imagePROGRAF iPF670 MFP L24e
- iPF670 MFP L24e with 24-inch wide scanner
- Easy-to-use scan-to-copy/file system for low-volume and entry-level users
- Direct Print & Share, Canon's cloud portal software solution for file sharing
- imagePROGRAF Print Utility, Canon's mobile printing app for iPad
- L24e Scanner includes:
- Hardware
- Power Supply
- Power Cord
- Ethernet Cable
- (2) Mounting Brackets
- Calibration Target
- Document Return Guides
- (2) Table-top Feet
- CD for Le Scan App Software
- Le Scanner Guide
- iPF670 Printer
- 2" Roll Holder with 3” Core Adapters
- 1 Print Head
- 1 Maintenance Cartridge, (installed)
- 6 Starter Ink Tanks (C, M, Y, BK, MBK, MBK)
- A2 Cut Sheet Heavyweight Coated Paper (5 pieces)
- Ethernet Card (built in)
- USB 2.0 High Speed Interface
- Quick Setup Guide (Poster)
- Power Cord
- PosterArtist Lite CD
- User Software CD with:
- imagePROGRAF Printer Driver
- Printer Driver Extra Kit (Free Layout, imageRUNNER Enlargement Copy modules) PC only
- imagePROGRAF Status Monitor PC only
- imagePROGRAF Direct Print & Share
- imagePROGRAF Print Plug-in for Microsoft Office®
- Media Configuration Tool
- Accounting Manager
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
This is the ideal system for those who do not require the advanced functionality of the MFP M40 imaging system. The new Le Series complements the current MFP M40 product line by providing a product that offers basic scan-to-copy capabilities at an affordable price.
Not just offering scan-to-copy. this imaging system also gives you the ability to scan to USB, scan to copy and archive, scan to multipage PDF and scan to your PC as well as reduce and enlarge images. With three different quality modes available, you can choose Draft, Standard or Best mode based on the scan/print you are making.
Scan-to-Copy/File Solution
The iPF670 MFP L24e is an affordable solution for providing easy-to-use scan-to-copy/file capabilities for the entry-level user. Designed for simple operation, this MFP has intuititive hardware and software making the learing curve minimal for those new to large format scanning.
A versatile system built for the way you work, the imagePROGRAF iPF670 MFP L24e includes:
- L24e Scanner
- iPF670 24-inch Printer
The iPF670 system comes available with user-friendly software solutions ready to meet your printing needs. Direct Print & Share1, Canon’s cloud portal solution and batch printing software, is available as a download and allows for files to be uploaded, downloaded, shared and printed from almost anywhere in the world! Also downloadable is a mobile printing app, imagePROGRAF Print Utility2, which allows for PDFs as well as JPEGs and PNGs to be printed through use of an Apple® iPad®2. The Accounting Manager software (PC only) allows you to track job costs, while the Print Plug-in for Microsoft® Office enables for documents created with Word®, Excel® or PowerPoint® to be easily printed in large format. Creating custom signage has never been easier with Canon's included PosterArtist Lite poster creation software, this easy-to-use software will have you creating professional large format prints quickly in just four easy to follow steps.
The L24e scanner incorporates a SingleSensor assembly technology, which helps provide consistent and better color accuracy with more detail in the shadows and highlights than a staggered CIS array scanner3.
Features:
The L24e scanner contains a single component image sensor that is the full width of the scanner and has long life LED Bi-directional illumination. Full width image capture, as opposed to time delayed scanning of separate sections, means less risk of misalignment of scan data. LED’s require virtually no warm up time and provide a wide and consistent color gamut, with low power consumption and less potential for shadowing at creases or folds.
The Real Preview feature allows you to check the print setting and the layout on the roll paper by providing a real time preview, giving you the option to change the print setting even after clicking “print." The Free Layout feature enables nesting and custom layouts of images or files of nearly any type (available for both Windows® and Apple® driver).
The imageRUNNER Enlargement Copy feature built-in to the printer driver lets you transfer data from their Color imageRUNNER device with Universal Send to the imagePROGRAF printer - all with the touch of a button - allowing you to easily create posters from hard copy documents.
| For those with more demanding poster creation needs, Canon's optional PosterArtist offers advanced features such as Auto Design, Variable Data, and in-application image editing features, as well as additional templates, royalty-free photos, and clip art. The built-in weblink feature in PosterArtist Lite links you directly to the PosterArtist website for useful hints and tips, and for even more free content for download.
Canon imagePROGRAF Accounting Manager tracks how much ink and media is being consumed while printing. Costs can be assigned to ink and paper to determine expenses based on “Cost of goods”. You can also input a variable cost that will be added to the total of the cost per print. The data is exportable to a .csv format for Microsoft Excel, from there the data can be used for billing purposes.
Accounting Features:
2. Automatic print quality options dependent on print application and media
3. Real Preview that allows you to change the document and printer settings after clicking "print"
4. Page nesting feature with Free Layout for Windows and Mac
5. imageRUNNER Enlargement Copy feature - with a hot folder solution to print Color imageRUNNER PDFs directly without opening in a PDF viewer
6. Economy Print Mode
7. Borderless printing
8. Easy setting/Advanced setting
- Your server must be compatible with a webDAV enabled cloud account, including but not limited to, Google, Carbonite or Rackspace, to take advantage of the cloud functionality. Storage capacity and any pricing thereof is based on the third-party cloud provider's current offering, at its sole discretion. Your cloud account is subject to the third-party cloud provider's terms and conditions. Neither Canon Inc. nor Canon U.S.A., Inc. represents or warrants any third party product, service or feature referenced hereunder.
