) (Without Stand) |
| Weight | Approximately 92 Lb. Without Stand Approximately 113 Lb. With Stand |
| Power Source | AC-100-240V (50-60Hz) |
| Power Consumption | Maximum: 140W Or Less Standby 5W Or Less Power Off: .5W Or Less (Compliant With Executive Order) |
| Operating Environment | Temperature: 59°-86° F (15°-30° C) Relative Humidity: 10-80% (No Condensation) |
| Item | Print Head: PF-04 Maintenance Cartridge: MC-10 Ink Tanks: PFI-007 (90ml: C, M, Y, BK, MBK, MBK) |
| Software Included | Software Available For Download: Canon Printer Driver3, Printer Driver Extra Kit (Free Layout, Color ImageRUNNER Enlargement Copy, Advanced Preview), Direct Print & Share, PosterArtist Lite (PC Only), Print Plug-In For Microsoft® Word/Excel/PowerPoint (PC Only), Status Monitor, Media Configuration Tool, Optimized Module For AutoCAD |
Maintenance Cartridge MC-10
Printer Stand ST-26
PosterArtist
- Template driven poster creation software
- Create professional-posters, banners and signage in just four easy steps
- Over 1500 royalty free images and clip art
- Over 200 professionally pre-designed templates
- Variable Data Printing
Print Head PF-04
Roll Holder Set RH2-26
2" or 3" core with supplied adapter
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
