Automated and efficient color control
The standard Inline Spectrophotometers (ILS) help operators achieve accurate, repeatable color, regardless of skill level. This imagePRESS V900 Series is designed to help you reliably meet deadlines and move projects out the door rapidly and with beautifully consistent results. Once you’ve initiated the process, the press can create a custom output profile and G7® calibration in just minutes.* Canon’s powerful ILS can automate your crucial color tasks. Multi D.A.T. then makes real-time adjustments to help produce consistent color throughout a run.
Offset-like print quality
Canon’s Translucent CV Toner allows a media's surface properties to be preserved, producing vibrant, vivid images across the sheet surface on a wide variety of stocks.
Crisp, rich images
The flexible transfer belt and simple transfer adjustment technology allow the toner to fill in the peaks and valleys of textured and embossed stocks. Full, rich solids and high-density images can be reliably produced for custom and premium applications.
Rock-solid stability
Advanced internal stability maintains a consistent environment. Now add to this the automatic measuring of multi-gradation density patches and precise front-to-back registration. The results are stunning highlights, mid-tones, and shadows that can meet high expectations.
