imagePROGRAF iPF655
- 24-inch Large Format Printer
- 5-Color Pigment/Dye Reactive ink set
- 80GB Hard Drive
- Support for HP/GL2 and HP RTL
- Economy Print Mode
- Main Unit and Basket
- 2" Roll Holder with 3" Core Adapters
- 1 Print Head
- 1 Maintenance Cartridge (installed)
- 6 Starter Ink Tanks (C, M, Y, BK, two MBK)
- Sample Pack, Cut Sheet Coated Paper
- Ethernet Card (built-in)
- USB 2.0 High Speed Interface
- User Manual CD
- Quick Setup Guide (Poster)
- Printer Reference Guide (Booklet)
- Power Cord
- Registration Card
- PosterArtist Lite Application CD
- User Software CD with:
- imagePROGRAF Printer Driver
- HDI Driver
- Digital Photo Front-Access
- Printer Driver Extra Kit (Free Layout, imageRUNNER Enlargement Copy modules)
- imagePROGRAF Status Monitor
- Media Configuration Tool
- Print Plug-in for Microsoft Office
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The 24" imagePROGRAF iPF655 is an exceptional large format printing solution with a small footprint, suited for the education and general-use markets, with the versatility to meet the demands of architects and engineers. With incredibly high resolutions, and an 80GB hard drive, the iPF655 is an ideal solution for any environment with a need for printing full-color signs, posters, drawings, and other large-format graphics quickly, effortlessly, and with remarkable detail.
A totally revamped, environmentally-conscious design with fully front-accessible operations allows for outstanding ease-of-use and flush wall installation in any environment. From loading paper to navigating through an intuitive designed control panel, the iPF655 simplifies large format printing. And with accounting functionality, a sub-ink tank system, and Gigabit Ethernet support, this printer achieves exceptionally high measures of productivity. Combined with its impressive speed, precision and high quality output, the imagePROGRAF iPF655 is the premier printing solution for the technical documents market.
Output a D-size (24"x36") drawing in approximately 28 seconds*. When you need to keep projects moving forward and meet deadlines, this kind of speed is critical. Powering these incredible print speeds is Canon's L-COA (Large Format Printer COmmon Architecture) print controller, driving the imagePROGRAF print engine to lay down ink with exceptional speed and precision. This unique, high-speed processor enables the print system to process large volumes of data while optimizing output of complex high-color GIS images and architectural renderings for maximum readability and color accuracy.
*When printing in fast mode on plain paper. Includes paper-cutting time.
This printer was designed to be space-saving and environmentally conscious. This printer carries a small footprint with fully front-accessible operation for flush wall installation that fits into almost any environment. Also, loading roll media is simple with built-in loading guide rails and an automatic roll feeder. Made with less plastic, and reduced CO2 emissions, this model has earned ENERGY STAR qualification, and draws only 140 watts of power during use.
Canon's unique sub-ink tank system means you can replace ink on-the-fly without stopping the printer. For long print runs, a high-capacity media basket comes standard with this printer. And its highly durable self-propelled dual rotary cutter allows for even faster printing of multi-page jobs.
Engineered for speed and advanced image production, this printer boasts Canon's latest print-head technology to lay down ink with unprecedented speed and accuracy. The new PF-04 print head incorporates a new nozzle shape to reduce satellite ink, producing cleaner lines and text, and minimizing mist. The high-precision, high-density print head, with a total of 15,360 nozzles, lays down 4 picoliter-size ink droplets that produce sharp detail and excellent image quality. The result is consistently accurate 2400 x 1200 dpi output with fine lines that are accurate to ±0.10% and as thin as 0.02mm.
A built-in 80GB hard drive within the printer increases productivity by relieving workload from the host PC, while providing a large capacity for print job data storage and retrieval. This 80GB hard drive enables job data to be stored in protected mailboxes for easy access via web browser or at the printer for job re-printing. The embedded hard disk is ideal for medium to large workgroups to share a printer efficiently with multiple users, offering ample job storage space.
Keep track of costs and allocate consumable expenses to projects more easily with the Print Job Accounting function. This management tool allows you to track print jobs by user to calculate ink and media costs, and the number of pages printed.
Accounting features:
- Auto Rotation
- Auto Nesting
- Log Recording Time
- Job Name
- Client Job ID
- Client Job Submission Time
- Job Execution Time
- Job Completion Time
- Job Completion State
- Ink consumption per job*
- Media Type
- Number of completed pages
- Media consumption area per job
- Extended Media type
Reduce total ink consumption by utilizing the Economy Print Mode for producing draft prints on select media. This feature regulates the use of all inks to produce quick check plots while minimizing the cost per print.
Ideal for technical applications, Canon's breakthrough 5-color dye/pigment Reactive Ink technology utilizes four highly colorfast dye inks for producing bold, expressive color, plus two channels of matte black ink for printing precise lines, smooth curves, and small text on technical and office documents. Now with new magenta ink for richer, more vivid reds, this ink system is ideal for both GIS drawings and posters. These Canon inks provide superior adhesion to media, scratch and marker resistance, and ensure minimal "bleeding" between colors and text. Even small text printed on colored backgrounds or on uncoated technical papers is crisp and legible.
With the Canon HDI Driver for AutoCAD application, the driver creates a vector graphical representation of the printed data. Here, points are defined and a curved line is calculated mathematically in order to achieve precision. The HDI Driver creates a graphically accurate drawing of the printed data.
Features:
- Exact page size that corresponds with the actual print size
- Print Type setting
- Print Quality setting
- Color Mode setting
- Brightness slide bar setting
- Black ink print feature
- Advanced media settings
This Windows® and Macintosh® drivers incorporate simplified page setup options, one-touch borderless printing, expanded color settings, and much more into a printer driver that is intuitive and easy-to-operate while still giving even the most advanced users the tools needed to stay productive.
