imagePROGRAF iPF6400
- 24-inch Large Format Printer
- 12-Color LUCIA EX Ink Set
- Color Calibration Management System
- Multi-sensor for color density detection
- Gallery Wrap Feature
- Main Unit with Stand & Basket
- 2" Roll Holder with 3" Core Adapters
- 2 Print Heads
- 1 Maintenance Cartridge, (installed)
- 12, 90ml Starter Ink Tanks (BK, MBK, C, M, Y, PC, PM, GY, PGY, R, G, B)
- Sample Roll Heavyweight Coated Paper
- Ethernet Card (built in)
- USB 2.0 High Speed Interface
- User Manual CD
- Quick Setup Guide (Poster)
- Printer Reference Guide (Booklet)
- Power Cord
- Registration Card
- PosterArtist Lite Application CD
- User Software CD with:
- imagePROGRAF Printer Driver
- Print Plug-in for Adobe Photoshop & Digital Photo Professional
- Media Configuration Tool
- Accounting Manager
- Print Plug-in for Microsoft Office
- Printer Driver Extra Kit
- imagePROGRAF Status Monitor
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
- Soft Tone
- Middle Tone
- Medium Hard Tone
- Hard Tone
- Strong Hard Tone
- Adjustment Pattern Setting
- Adobe CMM support
- Proof printing support
- Support for commercial profile creation tools
- Crop Marks: These lines are a guide for folding the paper for mounting.
- Edge Lines: The area outside these lines is the area that gets folded around to the back of the canvas. (Not actually displayed or printed) .
- Blue Lines: The area within these lines is the area that appears on the front surface of the canvas when mounted. (not actually printed) .
- Canvas Thickness: This area becomes the sides of the canvas when mounted. .
- Amount of Extension: This is the region that is printed protruding excessively in order to prevent white areas appearing on the sides of the canvas.
- Image: Wraps the image to the canvas sides.
- Soft Image: Performs Gaussian filtering on the image on the canvas sides.
- Reflection: Reflects the image on the canvas sides.
- Soft Reflection: Reflects the image on the canvas sides and performs Gaussian filtering.
- White, Black or Color Makes the canvas sides white, Black or a custom color.
- Media weight and thickness
- Ink drying
- Automatic cutting settings
- Borderless printing
- Paper feed amount
- Print-head height
- Vacuum strength
- Maximum ink usage
- Full screen preview
- More print quality selections
- Categorized paper type view
- Roll paper layout view
- Bi-cubic enlargement
- Job Cost (ink, Media and variable cost inputted by user)
- Ink Consumed per Job*
- Media Consumed per Job
- Job Completion time
- And more
1. For imagePROGRAF Printer Driver. For printing from PostScript applications such as Adobe Illustrator or QuarkXpress, please use a PostScript compatible RIP package. For a list of Canon recommended RIP packages, please consult with Canon Alliance and Industry Market list of RIP vendors.
2. The starter ink tanks initially packaged with the printer are not the same capacity as the replacement ink tanks specified here.
3. The maximum printable length varies depending on the application, OS, and RIP used.
| Printer Type | 12-Color 24-Inch Printer |
| Nozzle Text | Total: 30,720 All Colors: 2,560 Nozzles Each |
| Nozzle Pitch | 1,200 Dpi |
| Nozzle Recovery System | Non-Firing Nozzle Detection And Compensation |
| Resolution Text | 2,400 X 1,200 Dpi (Max) |
| Os Compatibility | Windows® (XP/Vista 32/64bit/Windows 7 32/64bit) Macintosh® (OSX) |
| Standard Interfaces | USB 2.0 High-Speed 10/100/1000 Base-T/TX |
| Ink Droplet Size | 4 Picoliter |
| Ink Capacity | 330ml Per Color2 (Optional 300ml) |
| Ink Type | LUCIA EX Ink (Pigment Based) |
| Color Set | Cyan, Photo Cyan, Magenta, Photo Magenta, Yellow, Black, Matte Black, Red, Green. Blue, Gray, Photo Gray |
| Buffer Ram | 384 MB |
| Media Width | Cut Sheet: 8" - 24" |
| Media Thickness | Top Loading Manual Feed: 0.07 - 0.8mm (3.2 - 31.4mil) Front Loading Manual Feed: 0.5 - 1.5mm (19.6 - 59.0mil) Roll: 0.07 - 0.8mm (3.2 - 31.4mil) |
| Maximum Roll Print Length | 59 Feet (18 Meters)3 |
| Maximum Media Roll Diameter | 5.9" (150mm) |
| Borderless Printing Width | 10" (254 Mm), B4 (257 Mm), A3+ (329 Mm), 14" (356 Mm), 16" (407 Mm), A2 (420 Mm), A2+/17" (432 Mm), B2 (515 Mm), A1 (594 Mm), 24" (610 Mm) |
| Paper Feed Method | Roll Feed: One Roll, Front Output Top Loading Manual Feed: One Sheet, Front Output Front Loading Manual Feed: One Sheet, Front Output |
| Languages | GARO (Canon Proprietary) |
| Noise Level Approx | Operation: 47 DB (A) Or Less Acoustic Power: Approx. 6.4 Bels Or Less |
| Physical Dimensions | 39.4" (H) X 48.3" (W) X 34.3" (D) |
| Weight | Approximately 154 Lbs. With Stand |
| Power Source | AC-100-240V (50-60Hz) |
| Power Consumption | Maximum: 100W Or Less Standby: 6W Or Less Power Off: .5W Or Less (Compliant With Executive Order) |
| Operating Environment | Temperature: 59°-86° F (15°-30° C) Relative Humidity - 10-80% (No Condensation) |
| Item | Print Head (PF-05) Maintenance Cartridge (MC-16) Ink Tanks (PFI-106, PFI-206) |
| Software Included | Canon Printer Driver, Print Plug-In For Adobe Photoshop. Print Plug-In For Digital Photo Professional, PosterArtist Lite (PC Only), Printer Driver Extra Kit (Free Layout, Color ImageRUNNER Enlargement Copy, Advanced Preview), Print Plug-In For Microsoft® Word/Excel/PowerPoint (PC Only), Accounting Manager, Gallery Wrap Feature |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
