imagePROGRAF iPF6400S
- 24-inch Large Format Printer
- 8-Color LUCIA EX Ink Set
- Optional SU-21 Spectrophotometer
- Multi-Sensor for color density detection
- Sub-ink Tank System and increased ink tank capacity
- Main Unit with Stand & Basket
- 2" Roll Holder with 3" Core Adapters
- 2 Print Heads
- 1 Maintenance Cartridge, (installed)
- 4, 90ml Starter Ink Tanks (BK, MBK, M, Y)
- 4, 120ml Starter Ink Tanks (C, PC, PM, GY)
- A2 Sized Heavyweight Coated Paper Cut Sheets (5)
- Ethernet Card (built in)
- USB 2.0 High Speed Interface
- Quick Setup Guide (Poster)
- Printer Reference Guide (Booklet)
- Power Cord
- Registration Card
- PosterArtist Lite Application CD
- User Software CD with:
- imagePROGRAF Printer Driver
- Print Plug-in for Adobe Photoshop
- Media Configuration Tool
- Accounting Manager
- Print Plug-in for Microsoft Office
- Printer Driver Extra Kit
- imagePROGRAF Status Monitor
- Color Calibration Management Console
- Print Plug-in for Digital Photo Professional
- Printer Driver Optimization Module for AutoCAD
- Direct Print & Share
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
- A fully automated carriage that opens and closes the sensor, allowing for media of different thicknesses to be loaded and used with this device.
- Unique to Canon’s device is a specialized single piece backing plate that has both black and white stripes on it and is user switchable!
- User-switchable UV blocking filter that can be switched on and off according to paper type; no need to purchase individual sensors to respond to each paper type.
- Scan Speed of 10 inches per second
- The ability to generate color calibration charts is possible for non-Canon branded Media, allowing users to expand their workflow options.
- 2010 XRGA measurement standard compliance.
- Remotely monitor/execute color calibrations for all printers on network, as well as be able to schedule remote calibrations based on system needs.
- Determine the media type loaded in each device on the network
- Determine the serial number of the printer device and other general information
- Obtain accounting information from each printer on the network
- Access the Status Monitor for each printer on the network
- Job Cost (ink, Media and variable cost inputted by user)
- Ink Consumed per Job*
- Media Consumed per Job
- Job Completion time
- And more
*Ink usage is estimate, and error tolerance is ±15%
The following new or enhanced features are provided in the Print Plug-In for Photoshop:
- Adjustment Pattern Setting
- Support for commercial profile creation tools
- Crop Marks: These lines are a guide for folding the paper for mounting.
- Edge Lines: The area outside these lines is the area that gets folded around to the back of the canvas. (Not actually displayed or printed)
- Blue Lines: The area within these lines is the area that appears on the front surface of the canvas when mounted. (not actually printed)
- Canvas Thickness: This area becomes the sides of the canvas when mounted.
- Amount of Extension: This is the region that is printed protruding excessively in order to prevent white areas appearing on the sides of the canvas.
- Image: Wraps the image to the canvas sides.
- Soft Image: Performs Gaussian filtering on the image on the canvas sides.
- Reflection: Reflects the image on the canvas sides.
- Soft Reflection: Reflects the image on the canvas sides and performs Gaussian filtering.
- White, Black or Color Makes the canvas sides white, Black or a custom color
- Media weight and thickness
- Ink drying
- Automatic cutting settings
- Borderless printing
- Paper feed amount
- Print-head height
- Vacuum strength
- Maximum ink usage
2. The starter ink tanks initially packaged with the printer are not the same capacity as the replacement ink tanks specified here.
