imagePROGRAF iPF670
- 24-inch, 5-Color Large Format Printer
- Stand Edition Available
- For Entry-Level, Low Volume Users
- Sub-ink Tank System
- Print Speeds of up to 28 seconds per A1/ sized print
- Creative and Workflow software included
- iPF670 Printer (Stand option available)
- 2" Roll Holder with 3" Core Adapters
- 1 Print Head
- 1 Maintenance Cartridge, (installed)
- 6 Starter Ink Tanks (C, M, Y, BK, MBK, MBK)
- Sample Cut Sheet Coated Paper (A2 size/5 sheets)
- Ethernet Card (built in)
- USB 2.0 High Speed Interface
- Quick Setup Guide (Poster)
- Power Cord
- Registration Card
- PosterArtist Lite Application CD
- User Software CD with:
- imagePROGRAF Printer Driver
- Printer Driver Extra Kit (Free Layout, imageRUNNER Enlargement Copy modules) PC only
- imagePROGRAF Status Monitor PC only
- imagePROGRAF Direct Print & Share
- imagePROGRAF Print Plug-in for Microsoft Office®
- Media Configuration Tool
- Accounting Manager
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
From a software perspective, the iPF670 printer comes loaded with user-friendly software solutions ready to meet your printing needs. Direct Print & Share, Canon’s cloud portal solution2, is available as a download and allows for files to be uploaded, downloaded, shared and printed from almost anywhere in the world! Also downloadable is a mobile printing app, imagePROGRAF Print Utility2, which allows for PDFs to be printed through use of an Apple® iPad®. The Accounting Manager software (PC only) allows you to track job costs, while the Print Plug-in for Microsoft Office enables for documents created with Word, Excel or PowerPoint to be easily printed in large format. Creating custom signage has never been easier with Canon's included PosterArtist Lite poster creation software, this easy-to-use software will have you creating professional large format prints quickly in just four easy to follow steps. To improve versatility, the iPF670 printer has a Media Configuration Tool that will give you optimal usage of your Canon-branded media when creating your desired output.
1. Easy-to-use preset document profiles (examples are Poster, CAD, Photo)
2. Automatic print quality options dependent on print application and media
3. Real Preview that allows you to change the document and printer settings after clicking "print"
4. Page nesting feature with Free Layout for Windows and Mac
5. imageRUNNER Enlargement Copy feature - with a hot folder solution to print Color imageRUNNER PDFs directly without opening in a PDF viewer
6. Economy Print Mode
7. Borderless printing
8. Easy setting/Advanced setting
- Log Recording Time
- Job Name
- Client Job ID
- Client Job Submission Time
- Job Execution Time
- Job Completion Time
- Job Completion State
- Media Type
- Number of completed pages
- Media consumption area per job
- Direct Print & Share cloud portal support
- File format to allow for easy sharing of poster files
Visit www.usa.canon.com/posterartist for a free demo version to download.
- Your server must be compatible with a webDAV enabled cloud account, including but not limited to, Google, Carbonite or Rackspace, to take advantage of the cloud functionality. Storage capacity and any pricing thereof is based on the third-party cloud provider's current offering, at its sole discretion. Your cloud account is subject to the third-party cloud provider's terms and conditions. Neither Canon Inc. nor Canon U.S.A., Inc. represents or warrants any third party product, service or feature referenced hereunder.
- Available on AppStore. Compatible with iPad 2 or later, running iOS 6.1 or later. Data charges may apply. Printed output will be same size as original file. Mobile device and large format printer must utilize the same network. Printer must be connected to the same router that mobile device is connected to via wireless capability. Wireless performance may vary based on terrain and distance between the printer and wireless network clients. In order to print from imagePROGRAF Print Utility, user must open their PDF file in another, supported iPad app. Then, the user would select "Open in" and choose the print utility app.
- For imagePROGRAF Printer Driver. For printing from PostScript applications such as Adobe Illustrator or QuarkXpress, please use a PostScript compatible RIP package. For a list of Canon recommended RIP packages, please consult with Canon Alliance and Industry Market list of RIP vendors.
- The starter ink tanks initially packaged with the printer are not the same capacity as the replacement ink tanks specified here.
- The maximum printable length varies depending on the application, OS, and RIP used.
- A1 plain paper, cut speed: fast mode.
| Printer Type | 5-Color 24-Inch Printer |
| Nozzle Text | Total: 15,360 MBK: 5,120 Nozzles C, M, Y, BK: 2,560 Nozzles Each |
| Nozzle Pitch | 1,200 Dpi Non-Firing Nozzle Detection And Compensation |
| Resolution Text | 2,400 X 1,200 Dpi (Max) |
| Os Compatibility | Windows® (XP 32bit/Vista/7/8) Macintosh® (OSX 10.6.8-10.9X) |
| Standard Interfaces | USB 2.0 High-Speed 10/100/1000 Base-T/TX |
| Ink Droplet Size | 4 Picoliter |
| Ink Capacity | 130ml Per Color2 |
| Ink Type | Dye/Pigment Reactive Ink |
| Color Set | Dye: Cyan, Magenta, Yellow, Black Pigment: Matte Black |
| Buffer Ram | 256MB |
| Media Width | Cut Sheet: 8"- 24" (203.2mm - 610mm) Roll Feed: 10" - 24" (254mm - 610mm) |
| Media Thickness | 0.07-0.8mm (2.8-31.4mil) |
| Maximum Roll Print Length | Roll Feed: 59' (18 Meters) 3 Cut Sheet: 63" (1.6 Meters) |
| Maximum Media Roll Diameter | 5.9" (150mm) |
| Borderless Printing Width | 10", B4, A3, 14", A2, 17", B2 (20.28"/515 Mm), A1 (23.38"/594mm), 24" |
| Paper Feed Method | Roll Feed: One Roll, Top-Loading, Front Output Cut Sheet: One Sheet, Top Loading, Front Output |
| Languages | GARO (Canon Proprietary) |
| Noise Level Approx | Operation: 47 DB (A) Standby: 35 DB (A) Or Less Acoustic Power: Approx. 6.5 Bels |
| Physical Dimensions | 42" (H) X 39" (W) X 34" (D) (When Basket Is Open) 42” (H) X 39” (W) X 28” (D) (When Basket Is Closed) 20" (H) X 39" (W) X 27" (D) (Without Stand) |
| Weight | Approximately 116 Lb. With Stand Approximately 95 Lb. Without Stand Box Dimensions/ Weight: 42" (H) X 44" (W) X 33"(D), 196 Lb. With Stand 30" (H) X 44" (W) X 33"(D), 158 Lb. Without Stand |
| Power Source | AC-100-240V (50-60Hz) |
| Power Consumption | Maximum: 140W Or Less Standby 5W Or Less Power Off: .5W Or Less (Compliant With Executive Order) |
| Operating Environment | Temperature: 59°-86° F (15°-30° C) Relative Humidity: 10-80% (No Condensation) |
| Item | Print Head: PF-04 Maintenance Cartridge: MC-10 Ink Tanks: PFI-107 (130ml: C, M, Y, BK, MBK) |
| Software Included | Canon Printer Driver, Printer Driver Extra Kit (Free Layout, Color ImageRUNNER Enlargement Copy, Advanced Preview), Direct Print & Share, ImagePROGRAF Print Utility, PosterArtist Lite (PC Only), Print Plug-In For Microsoft® Word/Excel/PowerPoint (PC Only), Status Monitor, Media Configuration Tool, Optimized Module For AutoCAD |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
