imagePROGRAF iPF6400SE
- 24-inch Large Format Printer
- 6-Color LUCIA EX Ink Set
- Optimized Poster Printing Mode
- Sub-ink Tank System and Large Capacity Ink Tanks
- Compact Design
- Main Unit with Stand & Basket
- 2" Roll Holder with 3" Core Adapters
- 1 Print Head
- 1 Maintenance Cartridge, (installed)
- 6, 90ml Starter Ink Tanks (C, M, Y, BK, MBK, R)
- A2 Sized Heavyweight Coated Paper Cut Sheets (5)
- Ethernet Card (built in)
- USB 2.0 High Speed Interface
- Quick Setup Guide (Poster)
- Printer Reference Guide (Booklet)
- Power Cord
- Registration Card
- PosterArtist Lite Application CD
- User Software CD with:
- imagePROGRAF Printer Driver
- Media Configuration Tool
- Accounting Manager
- Print Plug-in for Microsoft Office
- Printer Driver Extra Kit
- imagePROGRAF Status Monitor
- Direct Print & Share
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The imagePROGRAF iPF6400SE, 24-inch large format printer is designed for vibrant poster creation in the signage, infographics display, and retail markets while maximizing productivity. The 6-Color LUCIA EX pigment ink set emphasizes the use of red ink, which allows for incredibly vibrant and eye-catching prints to be produced while providing benefits such as scratch resistance. The printer includes a color profile that’s designed specifically for poster creation to maximize use of the LUCIA EX ink system’s strengths in color reproduction, and helps to produce a wide color gamut that is in some cases comparable to what’s seen on 8-Color devices. The compact design of the iPF6400SE allows for the printer to be placed in small offices and stores where space is not a luxury. The iPF6400SE also features an economy printing mode that reduces ink consumption by about 50% compared to standard mode to help cut down on printing costs. The printer supports ink tank sizes of 130ml and 300ml to enhance productivity, and has a Sub-ink tank system that keeps ink in reserve to allow for tanks to be changed without interrupting a print.
To expand poster printing options and capabilities, the iPF6400SE printer comes bundled with a free copy of Canon’s PosterArtist Lite software, which enables easy poster creation in just four steps. PosterArtist Lite comes with an image correction function that enables a user to automatically correct their image colors, as well as cut out selected areas of an image, right from within the software. The printer come standard with additional applications and utilities that help make the printing process extremely user friendly such as; an Accounting Manager tool that helps keep track of job costs, a Print Plug-in for Microsoft Office, and Direct Print and Share, Canon’s cloud-based portal solution. To improve versatility, the iPF6400SE has a Media Configuration Tool which allows customers to not only utilize existing Canon-branded media, but also with non-Canon branded media. By expanding on Canon's innovative and technological achievements, the imagePROGRAF iPF6400SE printer helps achieve consistently eye-popping customer-friendly prints.
- Job Cost (ink, Media and variable cost inputted by user)
- Ink Consumed per Job*
- Media Consumed per Job
- Job Completion time
- And more
- Media weight and thickness
- Ink drying
- Automatic cutting settings
- Borderless printing
- Paper feed amount
- Print-head height
- Vacuum strength
- Maximum ink usage
2. The starter ink tanks initially packaged with the printer are not the same capacity as the replacement ink tanks specified here.
3. The maximum printable length varies depending on the application, OS, and RIP used.
†† You must open a Google Cloud account to take advantage of the cloud functionality. Storage capacity and any pricing thereof is based on Google's current offering and is at Google's discretion. Your Google Cloud account is subject to Google's terms and conditions, which is subject to change at Google's discretion. Neither Canon, Inc., nor Canon U.S.A., Inc. represents or warrants any third party product, service or feature referenced hereunder.
| Printer Type | 6-Color 24-Inch Printer |
| Nozzle Text | Total: 15, 360 C, M, Y, BK, MBK, R: 2,560 Nozzles Each |
| Nozzle Pitch | 1,200 Dpi X 2 Non-Firing Nozzle Detection And Compensation |
| Resolution Text | 2,400 X 1,200 Dpi (Max) |
| Os Compatibility | Windows® (XP/Vista/7/8), Macintosh® (OSX) |
| Standard Interfaces | USB 2.0 High-Speed 10/100 Base-T/TX |
| Ink Droplet Size | 4 Picoliter |
| Ink Capacity | 130 And 300ml Per Color Available2 |
| Ink Type | LUCIA EX Ink (Pigment Based) |
| Color Set | Cyan, Magenta, Yellow, Black, Matte Black, Red |
| Buffer Ram | 256 MB |
| Media Width | Cut Sheet And Roll: 8" - 24" |
| Media Thickness | Top Loading Manual Feed: 0.07 - 0.8mm (3.2 - 31.4mil) Roll: 0.07 - 0.8mm (3.2 - 31.4mil) |
| Maximum Roll Print Length | 59 Feet (18 Meters)3 |
| Maximum Media Roll Diameter | 5.9" (150mm) |
| Borderless Printing Width | 10" (254 Mm), B4 (257 Mm), 14" (356 Mm), 16" (407 Mm), A2 (420 Mm), A2+/17" (432 Mm), B2 (515 Mm), A1 (594 Mm), 24" (610 Mm) |
| Paper Feed Method | Roll Feed: One Roll, Front Output TTop Loading Manual Feed: One Sheet, Front Output |
| Languages | GARO (Canon Proprietary) |
| Noise Level Approx | Operation: 49 DB (A) Or Less Standby: 35 DB (A) Or Less Acoustic Power: Approx. 6.4 Bels Or Less |
| Physical Dimensions | 39.0" (H) X 40.0" (W) X 29.6" (D) |
| Weight | Approximately 119 Lbs. With Stand |
| Power Source | AC-100-240V (50-60Hz) |
| Power Consumption | Maximum: 100W Or Less Standby: 5W Or Less Power Off: .5W Or Less (Compliant With Executive Order) |
| Operating Environment | Temperature: 59°-86° F (15°-30° C) Relative Humidity: 10-80% (No Condensation) |
| Item | Print Head (PF-05), Maintenance Cartridge (MC-16), Ink Tanks (PFI-106/PFI-206) |
| Software Included | Canon Printer Driver, PosterArtist Lite (PC Only), Printer Driver Extra Kit (Free Layout, Color ImageRUNNER Enlargement Copy, Advanced Preview), Print Plug-In For Microsoft® Word/Excel/PowerPoint, Accounting Manager (PC Only), Direct Print & Share, Optimized Module For AutoCAD (PC Only) |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