3. The maximum printable length varies depending on the application, OS, and RIP used.
†† You must open a Google Cloud account to take advantage of the cloud functionality. Storage capacity and any pricing thereof is based on Google’s current offering and is at Google's discretion. Your Google Cloud account is subject to Google’s terms and conditions, which is subject to change at Google's discretion. Neither Canon, Inc., nor Canon U.S.A., Inc. represents or warrants any third party product, service or feature referenced hereunder.
| Printer Type | 8-Color 24-Inch Printer |
| Nozzle Text | Total: 30,720 C, PC, PM, GY: 5,120 Nozzles Each BK, MBK, Y, M: 2,560 Nozzles Each |
| Nozzle Pitch | 1,200 Dpi Non-Firing Nozzle Detection And Compensation |
| Resolution Text | 2,400 X 1,200 Dpi (Max) |
| Os Compatibility | Windows® (XP/Vista/7/8), Macintosh® (OSX) |
| Standard Interfaces | USB 2.0 High-Speed 10/100/1000 Base-T/TX |
| Ink Droplet Size | 4 Picoliter |
| Ink Capacity | 130 And 300ml Per Color Available2 (Optional 300ml) |
| Ink Type | LUCIA EX Ink (Pigment Based) |
| Color Set | Cyan, Photo Cyan, Magenta, Photo Magenta, Yellow, Black, Matte Black, Gray |
| Buffer Ram | 250 GB / 250 MB |
| Media Width | Cut Sheet And Roll: 8" - 24" |
| Media Thickness | Top Loading Manual Feed: 0.07 - 0.8mm (3.2 - 31.4mil) Front Loading Manual Feed: 0.5 - 1.5mm (19.6 - 59.0mil) Roll: 0.07 - 0.8mm (3.2 - 31.4mil) |
| Maximum Roll Print Length | 59 Feet (18 Meters)3 |
| Maximum Media Roll Diameter | 5.9" (150mm) |
| Borderless Printing Width | 10" (254 Mm), B4 (257 Mm), 14" (356 Mm), 16" (407 Mm), A2 (420 Mm), A2+/17" (432 Mm), B2 (515 Mm), A1 (594 Mm), 24" (610 Mm) |
| Paper Feed Method | Roll Feed: One Roll, Front Output Top Loading Manual Feed: One Sheet, Front Output Front Loading Manual Feed: One Sheet, Front Output |
| Languages | GARO (Canon Proprietary) |
| Noise Level Approx | Operation: 47 DB (A) Or Less Acoustic Power: Approx. 6.4 Bels Or Less |
| Physical Dimensions | 39.4" (H) X 48.3" (W) X 29.6" (D) 39.4" (H) X 48.3" (W) X 34.4" (D) (With Optional SU-21 Spectrophotometer Attached) |
| Weight | Approximately 154 Lbs. With Stand Approximately 200 Lbs. With Optional SU-21 Spectrophotometer Attached |
| Power Source | AC-100-240V (50-60Hz) |
| Power Consumption | Maximum: 100W Or Less Standby 5W Or Less Power Off: .5W Or Less (Compliant With Executive Order) |
| Operating Environment | Temperature: 59°-86° F (15°-30° C) Relative Humidity: 10-80% (No Condensation) |
| Item | Print Head (PF-05), Maintenance Cartridge (MC-16), Ink Tanks (PFI-106/PFI-206) |
| Software Included | Canon Printer Driver, Print Plug-In For Adobe Photoshop. Print Plug-In For Digital Photo Professional, PosterArtist Lite (PC Only), Printer Driver Extra Kit (Free Layout, Color ImageRUNNER Enlargement Copy, Advanced Preview), Print Plug-In For Microsoft® Word/Excel/PowerPoint (PC Only), Accounting Manager, Gallery Wrap Feature, Color Calibration Management Console, Printer Driver Optimization Module For AutoCAD, Direct Print & Share Optional SU-21 Spectrophotometer Model: X-Rite SU-21 Color Measurement Width: 480mm Max. Media Thickness: 0.50mm XRGA Compliant: Yes ISO 13655 Compliant: Yes User Switchable UV Filter: Yes White/Black Backing: Included On One Strip Support For Third Party RIPS: Most Leading Third Party RIPS |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
