imagePROGRAF iPF6300S
- Main Unit with Stand & Basket
- 2" Roll Holder with 3" adapters
- 2 Print Heads
- 1 Maintenance Cartridge, (Installed)
- 8 Starter Ink Tanks (BK/MBK/C/M/Y/PC/PM/GY)
- Sample Roll Heavyweight Coated Paper
- Media Swatch Kit
- Ethernet Card (built in)
- USB 2.0 High Speed Interface
- User Manual CD
- Quick Start Guide
- Reference Guide
- Menu Map
- Power Cord
- Registration Card
- PosterArtist Lite
- User Software CD with:
- imagePROGRAF Printer Driver
- Accounting Manager
- Print Plug-in for Photoshop & Digital Photo Professional
- Print Plug-in for Microsoft Office
- Printer Driver Extra Kit
- Digital Photo Front-Access
- GARO Status Monitor
- Media Configuration Tool
OVERVIEW
SPECIFICATIONS
ACCESSORIES
RESOURCES
SUPPORT
MISCELLANEOUS
The 24" imagePROGRAF iPF6300S printer is a versatile large format solution for those who need a small footprint device for quality output and production. Ideal for the photograph, proofing and production markets, the iPF6300S delivers high quality imaging while increasing overall productiviy. Equipped with an 8-Color LUCIA EX ink set, 160GB hard drive, built-in calibration and borderless printing, the iPF6300S is an excellent solution for portraits, advertisements, retail signage and contract proofs.
Create vibrant colors and expressive tones with LUCIA EX ink. Canon's newly formulated 8-Color LUCIA EX ink set increases the achievable color gamut by approximately 20% more than previous imagePROGRAF 8-Color printers and provides for smooth color gradations, improved scratch resistance and minimized color shifts.
At 24": wide, the iPF6300S is a small but powerful workhorse, And with a 160GB hard drive, handling multiple complex jobs is simple, especially in shared printer environments. And for lower total cost of operation, Fast/Economy modes reduce printer ink consumption to minimize cost per print.
- Wider color gamut
- Better scratch resistance
- Less graininess
- Smoother gradation
- Reduced bronzing
- Sharper blacks
The following features are provided in the Print Plug-In for Photoshop:
- Proof printing support
- Enhanced image processing technology
- Support for commercial profile creation tools
Features:
- Full screen preview
- More print quality selections
- Categorized paper type view
- Roll paper layout view
- Bi-cubic enlargement
Settings that can be configured using media parameter adjustment features include:
- Media weight and thickness
- Ink drying time for rolls
- Automatic cutting settings for rolls
- Borderless printing for rolls
- Paper feed amount
- Print-head height
- Vacuum strength
- Maximum ink usage
Features include:
- Job Name
- Job Completion Time
- Ink consumption per job
- Print dimensions
- Media Type
- Media consumption area per job
- Easy-to-use preset document profiles (examples are Poster, CAD, Photo)
- Automatic print quality options dependent on print application and media
- Real Preview that lets users change document and printer settings after clicking "print"
- Page nesting feature with Free Layout for Windows and Mac
- imageRUNNER Enlargement Copy feature - with a hot folder solution to print Color imageRUNNER PDFs directly without opening in a PDF viewer
- Economy Print Mode
- Easy setting/Advanced setting
- Provides professionally designed templates to simplify poster creation
- Over 1GB of preloaded files in a wide variety of poster designs and artwork
- Auto Design Feature - Template Creation Engine
- Variable Data Printing
- Page Capture feature allows users to load desired data from other applications into a PosterArtist poster, such as Microsoft® Word®, Excel®, and Adobe® Acrobat®
- Import images directly from most digital cameras
- For imagePROGRAF Printer Driver: For printing from PostScript applications, such as Adobe Illustrator or QuarkExpress, please use a PostScript compatiable RIP package. For a list of Canon recommended RIP packages, please consult with Canon Alliance and Industry Marketing list of RIP vendors.
- The starter ink tanks initially packaged with the printer are not the same capacity as the replacement ink tanks specified here.