The Real Preview feature ensures users that the print setting and the layout on the roll paper is correct by providing real time preview, allowing users to change the print setting even after clicking on "print." The Free Layout feature enables nesting and custom layouts of images or files of nearly any type (available for both Windows and Mac driver).
The imageRUNNER Enlargement Copy feature built-in to the printer driver lets users transfer data from their Color imageRUNNER device with Universal Send to the imagePROGRAF printer - all with the touch of a button - enabling users to easily create posters from hard copy documents.
At a Glance:
- Easy-to-use preset document profiles (examples are Poster, CAD, Photo)
- Automatic print quality options dependent on print application and media
- Real Preview that lets users change document and printer settings after clicking "print"
- Page nesting feature with Free Layout for Windows and Mac
- imageRUNNER Enlargement Copy feature - with a hot folder solution to print Color imageRUNNER PDFs directly without opening in a PDF viewer
- Borderless printing
- Easy setting/Advanced setting
Canon's included PosterArtist Lite poster creation software gives users the ability to quickly and easily create professional large format prints. Users simply follow the program's four (4) easy steps to create posters that can be used in applications such as Office presentation, Trade shows, Retail Signage, and much, much more. The PosterArtist QuickCopy feature provides an easy solution for a CanoScan desktop scanner to be used as a copier, making letter-size flyers and documents into full-size posters with a touch of a button.
For those with more demanding poster creation needs, Canon's optional PosterArtist offers advanced features such as Auto Design, Variable Data, and in-application image editing features, as well as additional templates, royalty-free photos, and clip art. The built-in weblink feature in PosterArtist Lite links users directly to the PosterArtist website for useful hints and tips, and even more free contents for download.
Visit www.usa.canon.com/posterartist for a free demo version to download.
This utility makes it easy to print large-format documents created in Microsoft Word, Excel, or PowerPoint. The Plug-in appears in a tool bar inside the Microsoft application and has an easy-to-follow "Wizard". The Plug-in will bypass the printer driver to simplify the printing process. A few simple steps convert your 8.5" x 11" office document to poster size.
1. For imagePROGRAF Printer Driver. For printing from PostScript applications such as Adobe Illustrator or QuarkXpress, please use a PostScript compatible RIP package. For a list of Canon recommended RIP packages, please consult with Canon Alliance and Industry Market list of RIP vendors.
2. The starter ink tanks initially packaged with the printer are not the same capacity as the replacement ink tanks specified here.
3.The maximum printable length varies depending on the application, OS, and RIP used.
4. For AutoCAD or AutoCAD LT 2000. 2000i, 2002, 2004, 2005, 2006, 2007, 2008.
| Printer Type | 5-Color 24-Inch Printer |
| Nozzle Text | Total: 15,360 MBK: 5,120 Nozzles C, M, Y, BK: 2,560 Nozzles Each |
| Nozzle Pitch | 1,200 Dpi Non-Firing Nozzle Detection And Compensation |
| Resolution Text | 2,400 X 1,200 Dpi (Max) |
| Os Compatibility | Windows XP/Server 2003/Server 2008/Vista/7 (32/64bit), Macintosh OSX 10.3.9-10.6 (32 Bit), OS X 10.5-10.6 (64 Bit) |
| Standard Interfaces | USB 2.0 High-Speed 10/100/1000 Base-T/TX |
| Ink Droplet Size | 4 Picoliter |
| Ink Capacity | 130ml Per Color2 |
| Ink Type | Dye/Pigment Reactive Ink |
| Color Set | Dye: Cyan, Magenta, Yellow, Black Pigment: Matte Black (Two Channels) |
| Buffer Ram | 256 MB |
| Hard Drive | 80GB |
| Media Width | Roll Feed - 10" - 24" (254mm - 610mm) Cut Sheet - 8" - 24" (203.2mm - 914mm) |
| Media Thickness | 0.07-0.8mm (2.8-31.4mil) |
| Maximum Roll Print Length | Roll Feed - 59' (18 Meters)3 Cut Sheet - 63" (1.6 Meters) |
| Maximum Media Roll Diameter | 5.9" (150mm) |
| Borderless Printing Width | 10", 14", 17", 24" B2 (20.28"/515 Mm), A1 (23.38"/594mm) |
| Paper Feed Method | Roll Feed: One Roll, Top-Loading, Front Output Cut Sheet:: One Sheet, Top Loading, Front Output |
| Languages | Language: GARO (Canon Proprietary), HP-GL/2, HP-RTL |
| Noise Level Approx | Operation: 47 DB (A) Or Less Standby: 35 DB (A) Or Less Acoustic Power: 6.4 Bels |
| Physical Dimensions | 41.8" (H) X 39.3" (W) X 34.3" (D) |
| Weight | Approx. 119 Lbs. (54 Kg) |
| Power Source | AC-100-120V (50-60Hz) |
| Power Consumption | Maximum: 140W Or Less Standby 5W Or Less Power Off: 1W Or Less (Compliant With Executive Order) |
| Operating Environment | Temperature: 59°-86° F (15°-30° C) Relative Humidity: 10-80% (No Condensation) |
| Item | Print Head (PF-04) Maintenance Cartridge (MC-07) Ink Tanks (PFI-102: C, Y, K, MBK), (PFI-104:M) |
| Software Included | Canon Printer Driver, Digital Photo Front-Access, Printer Driver Extra Kit (Free Layout, Color ImageRUNNER Enlargement Copy, Advanced Preview), HDI Driver For AutoCAD4, PosterArtist Lite (PC Only), Print Plug-In For Microsoft® Word/Excel/PowerPoint (PC Only) |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