- Available on AppStoresm. . Compatible with iPad 2 or later, running iOS 6.1 or later. Data charges may apply. Printed output will be same size as original file. Mobile device and large format printer must utilize the same network. Printer must be connected to the same router that mobile device is connected to via wireless capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients. In order to print from imagePROGRAF Print Utility, user must open their PDF file in another, supported iPad app. Then, the user would select "Open in" and choose the print utility app.
- SingleSensor Technology Assembly means that multiple sensors are contained in one assembly device.
- A1 plain paper, cut speed: fast mode.
- For imagePROGRAF Printer Driver. For printing from PostScript applications such as Adobe Illustrator or QuarkXpress, please use a PostScript compatible RIP package. For a list of Canon recommended RIP packages, please consult with Canon Alliance and Industry Market list of RIP vendors.
- For AutoCAD or AutoCAD LT 2000. 2000i, 2002, 2004, 2005, 2006, 2007, 2008 - 2015
- The starter ink tanks initially packaged with the printer are not the same capacity as the replacement ink tanks specified here.
- The maximum printable length varies depending on the application, OS, and RIP used.
| Printer Type | 5-Color 24-Inch Printer |
| Nozzle Text | Total: 15,360 MBK: 5,120 Nozzles C, M, Y, BK: 2,560 Nozzles Each |
| Nozzle Pitch | 1,200 Dpi Non-Firing Nozzle Detection And Compensation |
| Os Compatibility | Windows® (XP/Vista/7/8.1/10) Mac (OS10.6.8-10.10x) |
| Standard Interfaces | USB 2.0 High-Speed 10/100/1000 Base-T/TX |
| Ink Droplet Size | 4 Picoliter |
| Ink Capacity | 130ml Per Color7 |
| Ink Type | Dye/Pigment Reactive Ink |
| Color Set | Dye: Cyan, Magenta, Yellow, Black Pigment: Matte Black |
| Buffer Ram | 256 MB |
| Hard Drive | N/A |
| Media Width | Cut Sheet - 8"- 24" (203.2mm - 610mm) Roll Feed - 10" - 24" (254mm - 610mm) |
| Media Thickness | 0.07-0.8mm (2.8-31.4mil) |
| Maximum Roll Print Length | Roll Feed - 59' (18 Meters)8 Cut Sheet - 63" (1.6 Meters) |
| Maximum Media Roll Diameter | 5.9" (150mm) |
| Borderless Printing Width | 10", 14", 17", 24" B2 (20.28"/515 Mm), A1 (23.38"/594mm) |
| Paper Feed Method | Roll Feed: One Roll, Top-Loading, Front Output Cut Sheet: One Sheet, Top Loading, Front Output |
| Languages | Language: GARO (Canon Proprietary), HP-GL/2, HP-RTL |
| Noise Level Approx | Operation: 47 DB (A) Or Less Standby: 35 DB (A) Or Less Acoustic Power: 6.4 Bels |
| Physical Dimensions | 42" (H) X 39" (W) X 34" (D) (With Basket Open) |
| Weight | Approximately 116 Lbs. With Stand |
| Power Source | AC-100-240V (50-60Hz) |
| Power Consumption | Maximum: 140W Or Less Standby 5W Or Less Power Off: 0.5W Or Less (Compliant With Executive Order) |
| Operating Environment | Temperature: 59°-86° F (15°-30° C) Relative Humidity: 10-80% (No Condensation) |
| Item | Print Head (PF-04) |
| Item | Maintenance Cartridge (MC-10) |
| Item | Ink Tanks (PFI-107: C, M, Y, BK, MBK) |
| Warranty | Scanner Type: Contact Image Sensor (CIS) Technology Scan Accuracy: +/- 0.20% Speed: 3 Ips Monochrome, 1 Ips Color (Copy, Standard Mode) Optical Resolutions: 600 Dpi Max Resolutions: 600 Dpi Max. Document Size Width: 26 Inch Document Width (24 Inch Image Width) Length: 109 Inch Thickness: 0.5mm Standard Interface: (Scan To USB) USB 2.0 / (Scan To Network) Gigabit Ethernet |
| Software Included | Canon Printer Driver, Printer Driver Extra Kit (Free Layout, Color ImageRUNNER Enlargement Copy, Advanced Preview), Direct Print & Share, ImagePROGRAF Print Utility2, PosterArtist Lite (PC Only), Print Plug-In For Microsoft® Word/Excel/PowerPoint (PC Only), Status Monitor, Media Configuration Tool, Optimized Module For AutoCAD6 |
| Print Resolution | 2,400 X 1,200 Dpi (Max) |
PFI-107MBK
Matte Black Ink Tank 130ml
PFI-107BK
PFI-107M
Magenta Ink Tank 130ml
Maintenance Cartridge MC-10
PFI-107C
Cyan Ink Tank 130ml
PFI-107Y
Yellow Ink Tank 130ml
PosterArtist
- Template driven poster creation software
- Create professional-posters, banners and signage in just four easy steps
- Over 1500 royalty free images and clip art
- Over 200 professionally pre-designed templates
- Variable Data Printing
Print Head PF-04
Roll Holder Set RH2-33
2" or 3" core with supplied adapter
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