- The maximum printable length varies depending on the application, OS, and RIP used.
| Printer Type | 8-Color 24-Inch Printer |
| Nozzle Text | Total: 30,720 C, PC, PM, GY: 5,120 Nozzles Each BK, MBK, Y, M: 2,560 Nozzles Each |
| Nozzle Pitch | 1,200 Dpi |
| Nozzle Recovery System | Non-Firing Nozzle Detection And Compensation |
| Resolution Text | Color: 2,400 X 1,200 Dpi (Max) |
| Os Compatibility | Windows XP/Server 2003/Server 2008/Vista/7 (32/64 Bit), Macintosh OSX 10.3.9-10.6 (32/64 Bit) |
| Standard Interfaces | USB 2.0 High-Speed 10/100/1000 Base-T/TX |
| Ink Compatibility | LUCIA EX Ink (Pigment-Based) |
| Ink Droplet Size | 4 Picoliter |
| Ink Capacity | 130ml Per Color2 |
| Color Set | Cyan, Photo Cyan, Magenta, Photo Magenta, Yellow, Black, Matte Black, Gray |
| Buffer Ram | 384MB |
| Hard Drive | 160GB |
| Media Width | Cut Sheet And Roll: 8"-24" Roll: 10"-24" |
| Media Thickness | Top Loading Manual Feed: 0.07 - 0.8mm (2.8 - 31.4mil) Front Loading Manual Feed: 0.5mm - 1.5mm (19.6mil - 59.0mil) Roll: 0.07 - 0.8mm (2.8 - 31.4mil) |
| Maximum Roll Print Length | 59 Feet (18 Meters)3 |
| Maximum Media Roll Diameter | 5.9" (150mm) |
| Borderless Printing Width | 10" (254 Mm), B4 (257 Mm), A3+ (329 Mm), 14" (356 Mm), 16" (407 Mm), A2 (420 Mm), A2+/17" (432 Mm), B2 (515 Mm), A1 (594 Mm), 24" (610 Mm) |
| Paper Feed Method | Roll Feed: One Roll, Front Output Top Loading Manual Feed: One Sheet, Front Output Front Loading Manual Feed: One Sheet, Front Output |
| Languages | GARO (Canon Proprietary) |
| Noise Level Approx | Operation: 47 DB (A) Or Less Acoustic Power: 6.4 Bels |
| Physical Dimensions | 39" (H) X 46.3" (W) X 34.3" (D) |
| Weight | Approximately 146 Lbs With Stand |
| Power Source | AC-100-120V (50-60Hz) |
| Power Consumption | Maximum: 100W Or Less Standby 7W Or Less Power Off: 1W Or Less (Compliant With Executive Order) |
| Operating Environment | Temperature: 59°-86° F (15°-30° C) Relative Humidity - 10-80% (No Condensation) |
| Item | Print Head (PF-05) Maintenance Cartridge (MC-16) Ink Tanks (PFI-105) |
| Software Included | Canon Printer Driver, PosterArtist Lite, Accounting Manager, Print Plug-In For Adobe Photoshop, Print Plug-In For Digital Photo Professional, Print Plug-In For Microsoft Office, Digital Photo Front-Access, Printer Driver Extra Kit (Free Layout, ImageRUNNER Linking Function) |
- Windows Server 2025
- macOS 15
- macOS 14
- macOS 13
- Windows 11
- macOS 12
- Windows Server 2022
- macOS 11
- Linux MIPS
- Linux ARM
- macOS 11.0
- macOS 10.15
- macOS v10.13
- macOS v10.14
- Windows Server 2019 (x64)
- macOS v10.14
- macOS v10.13
- Windows Server 2016 (x64)
- macOS v10.12
- Linux 64bit
- Linux 32bit
- OS X v10.11
- Windows 10
- Windows 10 (x64)
- OS X v10.10
- OS X v10.9
- Windows 8.1 (x64)
- Windows 8.1
- Windows Server 2012 (x64)
- Windows 8
- Windows 8 (x64)
- Windows 7
- Windows 7 (x64)
- Windows Vista
- Windows Vista (x64)
- Windows XP
- Windows XP (x64)
- Windows Server 2008
- Windows Server 2008 (x64)
- Windows Server 2003
- Windows Server 2003 (x64)
- Windows Server 2003 R2
- Windows 2000
- Windows NT
- Windows 3.1
- Windows Me
- Windows 98
- Windows 95
- Mac OS X v10.8
- Mac OS X v10.7
- Mac OS X v10.6
- Mac OS X v10.5
- Mac OS X v10.4
- Mac OS X v10.3
- Mac OS X v10.2
- Mac OS X v10.1
- Mac OS X
- Mac OS 9
- Mac OS 8
- Linux (x64)
- Linux (x32)
- Linux
- Not Applicable
Windows 11
Windows® 10
Click Settings.
Windows 8 or Windows 8.1
Windows 7
Linux
